Results 1 to 4 of 4
Thread: Cold start license plate light check.
    Jan 2018
    Lovettsville, VA USA
    I have a 2017 GTI. The license plate lights went out so I changed with an LED. The computer doesn't like the lower wattage/load of the new lighting.
    Is there a way to disable the cold check completely? Are there any other helpful tweaks related to these checks?
    I do have an autoscan below.
    Thank you!
    John
    Monday,17,February,2020,17:44:08:60615
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VirtualBox)
    VCDS Version 19.6.2.2 (x64)
    VIN: 3VW447AU7HM020445   License Plate: NOWIRES
    Mileage: 73647km-45762mi   Repair Order: NA
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 05 08 09 15 16 17 19 2B 32 42 44 47 52 55 5F 75 A9
    VIN: 3VW447AU7HM020445   Mileage: 73647km-45762miles
    Address 01: Engine (J623-CXCB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 L    HW: 06K 907 425 B
       Revision: --H13---
       Coding: 091D00124424002F1000
       Shop #: WSC 00066 790 00202
       ASAM Dataset: EV_ECM20TFS0205G0906259L 001004
       ROD: EV_ECM20TFS0205G0906259L.rod
       VCID: 377D43FB8EA143F754-8063
    20277 - Terminal 15 Voltage
              P151B 00 [032] - Implausible
                        Mileage: 73285 km
                        Date: 2020.02.04
                        Time: 17:44:28
                        Engine speed: 913.00 /min
                        Normed load value: 14.1 %
                        Coolant temperature: 89 ∞C
                        Intake air temperature: 31 ∞C
                        Voltage terminal 30: 11.855 V
                        Unlearning counter according OBD: 34
                        Engine: operating status: IS
                        STATE_LS_SAE[1]: OL_CDN
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 27 kPa
                        Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.943 V
                        FAC_TPS_1_SAE: 11.328125 %
                        FUP_H_SAE: 10710.0 kPa
    21406 - EVAP Emission Control Sys
              P0441 00 [096] - Incorrect Flow
       Part No SW: 0D9 300 020 L    HW: 02E 927 770 AQ
       Component: DQ250-6V MQB  H54 4902
       Revision: 06354004    Serial number: TFK01607270675
       ROD: EV_TCMDQ250021.rod
       VCID: 1E33B65F015B12BFB7-804B
    Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
       Part No SW: 5Q0 614 517 AF    HW: 5Q0 614 517 AF
       Component: ESC           H62 0398
       Revision: 00000000    Serial number: 52316000001735
       Coding: 01FA6BA15422096C807B020441C86880D62A90014082163600430051C00903
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_Brake1UDSContiMK100ESP 035019
       ROD: EV_Brake1UDSContiMK100ESP_035_VW37.rod
       VCID: 75E189F3D42DF1E786-8021
    16401 - Tire Pressure Warning
              C102D 00 [008] - -
                        Reset counter: 165
                        Mileage: 73110 km
                        Date: 2020.01.30
                        Time: 19:44:57
       Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
       Revision: 00021000    Serial number: 0415197787
       Coding: 032C00
       VCID: 3B755FCBB2896797B0-806F
       Part No SW: 5GM 907 426 C    HW: 5GM 907 426 C
       Component: AC Manuell    H03 1601
       Revision: 00001K03
       Coding: 00020004200100000000000000000002
       ASAM Dataset: EV_ACManueBHBVW37X 004132
       ROD: EV_ACManueBHBVW37X_004.rod
       VCID: 489F3007F35F3C0F2D-801D
       Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
       Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
       Revision: --------    Serial number: 865815081601C2
       Coding: 00111A464041A26969E44000001407201800000000000000000000000000
       Shop #: WSC 00066 790 00208
       ROD: EV_BCMBOSCH_015.rod
       VCID: 7AFB9ACFFD339E9FEB-802F
       Component: WWS    150612  043 0551
       Serial number:         150703161040
       Subsystem 2 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
       Component: RLS  042 0105
       Serial number: S6Y16M08D04H02M01S38
       Coding: 00A8DD
       Sun Roof:
       Subsystem 3 - Part No SW: 5GD 959 591 A    HW: 5GD 959 591 A
       Component: J245 PS60.006  H07 0170
       Serial number: 03691601491104161737
       Coding: 181803
    550677 - Databus
                        Reset counter: 156
                        Mileage: 73005 km
                        Date: 2020.01.29
                        Time: 14:23:25
    12298 - License Plate Light
              B12CA 15 [008] - Open or Short to Plus
                        Reset counter: 170
                        Mileage: 73614 km
                        Date: 2020.02.17
                        Time: 13:00:38
    12307 - License Plate Light
              B12CA 01 [009] - Electrical Failure
                        Reset counter: 130
                        Mileage: 73493 km
                        Date: 2020.02.16
                        Time: 18:26:22
    204546 - Remote key 2
              B147A 18 [008] - Current Too Low
       Serial number: 003GCR05MLZC
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 479D333BFE41337724-8013
       Occupant Detection:
       Serial number: IBH000000000005SD9N
       Coding: 303131
       Subsystem 2 - Part No SW: -----------    HW: 480 001 708 16
       Serial number: 3570000000028720CD1H
       Subsystem 3 - Part No SW: -----------    HW: 480 001 708 16
       Serial number: 358000000001D4818D1M
       Subsystem 4 - Part No SW: -----------    HW: 480 402 907 16
       Serial number: 3510002C52095065036L
       Subsystem 5 - Part No SW: -----------    HW: 480 400 606 16
       Serial number: 3520002AB20FC7319332
       Subsystem 6 - Part No SW: -----------    HW: 480 400 808 16
       Serial number: 3550002A1215E1C3821W
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 400 808 16
       Serial number: 3560002BB21FBE82512D
       Revision: FF034034    Serial number: 20160824400622
       Coding: 0410
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 0407E4378FF7D86F81-8051
       Part No SW: 5G1 920 856 B    HW: 5G1 920 856 B
       Component: KOMBI         344 8311
       Coding: 0BAD091AA980CF0502086E001000000000000000
       VCID: 2D5161937CFDF9273E-8079
    9456681 - Key
              B104C 29 [008] - Implausible Signal
                        Mileage: 73212 km
                        Date: 2020.02.04
                        Time: 07:24:27
       Revision: --------    Serial number: 15071610800932
       Coding: 0101000830085900FB00002B1C0F00000001050000000000000000000000
       Shop #: WSC 00066 790 07026
       ROD: EV_GatewConti_013.rod
       VCID: 7CF79CD7F707A0AFF9-8029
       Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H11 0103
       Serial number: 29160001591040096337
       Coding: 31FFFF
       Revision: 00000000    Serial number: 16000145141004
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 346774F79FD7A8EF71-8061
    Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
       Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
       Component: Quersperre    H52 8042
       Serial number: HA1-00007.07.16
       Coding: 0001
       ASAM Dataset: EV_LockElectHA1VW37X 001007
       ROD: EV_LockElectHA1VW37X.rod
       Serial number: 15091606050AE9
       Coding: 003E13200000020000000000
       VCID: 4385272BCA791F57F8-8017
       Serial number: 00000000000013877662
       Coding: 011000
    65573 - Local Data Bus
              U10BA 00 [008] - No Communication
                        Reset counter: 156
                        Mileage: 73005 km
                        Date: 2020.01.29
                        Time: 14:23:25
       Coding: 8102
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 3A7B5ACFBDB35E9FAB-806F
    Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
       Part No SW: 5Q0 035 456     HW: 5Q0 035 456
       Component: MIB2_lite_amp H30 0150
       Revision: 00000001    Serial number: VWZ8Z1GBA0276H$
       Coding: 2200000000AAAAAA000000000000
       ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
       ROD: EV_AMPMst12C1Gen2ALPI.rod
       VCID: 6DD1A193BC7D39277E-8039
       Serial number: 250916060504F6
       VCID: 428B222FD563165FF3-8017
       Serial number: 00000000000004292199
       Coding: 091000
       Coding: 021A01010B000400
       VCID: 408F2827DB6F044FE5-8015
       Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H01 0004
       Coding: 2E0000
       Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 0004
       Coding: 2E0000
       Part No SW: 3Q0 035 844 A    HW: 3Q0 035 844 A
       Component: MU-S-S-US     710 0751
       Coding: 027300000000000051220002001808009F0203F40120010002
       ROD: EV_MUStd4CDELP_VW37.rod
       Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
       Component: ABT_Std-2  H53 1031
       Serial number: VWZ8Z9SJW0151Z
              B11CF 53 [009] - Deactivated
                        Reset counter: 140
                        Mileage: 56624 km
                        Date: 2018.11.27
                        Time: 13:28:12
                        Voltage terminal 30: 14.6 V
                        SDARS_tuner_status_2-Audio Signal: Available
                        SDARS_tuner_status_2-Antenna current: 137 mA
                        SDARS_tuner_status_2-Reception quality: optimum_signal
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
    6720 - Rear View Camera
              B1102 31 [008] - No Signal
                        Reset counter: 154
                        Mileage: 72625 km
                        Date: 2020.01.26
                        Time: 17:12:37
                        Voltage terminal 30: 14.5 V
       Component: OCULowMQBUS   007 0568
       Coding: 02730002C2823A017F1E06000000
       ROD: EV_OCULowMQB.rod
       Component: SAS-GEN 2     H06 SASH06 00140014
       Serial number: 160725200859
       ROD: N/A
       VCID: 6BD5AF8B8269371760-803F
    End-------------------------(Elapsed Time: 05:04)--------------------------
    Since you've retrofit a different part than the one that belongs in the car, this thread is moving to... Retrofits.
    Apr 2018
    ITALY
    please post an adaptation map of module 09, we only need to tell the BCM your license plate lights are now LED modules.
    my Golf came out of the factory with 13 ECUs. now she has 20. and counting
  4. Likes PetrolDave, Uwe liked this post
    Jan 2015
    Bosnia and Herzegovina
    login 31347
    adaptations
    Leuchte25KZL HA59-Lasttyp 25 set to 41- LED Keinleistung
    There are 3 kind of services
    GOOD CHEAP FAST
    But you can only choose 2:
    GOOD and CHEAP won't be FAST
    FAST and GOOD won't be CHEAP
    CHEAP and FAST won't be GOOD
  6. Likes Uwe liked this post
