Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Error code with dates in the future
    New User
    Feb 2020
    FRANCE
    Measuring values should be in a CSV file starting with "blockmap-17".
    no file generated. Why?
  2. #12
    Do you have measuring values when you connect manually to controller 17? Did you completely drain your battery?
  3. #13
    Wait, you have a HEX-USB+CAN... that's why. Connect to 17 manually, enter "day" in the search field, select something that matches "day counter", and save/screenshot the value VCDS displays.
  4. Likes Uwe liked this post
  5. #14
    New User
    Feb 2020
    FRANCE
    in manual mode, the value is 1245d for IDE00819.
    sorry, i dont understand : Did you completely drain your battery?.
  6. Likes Eric liked this post
  7. #15
    May 2014
    ^^Eric: What a fascinating thread and what an extremely interesting question - what is the format of the date field on OBD?
    I just pulled a random hex17 module from my database: the IDE00819 value is 206 for the admap date 13 August 2018 (confirmed by the year, month, day, channel values in the module).
    If I'm not violating Ross-Tech commercial secrets - what is the conversion algorithm to human date (Please don't tell me to read the Standard)?
  8. #16
    What standard?
    "OBD Standards" only apply to generic OBD-II /EBOD data, which this isn't.
  9. Likes DV52 liked this post
  10. #17
    May 2014
    ^^^Uwe: my question (and your response) clearly confirms that I don't understand the "OBD Standards"!!
    When I look back on my (fortunately) unremarkable life, its one of my many regrets. Hopefully there's still time and it's on my bucket list - but much alcohol is required before I get the courage to buy a copy of the Standards and then even more drink is needed to fortify the grey-matter in my head before opening the first page of the document.
    But I do envy anyone who can refer to the OBD standards with authority -respect!!
  11. #18
    New User
    Feb 2020
    FRANCE
    Hello Eric
    do you have suggestion?
    thank for your help
  12. #19
    Sorry, I can't make sense of it. The freeze frame, when it depends on the day counter, is supposed to be in the past compared to the time you're scanning. I see that your VCDS autoscan has the correct date, yet those FF dates are ahead of the scan's date. I was thinking maybe the day counter would be a very high or somehow negative value, but your day counter looks normal. Even then it would hardly explain the two different years. Either it's a new freeze frame format we don't understand, or your engine got the date from the cluster wrong. A scan with ODIS would tell us which it is.
  13. Likes Uwe liked this post
