Results 1 to 10 of 19
Thread: Error code with dates in the future
    New User
    Feb 2020
    FRANCE
    I use a HEX + CAN interface for VW T6 of 2017.
    after a auto-scan with VCDS 19.6.2, I find error codes with dates of 2026 and 2033.
    Why are the dates not correct?
    The problem is it a bad time management in the calculator or a version too old my ross-tech interface.
    Thank you for answer
    Extract off auto-sacn
    Sunday,19,January,2020,09:43:07:35032
    VCDS Version: 19.6.2.0
    VIN: WV2ZZZ7HZHH050025 License Plate:
    Chassis Type: 7H-VN75 (7E0)
    Scan: 01 03 04 08 09 10 15 17 18 19 25 5F 61 69
    VIN: WV2ZZZ7HZHH050025 Mileage: 17880km-11110miles
    Address 01: Engine (2D2D2-CXFA) Labels:. 04L-907-309-V2.clb
    Part No SW: 04L 906 056 KM HW: 04L 907 445
    Component: R4 2.0l TDI H02 6186
    Revision: 23002001
    Coding: 0019401C432401080000
    Shop #: WSC 02737 790 50316
    ASAM Dataset: EV_ECM20TDI03004L906056KM 004013
    ROD: EV_ECM20TDI03004L906056JT.rod
    VCID: 020B31B49587C95FB1-8056
    30540 - Throttle Position Sensor (G69)
    P0121 00 [032] - Implausible Signal
    Mileage: 15875 km
    Date: 2033.01.03
    Time: 11:23:05
    27176 - Coolant Pump for Intercooler
    P190D 00 [032] - Mechanical Malfunction
    Fault Frequency: 7
    Mileage: 12789 km
    Date: 2026.01.14
    Time: 07:03:32
    The dates are stored by the modules in the car and just read by VCDS, so the strange dates are "created" by the firmware in the car not VCDS.
    Sometimes those dates are "relative" rather than absolute, and if the offset isn't correct, well....
  4. Likes PetrolDave liked this post
    Please provide:
    1) Unedited autoscan
    2) Adp and MWB maps from cluster
  6. Likes Uwe, PetrolDave liked this post
    New User
    Feb 2020
    FRANCE
    Morning,
    I am new to VCDS. Can you explain to me how to provide the Adp and MWB maps from cluster.
    thank you
    -----------full scan : -------
       Revision: 23002001
                        Mileage: 15875 km
                        Date: 2033.01.03
                        Time: 11:23:05
                        Coolant temperature: 83 C
                        Intake air temperature: 6 C
                        Voltage terminal 30: 12.281 V
                        Unlearning counter according OBD: 13
                        Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
                        Throttl.valve adapt. 1 bank 1: posit feedback - Spec.value: -0.01 %
                        Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 100.00 %
                        Throttl.valve adapt. 1 bank 1: posit feedback - Offset closed: 0.27 %
                        Throttl.valve adapt. 1 bank 1: posit feedback - Uncnd vlt: 4.740 V
                        Fault Frequency: 7
                        Mileage: 12789 km
                        Date: 2026.01.14
                        Time: 07:03:32
                        Engine speed: 830.25 /min
                        Normed load value: 31.0 %
                        Coolant temperature: 60 C
                        Intake air temperature: 14 C
                        Voltage terminal 30: 13.210 V
                        Unlearning counter according OBD: 26
                        Air mass at air mass meter 1: 28.8 kg/h
                        Extern.temp.sens.1 bank 1: raw value: 16.0 C
                        Charge air cool.output temp.sens.1 bank 1: raw value: 24.5 C
                        Heater supp.pump 1 bank 1 charg.air cool.circuit: activat.: 10.00 %
                        Turbocharg. 1 compressor outlet:temp.sensor 1 bank 1: raw value: 29.0 C
    Readiness: N/A
    Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
       Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
       Component: ESC           H06 0133
       Revision: 00000000    Serial number: 42446000002000
       Coding: 617E40982567847E86750278A48721D2780000
       Shop #: WSC 02739 790 50316
       VCID: 3F8DF840A6F564B79E-806A
       Part No SW: 6R0 959 654     HW: 6R0 959 654
       Component: LENKW.SENSOR  H07 0070
       Serial number: 04091613470053
       Coding: 01
       ROD: EV_LWSKLOVW25X.rod
       VCID: 7EF34544E17FADBFD5-802A
       Part No SW: 7E0 907 047 AH    HW: 7E0 907 047 AH
       Component: Climatic-T5   H22 0708
       Revision: 00001002
       Coding: 0000000003
       ROD: EV_ClimaT5Basis.rod
       VCID: 70EF6B7CAB2BCBCF57-8024
       Part No SW: 7E0 937 090 B    HW: 7E0 937 090
       Component: BCM PQ25 Max4 H81 0744
       Revision: B9081001    Serial number: 0982 251160827
       Coding: 62A0393A0B332012002809742C2B8CD40F94710F60444D60320400230840
       Shop #: WSC 02737 534 543441
       VCID: 2A5BB9144577F11FD9-807E
       Subsystem 1 - Part No SW: 7E0 959 801 M    HW: 7E0 959 801 M
       Component: J386__TSG_FT  003 0653
       Serial number: KU0KU031081662442041
       Coding: 0400A0
       Subsystem 2 - Part No SW: 7E0 959 802 M    HW: 7E0 959 802 M
       Component: J387__TSG_BT  003 0653
       Serial number: KU0KU030081662435642
       Coding: 1400A0
       Subsystem 3 - Part No SW: 7E0 959 442     HW: 7E0 959 442   Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H02 0103
       Serial number: 29160001732220126354
       Coding: B0FFFF
       Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
       Component: PARKHILFE 8K  H06 0212
       Revision: --------    Serial number: 28261620303094
       Coding: 10800C
       ASAM Dataset: EV_VW75XParkAssis8K 001012
       ROD: EV_VW75XParkAssis8K_001_VN75.rod
       VCID: 71E96E78A021C2C758-8024
       Part No SW: 7E0 959 655 H    HW: 7E0 959 655 H
       Component: VW10Airbag01R H08 0018
       Revision: --------    Serial number: 003V400138Z%
       Coding: 000000000000000000000000000000003152
       Shop #: WSC 02734 790 50316
       VCID: 3B758C50B2ED7897B2-806E
       Serial number: 3495ZRB40533V6TCFPDP
       Serial number: 3505ZRB400A571NGHHGU
       Part No SW: 7E0 920 870 S    HW: 7E0 920 870 S
       Component: KOMBI         H03 1104
       Coding: 140F010300
       VCID: 39799658B8D14A87A0-806C
    Address 18: Aux. Heat (J364)       Labels:| 7E0-963-27X-18.clb
       Part No SW: 7E0 963 273 A    HW: 7E0 963 273 A
       Component: STH-T5GP2     003 0009
       Coding: 4101
       ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001013
       ROD: EV_AuxilParkiHeateWOST5G2.rod
       VCID: 2B55BC10428DE81722-807E
       Part No SW: 7E0 909 901     HW: 7E0 937 090
       Component: GW-K-CAN TP20 H81 0744
       Revision: B9081001
       Coding: 042205
       VCID: 68DF031C9BFB030F0F-803C
       Component: IMMO          H03 1104
       VCID: 6ADB79148DF7311F19-803E
       Part No SW: 1K8 035 150 H    HW: 1K8 035 150 H
       Component: MU-E--ER      055 7067
       Serial number: 24081600010076
       Coding: 06570000FF00000041110001000000001F0000C40000010001
       ASAM Dataset: EV_MUEnt4CGen2LGE 001032
       VCID: 2A5BB9144D77F11FD9-807E
       Part No SW: 7E0 907 534     HW: 7E0 937 090
       Component: Batt.regelung H81 0744
       Coding: 530B1A73
       Shop #: WSC 02739 790 00000
       Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
       Serial number: 75410903001608151438
       Part No SW: 1K0 907 383 H    HW: 1K0 907 383 G
       Component: Anhaenger     H12 0130
       Revision: 3B001001    Serial number: 00000412480371
       Coding: 0100000101000000
       VCID: 326BA1746DA7B9DF61-8066
    End-------------------------(Elapsed Time: 03:11)--------------------------
    May 2014
    Quote Originally Posted by JCS13 View Post
    Morning,
    thank you
    ^^^^^Look at RT's magnificent video HERE. This video has a dual purpose, but if you start at about 2:19 minutes, you will learn how to generate an Adp (or, "admap") for individual control modules like the cluster (which VCDS identifies as the "Instrument" module @ address hex17 -see your auto-scan).
    At about 2:33 minutes into the video choose different options as follows:
    For an Adp:
    Single controller address = 17
    Under "Function", tick Adaptations
    Under "output", click the CSV file radio button
    the set-up should look like this, (but use "17", instead of "09" in the pic:
    For a MWB map, again enter 17 into Single controller address, but tick Measuring values under Function
    For each type of map - then just press the Go button and magic stuff will happen!!
    May the force be with yo
    PS: you can tick both Adaptations AND Measuring values to streamline the process and to generate a single file containing the 2 x data sets - if you want
  9. Likes Eric, Uwe, PetrolDave liked this post
  10. #7
    New User
    Feb 2020
    FRANCE
    hello,
    thank to DV52 for the procedure.
    below Adaptations AND Measuring values data:
    ;SW:7E0-920-870-S   HW:7E0-920-870-S ---  Instruments
    ;Component:KOMBI         H03 1104, Coding:140F010300
    ;EV_Kombi_UDS_VDD_RM09,A05733,EV_Kombi_UDS_VDD_RM09_005_VW25.rod
    ;Wednesday,19,February,2020,14:33:23:35032
    ;VCDS Version: Release 19.6.2  Data version: 20190930 DS308.0
    ;VCID: 39799658B8D14A87A0-806C
    IDE00301-Distance,17880 km,2
    IDE00342-ESI: Resetting ESI,Reset ,1
    IDE00343-Language version,French ,1
    IDE00344-Seat belt warning,Version 4 ,1
    IDE00492-MAS00900-ESI: Coding of Service Interval Extension (SIE)-Oil level,Oil level evaluation ,1
    IDE00492-MAS02003-ESI: Coding of Service Interval Extension (SIE)-Status ESI or SID,ESI or SID on ,1
    IDE00492-MAS02006-ESI: Coding of Service Interval Extension (SIE)-Selection of ESI or SID,Extended Service Intervals (ESI) ,1
    IDE00492-MAS02010-ESI: Coding of Service Interval Extension (SIE)-Oil pressure,dynamic oil pressure ,1
    IDE00492-MAS02011-ESI: Coding of Service Interval Extension (SIE)-Remote clock receiver,without remote clock receiver ,1
    IDE00492-MAS02012-ESI: Coding of Service Interval Extension (SIE)-Oil quality,good oil quality ,1
    IDE00492-MAS02013-ESI: Coding of Service Interval Extension (SIE)-TOG,Oil level thermal sensor connected to instrument cluster ,1
    IDE00493-Display correction of fuel gauge,-0.5 ,1
    IDE00499-Display correction of consumptions and operating range,100 %,1
    IDE00500-Hour,14 H,1
    IDE00501-Minute,32 min,1
    IDE00505-Speed threshold of dynamic oil pressure warning,kein Offset ,1
    IDE00510-ESI: distance driven from inspection,6900 km,2
    IDE00511-ESI: time from inspection,434 d,2
    IDE00512-ESI: minimum value km-driving distance/inspection,20000 km,2
    IDE00513-ESI: maximum value km-driving distance/inspection,40000 km,2
    IDE00514-ESI: maximum value of time between inspections,730 d,2
    IDE00515-ESI: oil quality,good oil quality ,1
    IDE00517-ESI: soot entry,9200 km,2
    IDE00518-ESI: thermal load,4500 km,2
    IDE00711-Trip recorder,not installed ,1
    IDE00714-MAS00888-Additional coding-Tank characteristic curve,1 ,1
    IDE00714-MAS01209-Additional coding-Speed source,via CAN ,1
    IDE00714-MAS01210-Additional coding-Coolant temperature source,via CAN ,1
    IDE00714-MAS01211-Additional coding-Locking bit,locked ,1
    IDE00714-MAS04066-Additional coding-Number of fuel level sensors,1 ,1
    IDE00827-ESI: minimum value of time between inspections,730 d,2
    IDE02200-Component protection showroom mode,not activated ,1
    IDE02327-Indicator light for start-stop operation,active ,1
    IDE02489-Display depiction,Not available ,1
    IDE02494-Automatic door locking,Yes ,1
    IDE03177-MAS02569-Acoustics for timeout signaling-All-wheel electronics,Not available ,1
    IDE03177-MAS02570-Acoustics for timeout signaling-Lock Electronics,Not available ,1
    IDE03346-IDE00301-Units adjusted-Distance,Kilometers ,2
    IDE03346-IDE00316-Units adjusted-Time,24h ,2
    IDE03346-MAS01230-Units adjusted-Date,dd_mm_yy ,2
    IDE03346-MAS01456-Units adjusted-Speed,Kilometers per hour ,2
    IDE03346-MAS02201-Units adjusted-Temperature,C ,2
    IDE03346-MAS03032-Units adjusted-Volume,Liter ,2
    IDE03346-MAS03033-Units adjusted-Consumption,Liters per 100 km ,2
    IDE03346-MAS03034-Units adjusted-Pressure,bar ,2
    IDE03349-FIX: Max. distance until next mileage-related inspection,40000 km,2
    IDE03350-FIX: Maximum time until next time-dependent inspection,365 d,2
    IDE03351-FIX: Distance covered since last mileage-dependent inspection,6900 km,2
    IDE03352-FIX: Time since last time-dependent inspection,435 d,2
    IDE03481-MAS01632-Emergency telephone number-Status,not active ,25
    IDE03481-MAS04225-Emergency telephone number-Preselection,000000000000000000000000 ,25
    IDE03481-MAS04226-Emergency telephone number-Telephone number,000000000000000000000000 ,25
    IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time,10 s,5
    IDE03568-ENG102019-Service-key settings-p_main_switch_basis,On ,5
    IDE03568-ENG102414-Service-key settings-p_main_switch_keyless,On ,5
    IDE03568-ENG102611-Service-key settings-p_write_delay_speed,20 km/h,5
    IDE03568-ENG103545-Service-key settings-p_write_delay_time,40 s,5
    IDE03568-ENG104099-Service-key settings-p_write_distance,20 km,5
    IDE04848-Volume to be replenished,No ,1
    IDE05583-Pause recommendation,Yes ,1
    IDE05930-Service notification in days,30 d,1
    IDE05931-FIX: Reset value for next mileage-dependent inspection,30000 km,2
    IDE05932-FIX: Reset value for next time-dependent inspections,365 d,2
    IDE06418-Light warning buzzer: condition,closed ,1
    IDE06588-Ignition active message: actuator,Driver door ,1
    IDE07221-Cylinder shut-off,No ,1
    IDE08753-IDE00837-MFA display cylinder shut down-Instantaneous consumption,No ,1
    IDE08753-MAS03930-MFA display cylinder shut down-Average consumption,No ,1
    IDE08753-MAS03934-MFA display cylinder shut down-Range,No ,1
    IDE08753-MAS05871-MFA display cylinder shut down-Full engine operation,No ,1
    IDE09257-Power steering,Version 2 ,1
    IDE10059-MAS00844-Component protection mode-Radio,requested ,1
    IDE10059-MAS01799-Component protection mode-Navigation,not requested ,1
    IDE10059-MAS05506-Component protection mode-Stopping distance reduction,not requested ,1
    IDE10059-ENG114193-Component protection mode-Vorhalt,not requested ,1
    IDE11086-Service notification,30 d,1
    ENG112420-MAS03095-additional_adaption-Function status,No ,3
    ENG112420-MAS03118-additional_adaption-Logic address,0 ,3
    ENG112417-indicator_celebration,not active ,1
    ENG141644-Scale_dimming_algorithm,Autolicht / Abblendlicht / Nebellicht ,1
    ENG108924-Service_Key_Clear_All_Counters,Yes ,1
    ENG112416-IDE01766-velocity_detection-Distance impulses,4 ,1
    ENG112416-MAS01209-velocity_detection-Speed source,Distance impulses ,1
    Elapsed Time: 00:36
    Thank you by advance
  11. #8
    You only have the adaptations here. I'm looking specifically for IDE00819: Day counter . On a Passat NMS with the same ASAM ID, it's only present in measuring values.
  12. #9
    New User
    Feb 2020
    FRANCE
    With the tool 'Controller Channel Map' option Single Controller adress on 17,
    I do not have a CSV file generated for Measuring value.
    I only have a CSV file for the Adaptations but there is no value IDE00819
    is what I use the right method?
    thank you
  13. #10
    Measuring values should be in a CSV file starting with "blockmap-17".
  14. Likes Uwe liked this post
