Results 1 to 3 of 3
Thread: 2015 VW golf 7 Engine light always on ---need help---
    Nov 2019
    Croatia
    I started my car this morning and the engine light came on and stayed on... I was 400km away from home so i had to drive back with the engine light on all the time.
    Driving was fine, i didnt notice anything wrong. As soon as i got home i plugged in my HEX V2 and and made an auto scan.
    The fault code came out: 15920 - Cylinder 3 Glow Plug Circuit (Q12)
    More details in my auto scan.
    can someone tell me something about this problem.
    The car still has warranty so i hope that it covers this issue.
    Monday,17,February,2020,15:56:12:55161
    VIN: WVWZZZAUZGP044747   License Plate:
    Mileage: 78128km-48546mi   Repair Order:
                    Address 01: Engine       Labels: 04L-907-309-V1.clb
    Control Module Part Number: 04L 906 056 CL    HW: 04L 907 445 B
      Component and/or Version: R4 1.6l TDI   H06 6336
               Software Coding: 0111401A432405092000
                Work Shop Code: WSC 00028 028 00031
                  ASAM Dataset: EV_ECM16TDI03004L906056CL 004011 (VW37)
                           ROD: EV_ECM16TDI03004L906056_004.rod
                          VCID: 79AFEA6F8954255F8EB-802C
              P0673 00 [236] - Electrical Fault
                        Mileage: 77261 km
                        Date: 2020.02.15
                        Time: 13:00:43
                        Engine speed: 875.25 /min
                        Normed load value: 34.1 %
                        Coolant temperature: 10 °C
                        Intake air temperature: 13 °C
                        Voltage terminal 30: 15.007 V
                        Control Module temperature: 14.5 °C
                        Mean injection quantity: 9 mg/stroke
                        Accelerator pedal travel: raw value: 0.00 %
                        Limitation: torque: 162.0 Nm
    27277 - System Voltage
              P0562 00 [032] - Too Low
    Readiness: N/A
    Monday,17,February,2020,15:57:04:55161
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 03 08 09 10 15 16 17 18 19 20 42 44 52 55 5F
    VIN: WVWZZZAUZGP044747   Mileage: 78128km-48546miles
    Address 01: Engine (J623-CXXB)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 056 CL    HW: 04L 907 445 B
       Component: R4 1.6l TDI   H06 6336
       Revision: 22004001
       Shop #: WSC 00028 028 00031
                        Mileage: 77261 km
                        Date: 2020.02.15
                        Time: 13:00:43
    Readiness: N/A
       Part No SW: 3Q0 907 379 AF    HW: 3Q0 907 379 F
       Component: ESC           H42 0625
       Revision: 00000000    Serial number: 92455000009657
       Coding: 01FA62A124240970077E060441CA2580462490E06082A4F300400078C002
       VCID: 7EA5F973907A0267BB9-802A
       Part No SW: 5G0 907 044 BE    HW: 5G0 907 044 BE
       Revision: 00001K08
       Coding: 00020104204101011005000000101002
       Shop #: WSC 00028 028 00023
       VCID: 6B83C027F30887CF0C7-803E
       Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
       Serial number: 01061525301036
       Coding: 00000B46C24122FB4BE44000001C07081400000000000000000000000000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 094F9AAFD9B435DF9EB-805C
       Component: WWS    150819  043 0551
       Serial number:         150828155800
       Component: RLHS  037 0059
       Serial number: S4Y15M09D18H22M49S07
       Coding: 90A8DD
       Revision: --------    Serial number: 39391525901725
       Coding: 0031051001
       VCID: 43D34887BB18AF8F947-8016
       Serial number: 003F6R129EH8
       Shop #: WSC 00028 028 00003
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 41DF428FA104BD9F86B-8014
       Subsystem 1 - Part No SW: -----------    HW: 480 000 809 15
       Serial number: 357670000009F2D85611
       Subsystem 2 - Part No SW: -----------    HW: 480 000 809 15
       Serial number: 358670000000E2D8561Z
       Subsystem 3 - Part No SW: -----------    HW: 480 400 709 15
       Serial number: 35165029F1D25F72535I
       Subsystem 4 - Part No SW: -----------    HW: 480 400 709 15
       Serial number: 3526502AB1D25F7312DK
       Subsystem 5 - Part No SW: -----------    HW: 480 400 709 15
       Serial number: 35565029F1D25F7422ET
       Part No SW: 5Q0 953 507 FT    HW: 5Q0 953 549 F
       Component: Lenks. Modul  003 0110
       Revision: --------    Serial number: 16091504220163
       Coding: 0400
       ROD: EV_SMLSKLOMQB_010_VW37.rod
       VCID: 0D47AEBFADDC29FFB23-8058
       Part No SW: 5G1 920 751 A    HW: 5G1 920 751 A
       Component: KOMBI         302 6420
       Coding: 07A51A002B80000801087E001400000000000000
       VCID: 2615F113286A7AA7939-8072
       Part No SW: 5Q0 963 272 E    HW: 5Q0 963 272 E
       Component: STH-MQB       007 0072
       Coding: 9309
       ASAM Dataset: EV_AuxilParkiHeateWOS 002018
       VCID: 38292F6BF2DEFC57315-806C
       Subsystem 1 - Part No SW: 5Q0 963 513 A    HW: 5Q0 963 513 A
       Component: R149 T91-LIN  003 0301
       Serial number: 00000000000001217045
       Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2227
       Revision: --------    Serial number: 10091510801230
       Coding: 030100041F087300FB00024A080F00010001050000000000000000000000
       ROD: EV_GatewConti_013.rod
       VCID: 75B7E65FA54C413FEA3-8020
       Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H17 0103
       Serial number: 29150001801650025372
       Coding: 28FFFF
       Serial number: 8374837303
    Address 20: High Beam Assist. (J844)       Labels:| 8X0-857-511.clb
       Part No SW: 5G0 857 511 D    HW: 5G0 857 511
       Component: FLA           H04 0002
       Revision: AA001001
       Coding: 02018864727264565625393E01
       VCID: 2B030027338847CF4C7-807E
       Serial number: 0000166418393
       Coding: 00310320D000020000001000
       VCID: 47CB5C978F2083AF48F-8012
       Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000010271485
       Component: EPS_MQB_ZFLS  126 1063
       Coding: 0103
       VCID: 44D14B9BBE16A8B7ADD-8010
       Serial number: 0000165902439
       Coding: 00310120DE00020000801000
       VCID: 46D55193882A9AA7B39-8012
       Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000010275180
       Coding: 090000
       Coding: 028A00000B000200
       VCID: 40D9478BAA0EB497895-8014
       Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Coding: 2E0000
       Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Coding: 2E0000
       Part No SW: 3Q0 035 846     HW: 3Q0 035 846
       Component: MU-S-N-ER     H24 0245
       Serial number: VWZAZ2R0476466
       Coding: 02730001FF00000051110001000808001F0100C401200100CF
       ROD: EV_MUStd4CTSAT_VW37.rod
       VCID: 6E85C933C01A72E72B9-803A
       Component: ABT_Std-2_Nav  H43 4064
       Serial number: VWZ6Z9R2552271
       Subsystem 2 - Part No SW: 5NA 919 866 AG    HW: -----------
       Component: ECE AS 2020  --- 1310
    5688 - Control Head for Mulimedia System
              B13C9 F2 [008] - On/Off Switch
                        Reset counter: 187
                        Mileage: 75885 km
                        Date: 2020.01.18
                        Time: 16:41:46
                        Voltage terminal 30: 12.6 V
    7201 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Road sign display (0x21) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 150
                        Mileage: 76099 km
                        Date: 2020.01.23
                        Time: 18:39:25
                        Voltage terminal 30: 12.2 V
                        BAP-BAP_Function_ID: 02
    End----------(Elapsed Time: 01:39, VBatt start/end: 12.3V/12.4V)-----------
    May 2017
    The engine light will clear after few starts if the fault is not permanent.
    I would not worry about that intermittent fault at this point. I’ve had those randomly with cold engine and cold weather. In my case though the engine light has never been lit. Just fault code registered to fault memory
    I'd probably consider charging or getting a new battery & if the charging system checked out as OKAY with a good inspection of the freewheel clutch on alternator if supported and the drive belt ......
  4. Likes PetrolDave, downtime liked this post
