Results 1 to 6 of 6
Thread: VW MK5 ABS system function test
    Verified VCDS-User
    Aug 2018
    Romania
    Hello there,
    I got an VW MK5 where i got the ABS function test active and it wont enter in the learning mode.
    As a background the owner disconnect the battery for replacing it and when he saw the ESP light on he try to enter with VCDS to solve the issue without driving with the car.
    He activated from mistake ABS system test and now it seems that the test it doesn't dissapear.
    I check the errors on ABS module and it doesn't give me any except this one.
    I monitor the ABS sensors on the wheels and everything is ok .
    I mention that the steering wheel is still working hard and i can get rid of that error on the steering wheel module.
    I also calibrated the angle sensor on the ABS module and is say ok.
    Can somebody help me with some info?
    Saturday,15,February,2020,13:19:07:32554
    Workshop Code: 022 21992 002029
    VIN: WVWZZZ1KZ7W607118   License Plate:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 69 72
    VIN: WVWZZZ1KZ7W607118   Mileage: 202450km-125796miles
    Address 01: Engine        Labels: 03G-906-016-BKC.clb
       Part No SW: 03G 906 021 KQ    HW: 03G 906 021 AN
       Component: R4 1,9L EDC G000SG  9247
       Revision: --H06---    Serial number: VWZBZ0G0583025
       Coding: 0000071
       Shop #: WSC 01392 785 00200
       VCID: 78BC1D060BAC618F9F-802C
    005658 - Glowplug for Cylinder 1 (Q10)
                   P161A - 000 - Open Circuit
                        Fault Status: 01110000
                        Mileage: 202434 km
                        Time: 16:46:31
                        RPM: 378 /min
                        Voltage: 9.65 V
                        Bin. Bits: 00101100
                        Temperature: 0.9°C
                        Bin. Bits: 01110000
    005660 - Glowplug for Cylinder 3 (Q12)
                   P161C - 000 - Open Circuit
                        Mileage: 202434 km
                        Time: 16:46:31
                        RPM: 378 /min
                        Voltage: 9.65 V
                        Bin. Bits: 00101100
                        Temperature: 0.9°C
                        Bin. Bits: 01110000
       Revision: 00H11001
       Coding: 0021234
       VCID: 73A62A2A12CA02D7AA-8026
       Part No SW: 1K0 907 044 BN    HW: 1K0 907 044 BN
       Component: ClimatronicPQ35 110 1010
       Revision: 00110021    Serial number: 00000000000000
       VCID: 74A4293617C405EFB3-8020
       Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
       Component: Bordnetz-SG     H52 2002
       Revision: 00H52000    Serial number: 00000006824428
       Coding: 098B8F2700041800470A00000F00000000095D035C0001
       Shop #: WSC 00000 785 00200
       VCID: 6C9431564FF4DD2F6B-8038
       Subsystem 1 - Part No: 5M0 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer 010307 020  0501
       Coding: 00038805
       Component: 1D AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD13DB7+
       Coding: 0012612
       Shop #: WSC 01373 785 00200
       VCID: 3D32CC12640E84A78C-8068
       Subsystem 1 - Serial number: 6332MSME123670482
       Subsystem 2 - Serial number: 6342MSME153E7206A
       Subsystem 3 - Serial number: 6351HSME0C785B58N
       Subsystem 4 - Serial number: 6361HSME0C7E0531A
       Part No SW: 1K0 953 549 BC    HW: 1K0 953 549 BC
       Component: Lenksäulenmodul 036 0070
       Coding: 0000042
       Part No SW: 1K0 920 863 B    HW: 1K0 920 863 B
       Component: KOMBIINSTRUMENT VN4 8212
       Revision: V0007000    Serial number: VWZBZ0G0583025
       Coding: 0005103
       Shop #: WSC 21992 022 02029
       VCID: 2A18F74E8580031FD9-807E
       Part No SW: 1K0 907 530 K    HW: 1K0 907 951
       Component: J533__Gateway   H04 0021
       Revision:   H04 02    Serial number: 120307F2001519
       Coding: 3D3F434007009002
       VCID: 2F2EE65ABE6266370E-807A
       Part No: 1K0 920 863 B
       Component: IMMO VN4            8212
       Component: Tuer-SG         005 0989
       Coding: 0000180
       VCID: 383CDD064B2CA18F5F-806C
       Part No: 1K1 909 144 L
       Component: EPS_ZFLS Kl.070 H07 1806
       Shop #: WSC 00999 444 64523
       VCID: 3424E936574445EF73-8060
    02546 - Steering Limit Stop
                        Mileage: 202440 km
                        Temperature: 15.0°C
                        Voltage: 14.20 V
                        Voltage: 14.00 V
       Component:    KSG PQ35 G2  020 0203
       Coding: 809002005103087F2D04840560084F03E0FCA0
       VCID: 03467AEA426A3257BA-8056
       Coding: 0000180
       VCID: 393AD8027026B887A0-806C
       Part No: 5M0 035 186 B
       Component: Radio GR0       020 0023
       Revision: 0002006S    Serial number: VWZ2Z2G1882425
       Coding: 0020200
       VCID: 2B16F24A8A7A1A1722-807E
       Component: Tuer-SG         005 0914
       Coding: 0000144
       Shop #: WSC 01392 785 1012552
    Address 69: Trailer        Labels: 1K0-907-383-V1.clb
       Part No SW: 1K0 907 383     HW: 1K0 907 383
       Component: ANHAENGERELEKTR 003 0020
       VCID: 6A98374E4500C31F19-803E
       Coding: 0000144
    End----------(Elapsed Time: 01:10, VBatt start/end: 12.5V/12.0V)-----------
    Did you try & In the same session correct any faults for SAS G85 in 0x44 do the adaptation and then move directly to 0x03 to finish it?
  3. Likes downtime liked this post
    HQ
    Jef
  5. Likes Jack@European_Parts, Uwe, downtime liked this post
  6. #4
    Verified VCDS-User
    Aug 2018
    Romania
    So i try to do the adaptation of Steering Limit Stop from WIKI but nothing and in terms of basic settings i try to calibrate again SAS from 0x03 but it say ok but the error doesn't dissapear from 0x44.
    The thing is that i don't see the values on SAS when i check measure blocks in 0x44 or 0x3 and i don't know if there should be any since the calibration is not ok.
    I don't understand how to "move dirrectly to finish it" (you mean to make the basic setting from 0x44 module and not 0x3?
    Thanks!
    Verified VCDS-User
    Aug 2018
    Romania
    i did already all the steps from the whole WIKI/Youtube but i have the same issue.
    DID YOU KNOW YOU HAVE TO FIX THE MECHANICAL or ELECTRICAL PROBLEM?
