Can anybody help,I have disabled the stop/start on my car which is o/k. But the engine cuts out when I open drivers door to shut the gate. Thank you in advance.
Monday,17,February,2020,12:27:29:39116
VCDS Version: 19.6.2.2 (x64) HEX-V2 CB: 0.4508.4
VIN: WAUZZZ8K7DA222393 License Plate:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 44 46 47 52 53 56 62 72 77
VIN: WAUZZZ8K7DA222393 Mileage: 57570km-35772miles
Address 01: Engine (J623-CJEB) Labels:. 06L-906-264-CJE.clb
Part No SW: 8K0 906 264 A HW: 8K0 906 264
Component: 1.8l R4 TFSI H07 0004
Revision: --H07---
Coding: 12030032242501022000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM18TFS0218K0906264A 001004
ROD: EV_ECM18TFS0218K0906264A.rod
VCID: 2F381AF68794C0BF60F-807A
15462 - Control Circuit for Coolant Bypass Valve
P2681 00 [040] - Open Cricuit
Fault Frequency: 64
Mileage: 57496 km
Date: 2020.02.04
Time: 13:58:01
Engine speed: 1382.00 /min
Normed load value: 23.9 %
Vehicle speed: 42 km/h
Coolant temperature: 94 °C
Intake air temperature: 13 °C
Voltage terminal 30: 14.160 V
Engine: operating status: PL
Engine temp. management actuator: raw value: 2071
Engine temperature management actuator: stop open: 136
Engine temperature management actuator: after-run stop: 3950
RVC_SP: 128.50 °
RVC_AV: 128.91 °
RVCPWM: 0.000 %
Readiness: 0000 0001
Address 02: Auto Trans (J217) Labels:| 0AW-927-156.clb
Part No SW: 8K5 927 155 Q HW: 0AW 927 156 K
Component: 0AW 18TFSIRdW H05 0001
Revision: --H05--- Serial number: 0000000684
Coding: 000002
Shop #: WSC 06335 000 00000
ASAM Dataset: EV_TCMVL381 A02432
ROD: EV_TCMVL381.rod
VCID: 46D65F52082E61F7B39-8012
Part No SW: 8K0 907 379 CG HW: 8K0 907 379 CG
Component: ESP8 front H09 0100
Coding: 051544
VCID: 005A894A6A0A8FC7C95-8054
Part No SW: 8K0 907 064 GC HW: 8K0 907 064 FC
Component: BCM2 2.0 H12 0633
Coding: 01B24040000000000000
VCID: 77A8E2963FC4C87FF8F-8022
Subsystem 1 - Part No SW: 8K0 959 754 H HW: 8K0 959 754 H
Serial number: 0813000029141013
Serial number: 2313000032152004
Part No SW: 8K2 820 043 S HW: 8K2 820 043 S
Revision: D0000000 Serial number: 01050320132246
Coding: 642402C000
VCID: 392C24AE49501E0FCEB-806C
Part No SW: 8K0 907 063 DC HW: 8K0 907 063 DC
Component: BCM1 1.0 H16 0103
Revision: 03016001 Serial number: 00000564626302
Coding: 290000308034A7C00081000000001F1F001D460827080201000008004000020000000020000000
VCID: 73B0D6862BBCA45FC47-8026
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 280213 H06 0080
Serial number: SWF13020280144
Coding: 00FD11
Component: G397_RLFS H06 0002
Serial number: 21060597
Coding: 02005D
Component: E1 - LDS H03 0031
Serial number: 00000000000103130458
Serial number: D6184896000000000001
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Serial number: 003KFD98U90L
Coding: 30534435363030303030554A3052384B3053
Shop #: WSC 34713 001 1048576
VCID: 48CA516A023A7787415-801C
Serial number: 6334MSME76244B13B
Serial number: 6344MSME7624377CM
Serial number: 6352QSME3E290952L
Serial number: 6362QSME7026336CH
Serial number: 63732SME4D2C2948A
Serial number: 63832SME512C57683
Revision: 00000000 Serial number: 20130311000987
Coding: 000017
VCID: 4FF87A76E7D4A0BF00F-801A
Part No SW: 8K0 920 982 C HW: 8K0 920 982 C
Component: KOMBIINSTR. H35 0556
Revision: 00400000 Serial number: UVM59ZC3E
Coding: 3386100002012600010000
VCID: 3432159A6E32E3671DD-8060
Part No SW: 8R0 907 468 L HW: 8R0 907 468 A
Component: GW-BEM 5CAN H11 0055
Revision: 1V070026 Serial number: 2641V13227818C
Coding: 80CF07FF00
VCID: 48CA516A02BA7787415-801C
Serial number: 9342140103
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Serial number: 13064000332021200181
Part No SW: 8K0 959 793 S HW: 8K0 959 793 Q
Component: TSG FA H02 0506
Revision: Serial number: 0000054034523
Coding: 011002204001410001
VCID: 50FA790AFAEABF47195-8004
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H37 0507
Revision: 00001000 Serial number: 0004246404
Coding: 100000000001
Shop #: WSC 06334 000 00000
ROD: EV_RCEPSAU48X_008.rod
VCID: 3432159A6EB2E3671DD-8060
Revision: 00002001 Serial number: 0300466936
Coding: 013B062220B90000803002368000000F
Address 47: Sound System (J525) Labels:. 8T0-035-223-ASC.clb
Part No SW: 8R0 035 223 G HW: 8R0 035 223 E
Component: DSP STD H11 0460
Revision: 00000000 Serial number: 00000000000001
Coding: 0203010102
VCID: 303A198A9A2ADF47795-8064
Part No SW: 8K0 959 792 S HW: 8K0 959 792 Q
Component: TSG BF H02 0506
Revision: Serial number: 0000054065080
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 00000001267433
ROD: EV_ParkiBrake_AU48.rod
VCID: 382A21AA72DA0707315-806C
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8R2 035 186 N HW: 8R2 035 186 N
Component: Concert3 H05 0470
Revision: 00000002 Serial number: AUZ5Z6M1866122
Coding: 0502008201028D00035B071000
VCID: 41DC4C4E218046CF86B-8014
Subsystem 1 - Part No SW: 8T0 919 603 G HW: 8T0 919 603 G
Component: Display
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0506
Revision: Serial number: 0000053951009
Coding: 010002204001210001
VCID: 46D65F5208AE61F7B39-8012
Component: TSG HR H01 0506
Revision: Serial number: 0000053952091
Part No SW: 8T0 862 335 F HW: 8T0 862 335 E
Component: FSE_256x BT H45 0660
Revision: 00000000 Serial number: 00000005629881
Coding: 0010320
VCID: 3D2430BE5178222FE23-8068
End----------(Elapsed Time: 01:37, VBatt start/end: 12.7V/12.5V)-----------
