P2294 N276 problem
Fahrenheit_29
Sedalia, MO, USA
C?ID=396291
I have an 07 Jetta GLI Fahrenheit #27
I got an EPC light and limp mode a month ago. I think I had a P2293 code at first but I know only have a P2294. I put a new HPFP on with JHM upgraded internals. I just installed a new fuel rail pressure sensor as I was seeing 5 to 7 bar at the rail consistently. I checked fuses. I can actuate the n80 valve with vcds which uses some of the same electrical I believe. I am getting a circuit open on n276 fault and I think wiring is my last option of troubleshooting and just want some other input just in case I missed something. Here's my full autoscan. I know there's lots of other issues, battery was recently unhooked, headlight switch unhooked. No factory radio, aftermarket headlights, a few other things maybe...
Saturday,15,February,2020,15:11:41:64993
VIN: 3VWWJ71K57M155065   License Plate:
Mileage: 248410km-154354mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 62 65 72
          77
VIN: 3VWWJ71K57M155065   Mileage: 248410km-154354miles
62-Door, Rear Left -- Status: Malfunction 1010
72-Door, Rear Right -- Status: Malfunction 1010
   Part No SW: 1K0 907 115 H    HW: 8P0 907 115 B
   Revision: 5BH15---    Serial number: VWZ7Z0F8240645
   Coding: 0403010A18070160
   VCID: 2B0301C3DF0AEE4F4C7-807E
008852 - Fuel Pressure Regulator Valve (N276)
               P2294 - 004 - Open Circuit - MIL ON
                    Fault Status: 11100100
                    Mileage: 248415 km
                    Time: 01:44:46
                    RPM: 770 /min
                    Load: 11.4 %
                    Temperature: 42.0°C
                    Temperature: 12.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 14.097 V
Readiness: 0110 0101
   Revision: 00H11001
   Coding: 0021122
   VCID: 73B3D9A347BAF68FC47-8026
   Part No: 1K0 820 047 GS
   Component: Climatic PQ35   120 0606
   VCID: 7BA3F1836FEABECF9C7-802E
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
   Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000000525339
   Coding: 17058E23400415465C140062001400000019770B630000
   VCID: 6C81C2DF1A84297705D-8038
   Component: Wischer 230307 020  0501
   Coding: 00040853
   Shop #: WSC 12345
02498 - Left Low Beam Reflector Motor (V294)
                    Fault Status: 01111100
                    Reset counter: 117
                    Mileage: 234589 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.75 V
02499 - Right Low Beam Reflector Motor (V295)
                    Reset counter: 117
                    Mileage: 234545 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.30 V
                    Reset counter: 150
                    Mileage: 243089 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.65 V
                    Reset counter: 150
                    Mileage: 246747 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.60 V
                    Fault Status: 01100010
                    Reset counter: 117
                    Mileage: 248415 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 9.90 V
   Part No SW: 8E0 035 593 H    HW: 8E0 035 593 H
   Component: SDAR SIRIUS     H06 0080
   Revision: 00000000    Serial number: AUZ4Z7G0053353
   VCID: 2E0508D7EC189B676B9-807A
                    Reset counter: 154
                    Mileage: 238612 km
                    Time: 03:37:38
01304 - Radio
                    Reset counter: 117
                    Mileage: 248415 km
                    Time: 21:16:50
   Revision: 05034000    Serial number: 003B6M01AWHG
   Coding: 0013889
   Subsystem 2 - Serial number: 6332MSME170D3C34E
   Subsystem 3 - Serial number: 6342MSME16794B6EU
   Subsystem 4 - Serial number: 6351HSME0C4660746
   Subsystem 5 - Serial number: 6361HSME0C571D5EP
   Subsystem 6 - Serial number: 63727SME0C286343+
   Subsystem 7 - Serial number: 63827SME0C284138%
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Component: J0527           036 0070
   Coding: 0002021
   VCID: 015F836B0D06D41FC6B-8054
   Part No SW: 1K6 920 973 A    HW: 1K6 920 973 A
   Component: KOMBIINSTRUMENT VDD 1610
   Revision: V0003000    Serial number: VWZ7Z0F8240645
   Coding: 0021107
   Shop #: WSC 25019 444 67490
   VCID: 313F13ABFD26849F76B-8064
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0021
   Revision:   H04 02    Serial number: 030307F1000869
   Coding: 7DBF03E00F001002
   Shop #: WSC 24313 444 05014
   VCID: 2F3B15D3EB12926F60F-807A
                    Fault Status: 00110100
                    Reset counter: 150
                    Mileage: 243089 km
                    Time: 05:31:55
                    Reset counter: 150
                    Mileage: 246747 km
                    Time: 15:08:30
01304 - Radio
                    Reset counter: 194
                    Mileage: 239937 km
                    Time: 02:30:27
   Component: Kompass         005 0004
   Revision: 00005000    Serial number: 1293324T2HH804
   Coding: 0000003
   VCID: 392F2B8B25564CDFCEB-806C
   Component: IMMO            VDD 1610
   Component: J386  TUER-SG FT    1133
   Revision: 32008001    Serial number: 00000519478227
   Coding: 0001205
   VCID: 3B2331832F6A7ECFDC7-806E
                    Fault Status: 01100101
                    Reset counter: 117
                    Fault Status: 00111000
                    Reset counter: 157
                    Mileage: 234545 km
00105 - Signal Central Locking SAVE/LOCK Drivers Side
                    Reset counter: 144
                    Mileage: 244318 km
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.069 H07 1806
   VCID: 34311ABF0234B1B71DD-8060
   Component:    KSG PQ35 RDK 052 0218
   Coding: 12900F880186483F2D04058FB0888F2488DC00
   Shop #: WSC 00066 123 12345
   VCID: 04518A7F1214C137EDD-8050
   Part No SW: 1K0 959 702 P    HW: 1K0 959 792 L
   Component: J387  TUER-SG BT    1133
   Revision: 32008001    Serial number: 00000554478226
   Coding: 0001204
   VCID: 3C21329F2A6479F7D5D-8068
                    Fault Status: 00100101
                    Reset counter: 157
                    Reset counter: 117
                    Mileage: 233938 km
   Part No: 1T0 907 357
   Coding: 0000003
   VCID: 74B1DABF42B4F1B7DDD-8020
01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
            010 - Open or Short to Plus
01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
Address 56: Radio
   Part No SW: 1K0 959 703 Q    HW: 1K0 959 795 J
   Component: J388   TUER-SG HL   1120
   Revision: 12006001    Serial number: 00000001211956
   Coding: 0001168
   VCID: 3E2538973C786BE7FB9-806A
                    Reset counter: 157
                    Mileage: 236611 km
                    Fault Status: 00101100
                    Reset counter: 157
                    Mileage: 236611 km
   Component:    RDK              0440
   Coding: 0100101
00625 - Vehicle Speed Signal
                    Reset counter: 130
                    Mileage: 244494 km
                    Time: 07:54:24
   Part No SW: 1K0 959 704 Q    HW: 1K0 959 794 J
   Component: J389   TUER-SG HR   1120
   Revision: 12006001    Serial number: 00000001235083
   Coding: 0001168
   VCID: 3FDB45933B7262EFF0F-806A
                    Reset counter: 157
                    Mileage: 233938 km
                    Fault Frequency: 226
                    Reset counter: 117
                    Mileage: 233938 km
Address 77: Telephone (J738)       Labels:. 1K8-035-730.clb
   Part No SW: 1K8 051 730 B    HW: 1K8 051 730 B
   Component: Telefon       H02 5400
   Revision: 00002000    Serial number: 20389520240338
   Coding: 402120
   VCID: 2615F0F7C8E8D327939-8072
03427 - Right Audio Channel
                    Reset counter: 194
                    Mileage: 239937 km
01304 - Radio
                    Reset counter: 117
                    Mileage: 239937 km
End----------(Elapsed Time: 01:30, VBatt start/end: 14.3V/14.3V)-----------
Saturday,15,February,2020,15:14:46:64993
                Address 01: Engine       Labels: 06F-907-115-AXX.clb
Control Module Part Number: 1K0 907 115 H    HW: 8P0 907 115 B
  Component and/or Version: 2.0l R4/4V TFSI     0020
           Software Coding: 0403010A18070160
            Work Shop Code: WSC 00066 000 00000
                    Mileage: 248415 km
                    Time: 01:44:46
                    RPM: 770 /min
                    Load: 11.4 %
                    Temperature: 42.0°C
                    Temperature: 12.0°C
                    Voltage: 14.097 V
Sunday,16,February,2020,17:20:42:64993
          77
                    Mileage: 248415 km
                    Time: 01:06:46
                    RPM: 1113 /min
                    Load: 3.1 %
                    Temperature: 56.0°C
                    Temperature: 18.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 14.224 V
   Revision: 00H11001
   Coding: 0021122
            013 - Check DTC Memory
   Coding: 00040853
   Shop #: WSC 12345
01800 - Light Switch (E1)
                    Reset counter: 117
                    Mileage: 248415 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.15 V
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 117
                    Mileage: 248415 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.20 V
                    Reset counter: 154
                    Mileage: 238612 km
                    Time: 03:37:38
01304 - Radio
                    Reset counter: 117
                    Mileage: 248415 km
                    Time: 01:04:29
   Coding: 0013889
   Coding: 0002021
   Coding: 0021107
01304 - Radio
                    Reset counter: 117
                    Mileage: 248415 km
                    Time: 21:29:51
   Coding: 0000003
   Coding: 0001205
                    Reset counter: 117
                    Mileage: 248415 km
                    Fault Status: 01101101
                    Reset counter: 117
   Coding: 0001204
                    Fault Frequency: 127
                    Reset counter: 117
                    Mileage: 248415 km
   Coding: 0000003
Address 56: Radio
   Coding: 0001168
   Component:    RDK              0440
   Coding: 0100101
   Coding: 0001168
                    Reset counter: 157
                    Mileage: 248415 km
                    Reset counter: 117
                    Mileage: 248415 km
   Coding: 402120
                    Reset counter: 117
                    Mileage: 248415 km
01304 - Radio
                    Reset counter: 117
                    Mileage: 248415 km
End----------(Elapsed Time: 01:28, VBatt start/end: 14.1V/13.8V)-----------
Sure sounds like wiring, damaged HPP from current aforementioned history or smoked ECU, no?
Time for 123 load lights!
Better JPPSG for FOD!
Fahrenheit_29
Sedalia, MO, USA
C?ID=396291
ECU better not be fried. Only cel I have is the p2294 for n276, everything else is fine. I'm working on getting to the ECU now to test continuity on these 2 wires....I need a stupid wiper arm puller to get them off lol
Decade box can qualify harness and ECU to rule out with DVOM?
Wouldn't be first time saw bad new pump!
MVB_
C?ID=164610
Curious if you tested both the old & "new" fuel pressure regulator valve N276- terminals 1 to 2 for resistance......specified value: {25 to 35 Ω (at approx. 20° C).
PS for the ww puller most of the auto stores have one that will work on the MK5 but you may need to modify it just a little for clearance around the arm.
Fahrenheit_29
Sedalia, MO, USA
C?ID=396291
I did not test resistance on the n276. I can try that this morning and let you know. I planned on load testing the wires as soon as I get to them. The wires do seem crusty
Fahrenheit_29
Sedalia, MO, USA
C?ID=396291
At 5° c both fuel pressure regulators are reading 1.6 ohms. I don't know how much that should change being warm but I can do that later
Fahrenheit_29
Sedalia, MO, USA
C?ID=396291
I brought the n276 up to around 73 degrees F and it was still measuring 1.6 ohms basically. Between the 2 pins. What does that mean?
Does it mean you are not using the RTFB?
Stop being lazy and get to work!
Fahrenheit_29
Sedalia, MO, USA
C?ID=396291
Well I'm new here. Maybe I missed something. Can you enlighten me please on what you are referring to???
Fahrenheit_29
Sedalia, MO, USA
C?ID=396291
I guess you are referring to the owners manual maybe helping me. I did not get one with the car.
PetrolDave
Westbury, UK
C?ID=1423
See how RTFB is bold green underlined? Hover your mouse over it and a popup will appear with an explanation (BTW it's NOT the owners manual).
Fahrenheit_29
Sedalia, MO, USA
C?ID=396291
I'm on a phone. Nothing happens when I click it. It's just green lol
Fahrenheit_29
Sedalia, MO, USA
C?ID=396291
Alright I got logged in. I'm assuming the wiring diagrams and component locations will have everything I need?
Fahrenheit_29
Sedalia, MO, USA
C?ID=396291
Alright the Wiring diagram was very hard to dig through without an index lol. maybe i missed it. what i found was the N276 connects to pin 19 of the ECU Harness and also to a leg of the A4 Relay under the hood. that relay powers other things for the engine and those things seem to be working fine. i put a 9 volt battery to those two points and the N276 actuated just fine so the wiring has to be good as well. I think either the ECU is the issue or the new "Ebay" HPFP came with the wrong or a bad N276. are there different N276s? could it just not be the right one? both the old and the new N276 read the same resistance....i dont know if i should buy another HPFP or not...it might be the next cheapest thing to try though....
OP do you understand how the N276 works and is to be tested using RTFB WD and SSP?
Instead of fiddling with 9 volt batteries why not overlay the two wires to test and address the actual data the controller has given you insight too you ignore?
