I pulled the plug and ran a continuity test from the pin in the plug to the pin on the n276 plug. I was using my elenco dmm. That same test yielded a .6 ohm resistance on the wire. Load tests with a light like in the video seem good as well. I did this on both wires. The second wire runs to a relay in the fuse box
An overlay test, do you mean new wires from each location to the plug? I did not.
I have a decade box on the way. Not sure what resistance to throw at it as the 25 to 35 ohms listed on a site, people have said may be wrong...I understand how the reads a temp sensor, not really sure how that compares to the n276 as it's actuated by the and not just referenced if I'm not mistaken. If that's the case I'm not sure how a decade box could help. I guess key on engine off testing it might do something if I could figure out the correct resistance.
I was told here that my hpfp I purchased on
eBay is clearly an
eBay third party part even though it's stamped Hitachi. I'm not happy with the fitment of it so I'm probably going to buy another one from a more reputable site and swap my internals into it. I'm wondering if the n276 in this cheap one i got might be bad or the wrong part, causing my problem.
One test I'm scared to do but might help is throwing 9 volts to the n276 while car is running and watching the fuel pressure at the rail to see if it will even build pressure. I know this can be dangerous because it could build too much pressure but it would be just for a split second and watching the graph.
Lastly I read somewhere that the module on the fuel tank can cause this too, since I can't actuate the n276 from I'm assuming that's not the case. Any input on this one would be cool.
Sorry for all the info but it's where I'm at with it. I understand wiring but when it comes to how all the systems work together in the car I'm still learning. I feel like if I can't actuate the n276 it can only be the sensor, wiring, or the . I can actuate other solenoids and it uses the same relay so I don't think the relay is bad
