Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: P2294 N276 problem
    Feb 2020
    Sedalia, MO, USA
    P2294 N276 problem
    I have an 07 Jetta GLI Fahrenheit #27
    I got an EPC light and limp mode a month ago. I think I had a P2293 code at first but I know only have a P2294. I put a new HPFP on with JHM upgraded internals. I just installed a new fuel rail pressure sensor as I was seeing 5 to 7 bar at the rail consistently. I checked fuses. I can actuate the n80 valve with vcds which uses some of the same electrical I believe. I am getting a circuit open on n276 fault and I think wiring is my last option of troubleshooting and just want some other input just in case I missed something. Here's my full autoscan. I know there's lots of other issues, battery was recently unhooked, headlight switch unhooked. No factory radio, aftermarket headlights, a few other things maybe...
    Saturday,15,February,2020,15:11:41:64993
    VIN: 3VWWJ71K57M155065   License Plate:
    Mileage: 248410km-154354mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 62 65 72
              77
    VIN: 3VWWJ71K57M155065   Mileage: 248410km-154354miles
    62-Door, Rear Left -- Status: Malfunction 1010
    72-Door, Rear Right -- Status: Malfunction 1010
       Part No SW: 1K0 907 115 H    HW: 8P0 907 115 B
       Revision: 5BH15---    Serial number: VWZ7Z0F8240645
       Coding: 0403010A18070160
       Shop #: WSC 00066 000 00000
       VCID: 2B0301C3DF0AEE4F4C7-807E
    008852 - Fuel Pressure Regulator Valve (N276)
                   P2294 - 004 - Open Circuit - MIL ON
                        Fault Status: 11100100
                        Mileage: 248415 km
                        Time: 01:44:46
                        RPM: 770 /min
                        Load: 11.4 %
                        Temperature: 42.0C
                        Temperature: 12.0C
                        Absolute Pres.: 980.0 mbar
                        Voltage: 14.097 V
    Readiness: 0110 0101
       Revision: 00H11001
       Coding: 0021122
       VCID: 73B3D9A347BAF68FC47-8026
       Part No: 1K0 820 047 GS
       VCID: 7BA3F1836FEABECF9C7-802E
    00229 - Refrigerant Pressure
                002 - Lower Limit Exceeded
       Revision: 00H52000    Serial number: 00000000525339
       Coding: 17058E23400415465C140062001400000019770B630000
       Shop #: WSC 12345 123 12345
       VCID: 6C81C2DF1A84297705D-8038
       Component: Wischer 230307 020  0501
       Coding: 00040853
       Shop #: WSC 12345
    02498 - Left Low Beam Reflector Motor (V294)
                        Fault Status: 01111100
                        Reset counter: 117
                        Mileage: 234589 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 11.75 V
    02499 - Right Low Beam Reflector Motor (V295)
                        Reset counter: 117
                        Mileage: 234545 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 11.30 V
                        Reset counter: 150
                        Mileage: 243089 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.65 V
                        Reset counter: 150
                        Mileage: 246747 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.60 V
                        Fault Status: 01100010
                        Reset counter: 117
                        Mileage: 248415 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 9.90 V
       Part No SW: 8E0 035 593 H    HW: 8E0 035 593 H
       Component: SDAR SIRIUS     H06 0080
       Revision: 00000000    Serial number: AUZ4Z7G0053353
       VCID: 2E0508D7EC189B676B9-807A
                        Reset counter: 154
                        Mileage: 238612 km
                        Time: 03:37:38
    01304 - Radio
                        Reset counter: 117
                        Mileage: 248415 km
                        Time: 21:16:50
       Component: 6A AIRBAG VW8R  034 8000
       Revision: 05034000    Serial number: 003B6M01AWHG
       Coding: 0013889
       Subsystem 2 - Serial number: 6332MSME170D3C34E
       Subsystem 3 - Serial number: 6342MSME16794B6EU
       Subsystem 4 - Serial number: 6351HSME0C4660746
       Subsystem 5 - Serial number: 6361HSME0C571D5EP
       Subsystem 6 - Serial number: 63727SME0C286343+
       Subsystem 7 - Serial number: 63827SME0C284138%
       Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
       Coding: 0002021
       VCID: 015F836B0D06D41FC6B-8054
       Part No SW: 1K6 920 973 A    HW: 1K6 920 973 A
       Revision: V0003000    Serial number: VWZ7Z0F8240645
       Coding: 0021107
       Shop #: WSC 25019 444 67490
       VCID: 313F13ABFD26849F76B-8064
       Part No SW: 1K0 907 530 K    HW: 1K0 907 951
       Component: J533__Gateway   H04 0021
       Revision:   H04 02    Serial number: 030307F1000869
       Coding: 7DBF03E00F001002
       Shop #: WSC 24313 444 05014
       VCID: 2F3B15D3EB12926F60F-807A
                        Fault Status: 00110100
                        Reset counter: 150
                        Mileage: 243089 km
                        Time: 05:31:55
                        Reset counter: 150
                        Mileage: 246747 km
                        Time: 15:08:30
    01304 - Radio
                        Reset counter: 194
                        Mileage: 239937 km
                        Time: 02:30:27
       Part No SW: 1K5 919 965 A    HW: 1K5 919 965 A
       Component: Kompass         005 0004
       Revision: 00005000    Serial number: 1293324T2HH804
       Coding: 0000003
       VCID: 392F2B8B25564CDFCEB-806C
       Component: IMMO            VDD 1610
       Component: J386  TUER-SG FT    1133
       Revision: 32008001    Serial number: 00000519478227
       Coding: 0001205
       VCID: 3B2331832F6A7ECFDC7-806E
                        Fault Status: 01100101
                        Reset counter: 117
                        Fault Status: 00111000
                        Reset counter: 157
                        Mileage: 234545 km
                        Fault Frequency: 8
                        Reset counter: 144
                        Mileage: 244318 km
       Part No: 1K1 909 144 L
       Component: EPS_ZFLS Kl.069 H07 1806
       VCID: 34311ABF0234B1B71DD-8060
       Component:    KSG PQ35 RDK 052 0218
       Coding: 12900F880186483F2D04058FB0888F2488DC00
       Shop #: WSC 00066 123 12345
       VCID: 04518A7F1214C137EDD-8050
       Component: J387  TUER-SG BT    1133
       Revision: 32008001    Serial number: 00000554478226
       Coding: 0001204
       VCID: 3C21329F2A6479F7D5D-8068
                        Fault Status: 00100101
                        Reset counter: 157
                        Fault Status: 01101100
                        Reset counter: 117
                        Mileage: 233938 km
       Part No: 1T0 907 357
       Coding: 0000003
       VCID: 74B1DABF42B4F1B7DDD-8020
                010 - Open or Short to Plus
    Address 56: Radio
       Component: J388   TUER-SG HL   1120
       Revision: 12006001    Serial number: 00000001211956
       Coding: 0001168
       VCID: 3E2538973C786BE7FB9-806A
                        Reset counter: 157
                        Mileage: 236611 km
    01554 - Motors for Central Locking; Rear Doors; Lock
                        Fault Status: 00101100
                        Reset counter: 157
                        Mileage: 236611 km
       Component:    RDK              0440
       Coding: 0100101
    00625 - Vehicle Speed Signal
                        Reset counter: 130
                        Mileage: 244494 km
                        Time: 07:54:24
       Component: J389   TUER-SG HR   1120
       Revision: 12006001    Serial number: 00000001235083
       Coding: 0001168
       VCID: 3FDB45933B7262EFF0F-806A
                        Reset counter: 157
                        Mileage: 233938 km
                        Fault Frequency: 226
                        Reset counter: 117
                        Mileage: 233938 km
    Address 77: Telephone (J738)       Labels:. 1K8-035-730.clb
       Part No SW: 1K8 051 730 B    HW: 1K8 051 730 B
       Component: Telefon       H02 5400
       Revision: 00002000    Serial number: 20389520240338
       Coding: 402120
       VCID: 2615F0F7C8E8D327939-8072
    03427 - Right Audio Channel
                        Fault Status: 01101011
                        Reset counter: 194
                        Mileage: 239937 km
    01304 - Radio
                        Reset counter: 117
                        Mileage: 239937 km
    End----------(Elapsed Time: 01:30, VBatt start/end: 14.3V/14.3V)-----------
    Saturday,15,February,2020,15:14:46:64993
                    Address 01: Engine       Labels: 06F-907-115-AXX.clb
    Control Module Part Number: 1K0 907 115 H    HW: 8P0 907 115 B
      Component and/or Version: 2.0l R4/4V TFSI     0020
               Software Coding: 0403010A18070160
                Work Shop Code: WSC 00066 000 00000
                        Mileage: 248415 km
                        Time: 01:44:46
                        RPM: 770 /min
                        Load: 11.4 %
                        Temperature: 42.0C
                        Temperature: 12.0C
                        Voltage: 14.097 V
    Sunday,16,February,2020,17:20:42:64993
              77
                        Mileage: 248415 km
                        Time: 01:06:46
                        RPM: 1113 /min
                        Load: 3.1 %
                        Temperature: 56.0C
                        Temperature: 18.0C
                        Absolute Pres.: 970.0 mbar
                        Voltage: 14.224 V
       Revision: 00H11001
       Coding: 0021122
                013 - Check DTC Memory
       Coding: 00040853
       Shop #: WSC 12345
    01800 - Light Switch (E1)
                        Fault Status: 01101000
                        Reset counter: 117
                        Mileage: 248415 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.15 V
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 117
                        Mileage: 248415 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.20 V
                        Reset counter: 154
                        Mileage: 238612 km
                        Time: 03:37:38
    01304 - Radio
                        Reset counter: 117
                        Mileage: 248415 km
                        Time: 01:04:29
       Coding: 0013889
       Coding: 0002021
       Coding: 0021107
    01304 - Radio
                        Reset counter: 117
                        Mileage: 248415 km
                        Time: 21:29:51
       Coding: 0000003
       Coding: 0001205
                        Reset counter: 117
                        Mileage: 248415 km
                        Fault Status: 01101101
                        Reset counter: 117
       Coding: 0001204
                        Fault Frequency: 127
                        Reset counter: 117
                        Mileage: 248415 km
       Coding: 0000003
    Address 56: Radio
       Coding: 0001168
       Component:    RDK              0440
       Coding: 0100101
       Coding: 0001168
                        Reset counter: 157
                        Mileage: 248415 km
                        Reset counter: 117
                        Mileage: 248415 km
       Coding: 402120
                        Reset counter: 117
                        Mileage: 248415 km
    01304 - Radio
                        Reset counter: 117
                        Mileage: 248415 km
    End----------(Elapsed Time: 01:28, VBatt start/end: 14.1V/13.8V)-----------
    Sure sounds like wiring, damaged HPP from current aforementioned history or smoked ECU, no?
    Time for 123 load lights!
    Better JPPSG for FOD!
    Feb 2020
    Sedalia, MO, USA
    ECU better not be fried. Only cel I have is the p2294 for n276, everything else is fine. I'm working on getting to the ECU now to test continuity on these 2 wires....I need a stupid wiper arm puller to get them off lol
    Feb 2020
    Sedalia, MO, USA
    HPFP better not be damaged. It's brand new
    Decade box can qualify harness and ECU to rule out with DVOM?
    Wouldn't be first time saw bad new pump!
  6. #6
    Feb 2015
    Curious if you tested both the old & "new" fuel pressure regulator valve N276- terminals 1 to 2 for resistance......specified value: {25 to 35 Ω (at approx. 20 C).
    PS for the ww puller most of the auto stores have one that will work on the MK5 but you may need to modify it just a little for clearance around the arm.
  7. #7
    Feb 2020
    Sedalia, MO, USA
    I did not test resistance on the n276. I can try that this morning and let you know. I planned on load testing the wires as soon as I get to them. The wires do seem crusty
  8. #8
    Feb 2020
    Sedalia, MO, USA
    At 5 c both fuel pressure regulators are reading 1.6 ohms. I don't know how much that should change being warm but I can do that later
  9. #9
    Feb 2020
    Sedalia, MO, USA
    I brought the n276 up to around 73 degrees F and it was still measuring 1.6 ohms basically. Between the 2 pins. What does that mean?
  10. #10
    Does it mean you are not using the RTFB?
    Stop being lazy and get to work!
