Results 11 to 20 of 36
Thread: P2294 N276 problem
    Feb 2020
    Sedalia, MO, USA
    Well I'm new here. Maybe I missed something. Can you enlighten me please on what you are referring to???
  2. #12
    Feb 2020
    Sedalia, MO, USA
    I guess you are referring to the owners manual maybe helping me. I did not get one with the car.
  3. #13
    So you are working and modifying a car without the repair manual or ( RTFB )?
    Here is a link to it sir.
    http://wiki.ross-tech.com/wiki/index...ir_Information
  4. Likes Uwe liked this post
  5. #14
    See how RTFB is bold green underlined? Hover your mouse over it and a popup will appear with an explanation (BTW it's NOT the owners manual).
  6. Likes Uwe liked this post
  7. #15
    Feb 2020
    Sedalia, MO, USA
    I'm on a phone. Nothing happens when I click it. It's just green lol
  8. #16
    Feb 2020
    Sedalia, MO, USA
    Alright I got logged in. I'm assuming the wiring diagrams and component locations will have everything I need?
  9. #17
    Feb 2020
    Sedalia, MO, USA
    Alright the Wiring diagram was very hard to dig through without an index lol. maybe i missed it. what i found was the N276 connects to pin 19 of the ECU Harness and also to a leg of the A4 Relay under the hood. that relay powers other things for the engine and those things seem to be working fine. i put a 9 volt battery to those two points and the N276 actuated just fine so the wiring has to be good as well. I think either the ECU is the issue or the new "Ebay" HPFP came with the wrong or a bad N276. are there different N276s? could it just not be the right one? both the old and the new N276 read the same resistance....i dont know if i should buy another HPFP or not...it might be the next cheapest thing to try though....
  10. #18
    Quote Originally Posted by Fahrenheit_29 View Post
    or new "Ebay" HPFP came with the wrong or a bad N276.
    Did it ship directly from China?
  11. #19
    OP do you understand how the N276 works and is to be tested using RTFB WD and SSP?
    008852 - Fuel Pressure Regulator Valve (N276)
    P2294 - 004 - Open Circuit
    Instead of fiddling with 9 volt batteries why not overlay the two wires to test and address the actual data the controller has given you insight too you ignore?
  12. #20
    Feb 2020
    Sedalia, MO, USA
    No it came from New Jersey. Here's a link to the exact one I bought.
    https://www.ebay.com/itm/333263767437
