Results 1 to 3 of 3
Thread: 2015 Skoda Superb
    Jan 2020
    2015 Skoda Superb
    Did auto scan on my car and came up with following fault codes on Modules 03;08 and 13
    Sunday,16,February,2020,20:21:11:23015
    VCDS Version: 19.6.2.2  HEX-V2 CB: 0.4508.4
    VIN: TMBKJ7NP7G7010384   License Plate: BF65AFY
    Mileage: 126349km-78509mi   Repair Order:
    Chassis Type: NP-SK48 (5Q0)
    Scan: 01 02 03 08 09 10 13 15 16 17 19 36 42 44 52 55 5F 6D BB BC
    VIN: TMBKJ7NP7G7010384   Mileage: 126349km-78509miles
    Address 01: Engine (J623-DFCA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 FN    HW: 04L 907 309 M
       Component: R4 2,0L EDC   H22 1195
       Revision: B4H22---
       Coding: 011D0012036501082000
       Shop #: WSC 33361 790 00063
       ASAM Dataset: EV_ECM20TDI01104L906026FN 002001
       ROD: EV_ECM20TDI_002_VW48.rod
       VCID: 7BA3F0BCE360FEAF9C7-802E
       Part No SW: 0D9 300 041 B    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H53 4803
       Revision: 06253104    Serial number: TFK01506030175
       ROD: EV_TCMDQ250021.rod
       VCID: 176BCC0CFF083ACF18F-8042
              P1734 00 [002] - -
       Revision: 00000000    Serial number: 61755000000504
       Coding: 1E07929C34210B6C077A060841C74978492CD0E0608292F51861F078C209
       VCID: 7AADF5B8EC5AC7A7871-802E
    8291 - Databus
              [FCAN: MO_QBit_Motormomente signal is invalid]
                        Reset counter: 243
                        Mileage: 126339 km
                        Date: 2020.02.16
                        Time: 16:17:27
       Part No SW: 3V0 907 044 AR    HW: 3V0 907 044 AR
       Component: AC Automat    H32 3601
       Revision: 20K04000    Serial number: 00000B00007779
       Coding: 12110104000100011005000000101000
       ASAM Dataset: EV_ACClimaPrehVW37X 002009
       ROD: EV_ACClimaPrehVW37X.rod
       VCID: 04518B409E9E8157EDD-8050
    263425 - Air Quality Sensor
              B10AF 04 [009] - Internal System Fault
                        Fault Frequency: 7
                        Reset counter: 203
                        Mileage: 126339 km
                        Date: 2020.02.16
                        Time: 15:58:50
                        Outside air temperature: 4.5 °C
                        Voltage terminal 30: 12.0 V
                        Air quality status: ERROR
       Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
       Component: BCM MQBAB H   H24 0173
       Serial number: 01061516206537
       Coding: 0F001A46C2C722FB17844086B10C57280000000000000000000000000000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 094F9A74B9BCDC3F9EB-805C
       Subsystem 1 - Part No SW: 3V2 955 119     HW: 3V1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: 48x RL 150122  032 0121
       Serial number: 00000001501200605855
       Coding: 165DDD
       Component: RLHS  037 0059
       Serial number: S5Y15M06D23H11M41S49
       Coding: 00084D
       Component: Sensor, DWA  006 0326
       Serial number: 000000000ZY151271JNE
       Serial number: 00000000000061677508
       Part No SW: 5Q0 919 283 G    HW: 5Q0 919 283
       Component: PARKHILFE 4K  H10 0056
       Revision: --------    Serial number: 39291513909291
       Coding: 0001050011
       ASAM Dataset: EV_EPHVA14AU3700000 002024
       VCID: 3D273EA4BDF4309FE23-8068
       Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
       Component: ACC BOSCH MQB H04 0192
       Coding: 3200678151FFC428949C804D
       ASAM Dataset: EV_ACCBOSCHVW48X 001008
       ROD: EV_ACCBOSCHVW48X.rod
       VCID: 34311B808EBEF1D71DD-8060
    1067 - Databus
              [FAULT_TIMEOUT_MOTOR_20]
                        Reset counter: 243
                        Mileage: 126339 km
                        Date: 2020.02.16
                        Time: 16:17:26
                        Control Module temperature: 24 °C
                        Voltage terminal 15: 11.9 V
                        Status_ACC_System: ACC_Off_MainSwitch_Off
    1088 - Databus
              [FAULT_TIMEOUT_TSK_06]
                        Reset counter: 243
                        Mileage: 126339 km
                        Date: 2020.02.16
                        Time: 16:17:26
    2065 - Databus
              [FAULT_TSK_HANDSHAKE]
                        Reset counter: 243
                        Mileage: 126339 km
                        Date: 2020.02.16
                        Time: 16:17:26
       Part No SW: 5Q0 959 655 AK    HW: 5Q0 959 655 AK
       Component: AirbagVW21    005 0130
       Serial number: 003Q5R0W5F1S
       Coding: 98CCC0C0000000005C5400CF00C800000065
       ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
       ROD: EV_AirbaVW20SMEVW37X.rod
       Subsystem 1 - Part No SW: -----------    HW: 480 001 306 15
       Serial number: 357000000001AA316418
       Subsystem 2 - Part No SW: -----------    HW: 480 001 606 15
       Serial number: 358000000009939CD41X
       Subsystem 3 - Part No SW: -----------    HW: 480 400 806 15
       Serial number: 3510002C31B4148120AP
       Subsystem 4 - Part No SW: -----------    HW: 480 400 806 15
       Serial number: 3520002A71B41482E2E4
       Subsystem 5 - Part No SW: -----------    HW: 480 400 206 15
       Serial number: 3550002B71B41484C0B3
       Part No SW: 5Q0 953 521 GB    HW: 5Q0 953 569 A
       Revision: FF033033    Serial number: 20150626500612
       Coding: 6410
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 78A9EFB0D256D5B7F15-802C
       Part No SW: 3V0 920 941     HW: 3V0 920 941
       Component: KOMBI         212 6421
       Coding: 27A5090A2F80A60001886A011000000000000000
       ROD: EV_DashBoardVDDMQBAB_SK48.rod
       VCID: 72BDDD98B42ABFE7CF1-8026
       Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2227
       Revision: --------    Serial number: 18061510801238
       Coding: 030100044F087300EB00025A1C0F00010001070000000000000000000000
       Shop #: WSC 73430 790 00063
       ROD: EV_GatewConti_013.rod
       VCID: 75B7E684C544A8DFEA3-8020
       Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
       Component: E221__MFL-PR6  H02 0150
       Serial number: 000000000B2501110615
       Serial number: 2426037003
    Address 36: Seat Mem. Drvr (J810)       Labels:* None
       Part No SW: 5Q0 959 760 A    HW: 5Q0 959 760 A
       Component: Sitzmemory    H06 0009
       Serial number: Y0006OF311338
       Coding: 001400000000010001A080808080000000008181000000D4
       ASAM Dataset: EV_SeatMemorDriveSide 001015
       ROD: EV_SeatMemorDriveSide_001.rod
       VCID: 3B2330BCA3E03EAFDC7-806E
       Serial number: 110515BEA07721
       Coding: 001D0820DE01040000001100
       VCID: 43D3485CDB10466F947-8016
       Component: EPS_MQB_ZFLS  125 1061
       Coding: 8103
       Serial number: 010515BDU11678
       Coding: 001D0220DE01040000001100
       VCID: 42DD4D58C40A4F679F1-8016
       Coding: 06DE00003F010000
       VCID: 40D94750CA065D77895-8014
       Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H01 0005
       Coding: B20000
       Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 0005
       Coding: B20000
    Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-HGH2.clb
       Part No SW: 3V0 035 020 A    HW: 3V0 035 020
       Component: MU-H-ND-EU    H41 0318
       Serial number: A435D0FB000186
       Coding: 03840201FF00000011111201008808002F0000C601200100DE
       ROD: EV_MUHig4CGen2HBAS_SK37.rod
       VCID: 2411EBC03E5E61578DD-8070
       Subsystem 1 - Part No SW: 3V0 919 606     HW: 3V0 919 606
       Component: ABT_High-2  H44 1028
       Serial number: SKZ8Z9RAM003H8
       Subsystem 2 - Part No SW: V03 959 803 TF    HW: -----------
       Component: ECE 2019/2020  --- 0177
       Component: Gracenote2  --- 1011
       Part No SW: 5Q0 959 107 G    HW: 5Q0 959 107 G
       Component: HDSG-Modul    H12 0250
       Revision: --------    Serial number: 30086912500000
       Coding: 0D00
       ASAM Dataset: EV_DeckLidCONTIAU736 001011
       ROD: EV_DeckLidCONTIAU736_AU73.rod
       VCID: 3C2133A0A6EE3997D5D-8068
       Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
       Serial number: 300515BEU05462
       Coding: 001800208001040000001100
       Serial number: 300515BEU05465
    End----------(Elapsed Time: 01:35, VBatt start/end: 12.4V/12.3V)-----------
    Any chance your ECU has been chipped/tuned/mapped?
    1195 is an older Volkswagen software version for that ECU; it does not appear to be a Skoda version...
    Jan 2020
    As far I know not. Bought car last year June from Skoda official dealer unless previous owner did something.
