Hi to all. I am totally new at this. Had issues with my sharan because it had adblue and dpf software removed by previous owner. Check engine light came on several times during 30000 km,with message NOx sensor 2 bank 1 P229 E 00- electrical malfunction,and this was a reason to change it. The story short, I did a SW update at the dealer and everything was active again. Adblue heater,was permanent fault that was not possible to erase and I have changed it and it is gone now. On the other hand the NOx sensor message is back and I have no solution. It is possible to delete it but it keeps coming back. The sensor is new so I doubt that it is also faulty. Any ideas ?
Scan:
Scan:
Friday,14,February,2020,17:41:36:18722
VIN: WVWZZZ7NZCV037472 License Plate:
Chassis Type: 7N-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 4C 52 53 56 61 62 72
VIN: WVWZZZ7NZCV037472 Mileage: 183520km-114034miles
Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 HH HW: 03L 907 309 Q
Component: R4 2.0l TDI H27 9982
Revision: 44H27--- Serial number:
Coding: 0019001A042401080000
Shop #: WSC 03020 425 00000
ASAM Dataset: EV_ECM20TDI01103L906018HH 003017
ROD: EV_ECM20TDI01103L906018F_VW36.rod
VCID: 77ABEC7BDF49D69FF8D-8022
9570 - NOx Sensor 2 Bank 1
P229E 00 [039] - Electrical Malfunction
Mileage: 183529 km
Date: 2020.02.14
Time: 17:36:34
Engine speed: 781.00 /min
Normed load value: 14.9 %
Coolant temperature: 89 °C
Intake air temperature: 17 °C
Voltage terminal 30: 14.320 V
Air mass: actual value (mg/stroke): 305.1 mg/stroke
Mean injection quantity: 4.49 mg/stroke
EGR Vacuum Regulator Solen.val.: activation: 72.01 %
NOx Emission NOx-Sensor: 0 ppm
NOx emission NOx sensor 2: 0 ppm
Air mass for release of NOx sensor 2 offset test: 0.0 g
Calculated efficiency of NOx conversion: 0.660
