Page 1 of 8 123 ... LastLast
Results 1 to 10 of 80
Thread: 2010 Passat DSG problems P1820, P1815, P0868
    Oct 2014
    I recently purchased a 2010 Passat with a little over 100k. When I went to look at the car the owner told me that it was running well but occasionally suffered from a harsh shift. The purchase price was absolutely unbelievable, $1000! Knowing it was worth more than that in parts I threw my money at her and ran.
    I have owned the car for a couple of weeks now and I can attest to the harsh shifting, along with an occasional fight over getting it into reverse. So, after some reading and a scan that revealed a P0868 code, I decided to re-calibrate the DSG using the guide at Ross-Tech. This here is where the real problems begin. After the calibration I took the car for the prescribed test drive. What follows is my experience on that drive and the subsequent drives.
    Test drive:
    Car fights to go into reverse, whines and shifts hard, barely gets out of parking space
    Shifts into 1st normally in D, shifts normally into second.
    At first stop the car shifts back into 1st.
    Pulling away the car shifts from 1st to 2nd and then the gear position indicator on the dash panel disappears!
    Coming to a stop the car shifts back into 1st and will not shift no matter what I try.
    I limp the car around the block in 1st and finally park it and turn it off.
    Second and subsequent drives:
    Car fights to go into reverse and whines, sometimes not going into reverse at all and the indicator light either flashes (uncommon) or disappears (very common).
    Shifts into 1st with a clunk and almost always with a whine, but only on the first time getting into 1st
    Shifting into 2nd there is a slipping and a chatter and will slip and/or chatter if you apply heavy throttle especially at low speed
    Shifting into 3rd comes with a clunk but other than that seems to perform fine in 3rd, no chatter or slip
    Shifting into 4th mild slipping and/or chatter again worse under load at low speeds
    5th and 6th seem to perform well but its difficult to tell because the car is moving fairly quickly to load the gear up (there are no hills in New Orleans to really load the gear up)
    I have ordered the fluid and filter to do a DSG fluid change and will perform that maintenance asap. The first scan with the P0868 code will be below as well as the scan after the calibration that came with code P1820 and P1815. I am currently debating testing and changing the solenoids associated with those codes. Any advise on the matter is greatly appreciated.
    FIRST SCAN
     Chassis Type: AN-VW46 (3C0)
    Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 53 56 62 65 72
              77
    VIN: WVWJK7AN0AE05XXXX   Mileage: 168850km-104918miles
    Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
       Part No SW: 06J 906 026 DA    HW: 06J 906 026 DA
       Component: MED17.5 TFSI 2,0    6987
       Revision: AAH08---    Serial number: VWZCZ000000000
       Coding: 0404010A1C070160
       Shop #: WSC 05095 444 14819
       VCID: 6C81C2E31A8F6E8705F-8038
    006439 - Relay for Aux Coolant Pump (J496)
                   P1927 - 000 - Open Circuit
                        Mileage: 168059 km
                        Date: 2014.04.15
                        Time: 08:52:60
                        Temperature: 90.0°C
                        Temperature: 51.0°C
                        Absolute Pres.: 1010.0 mbar
    005488 - Engine Start Blocked by Immobilizer
                   P1570 - 000 -  - Intermittent
                        Fault Frequency: 12
                        Mileage: 168822 km
                        Date: 2014.07.06
                        Time: 09:53:31
                        RPM: 1433 /min
                        Load: 22.0 %
                        Temperature: 14.0°C
                        Temperature: 15.0°C
       Part No SW: 02E 300 051 P    HW: 02E 927 770 AM
       Component: GSG DSG AG6     531 1979
       Revision: 06253104    Serial number: 00001506252006
       Shop #: WSC 04940 001 00001
       VCID: 2019E6D3A6C77AE7E97-8074
    17252 - Transmission Fluid Pressure Adaptation at Limit
                P0868 - 001 -  - Intermittent
                        Fault Status: 00100001
                        Fault Frequency: 255
                        Reset counter: 2
                        Mileage: 168446 km
                        Date: 2014.06.26
                        Time: 13:21:60
    Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
       Part No SW: 3C0 614 109 AF    HW: 3C0 614 109 AF
       Component: J104    C4 440 V2   0015
       Revision: --025---    Serial number: 00000795656837
       Coding: 0000380
       Shop #: WSC 05311 000 08193
       VCID: 629DACDBE84B28F7BF3-8036
       Part No SW: 1K0 820 047 JT    HW: 1K0 820 047 JT
       Component: Climatic PQ35   143 1515
       Revision: 00143034    Serial number: 00000000000000
       VCID: 7F5B05AF7BF9E51FB0D-802A
    00898 - Control Circuit A/C compressor
                010 - Open or Short to Plus
       Revision: 00H54000    Serial number: 00000003332387
       Coding: 15848F0340041000470000000F00000000285D435C000120000000000000
       Shop #: WSC 05124 067 57207
       VCID: 3333199F0731F17F045-8066
       Subsystem 1 - Part No: 3C1 955 419 B  Labels: 1KX-955-119.CLB
       Component: Wischer 310809 006  0208
       Coding: 00046997
       Shop #: WSC 05124
       Part No SW: 5N0 959 655 H    HW: 5N0 959 655 H
       Component: J234__01T VW10 HI   1916
       Revision: 20013000    Serial number: 003E1PJDN9XB
       Coding: 0012628
       VCID: 42DD4C5B488B48F79F3-8016
       Subsystem 1 - Part No: 3C0 959 339 D
       Component: BF-Gewichtsens. 001 0002
       Subsystem 2 - Serial number: 00000000004H10
       Subsystem 3 - Serial number: 0023.06.090000100000850062˙†63
       Subsystem 4 - Serial number: 850062˙†6332MTS662122649 ˙†63
       Subsystem 5 - Serial number: 22649 ˙†6342MTS679972369 ˙†63
       Subsystem 6 - Serial number: 72369 ˙†6351HTS6BBHP09KJ ˙†63
       Subsystem 7 - Serial number: P09KJ ˙†6361HTS69BDV09KJ ˙†63
       Subsystem 8 - Serial number: V09KJ ˙†63727TS68QS019KR ˙†63
       Subsystem 9 - Serial number: 019KR ˙†63827TS6RPS019KJ ˙
       Subsystem 10 - Serial number: 019KJ ˙
    Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
       Part No SW: 3C0 953 549 AJ    HW: 3C0 953 549 AJ
       Component: J0527               0030
       Revision: 00032000    Serial number: 3C5953507CN
       Coding: 0001711
       Shop #: WSC 05314 000 00000
       VCID: 74B1DA8342BFB647DDF-8020
       Subsystem 1 - Part No: 3C8 959 537 D  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TK6   H05 0022
       Coding: 00000226
       Part No SW: 3C0 920 972 E    HW: 3C0 920 972 E
       Component: KOMBI         H02 0206
       Coding: 260F00
       Shop #: WSC 05314 115 00000
       VCID: 2809FEF3C27782A7A17-807C
       Part No SW: 3C0 907 530 L    HW: 3C0 907 951
       Component: J533__Gateway   H13 0152
       Revision:   H13       Serial number: 3300P0992905F6
       Coding: FD807F07001602001002
       VCID: 2A0D04FBD0FBB0B7B73-807E
                        Fault Frequency: 7
                        Reset counter: 248
                        Mileage: 162326 km
                        Date: 2013.12.01
                        Time: 11:00:44
       Part No SW: 3C8 919 965     HW: 3C8 919 965
       Component: Kompass         001 0001
       Revision: 00001000    Serial number: 1614128T0C0G02
       VCID: 75B7E78749C5AF4FEA1-8020
       Part No SW: 3C0 959 433 AP    HW: 3C0 959 433 AP
       Component:    IMMO         052 0383
       Revision: 00052000    Serial number: VWZCZ000000000
       Shop #: WSC 77129 444 25107
       VCID: 78A9EEB35ED7D227F17-802C
       Subsystem 1 - Part No: 3C0 905 861 H
       Component:    ELV          028 0380
       3C0905861H     ELV          028 0380
    02823 - Requirements for Locking the Steering Column Lock not met
                        Reset counter: 50
                        Mileage: 168670 km
                        Date: 2014.07.02
                        Time: 10:39:05
    02861 - Electronic Steering Column Lock Check Sum Error
                        Fault Frequency: 15
                        Reset counter: 68
                        Mileage: 165154 km
                        Date: 2014.03.28
                        Time: 10:00:45
       Part No SW: 1K0 959 701 AR    HW: 1K0 959 793 N
       Component: J386  TUER-SG FT    1501
       Revision: 72009005    Serial number: 00000509098923
       Coding: 0001205
       Shop #: WSC 05311 000 00000
       VCID: 7EA5F8AB7CF3EC17BBB-802A
       Part No SW: 5N1 909 144 K    HW: 5N1 909 148 G
       Component: J500__APA-BS KL.148 0703
       Revision: 1AH03256    Serial number: 00092230120102
       Coding: 0000258
       VCID: 3A2D34BB205B0037C73-806E
    00750 - Warning Lamp
                        Fault Status: 00101100
                        Reset counter: 69
                        Mileage: 168566 km
                        Date: 2014.06.29
                        Time: 21:35:44
                        (no units): 4.0
                        Voltage: 11.90 V
       Component:    KSG PQ46 RDK 052 0412
       Coding: 13910F8001862E521004141FF08A0F0E085801
       Part No SW: 1K0 959 702 AR    HW: 1K0 959 792 N
       Component: J387  TUER-SG BT    1501
       Revision: 72009005    Serial number: 00000902998918
       Coding: 0001204
       Part No SW: 3C8 907 801 E    HW: 3C8 907 801 E
       Component: J540 EPB3  VW-15417 0007
       Revision:   010       Serial number: 00000000034936
       Coding: 0000057
       VCID: 2C0102E3DA0FAE8745F-8078
       Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
       Component: Radio Prem-8  H10 0034
       Revision: -----19S    Serial number: VWZ4Z7J1119975
       Coding: 0500040004
       VCID: 619FA3D7E14D33EFA69-8034
                        Reset counter: 32
                        Mileage: 144652 km
                        Date: 2013.01.15
                        Time: 11:43:59
                        Reset counter: 208
                        Mileage: 144652 km
                        Date: 2013.01.15
                        Time: 11:44:07
                        Reset counter: 248
                        Mileage: 162326 km
                        Date: 2013.12.01
                        Time: 12:08:05
       Part No SW: 1K0 959 703 AD    HW: 1K0 959 795 P
       Component: J388   TUER-SG HL   0308
       Revision: 42004101    Serial number: 00000001076882
       Coding: 0001168
       VCID: 72BDDC9B38ABB877CF3-8026
       Component:    RDK              0453
       Coding: 0100101
       Part No SW: 1K0 959 704 AD    HW: 1K0 959 794 P
       Component: J389   TUER-SG HR   0308
       Revision: 42004101    Serial number: 00000001023304
       Coding: 0001168
       VCID: 73B3D99F47B1B17FC45-8026
    Address 77: Telephone
    End----(Elapsed Time: 01:46, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
    SECOND SCAN
              77
    VIN: WVWJK7AN0AE05XXXX   Mileage: 168870km-104930miles
                        Mileage: 168059 km
                        Date: 2014.04.15
                        Time: 08:52:60
                        Temperature: 90.0°C
                        Temperature: 51.0°C
                        Fault Frequency: 12
                        Mileage: 168822 km
                        Date: 2014.07.06
                        Time: 09:53:31
                        RPM: 1433 /min
                        Load: 22.0 %
                        Temperature: 14.0°C
                        Temperature: 15.0°C
    005668 - MIL Request Signal Active (Check TCM for errors too!)
                   P1624 - 000 -
                        Mileage: 168871 km
                        Date: 2014.07.08
                        Time: 13:38:42
                        RPM: 2098 /min
                        Load: 16.1 %
                        Temperature: 81.0°C
                        Temperature: 42.0°C
                        Absolute Pres.: 1020.0 mbar
    18228 - Pressure Control Valve 2
                P1820 - 008 - Short to Plus - Intermittent
                        Reset counter: 39
                        Mileage: 168856 km
                        Date: 2014.07.08
                        Time: 11:00:58
    18223 - Pressure Control Valve 1
                P1815 - 008 - Short to Plus - Intermittent - MIL ON
                        Fault Status: 10101000
                        Reset counter: 40
                        Mileage: 168871 km
                        Date: 2014.07.08
                        Time: 13:38:23
       Coding: 0000380
       Coding: 00046997
       Shop #: WSC 05124
       Coding: 0012628
       Coding: 0001711
       Coding: 00000226
       Coding: 260F00
                        Fault Frequency: 7
                        Reset counter: 248
                        Mileage: 162326 km
                        Date: 2013.12.01
                        Time: 11:00:44
                        Reset counter: 50
                        Mileage: 168670 km
                        Date: 2014.07.02
                        Time: 10:39:05
                        Fault Frequency: 15
                        Reset counter: 68
                        Mileage: 165154 km
                        Date: 2014.03.28
                        Time: 10:00:45
       Coding: 0001205
       Coding: 0000258
                        Reset counter: 69
                        Mileage: 168566 km
                        Date: 2014.06.29
                        Time: 21:35:44
                        (no units): 4.0
                        Voltage: 11.90 V
       Coding: 0001204
       Coding: 0000057
       Coding: 0500040004
                        Fault Status: 00101011
                        Reset counter: 33
                        Mileage: 144652 km
                        Date: 2013.01.15
                        Time: 11:43:59
                        Reset counter: 208
                        Mileage: 144652 km
                        Date: 2013.01.15
                        Time: 11:44:07
                        Reset counter: 248
                        Mileage: 162326 km
                        Date: 2013.12.01
                        Time: 12:08:05
       Coding: 0001168
       Component:    RDK              0453
       Coding: 0100101
       Coding: 0001168
    End----(Elapsed Time: 01:44, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
    16.4905° S, 151.7375° W
    If the vehicle has the above fault code, the factory Guided Fault Finding test plan states the following:
    17252 - Transm. press. adaptation at limit stop
    Possible malfunction cause:
    - Transm. faulty.
    (then the test plan continues)....
    Replace the Dual-clutch transmission (DSG).
    => Repair manual 6-speed twin-clutch transmission 02E Rep.Gr.34.
    Personally, I would drain the DSG fluid, remove the filter and mechatronics and perform visual inspection to see if there is any indication of damage, sludge or other concerns before ever replacing the transmission.
    You may be able to "testing and changing the solenoids" and replace the DSG fluid and filter and not have any issues. I would say if the internals look good, then it maybe worth a try.
    I have an Audi A3 with over 200k miles on the original DSG, so they can last, but if it did fail, I would seriously consider a manual swap.
    We recommend to use the Official Factory Repair Information when attempting repair and diagnoses on these vehicles.
    Hope this helps,
    drpeter
    Did you document the safety and SMOG failure with NHTSA/EPA for failing useful life or as certified yet and required replacement under warranty at dealer for free or reimbursed?
    Were you dumb enough to consider buying a new one yet? ...........
    Posting the actual VIN might be more helpful than you realize?
    JPPSG yet the entire thread?
    Component: GSG DSG AG6 531 1979 <<<<<<<<<<<<<<<<<<<<<< I often wonder why this doesn't match the certificate, do you?
    https://iaspub.epa.gov/otaqpub/displ...d=25131&flag=1
    Don't forget to cross your part numbers and CVN for more FOD fun, well did you on page 152 and page 54 of other type certificate for ORVR used?
    https://iaspub.epa.gov/otaqpub/displ...d=25129&flag=1
    https://iaspub.epa.gov/otaqpub/displ...d=25130&flag=1
    Oct 2014
    please elaborate on
    "Don't forget to cross your part numbers and CVN for more FOD fun, well did you on page 152 and page 54 of other type certificate for ORVR used?"
    and
    "Did you document the safety and SMOG failure with NHTSA/EPA for failing useful life or as certified yet and required replacement under warranty at dealer for free or reimbursed?"
    as well as your statement on certificate matching, as I am very intrigued by all of these statements.
    I am unfamiliar with the Calibration data lookup as well
    I have not purchased a new one, nor do I intend to unless all other options are exhausted. Currently I am still trying to gather all the information possible to assist me in making an intelligent decision on the correct course of action. I was under the impression that at 105k mi that this vehicle is out of warranty.
    the full VIN is WVWJK7AN0AE057532
    All of a sudden I feel like Im in school again!
    Quote Originally Posted by TheSchwartz View Post
    Yep, and this is Jack:
  7. Likes Jack@European_Parts liked this post
    Hey what's this?
    What was the date of delivery of your vehicle & into commerce?
    Vehicle Identification No. WVWJK7AN0AE057532
    Model passat sedan
    PA
    Date of production 15.10.2009
    Model year 2010
    Sales type 3C25LD
    Engine Code CCTA
    Transmission Code LQY
    Emission standard 7GB Emission standard ULEV 2
    Aktivkohlebehälter / Ottopartikelfilter 1E4 Activated carbon canister (ORVR)
    and siphoning device for fueling
    PART NUMBER DESCRIPTION REMARK MODEL
    * 02E 300 051 PX 00X 6-speed dual clutch gearbox LQY Not available
    Dropped: Jan 1, 2012 (EKZ: L)
    Vehicle intelligent genuine part.
    Order only with additional instructions.
    Super-session
    02E 300 053 AX 00N 6-speed dual clutch gearbox
    06J 990 990 C Control unit for petrol engine 06J 906 026 DA
    Special editions E0A Without special action equipment
    Lockable wheel bolts 1PA Standard wheel bolts
    Vehicle class differentiation units/platform components 0HG Vehicle class differentiation -3C0-
    Trailer hitch 1D0 Without trailer hitch
    airbag 4UB Airbag for NAR
    Aktivkohlebehälter / Ottopartikelfilter 1E4 Activated carbon canister (ORVR) and siphoning device for fueling
    Storage compartment package QE2 Storage compartment
    Aerials 8ZH Antenna for AM/FM reception, "diversity"
    Exterior mirror setting 6XN Exterior mirrors, power-adjustable/ separately heated
    Left exterior mirror 5SH Left exterior mirror, flat (US)
    Right exterior mirror 5RR Right exterior mirror, convex (US)
    Drive type 1X0 Front-wheel drive
    "Multimedia"video/DVD/notebook connection 9WL Jack for external audio source
    Equipment levels A8X US comfort equipment
    Brake type in rear 1KW Disc brakes in rear
    batteries J0L Battery 340 A (70 Ah)
    Brake type, front 1ZG Disc brakes in front (Geomet D)
    Beverage holders 4M9 Beverage holders
    Battery/alternator capacity NY0 Standard battery/alternator capacity
    Component part sets with country-specific design requirements B0D Component parts set, complying with vehicle type for USA (without California), various parts
    vehicle tools and jack 1S1 vehicle tools and jack
    Brake systems 1AT Electronic stability control (ESC)
    Owner's manuals 0VM Information kit in American English
    Operating voltage 9Z0 Operating voltage 12 V
    Heated washer nozzles 9T1 Heated washer nozzles in front
    CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
    CD changer/CD player 7A0 Without CD changer/CD player
    "Charism" 2H0 Without "drive select"
    General operating permit, alterations C21 Operating permit, alteration
    Roof rails/roof load rack 3S0 Without roof rails/roof load rack
    Roof insert/convertible top 3FE Tilting and sliding glass sunroof with sunbshade
    Suspension system in rear 1JA Rear shock absorption, basic version 1
    Suspension system in front G07 Shock absorption in front
    Load-through hatch/ski bag 3X2 Load-through hatch
    Insert for the filling up of unleaded fuel/fuel type 2G1 Insert for the filling up of unleaded fuel
    Installation differentiation for components 0ES Installation differentiation for transmission DQ250 -- vehicle components --
    Theft protection system 7AG Electronic immobilizer with anti-theft alarm system (for USA)
    Inserts 7TM Decorative inserts
    Scuff plates 7M0 Plastic scuff plates in door apertures
    Park distance control 7X0 Without park distance control
    Electric interface for external use UF0 Without electric interface
    Manufacturing sequence differentiation 0FA Standard manufacturing sequence
    window regulator 4R4 Power windows with comfort operation and circuit breaker
    fire extinguisher 6A0 without fire extinguisher
    Pedestrian protection VL0 Standard pedestrian protection measures
    Pedal cluster VF0 Standard pedal cluster
    Headlight activation 8K4 Separate daytime running light -- NAR --
    Parking brake UH2 Parking brake
    Alternators 8GU Alternator 140 A
    Transmission types/gearshift mechanisms 0G7 tiptronic
    Weight category rear axle 0YE Weight range 5 installation control only, no requirement forecast
    Weight category front axle L03 Suspension range 03 installation control only, no requirement forecast
    Base engine TQ2 4-cylinder SI engine 2.0 l unit 06J.B
    Tie down straps/net/pocket 6M0 Without tie down straps/net/pocket
    cruise control system 8T2 Electronic cruise control system (CCS)
    Garage door opener VC0 without Garage door opener
    Transmission specifications G1A 6-speed automatic transmission
    Cruise control system and speed limiter 6Y9 without cruise control system
    Brackets 3P0 Without bracket for first aid kit and warning triangle
    Rear seats 3NU Rear bench seat, not split, split backrest, folding centre armrest
    Heating and air-conditioning system 9AP Climatic air-conditioning system (semi-automatic)
    Headlamps 8ES Twin headlamps for driving on the right, with integrated high beam (US design)
    Customized installation FC0 Without customized installation
    Interior light in footwell 6T1 Interior light in footwell
    Instrument clusters U5C Instrument cluster, mph speedometer - USA -
    Breakaway interior rearview mirror 4L2 Breakaway interior rearview mirror, dimming
    headphone connection, rear 8MA no headphone connection in rear
    Body style K8B Notchback
    Luggage compartment floor covering 6SE Luggage compartment floor covering in flat needle-punched nonwoven
    Cassette and CD storage unit 4W0 without cassette / CD tray
    Electronic map cooling system QS0 Without electronic map cooling system
    Child seats QA0 without child seat
    Climatic zones 0Y4 Cold and tropical climatic zones (US)
    Compass/road sign display QR1 With compass
    Seat ventilation/massage seat 4D0 Without seat ventilation/massage seat
    Fuel quantity for initial filling 1Z0 Initial standard fuel filling
    Fuel systems 1A2 Fuel system for SI engine with direct injection (FSI)
    Body measures 5C1 Body measures for increased safety requirements
    Radiator grille 6KA Radiator grille
    Rear license plate carrier 6P2 Rear license plate carrier (NAR)
    Front license plate carrier 6W3 Front license plate carrier (small, NAR)
    Paint preservative/transit coating 5K4 Full body cover (shape-adapted system) with additional transport protection measures
    Paint coating FB0 standard paint coating
    Rear cargo area 3GA Without luggage compartment floor
    Country codes FE0 Without country code (no DVD player in vehicle)
    Steering system arrangement L0L Left-hand drive
    Reading lamp 8S7 2 reading lights in front
    steering 1N3 Speed-related variable steering assist (Servotronic)
    Backrest release 3H0 Without backrest release for front seats
    Load edge protection 2P1 Plastic loading edge protection
    Lumbar support 7P7 Power-adjustable lumbar support for left front seat
    steering wheels 2PP Leather-wrapped multi-function steering wheel
    Speaker installation 8RM 8 speakers (passive)
    Headlight range control 8Q0 without beam length regulator
    Center armrest 6E3 Center armrest in front
    Multi-function display/trip computer 9Q5 Multi-function display with control
    Center console 3I5 Center console
    Engine cooling 8Z6 Hot country
    Engine specifications D2L 4-cylinder petrol engine 2.0 L/147 KW (16 V) Turbo FSI, homogeneous Basic engine is: T59/T61/TQ2/TU2/TD6/TN6
    Left vanity mirror 4SQ Left vanity mirror illuminated with cover and special mirror imprint (NAR)
    Right vanity mirror 4TQ Vanity mirror, right, illuminated, with cover and special mirror imprint (NAR)
    Navigation device 7Q0 without navigation system
    rear fog lamp 8TA witout rear fog lamp
    Front fog lamp/additional headlamp 8WD Integrated front fog lamps
    Hubcaps 1NL Trims for alloy wheels
    Wheels CA5 Alloy wheels 7.5J x 17
    Radios 8AX Radio Premium 8
    Smoker's/non-smoker's package 9JF Non-smoker's package (NAR)
    Tire pressure monitoring system 7K4 Tire pressure monitoring system 315 MHz High
    umbrella NS0 Without umbrella(s)
    tire HK1 All-season tires 235/45 R17 97H xl (NAR)
    Tire suppliers V0A Tires without specification of tire brand
    Spare wheel/breakdown kit 1G1 Space-saving spare wheel
    Restraint systems, front 4QQ 3-point seat belts in front with pretensioner and height adjustment, US label
    Side airbag 4X3 Side airbag in front, with curtain airbag
    Gearshift knob/handle 6Q2 Gearshift knob/handle in leather
    Special labels/plates 0SS Labels in English and French
    Tail lamp assemblies 8SL Taillight assemblies with diodes (LED) (for NAR)
    Locking mechanism for boot lid/cover rear 4E2 Tailgate/trunk lid release from inside (electrically)
    Front seat, left 3TF Comfort seat in front, left
    Front seat, right 3SF Comfort seat, front right
    Seat belt check 9P7 Visual and acoustic seat belt reminder, electric contact in buckle
    Outer rear seat belts 3ZD 3-point seat belts, outer rear with US label
    Center rear seat belts 3C8 3-point seat belt, center rear with US label
    seat covers N1S Seat trim covers in leatherette
    Seat adjustment 3PB Power seat on the left, right seat with manual height adjustment
    seat heater 4A3 seat heating for front seats separat controlable
    Side lights 8F1 Side-marker lamps
    Start-stop system/regenerative braking 7L3 Without start-stop system without regenerative braking
    Audio-response system/voice control QH0 without voice control
    Lane change assist/lane keeping system 7Y0 no lane change assistant
    Side and rear windows 4KC Side and rear windows in heat-insulating glass
    Protective side molding 4B4 Protective side molding
    Sunroof roller blind for rear/side windows 3Y0 without roller blind
    power outlet 7B3 12-volt outlet(s)
    Bumper 2JC Comfort bumpers
    Headlamp washer system 8X0 Without headlamp washer system
    Windshield wiper intermittent control/ light/rain sensor 8N4 Windshield wiper intermittent control with potentiometer (four speeds)
    Special approval measures 3M0 Without special measures
    Nameplate set 0PK Nameplate set "FSI"
    Special alarm systems 9A0 Without taxi alarm system
    Mass damper for steering wheels 1Q1 Mass damper for steering wheel, 26.5 Hz
    Door and lid locking system 4K0 Central locking w/ radio remote control and interior controls
    Type approval countries/countries with special requirements B34 Legal requirements for USA
    Carrier frequency for remote control 5D2 Carrier frequency 315 MHz
    Partition 3CA without partition
    Transit coating NT1 Transit coating (type 2)
    Door and side trim panels 3LJ Door and side trim panel in foam film, insert in leatherette
    TV reception/digital radio reception QU4 Satellite radio reception NAR integrated in device
    Assembly parts for engine (drive bearing) 1VG Installation parts for four-cylinder engine
    Identification plates 1EB without identification plate
    Delivery equipment 2A8 Delivery equipment, water border
    First aid kit / warning triangle 1T0 Without first aid kit and warning triangle
    Two-way radio installation preparation 9D0 without prepared for two way radio system
    Preparation for rotating beacon/siren combination 9F0 Without preparation for rotating beacon/siren combination
    Telephone / telematics 9W3 Mobile phone interface High (NAR)
    Additional warning lights 9TC Additional retro-reflectors (door area)
    LongLife Service Regime QG0 without service interval extension
    Heat accumulator system/auxiliary heater 7E0 W/o heat accumulator/auxiliary heating
    Windshield Glass 4GF Windshield in heat-insulating glass
    Second battery/battery installation 8FA without 2nd battery
    Additional tires (snow tires) 2WA without spare tyre
    floor mats 0TD Front and rear floor mats
    Decorative trims 4ZB Bright decorative trims
    Additional child seat anchors 3B3 Child seat anchors
    Auxiliary heating system 9M0 Without auxiliary heater/parking heater
  9. #8
    Oct 2014
    are you trying to tell me that the vehicle is still under warranty?
  10. #9
    Please answer the aforementioned questions in last post or maybe you see the self evident answers already?
  11. #10
    Oct 2014
    I am not the original owner so I am unsure of the date of delivery but I did notice the date listed under that gearbox. The vehicle has 104k on it. Should I be on the phone with a stealership?
