Results 1 to 5 of 5
Thread: AV input on Q8-4M, A8-4N, A6-4A, A7-4K
    Jan 2016
    I have recently retrofitted TV module to my Q8 4M but for some reason the AV input option is not showing. TV works just as it should. I believe this option should be within the media screen but there is nothing in the manual to provide any further clues. From early years the AV input option just seems to appear along with the TV. I have tested with a "real" AV input signal and the TV measuring values confirm signal present.
    Any assistance appreciated.
    SCAN below of current configuration. Sadly the car is full of errors which Audi are struggling to fix.
    Cheers,
    Sunday,16,February,2020,15:09:48:23598
    VIN: WAUZZZF1XKD020041   License Plate:
    Chassis Type: F1-AU58 (4N2)
    Scan: 01 02 03 06 09 13 15 16 17 19 2B 36 3C 42 44 46 47 52 57 5F
              61 65 69 6D 74 81 82 A5 AC BB BC C4 CA CB CC CD CF D6 D7 DB
              DC DE
    VIN: WAUZZZF1XKD020041   Mileage: 22225km-13809miles
    57-TV Tuner -- Status: Malfunction 0010
    BB-Door Rear Drv -- Status: Malfunction 0010
    C4-DC/DC Converter -- Status: OK 0000
    CA-Sunroof -- Status: OK 0000
    CB-Rear Axle Steering -- Status: OK 0000
    CC-Starter-Generator -- Status: OK 0000
    CD-Laser Scanner -- Status: Malfunction 0010
    DB-Frt Corner Rdar 1 -- Status: OK 0000
    DC-Frt Corner Rdar 2 -- Status: OK 0000
    DE-Charger 1 for mobile dev -- Status: OK 0000
    Address 01: Engine (J623-DHXA)       Labels: Redir Fail!
       Part No SW: 4M8 907 401     HW: 059 907 309 L
       Component: 3.0l V6 TDI   H26 0001
       Revision: CAH26---
       Coding: 2A2A4012057E050334286000000400000000000000000000
       Shop #: WSC 31414 242 00001
       ASAM Dataset: EV_ECM30TDI0114M8907401 001002
       ROD: EV_ECM30TDI0114M8907401.rod
       VCID: 6E85CE9CA012C7972BB-803A
       Part No SW: 4M8 927 158 G    HW: 0D5 927 156 P
       Component: 0D5  30TDIRdW H05 1001
       Revision: --H05---
       Coding: 100000
       Shop #: WSC 31414 239 00001
       ASAM Dataset: EV_TCMALX52011 002014
       ROD: EV_TCMALX52011.rod
       VCID: 40D94024CA0601E7897-8014
       Automatic Transmission Fluid Pump:
       Subsystem 1 - Part No SW: 4M0 927 154 AA    HW: 0D7 321 281 A
       Component: V552 ATFP  H01 0705
       Serial number: 180317000200
    Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-PRE-V1.clb
       Part No SW: 4M6 907 379 N    HW: 4M6 907 379
       Component: ESP9 Premium  H06 0850
       Coding: 24AA329631A40B96D39E5C95187E96E2F5BAC9244C8CD0CB3A186947AF5D93
       Shop #: WSC 61854 444 00001
       ASAM Dataset: EV_ESP9BOSCHCMP 004011
       ROD: EV_ESP9BOSCHCMP_004_AU65.rod
       VCID: 48C95804E23639A7417-801C
    450048 - Databus
              U1122 00 [040] - Implausible Message
              [Signal_FT_Tuer_Status_invalid_(0)_or_Signal_FT_Tuer_Status_QBit_invalid_(1)]
                        Mileage: 21803 km
                        Date: 2020.02.08
                        Time: 12:08:42
                        78 00 82 00 42 00 00 00 00 00
                        Unlearning counter according OBD-OBD unlearning counter: 20
       Part No SW: 4M6 959 760 B    HW: 4M6 959 760 B
       Component: MEM-BFS       009 0042
       Serial number: 00000356876723
       Coding: 0038B2400001BE810043010101010000810000070700878700000000000000
       Shop #: WSC 31414 050 00001
       ROD: EV_SCMPasseSideCONTIAU736_VW53.rod
       VCID: 3D2739D0BDF46C0FE21-8068
       Subsystem 1 - Part No SW: 4N0 907 182     HW: 4N0 907 182
       Component: N477 VB1 BFSv  H04 0011
       Serial number: SJ8001131118402580EB
       Coding: BF2F00
    Address 09: Cent. Elect. (J519)       Labels:* 4N0-907-063-V2.clb
       Part No SW: 4N0 907 063 DE    HW: 4N0 907 063 AE
       Component: BCM1 MLBevo   H10 0652
       Coding: 07000143C13900DD070C57889FFB8C78131B33110406009781010A001B3316810A45090200100000000003030041081B1802000044010104000000000000000000
       ASAM Dataset: EV_BCM1BOSCHAU651 014010
       ROD: EV_BCM1BOSCHAU651_014.rod
       VCID: 74B1DCF4CE3EED47DDF-8020
       Subsystem 1 - Part No SW: 4M8 955 119 A    HW: 4M8 955 119 A  Labels: 1KX-955-119.CLB
       Component: J400FRWISCH  052 0997
       Serial number: 904853F0401825000080
       Coding: 7DC727
       Serial number: 22115216X81A955555A0
       Coding: 02005D
       Light switch:
       Subsystem 3 - Part No SW: 4K2 941 501 A    HW: 4K2 941 501 A
       Component: E1 - LTM  H09 0086
       Serial number: 14S09.11.1800690839
       Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
       Serial number: GX1CE114091823810927
       Coding: 210000
       Interior Light Module:
       Subsystem 5 - Part No SW: 4K0 947 135 L    HW: 4K0 947 135 L
       Component: Dachmodul  H42 0413
       Serial number: Q00659725
       Coding: 0D0104
       Electrically Adjustable Steering Column:
       Subsystem 6 - Part No SW: 80A 907 705     HW: 80A 907 705
       Component: J866-EVLS-SG  H03 0100
       Serial number: WA135181000058589407
       Coding: 0A0100
       Front windshield washer pump:
       Subsystem 7 - Part No SW: 4N0 907 605 C    HW: 4N0 907 605 A
       Component: J1100/SWP  H21 0015
       Serial number: 00000000001833000817
       Coding: 040000
    67736 - Databus
              [Camera sensor blocked]
                        Reset counter: 48
                        Mileage: 21746 km
                        Date: 2020.02.06
                        Time: 12:50:57
                        average_Voltage_terminals: 14.80 V
                        Outside air temperature sensor-Resistance: 0.00 kOhm
                        Outside air temperature sensor-Outside air temperature on CAN: 6.50 ∞C
                        interior_temperature: 15.00 ∞C
                        Vehicle speed: 32.75 km/h
    393767 - Motor for Left Side Vent Flap
              B10C9 07 [008] - Mechanical Failure
                        Reset counter: 48
                        Mileage: 21745 km
                        Date: 2020.02.06
                        Time: 12:49:17
                        average_Voltage_terminals: 14.60 V
                        Outside air temperature sensor-Outside air temperature on CAN: 8.00 ∞C
                        interior_temperature: 14.50 ∞C
                        Vehicle speed: 1.52 km/h
    405507 - Functional Limitation due to Energy Management
              B10CD 00 [008] - -
              [Function limitation due to energy management system]
                        Reset counter: 48
                        Mileage: 21722 km
                        Date: 2020.02.04
                        Time: 22:06:16
                        average_Voltage_terminals: 11.40 V
                        Outside air temperature sensor-Outside air temperature on CAN: 7.00 ∞C
                        interior_temperature: 9.00 ∞C
                        Vehicle speed: 0.00 km/h
       Part No SW: 4M0 907 561 L    HW: 4K0 907 561
       Component: LRR4R         H04 0332
       Coding: 5665FF5C78082C00010360E0000000BE4A1246484481009E00
       Shop #: WSC 31414 042 00001
       ASAM Dataset: EV_ACCBOSCHAU65X 002023
       ROD: EV_ACCBOSCHAU65X_AU58.rod
       VCID: 392F2DC0A9DC502FCE9-806C
    2342 - Databus
              [FAULT_ACA_QF_STATUS_DISPLAY_ERROR]
                        Reset counter: 50
                        Mileage: 21803 km
                        Date: 2020.02.08
                        Time: 12:10:45
                        Control Module temperature: 10 ∞C
                        Voltage terminal 15: 13.3 V
                        Longitudinal_acceleration_vehicle_reference: 0.00 m/s≤
                        Steering_angle-Data: 341.400 ∞
                        Yaw_rate-Data: -0.025 rad/s
                        adjustment_calculation: On
                        Misalignment angle: horiz: 0.223 ∞
                        Misalignment angle: horiz: fast algorithm: 0.242 ∞
                        Congestion pilot: status: OFF
                        Outside air temperature: 8.50 ∞C
                        Sensor blindness: radar: no blindness detected
    2344 - Databus
              [FAULT_CAMERA_DIRT_OBJ]
                        Reset counter: 48
                        Mileage: 21746 km
                        Date: 2020.02.06
                        Time: 12:50:46
                        Control Module temperature: 26 ∞C
                        Voltage terminal 15: 14.0 V
                        Velocity_vehicle_reference: 14.07 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.29 m/s≤
                        Steering_angle-Data: -1.300 ∞
                        Yaw_rate-Data: 0.092 rad/s
                        Misalignment angle: horiz: 0.226 ∞
                        Misalignment angle: horiz: fast algorithm: -0.112 ∞
                        Outside air temperature: 6.50 ∞C
    2343 - Databus
              [FAULT_CAMERA_DIRT_PEDEST]
                        Reset counter: 48
                        Mileage: 21746 km
                        Date: 2020.02.06
                        Time: 12:50:46
    2135 - Door Control Module; Front Driver Side
              U14B7 00 [008] - Signal Not Qualified
              [FAULT_DRIVER_DOOR_INVALID]
                        Reset counter: 50
                        Mileage: 21803 km
                        Date: 2020.02.08
                        Time: 12:10:45
                        Voltage terminal 15: 12.0 V
                        Steering_angle-Data: 341.500 ∞
                        Yaw_rate-Data: 0.000 rad/s
       Part No SW: 4N0 959 655 Q    HW: 4N0 959 655 Q
       Component: AirbagVW31    H09 2710
       Serial number: 003YZM01HLRV
       Coding: AACCF0C000C00000985400FFF08D41A800C5
       Shop #: WSC 31414 030 00001
       ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
       ROD: EV_AirbaVW31SMEAU65x_VW53.rod
       VCID: 4ACD620CFC3ACBB7573-801E
       Belt Pretensioner left:
       Subsystem 1 - Part No SW: 4N0 980 945 A    HW: 4N0 980 945 A
       Component: BeltPretRevFL  H10 0115
       Serial number: 00AI2018320353200000
       Coding: 03F001
       Belt Pretensioner right:
       Subsystem 2 - Part No SW: 4N0 980 946 A    HW: 4N0 980 946 A
       Component: BeltPretRevFR  H10 0115
       Serial number: 00AI2018321306600000
       Coding: 03F001
       Subsystem 3 - Part No SW: -----------    HW: 480 001 711 18
       Serial number: 3570000000051B79C53P
       Subsystem 4 - Part No SW: -----------    HW: 480 001 711 18
       Serial number: 3580000000011A79C53L
       Subsystem 5 - Part No SW: -----------    HW: 480 032 111 18
       Component: SideSensor_Dr  002 0149
       Serial number: 351001C143E5EE60ED9X
       Subsystem 6 - Part No SW: -----------    HW: 480 031 911 18
       Component: SideSensor_Pr  002 0149
       Serial number: 352001C10D1E2CD03E0A
       Subsystem 7 - Part No SW: -----------    HW: 480 032 310 18
       Component: FrontSensor_D  002 0149
       Serial number: 355001C185A20E408AEG
       Front Sensor Passenger:
       Subsystem 8 - Part No SW: -----------    HW: 480 032 310 18
       Component: FrontSensor_P  002 0149
       Serial number: 356001C149F1E9F13C1Q
       Side Sensor B-Pillar Driver Front:
       Subsystem 9 - Part No SW: -----------    HW: 480 032 111 18
       Component: SideSens_B_Df  002 0149
       Serial number: 352001C143E5EA80AB1I
       Side Sensor B-Pillar Passenger Front:
       Subsystem 10 - Part No SW: -----------    HW: 480 031 911 18
       Component: SideSens_B_Pf  002 0149
       Serial number: 355001C10D1E2530FB27
       Part No SW: 4N0 907 129 AJ    HW: 4N0 907 129 AJ
       ROD: EV_SMLSKLOAU736_VW53.rod
       VCID: 79AFEDC0E95C902F8E9-802C
       Part No SW: 4K0 920 790 C    HW: 4K0 920 790 C
       Component: FBenRDWACC--- H11 0153
       Coding: A58410E67C88060001A3E164B080680008003000
       ASAM Dataset: EV_DashBoardAU65X 001017
       ROD: EV_DashBoardAU65X_VW53.rod
       VCID: 2D0709906D94FC8F521-8078
       Part No SW: 4N2 907 468 AB    HW: 4N2 907 468 AB
       Component: Gateway       H14 0037
       Revision: 8P030005    Serial number: 0588P769518B26
       Coding: 02010005000486408C960000005B0132DC9A00471C000000097D078E10000000
       Shop #: WSC 31414 245 00001
       ASAM Dataset: EV_CGateCONTIAU491 003150
       ROD: EV_CGateCONTIAU491_003_AU58.rod
       Subsystem 1 - Part No SW: 4M8 951 523     HW: 4M8 951 523
       Component: J453 MFL  H07 0004
       Serial number: 20181122100820 30881
       Subsystem 2 - Part No SW: 4K0 915 181 A    HW: 4K0 915 181 A
       Serial number: 7588520200181116073C
    131595 - Tire Pressure Monitoring Module
              U0127 00 [008] - No Communications
              [Timeout_Node_0x0B_DiagAdress_65_RDK]
                        Reset counter: 49
                        Mileage: 21786 km
                        Date: 2020.02.07
                        Time: 11:22:04
    8519683 - Energy Management Active
              U140B 00 [008] - -
                        Reset counter: 48
                        Mileage: 21722 km
                        Date: 2020.02.04
                        Time: 22:06:56
                        EM_vehicle_state: 02 10
                        Static current shutdown level: Deactivation stage 1
                        Auxiliary heater activation restriction request-Parking heater: Permitted
                        Auxiliary heater activation restriction request-Allowed parking heater runtime: 0 min
       Part No SW: 3Q0 905 861 C    HW: 3Q0 905 861 C
       Component: ELV-MLBevo    H05 0020
       Serial number: 18000342682014
       Coding: 8800000000000000
       ROD: EV_ELVMarqMQBA0_VW41.rod
       VCID: 34311CF48EBEAD471DF-8060
       Component: MEM-FS        009 0042
       Serial number: 00000356887363
       Coding: 00389A400001BE810003010101010000810000070700878700000000004000
       ROD: EV_SCMDriveSideCONTIAU736_VW38.rod
       Component: N475 VB1 FSv  H04 0011
       Serial number: SJ80011311184025805E
       Coding: BF2F00
    Address 3C: Lane Change (J769)       Labels:* None
       Part No SW: 4N0 907 566 F    HW: 4N0 907 566 A
       Component: MRR_HR H12 0266
       Coding: 5FFC00
       ASAM Dataset: EV_RearRadarS1DelphAU651 001018
       ROD: EV_RearRadarS1DelphAU651_AU58.rod
       Part No SW: 4M1 959 793 J    HW: 4M1 959 793 D
       Component: TSG FS001 0425
       Serial number: YE007RI626569
       Coding: 001DDA42520104C2A009B436
       Shop #: WSC 00460 210 00000
       ROD: EV_DCU2DriveSideMAXHCONT_VW27.rod
       VCID: 46D5563CE8222FD7B3B-8012
    196677 - Switch for Interior Door Handle
              B132E 29 [008] - Signal Implausible
                        Reset counter: 50
                        Mileage: 21803 km
                        Date: 2020.02.08
                        Time: 12:05:27
    196709 - Switch for Exterior Door Handle
              B132F 29 [008] - Signal Implausible
                        Reset counter: 50
                        Mileage: 21803 km
                        Date: 2020.02.08
                        Time: 12:05:27
       Part No SW: 4N0 909 144 D    HW: 4N0 909 144 A
       Component: EPS_MLBEVO2BS H21 0504
       Coding: B2000101010000
       ASAM Dataset: EV_EPSVWBSAU426 009015
       ROD: EV_EPSVWBSAU426_009.rod
       VCID: 313F15E071AC986F769-8064
       Part No SW: 8W0 907 064 FP    HW: 8W0 907 064 DP
       Component: BCM2 MLBevo   025 0406
       Coding: 013500002FB100406309A0046C00C80203004000804F02502F0400200504823F001F0100010F01
       ASAM Dataset: EV_BCM2HellaAU736 015015
       ROD: EV_BCM2HellaAU736_015_AU58.rod
       VCID: 0F7BB318C7D8AE9F40D-805A
       Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
       Serial number: 000000000ZY182842VMQ
       Subsystem 2 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
       Component: Sirene, DWA  004 0007
       Serial number: 00000000000000248300
       Rear Light Left 1:
       Subsystem 3 - Part No SW: 4M8 945 069 B    HW: 4M8 945 069 B
       Component: SHL_li1  H04 0004
       Serial number: 069B1811150000037063
       Subsystem 4 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
       Component: GEB.F.Heckoef  H17 0906
       Serial number: 11315144
       Rear Light Left 2:
       Subsystem 5 - Part No SW: 4M8 945 217 F    HW: 4M8 945 217 F
       Component: SHL_li2  H04 0004
       Serial number: 217F1811050000033098
       Rear Light Right 1:
       Subsystem 6 - Part No SW: 4M8 945 070 B    HW: 4M8 945 070 B
       Component: SHL_re1  H04 0004
       Serial number: 070B1811140000036935
       Rear Light Right 2:
       Subsystem 7 - Part No SW: 4M8 945 218 F    HW: 4M8 945 218 F
       Component: SHL_re2  H04 0004
       Serial number: 218F1811050000033098
       Part No SW: 4N0 035 223 B    HW: 4N0 035 223
       Component: MIB2_amp_P_D5 H01 0150
       Revision: 00000001    Serial number: AUZ8ZAJ6S00ZBS/
       Coding: 0135360A00AAAAAFAA0000010000
       ASAM Dataset: EV_AMPMst16C1Gen2pALPI 001010
       ROD: EV_AMPMst16C1Gen2pALPI.rod
       VCID: 2313EFA83B503AFFF45-8076
       Part No SW: 4M1 959 792 J    HW: 4M1 959 792 D
       Component: TSG BFS001 0425
       Serial number: YE007RJO12468
       Coding: 001DDA025E0104C2A009B434
       ROD: EV_DCU2PasseSideMAXHCONT_VW27.rod
       VCID: 45D75130D52424CFBA1-8010
    Address 57: TV Tuner (R78)       Labels:* None
       Part No SW: 8V0 919 191 C    HW: 8V0 919 191
       Component: DVB-DTV       H08 1800
       Coding: 0107030000000100000000
       ASAM Dataset: EV_TVMELC 001033
       ROD: EV_TVMELC_VW27.rod
       VCID: 3FDB43D8B7F87E1FF0D-806A
    8209 - Antenna 1 for TV
              B124D 11 [008] - Short to Ground
                        Reset counter: 51
                        Mileage: 21722 km
                        Date: 2020.02.06
                        Time: 09:47:03
                        Voltage terminal 30: 12.8 V
                        Connection status antenna 1-Antenna current: 0 mA
                        Connection status antenna 1-TV tuner to impedance converter: Short circuit to ground
                        Connection status antenna 1-Impedance converter to antenna: Not available
                        Connection status antenna 1-Phantom voltage: 0.3 V
                        Connection status antenna 1-level: 0
    Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
       Part No SW: 4K0 035 063 A    HW: 4K0 035 063 A
       Component: MU-H-LND-EU   046 2470
       Coding: 0135360100000000C3111102C00800302F0001E601F008008E
       ASAM Dataset: EV_MUHigGen2pALPI 001001
       ROD: EV_MUHigGen2pALPI_AU27.rod
       VCID: 211FE5A0214C28EFE69-8074
       Subsystem 1 - Part No: V03 959 804 LN
       Component: MIB2P_EU_Q219  0371
       Subsystem 2 - Part No SW: 4M8 919 605 A    HW: 4M8 919 605
       Component: DU AU536 High  H41 0144
       Serial number: INX00108101800100506
       Subsystem 3 - Part No: V03 959 800 EG
       Component: Gracenote2  1008
       Volume Control 1:
       Subsystem 4 - Part No SW: 4N1 919 616 A    HW: 4N1 919 616
       Component: LSR-D5/C8  H33 0108
       Serial number: 00004418000227672057
       Display Unit 5 For Multimedia System:
       Subsystem 5 - Part No SW: 4N0 919 603 B    HW: 4N0 919 603
       Component: DU AU651 Bot  H41 0144
       Serial number: INX00112081800050718
       Media socket:
       Subsystem 6 - Part No SW: 4N0 035 736 A    HW: 4N0 035 736
       Component: MediaConnectH  014 0133
       Serial number: 051800707102001
    Address 61: Battery Regul. (J1120)       Labels: None
       Part No SW: 4N0 915 105 B    HW: 4N0 915 105 B
       Component: BMS_48V_LiIon H06 0108
       ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
       ROD: EV_BMS48VLiIonLGAU536_AU58.rod
       VCID: 290FFD80597CE0AFBE9-807C
    Address 65: Tire Pressure (J502)       Labels: None
       Part No SW: 4M0 907 273 B    HW: 4M0 907 273 B
       Component: RDKHUFAU736   H04 0010
       Serial number: 40000000005092
       ASAM Dataset: EV_RDKHUFAU736 002007
       ROD: EV_RDKHUFAU736_AU58.rod
       VCID: 2F3B139867988E9F60D-807A
       Part No SW: 4M0 907 383 G    HW: 4M0 907 383 B
       Component: Anhaenger     H33 0273
       Revision: 9A001003    Serial number: 0499625962
       Coding: 0110000202000000
       ROD: EV_TrailFunctGener2Hella_VW27.rod
       VCID: 363526FC98C2BF5723B-8062
       Part No SW: 4M0 959 107 D    HW: 4M0 959 107 A
       Component: HDSG-Modul    H13 0170
       Revision: --------    Serial number: A2-C737-6252-2
       Coding: 28F0
       ASAM Dataset: EV_DeckLidCONTIAU736 001016
       ROD: EV_DeckLidCONTIAU736_AU38.rod
    Address 74: Chassis Control (J775)       Labels:* None
       Part No SW: 4M8 907 777 N    HW: 4M8 907 777
       Component: Fahrwerk-SG   H51 2031
       Serial number: 2411180589
       Coding: B85C6050F840
       ASAM Dataset: EV_ChassContrContiAU651 001011
       ROD: EV_ChassContrContiAU651_001_AU58.rod
       VCID: 4CC16414F64ED58765F-8018
       Air Suspension Compressor:
       Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
       Component: V66LFKompOLV  H06 0013
       Serial number: 00000000004130460309
       Coding: 303030
    Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
       Part No SW: 4M8 713 041 A    HW: 4N2 713 041 C
       Component: GSM-LL        H10 0077
       Revision: 0L0D5012    Serial number: 18080448660610
       ROD: EV_GSMWaehlZFAU736.rod
       VCID: 2A0D028C5C7AEBB7B73-807E
       Part No SW: 4M8 919 617 C    HW: 4M8 919 617 C
       Component: HeadupDisplay H08 1815
       Coding: 4700E0
       ASAM Dataset: EV_HeadUpDisplAU65X 001010
       ROD: EV_HeadUpDisplAU65X_AU58.rod
    Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
       Part No SW: 4KE 907 107 AC    HW: 4N0 907 107 H
       Component: zFAS Var C    H09 0291
       Coding: 04C184000000000000FFD60000F0C60C1B9F760000000000000000000096D401009BA8000000000000000080000000000000000000000000F980400000000000000078D0008000B000800080000000000080400000E0
       ASAM Dataset: EV_ZFASAU516 001003
       ROD: EV_ZFASAU516_001_AU58.rod
       VCID: 005980248A86C1E7C97-8054
    2117691 - Ethernet Databus
              U11C4 00 [008] - No Communications
              [Databus_Ethernet_no_communication]
                        Reset counter: 48
                        Mileage: 21769 km
                        Date: 2020.02.06
                        Time: 16:37:27
                        Ethernet signal quality: no link
    2117692 - Control unit for information electronics 1
              U1054 00 [008] - No Communication
              [Databus_Ethernet_missing_PDU]
                        Reset counter: 48
                        Mileage: 21769 km
                        Date: 2020.02.06
                        Time: 16:37:15
    221284 - Front Camera for Driver Assist Systems
              C12B3 FD [008] - View Temporarily Restricted
              [temp view limitations]
                        Reset counter: 48
                        Mileage: 21746 km
                        Date: 2020.02.06
                        Time: 12:50:46
                        EyeQ temperatures-CPU: -40 ∞C
                        EyeQ temperatures-VPM: 14 ∞C
                        Vehicle speed: 49.77 km/h
                        Front camera: blinding detection-Status: not active
                        Front camera: blinding detection-Blinding detected by light assistance assessment module: Yes
                        Front camera: blinding detection-Blinding detected by road sign recognition assessment module: Yes
                        Front camera: blinding detection-Blinding detected by pedestrian recognition assessment module: Yes
                        Front camera: blinding detection-Blinding detected by lane recognition assessment module: Yes
                        Front camera: blinding detection-Blinding detected by object recognition assessment module: Yes
                        Front camera: blinding detection-Blinding detected by distance regulation assessment module: Yes
                        Front camera: blinding detection-Blinding detected by road profile estimation assessment module: Yes
                        Front camera: blinding detection-Blinding detected by free space recognition assessment module: Yes
                        Front camera: blinding detection-Request for window defogger for front sensor system due to blinding: Yes
                        Front camera: blinding detection-Glare detected: No
                        Front camera: blinding detection-free view detected once: No
    282656 - Video Cable for Information Electronics 1
              B13B9 01 [008] - Electrical Failure
                        Reset counter: 48
                        Mileage: 21769 km
                        Date: 2020.02.06
                        Time: 16:37:15
    4107 - Databus
              [reversibler_Fehler_im_ACC_System]
                        Reset counter: 50
                        Mileage: 21803 km
                        Date: 2020.02.08
                        Time: 12:10:46
    Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
       Part No SW: 4M0 907 355 D    HW: 4M0 907 355 B
       Component: SCR-Stg-G3H05 0006
       ASAM Dataset: EV_RDCMINERGAU736 005012
       ROD: EV_RDCMINERGAU736_VW53.rod
       VCID: 323D1AEC74AAA3770F3-8066
       Part No SW: 4M1 959 795 J    HW: 4M1 959 795 D
       Component: TSG HFS003 0425
       Serial number: YE007RK617541
       Coding: 000DD802000104C2A008B024
                        Reset counter: 48
                        Mileage: 21745 km
                        Date: 2020.02.06
                        Time: 11:15:35
                        Reset counter: 48
                        Mileage: 21745 km
                        Date: 2020.02.06
                        Time: 11:15:35
       Component: TSG HBFS003 0425
       Serial number: YE007RK614195
    Address C4: DC/DC Converter (A7)       Labels: 4M0-959-663.clb
       Part No SW: 4M0 959 663 C    HW: 4M0 959 663 C
       Component: PCU10         022 0324
       ASAM Dataset: EV_DCDC48V210ABOSCHAU736 001008
       ROD: EV_DCDC48V210ABOSCHAU736.rod
       VCID: 3A2D32CCACDA5B37C73-806E
       Part No SW: 4K0 907 594 AC    HW: 4K0 907 594
       Component: SAD_STG_1     005 0002
       Coding: 728040053632
       ASAM Dataset: EV_SunRoofCONTIAU736 009011
       ROD: EV_SunRoofCONTIAU736_009_VW27.rod
       VCID: 75B7E1F0C544F44FEA1-8020
    Address CB: Rear Axle Steering (J1019)       Labels:* None
       Part No SW: 4M0 909 145 AA    HW: 4M0 909 145 E
       Component: HAL_MLBevoH08 0698
       Revision: --------    Serial number: CCC_098_B_1122_
       Coding: 42242A00
       ASAM Dataset: EV_RearAxleSteerZFAU736 010018
       ROD: EV_RearAxleSteerZFAU736_010.rod
       VCID: 6FBBD398A718CE9F20D-803A
    Address CC: Starter-Generator (----)       Labels:* None
       Part No SW: 4N0 903 028 H    HW: 4N0 903 028 H
       Component: BSG-HP1-65    H16 0523
       Serial number: 01121800020076
       Coding: 28000000000000
       ASAM Dataset: EV_Start48VAU651 001006
       ROD: EV_Start48VAU651_001.rod
       VCID: 303910E47AA69167797-8064
    Address CD: Laser Scanner (J1122)       Labels: None
       Part No SW: 4K8 907 660 B    HW: 4N0 907 660
       Component: LASER_SCANNER H36 0202
       ASAM Dataset: EV_LaserScannAU651 013013
       ROD: EV_LaserScannAU651_013.rod
       VCID: 353721F085C4B44F2A1-8060
    11567105 - Cleaning Failed
              B17FC 00 [008] - -
                        Reset counter: 52
                        Mileage: 21787 km
                        Date: 2020.02.07
                        Time: 18:53:00
                        Control Module temperature-Host: external temperature: 15 ∞C
                        Control Module temperature-Zynq: internal temperature: 30 ∞C
                        Control Module temperature-Host: internal temperature: 17 ∞C
                        Control Module temperature-Zynq: external temperature: 12 ∞C
                        Voltage terminal 15: 14.810 V
                        Vehicle speed: 48.39 km/h
                        Request for cleaning of laser scanner: not active
                        Washer fluid level: OK
                        Heating and cleaning management-Visibility: 0 %
                        Heating and cleaning management-Degree of contamination: 35 %
                        Heating and cleaning management-Heating status: 02
                        Heating and cleaning management-Cleaning status: 05
                        Outside air temperature: 8 ∞C
                        Counter_lense_cleanings-Cleaning_Sequence: 0
                        Counter_lense_cleanings-lense_clean_count_total: 0
                        Counter_lense_cleanings-lense_clean_count_trip: 2
    Address CF: Lane Chge Asst 2 (J770)       Labels:* None
       Component: MRR_HL H12 0266
       Coding: 5FFC00
       ASAM Dataset: EV_RearRadarS2DelphAU651 001018
       ROD: EV_RearRadarS2DelphAU651_AU58.rod
       Part No SW: 4K0 941 592 BC    HW: 4K0 941 592 B
       Component: LMS_MLBevo    H11 0031
       ASAM Dataset: EV_LMSLeftHELLAAU58X 001013
       ROD: EV_LMSLeftHELLAAU58X_AU38.rod
       VCID: 72BDDAECB42AE377CF3-8026
       ASAM Dataset: EV_LMSRightHELLAAU58X 001013
       ROD: EV_LMSRightHELLAAU58X_AU38.rod
    Address DB: Frt Corner Rdar 1 (J1089)       Labels:* None
       Part No SW: 4N0 907 669 F    HW: 4N0 907 669 A
       Component: MRR_VR H12 0266
       Coding: 003000
       ASAM Dataset: EV_FrontCorneRadarS1AU651 001018
       ROD: EV_FrontCorneRadarS1AU651_AU58.rod
    Address DC: Frt Corner Rdar 2 (J1088)       Labels:* None
       Component: MRR_VL H12 0266
       Coding: 003000
       Shop #: WSC 31414 142 00001
       ASAM Dataset: EV_FrontCorneRadarS2AU651 001018
       ROD: EV_FrontCorneRadarS2AU651_AU58.rod
    Address DE: Charger 1 for mobile dev (J1146)       Labels:* 4N0-035-502.clb
       Part No SW: 4N0 035 502 A    HW: 4N0 035 502 A
       Component: WLC Front     H10 0057
       Coding: 400000
       ASAM Dataset: EV_Charg1MobilDevicAU651 004001
       ROD: EV_Charg1MobilDevicAU651.rod
       VCID: 221DEAAC244A33F7FF3-8076
    End----(Elapsed Time: 03:00, VBatt start/end: 11.6V/11.6V. VIgn 11.7V)-----
    Aug 2014
    Where do you get the input from? Looking at the box it doesn't seem to have a special connector for input or or am i something?
    Tartu, Estonia
    Have You looked into ADP of 5F and 57?
    There
    The world is my oyster...
    Jan 2016
    The input is on the connector with the power and ring break - have checked adaptations of both 57 and 5F and there is nothing remotely like AV in. As said if I connect an AV source to the TV it shows input active on TV measuring blocks
    Aug 2014
    Quote Originally Posted by Mike_Jones View Post
    What pins are used for input? Just curious about it because it would be cool to try on other VW modules ...
