Results 1 to 4 of 4
Thread: Car auto transmission
    Jan 2020
    Israel
    hello all
    i have a skoda octavia 2011
    this car was using auto transmission and now its using manual, but im not sure if the ecu knows its using manual
    how can i check what transmission the ecu know and if still using automatic how to make it manual
    here the auto scan of the car
    Sunday,16,February,2020,09:01:28:04619
    VIN: TMBCT61Z4B2159759   License Plate:
    Chassis Type: 1Z-SK35 (7N0)
    VIN: TMBCT61Z4B2159759   Mileage: 172830km-107391miles
    15-Airbags -- Status: Not registered 0011
    16-Steering wheel -- Status: Malfunction 1010
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 LP    HW: 03L 906 023 JH
       Component: 1,6l R4 CR td H43 8810
       Revision: --H43---    Serial number:
       Coding: 00114016032400080000
       Shop #: WSC 73430 031 00066
       ASAM Dataset: EV_ECM16TDI02103L906023LP 003005
       ROD: EV_ECM16TDI02103L997557A.rod
       VCID: 7F5B05C7977C5C4FB0F-802A
    Readiness: 1110 1000
       Part No SW: 1K0 907 379 BD    HW: 1K0 907 379 BD
       Revision: 00H31001
       Coding: 113B201C09270003881204E990220041300000
       Shop #: WSC 73430 790 00066
       VCID: 75B7E7EFA5C0161FEA3-8020
       Part No SW: 3T0 907 044 BD    HW: 3T0 907 044 BD
       Component: Climatronic   H16 0402
       Revision: 00006001
       Coding: 0000000002
       ROD: EV_ClimaAutoBasis_SK35.rod
       VCID: 75B7E7EFA540161FEA3-8020
    9481748 - High Pressure Sensor
              B10AE 14 [009] - Open or Short to Ground
                        Reset counter: 195
                        Mileage: 172839 km
                        Date: 2020.02.16
                        Time: 17:03:17
       Part No SW: 1K0 937 087 J    HW: 1K0 937 087 J
       Component: BCM PQ35  H   103 0615
       Revision: 00103 AE
       Coding: 40000AB8A00508C040100080110001E4430000AE520081605C8440000040
       VCID: 38292EDBF252AB77315-806C
       Subsystem 1 - Part No: 1Z1 955 119 D  Labels: 1KX-955-119.CLB
       Component: Wischer 21041  26  0601
       Coding: 00D7B7
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 195
                        Mileage: 172839 km
                        Date: 2014.07.09
                        Time: 17:03:33
                            Term 15 On
                        Voltage: 12.30 V
                            Term 50 Off
                        Reset counter: 195
                        Mileage: 172839 km
                        Date: 2014.07.09
                        Time: 17:03:33
                            Term 15 On
                        Voltage: 12.30 V
                            Term 50 Off
       Component: Q6 AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PC2549J1
       Coding: 0020790
       VCID: 3D273FCFD1708E5FE23-8068
       Subsystem 1 - Serial number: 6332MSME5F103220%
       Subsystem 2 - Serial number: 6342MSME5F04504EJ
       Subsystem 3 - Serial number: 6351HSME2701413E%
       Subsystem 4 - Serial number: 6361HSME2701504B+
    00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
    00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
       Part No SW: 1K5 953 521 AG    HW: 5K0 953 569
       Revision: FF010040    Serial number: 20110426201382
       Coding: 4080140000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 72BDDCF3D42E0127CF1-8026
    226839 - Turn Signal Switch
              B1144 11 [009] - Short to Ground
                        Reset counter: 195
                        Mileage: 172839 km
                        Date: 2020.02.16
                        Time: 17:03:58
       Part No SW: 1Z0 920 803 M    HW: 1Z0 920 803 M
       Component: KOMBI         H05 0405
       Coding: 110800
       ROD: EV_Kombi_UDS_VDD_RM09_004_SK34.rod
       VCID: 3E2538C3D0F69547FB9-806A
    9453841 - Oil Level Thermal Sensor
              B1041 33 [009] - Signal low time > maximum
                        Fault Frequency: 9
                        Reset counter: 195
                        Mileage: 172559 km
                        Date: 2020.02.11
                        Time: 21:52:33
    9453842 - Oil Level Thermal Sensor
              B1041 35 [008] - Signal high time > maximum
                        Fault Frequency: 9
                        Reset counter: 235
                        Mileage: 172559 km
                        Date: 2020.02.11
                        Time: 21:39:51
    12718592 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Steuergerät für Lenksäulenelektronik: keine Kommunikation]
                        Reset counter: 229
                        Mileage: 172559 km
                        Date: 2020.02.11
                        Time: 23:45:40
       Part No SW: 7N0 907 530 C    HW: 1K0 907 951
       Component: J533  Gateway H37 0614
       Revision:   H37       Serial number: 250411F1002226
       Coding: 351302
       Shop #: WSC 73430 444 00550
       VCID: 303916FB1A227337795-8064
                        Fault Status: 01101011
                        Fault Frequency: 57
                        Reset counter: 195
                        Mileage: 172559 km
                        Date: 2014.07.04
                        Time: 21:31:06
                        Fault Status: 00110100
                        Reset counter: 229
                        Mileage: 172559 km
                        Date: 2014.07.04
                        Time: 23:45:40
                        Fault Frequency: 107
                        Mileage: 172559 km
                        Date: 2014.07.04
                        Time: 21:31:05
       Component: IMMO          H05 0405
       VCID: 6A8DC493FCFEC9E7771-803E
       Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
       Coding: 0000244
       VCID: 48C95E1B8EB2DBF7415-801C
       Part No: 1K0 909 144 H
       Component: EPS_ZFLS Kl. 69     2901
       Revision: 00H17000
       Shop #: WSC 73430 790 00000
       VCID: 2F3B15870B1C6CCF60F-807A
       Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
       Coding: 0000244
       VCID: 47CB5D2783ACD48F48F-8012
       Part No SW: 1Z0 035 161 F    HW: 1Z0 035 161 F
       Component: SWING         009 0065
       Revision: 0I001001    Serial number: SKZ1Z2L9051551
       Coding: 050004000001
       VCID: 313F13FF11287A3F76B-8064
    03138 - Input AUX IN
                        Reset counter: 189
                        Mileage: 172559 km
                        Date: 2014.07.04
                        Time: 21:15:55
       Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
       Coding: 0000144
       Shop #: WSC 73430 790 1012546
       VCID: 323D1CF3182E41270F1-8066
       Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
       Coding: 0000144
       VCID: 333319F7E734482F047-8066
    End----------(Elapsed Time: 00:51, VBatt start/end: 12.3V/12.3V)-----------
    The microfiche and take this to retrofit area.
    Get a subscription to partslink24 and research it.
    Quote Originally Posted by khaledabdulaziz View Post
    If the ECU thought there should be an Automatic transmission in this car, I would expect to see "missing messages" and/or "incorrectly coded" fault codes. Since you have neither of these, I think it is OK.
    PS: Moved to Retrofits.
    Jan 2020
    Israel
    Thanks a lot
