Results 1 to 7 of 7
Thread: Audi Q3 TDI 2013 Haldex deactivation
    Dec 2015
    Poland
    Hi.
    To verify source of vibration I would need to deactivate haldex coupling. Despite information in wiring diagrams there is no fuse (no 10) present in the car that may be taken out for this purpose.
    I have found in BASIC SETTINGS of haldex : " open 4motion coupling for ignition cycle" .
    Could someone explain if this will disconnect haldex for one ignition ?
    Is there another way to deactivate it temporary without a risk of damaging?
    thank you
    Got an Auto-Scan or a link to one previously posted?
    Dec 2015
    Poland
    Here it is. Thanks.
    Saturday,15,February,2020,15:16:46:29837
    VCDS Version: 19.6.2.0 (x64)
    VIN: WAUZZZ8U0ER047795   License Plate:
    Mileage: 134830km-83779mi   Repair Order:
    Chassis Type: 8U-AU21 (8U0)
    Scan: 01 03 08 09 10 15 16 17 19 20 22 25 42 44 46 52 53 55 5F 62
              6C 72
    VIN: WAUZZZ8U0ER047795   Mileage: 134830km-83779miles
       Part No SW: 03L 906 018 CM    HW: 03L 906 018 ES
       Component: R4 2.0l TDI   H28 9980
       Revision: 41H28---    Serial number:
       Coding: 00190012042601080000
       Shop #: WSC 67593 771 32928
       ASAM Dataset: EV_ECM20TDI01103L906018CM 003008
       ROD: EV_ECM20TDI01103L906018CM.rod
       VCID: 77FDBAB4CEB9C9F796-8022
    Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
       Part No SW: 5N0 614 109 AS    HW: 5N0 614 109 AS
       Component: J104   C6 450M V463 0150
       Revision: --H07---    Serial number: 00000007589134
       Coding: 0050823
       Shop #: WSC 00049 770 00153
       VCID: 7CF7A5983F9FEAAFFB-8028
       Part No SW: 8U0 820 043 C    HW: 8U0 820 043 C
       Component: E87  Klimavoll      0020
       Revision: 00H03000    Serial number: 8U0820043C
       VCID: 316944ACA85DD7C718-8064
    Address 09: Cent. Elect. (J519)       Labels:. 8X0-907-063.clb
       Part No SW: 8X0 907 063 N    HW: 8X0 907 063 N
       Component: BCM PQ35  M   112 0771
       Revision: AG112771
       Coding: 06000A2CE807F3C0201841C82100894C57FF84AA212F912BE4088E8400C5
       Shop #: WSC 00049 770 00010
       VCID: 479D0A74F6D9797726-8012
       Subsystem 1 - Part No SW: 8U1 955 119     HW: 8U1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS316 131026  H36 0085
       Serial number:         131028135332
       Coding: 0047F7
       Serial number: 21934329
       Coding: 02006E
       Subsystem 3 - Part No: 8X0 951 177
       Component: DWA-Sensor H0  H01 0020
    Address 10: Park/Steer Assist (J446)       Labels:| 8X0-919-475.clb
       Part No SW: 8X0 919 475 AD    HW: 4H0 919 475 AG
       Component: PARKHILFE 8K  H01 0070
       Revision: 11001001    Serial number: 61031414701923
       Coding: 280004
       Shop #: WSC 60003 129 28888
       ASAM Dataset: EV_EPHVA18AU21X0000 003008
       ROD: EV_EPHVA18AU21X0000_003.rod
       VCID: 081FC948B347B60FEF-805C
    Address 15: Airbags (J234)       Labels:| 8X0-959-655.clb
       Part No SW: 8U0 959 655 B    HW: 8U0 959 655 B
       Component: AirbagVW-AU10 H08 0520
       Serial number: 003LRR06EHVH
       Coding: 30353132313030303030554A304C38553053
       Shop #: WSC 00049 770 00119
       ASAM Dataset: EV_AirbaAU10SMEAU316 001005
       ROD: EV_AirbaAU10SMEAU316_001.rod
       VCID: 46830770F9D3607FDD-8012
       Subsystem 1 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
       Serial number: 3496KSME41504C29ZZZX
       Subsystem 2 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
       Serial number: 3506KSME040A5029ZZZI
       Serial number: 3516KSME3D104F29ZZZ-
       Serial number: 3526KSME41285029ZZZL
       Subsystem 5 - Part No SW: 8U0 959 651     HW: 8U0 959 651
       Serial number: 3555USME10613226ZZZN
    Address 16: Steering wheel (J527)       Labels:| 8X0-953-569.clb
       Part No SW: 8X0 953 501 B    HW: 5K0 953 569 AL
       Revision: FF010018    Serial number: 20131114200053
       Coding: 1184204000
       VCID: 39797C8CB82D1F87A0-806C
       Subsystem 1 - Part No SW: 8U0 951 528 G    HW: 8U0 951 528 G
    Address 17: Instruments (J285)       Labels:| 8X0-920-xxx-17.clb-SRI1
       Part No SW: 8U0 920 940 E    HW: 8U0 920 940 E
       Component: KOMBI_COLOUR  H01 0230
       Coding: 12CF00
       ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
       VCID: 3A7B6380BD2B149FA9-806E
    Address 19: CAN Gateway (J533)       Labels: 8X0-907-468.clb
       Part No SW: 8U0 907 468 Q    HW: 8U0 907 468 G
       Component: GAT 4CAN 1L M H13 0063
       Revision: 1P120037    Serial number: 3741P13A2202AB
       Coding: FBCF1A5A000100610253
       VCID: 50AF21280397BECF77-8004
       Component: J367-BDM  H07 0180
       Serial number: 30317F01391490503345
       Serial number: 13304000081011200181
       Part No SW: 8U0 857 511 B    HW: 8U0 857 511 B
       Component: FLA           H03 0012
       Revision: AA002001
       Coding: 02010A64747464545425363E00
       Shop #: WSC 00049 770 00157
       VCID: 3A7B6380B52B149FA9-806E
       Part No SW: 0AY 907 554 F    HW: 0AY 907 554 F
       Component: Haldex4Motion H52 7521
       Serial number: HA1-00021.09.13
       Coding: 0001
       VCID: 4E933F5011A3A83F65-801A
       Component: IMMO          H01 0230
       Coding: 000002
       ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04113
       ROD: EV_Immo_UDS_VDD_AU10.rod
    Address 42: Door Elect, Driver (J386)       Labels:. 8X0-959-793.clb
       Part No SW: 8X0 959 793 H    HW: 8X0 959 793 H
       Component: TSG FA        H10 0415
       Coding: 011E02205000000000
       Shop #: WSC 00049 770 00202
       VCID: 52AB2B200D9BCCDF41-8006
       Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
       Component: J500__APA-BS KL.374 1401
       Revision: 1BH04841    Serial number: 00132860007401
       Coding: 0000258
       VCID: 4189146C18FD4747E8-8014
    Address 52: Door Elect, Pass. (J387)       Labels:. 8X0-959-792.clb
       Part No SW: 8X0 959 792 H    HW: 8X0 959 792 H
       Component: TSG BF        H10 0415
       VCID: 51A9242C089DB7C778-8004
       Revision:   H19       Serial number: 00000001582312
       Coding: 0025167
       VCID: 366377B04133F0FF4D-8062
       Serial number: 131106-0002-014
       Coding: 1157A41010022500
       ROD: EV_HeadlRegulBasic.rod
       VCID: 428B1B60D5FB5C5FF1-8016
       Part No SW: 8U0 035 193 C    HW: 8U0 035 193 A
       Component: RMC Cnct Nav  H54 0801
       Coding: 01000600028157070823020103010000000000
       VCID: 356170BC9C35FBE744-8060
       Subsystem 1 - Part No: 8X0 919 884 H
       Component: P28-50-14.06  0001
       Subsystem 2 - Part No SW: 8U0 919 603     HW: 8U0 919 603
       Component: DUBasic AU316  H41 0018
       Serial number: AUZ8ZDD0604QPPF
    Nov 2014
    New Zealand
    Perhaps you already know this, but for clarity:
    Deactivating it doesn't disconnect it - the drive shaft from the front to the rear will still be driven by the front diff, and the rear diff and output side of the haldex will still be driven by the rear wheels, so basically the whole system will still spin as usual, it just won't have a coupling ability of when its activated.
    Unplugging the entire unit, or the oil pump will deactivate it about as good as you'll get.
    Allan
    The R32ran Thread
    How to post a full Auto-Scan
  5. Likes Uwe liked this post
    Dec 2015
    Poland
    Thank you. You're right but I have a vibration on hard acceleration on 5th and 6th gear from 2000 to 2500 rpm. It looks more power is being sent to the rear then as haldex measuring blocks show increased values (amp, voltage, PWM). I'd like to verify if it's the same with power only at front.
    Is it safe to run the car with haldex unplugged? Normally with haldex 5 10% power is being constantly sent to the rear...
    Will starting basic setting "open 4motion coupling for ignition cycle" disconnect coupling? When should it be started, with the engine running or stopped? I don't have possibility to reach plugs under the car. Thanks.
    Dec 2015
    Poland
    Anybody may help?
    Feb 2020
    New Zealand
    At my work we would normally remove the prop shaft and road test - also enables to have a feel of the universal joints on the shaft which we have found is often the cause
  9. Likes NZDubNurd, Uwe liked this post
