Audi Q3 TDI 2013 Haldex deactivation
gienol
C?ID=253640
Hi.
To verify source of vibration I would need to deactivate haldex coupling. Despite information in wiring diagrams there is no fuse (no 10) present in the car that may be taken out for this purpose.
I have found in BASIC SETTINGS of haldex : " open 4motion coupling for ignition cycle" .
Could someone explain if this will disconnect haldex for one ignition ?
Is there another way to deactivate it temporary without a risk of damaging?
thank you
Got an Auto-Scan or a link to one previously posted?
gienol
C?ID=253640
Here it is. Thanks.
Saturday,15,February,2020,15:16:46:29837
VCDS Version: 19.6.2.0 (x64)
VIN: WAUZZZ8U0ER047795   License Plate:
Mileage: 134830km-83779mi   Repair Order:
Chassis Type: 8U-AU21 (8U0)
Scan: 01 03 08 09 10 15 16 17 19 20 22 25 42 44 46 52 53 55 5F 62
          6C 72
VIN: WAUZZZ8U0ER047795   Mileage: 134830km-83779miles
   Part No SW: 03L 906 018 CM    HW: 03L 906 018 ES
   Component: R4 2.0l TDI   H28 9980
   Revision: 41H28---    Serial number:
   Coding: 00190012042601080000
   Shop #: WSC 67593 771 32928
   ASAM Dataset: EV_ECM20TDI01103L906018CM 003008
   ROD: EV_ECM20TDI01103L906018CM.rod
   VCID: 77FDBAB4CEB9C9F796-8022
Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
   Part No SW: 5N0 614 109 AS    HW: 5N0 614 109 AS
   Component: J104   C6 450M V463 0150
   Revision: --H07---    Serial number: 00000007589134
   Coding: 0050823
   Shop #: WSC 00049 770 00153
   VCID: 7CF7A5983F9FEAAFFB-8028
   Part No SW: 8U0 820 043 C    HW: 8U0 820 043 C
   Component: E87  Klimavoll      0020
   Revision: 00H03000    Serial number: 8U0820043C
   VCID: 316944ACA85DD7C718-8064
Address 09: Cent. Elect. (J519)       Labels:. 8X0-907-063.clb
   Part No SW: 8X0 907 063 N    HW: 8X0 907 063 N
   Component: BCM PQ35  M   112 0771
   Revision: AG112771
   Coding: 06000A2CE807F3C0201841C82100894C57FF84AA212F912BE4088E8400C5
   Shop #: WSC 00049 770 00010
   VCID: 479D0A74F6D9797726-8012
   Subsystem 1 - Part No SW: 8U1 955 119     HW: 8U1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS316 131026  H36 0085
   Serial number:         131028135332
   Coding: 0047F7
   Serial number: 21934329
   Coding: 02006E
   Subsystem 3 - Part No: 8X0 951 177
   Component: DWA-Sensor H0  H01 0020
Address 10: Park/Steer Assist (J446)       Labels:| 8X0-919-475.clb
   Part No SW: 8X0 919 475 AD    HW: 4H0 919 475 AG
   Component: PARKHILFE 8K  H01 0070
   Revision: 11001001    Serial number: 61031414701923
   Coding: 280004
   Shop #: WSC 60003 129 28888
   ASAM Dataset: EV_EPHVA18AU21X0000 003008
   ROD: EV_EPHVA18AU21X0000_003.rod
   VCID: 081FC948B347B60FEF-805C
Address 15: Airbags (J234)       Labels:| 8X0-959-655.clb
   Part No SW: 8U0 959 655 B    HW: 8U0 959 655 B
   Component: AirbagVW-AU10 H08 0520
   Serial number: 003LRR06EHVH
   Coding: 30353132313030303030554A304C38553053
   Shop #: WSC 00049 770 00119
   ASAM Dataset: EV_AirbaAU10SMEAU316 001005
   ROD: EV_AirbaAU10SMEAU316_001.rod
   VCID: 46830770F9D3607FDD-8012
   Subsystem 1 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3496KSME41504C29ZZZX
   Subsystem 2 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3506KSME040A5029ZZZI
   Subsystem 3 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3516KSME3D104F29ZZZ-
   Serial number: 3526KSME41285029ZZZL
   Subsystem 5 - Part No SW: 8U0 959 651     HW: 8U0 959 651
   Serial number: 3555USME10613226ZZZN
Address 16: Steering wheel (J527)       Labels:| 8X0-953-569.clb
   Part No SW: 8X0 953 501 B    HW: 5K0 953 569 AL
   Revision: FF010018    Serial number: 20131114200053
   Coding: 1184204000
   VCID: 39797C8CB82D1F87A0-806C
   Subsystem 1 - Part No SW: 8U0 951 528 G    HW: 8U0 951 528 G
Address 17: Instruments (J285)       Labels:| 8X0-920-xxx-17.clb-SRI1
   Part No SW: 8U0 920 940 E    HW: 8U0 920 940 E
   Component: KOMBI_COLOUR  H01 0230
   Coding: 12CF00
   VCID: 3A7B6380BD2B149FA9-806E
Address 19: CAN Gateway (J533)       Labels: 8X0-907-468.clb
   Part No SW: 8U0 907 468 Q    HW: 8U0 907 468 G
   Component: GAT 4CAN 1L M H13 0063
   Revision: 1P120037    Serial number: 3741P13A2202AB
   Coding: FBCF1A5A000100610253
   VCID: 50AF21280397BECF77-8004
   Component: J367-BDM  H07 0180
   Serial number: 30317F01391490503345
   Serial number: 13304000081011200181
   Part No SW: 8U0 857 511 B    HW: 8U0 857 511 B
   Component: FLA           H03 0012
   Revision: AA002001
   Coding: 02010A64747464545425363E00
   Shop #: WSC 00049 770 00157
   VCID: 3A7B6380B52B149FA9-806E
   Part No SW: 0AY 907 554 F    HW: 0AY 907 554 F
   Component: Haldex4Motion H52 7521
   Serial number: HA1-00021.09.13
   Coding: 0001
   VCID: 4E933F5011A3A83F65-801A
   Component: IMMO          H01 0230
   Coding: 000002
   ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386)       Labels:. 8X0-959-793.clb
   Part No SW: 8X0 959 793 H    HW: 8X0 959 793 H
   Component: TSG FA        H10 0415
   Coding: 011E02205000000000
   Shop #: WSC 00049 770 00202
   VCID: 52AB2B200D9BCCDF41-8006
   Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.374 1401
   Revision: 1BH04841    Serial number: 00132860007401
   Coding: 0000258
   VCID: 4189146C18FD4747E8-8014
Address 52: Door Elect, Pass. (J387)       Labels:. 8X0-959-792.clb
   Part No SW: 8X0 959 792 H    HW: 8X0 959 792 H
   Component: TSG BF        H10 0415
   VCID: 51A9242C089DB7C778-8004
   Part No SW: 3AA 907 801 H    HW: 3AA 907 801 H
   Component: J540 EPB4  VW-86594 0010
   Revision:   H19       Serial number: 00000001582312
   Coding: 0025167
   VCID: 366377B04133F0FF4D-8062
   Part No SW: 8X0 907 357 C    HW: 8X0 907 357 B
   Serial number: 131106-0002-014
   Coding: 1157A41010022500
   ROD: EV_HeadlRegulBasic.rod
   VCID: 428B1B60D5FB5C5FF1-8016
   Part No SW: 8U0 035 193 C    HW: 8U0 035 193 A
   Component: RMC Cnct Nav  H54 0801
   Coding: 01000600028157070823020103010000000000
   VCID: 356170BC9C35FBE744-8060
   Subsystem 1 - Part No: 8X0 919 884 H
   Component: P28-50-14.06  0001
   Subsystem 2 - Part No SW: 8U0 919 603     HW: 8U0 919 603
   Component: DUBasic AU316  H41 0018
   Serial number: AUZ8ZDD0604QPPF
NZDubNurd
New Zealand
C?ID=230482
Perhaps you already know this, but for clarity:
Deactivating it doesn't disconnect it - the drive shaft from the front to the rear will still be driven by the front diff, and the rear diff and output side of the haldex will still be driven by the rear wheels, so basically the whole system will still spin as usual, it just won't have a coupling ability of when its activated.
Unplugging the entire unit, or the oil pump will deactivate it about as good as you'll get.
gienol
C?ID=253640
Thank you. You're right but I have a vibration on hard acceleration on 5th and 6th gear from 2000 to 2500 rpm. It looks more power is being sent to the rear then as haldex measuring blocks show increased values (amp, voltage, PWM). I'd like to verify if it's the same with power only at front.
Is it safe to run the car with haldex unplugged? Normally with haldex 5 10% power is being constantly sent to the rear...
Will starting basic setting "open 4motion coupling for ignition cycle" disconnect coupling? When should it be started, with the engine running or stopped? I don't have possibility to reach plugs under the car. Thanks.
gienol
C?ID=253640
Anybody may help?
Rollux
New Zealand
C?ID=380572
At my work we would normally remove the prop shaft and road test - also enables to have a feel of the universal joints on the shaft which we have found is often the cause
