Results 1 to 4 of 4
Thread: Dpf regeneration
    Jan 2020
    Israel
    Dpf regeneration
    So I read about dpf regeneration (cleaning) on wiki.ross-tech
    And I read this sentence
    *Particle Filter Load below Specification (see MVB 108.2/3 -or- 241.2/3 VCDS should give the specified values)*
    But some cars using uds protocol has no meas.blocks and I have to use advance measure block but I don't know which boxes I have to check to see load specs
    Is it soot measure and soot calculated?
    Oct 2014
    Arandjelovac, Serbia
    Please activate account https://diagnostics.vis4vag.com/ and see procedure.
    Best regards,
    Boyan
    Jan 2020
    Israel
    i checked the procedure but sadly i didnt find the values in adv measurements
    Quote Originally Posted by khaledabdulaziz View Post
    Please post an Auto-Scan from a car you have this question about so we can look to see what measuring values are available in that specific ECU.
