Results 1 to 10 of 13
Thread: ABS coding lost
    Jan 2020
    Israel
    ABS coding lost
    Hi
    so i done resetting all adaptation values on MK100 abs and i lost its coding
    here the autoscan
    plz help
    Saturday,15,February,2020,12:20:20:04619
    VIN: TMBAG7NE9D0019598   License Plate:
    Chassis Type: NE-SK37 (5Q0)
    Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
    VIN: TMBAG7NE9D0019598   Mileage: 335139km-208245miles
       Part No SW: 04L 906 021 N    HW: 04L 907 309 B
       Component: R4 1,6L EDC   H22 4946
       Revision: 84H22---
       Coding: 01250012032401090000
       Shop #: WSC 73430 031 00207
       ASAM Dataset: EV_ECM16TDI01104L906021N 002007
       ROD: EV_ECM16TDI01104L906021N_002.rod
       VCID: 303916FB1AA27337797-8064
    8 Faults Found:
    5188 - Diesel Particle Filter
              P2463 00 [175] - Excessive Soot Accumulation
                        Mileage: 334948 km
                        Date: 2020.01.26
                        Time: 13:20:23
                        Engine speed: 769.00 /min
                        Normed load value: 20.8 %
                        Coolant temperature: 90 C
                        Intake air temperature: 66 C
                        Voltage terminal 30: 13.240 V
                        Counter for regeneration time of diesel particle filter: 0.00 s
                        Particle filter: kilometers since last regeneration: 1983741 m
                        Particle filter: soot mass measured: 9.59 g
                        Particle filter: soot mass calculated: 50.00 g
                        Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: 1 hPa
    4814 - System Voltage
              P0562 00 [032] - Too Low
                        Mileage: 335057 km
                        Date: 2020.01.27
                        Time: 02:12:19
                        Engine speed: 74.00 /min
                        Coolant temperature: 66 C
                        Intake air temperature: 61 C
                        Voltage terminal 30: 5.480 V
                        Unlearning counter according OBD: 36
                        Limitation: torque: 9.6 Nm
                        Limitation: accelerator pedal: 97.5 Nm
                        Cruise Control System (CCS): status-Bits 0-7: 0
                        Accelerator pedal travel: raw value: 0.00 %
                        Engine torque: 120.0 Nm
                        Generator: load signal: 0.02 %
    5250 - Function Restriction due to Faults in Other Modules
              U1113 00 [032] - -
                        Mileage: 335139 km
                        Date: 2020.01.27
                        Time: 21:59:11
                        Engine speed: 766.00 /min
                        Normed load value: 20.4 %
                        Coolant temperature: 94 C
                        Intake air temperature: 72 C
                        Voltage terminal 30: 13.160 V
                        Longitudinal acceleration: raw value: 32.767 m/s
                        Vehicle inclination acceleration angle: raw value: 0.000 m/s
                        Status: incline angle-Bits 0-7: 1
                        Longitudinal acceleration: 0.107 m/s
                        Longitudinal acceleration sensor: status-Bits 0-7: 1
                        Vehicle lateral acceleration: raw value: -0.01 g
                        Vehicle lateral acceleration: 0.00 g
    20557 - Heater support pump
              P16C7 00 [175] - locked
                        Fault Frequency: 47
                        Mileage: 334948 km
                        Date: 2020.01.26
                        Time: 13:20:28
                        Engine speed: 769.50 /min
                        Voltage terminal 30: 13.200 V
                        Heater support pump 1 bank 1 second.circuit: activat.: 95.00 %
                        Extern.temp.sens.1 bank 1: raw value: 23.0 C
                        Shut-off timer: last engine shut-off time: 3 s
    5608 - No Communications with Steering Angle Sender (G85)
              U0126 00 [032] - -
                        Mileage: 335139 km
                        Date: 2020.01.27
                        Time: 21:41:38
                        Normed load value: 20.0 %
                        Coolant temperature: 84 C
                        Intake air temperature: 62 C
                        selected gear-Bits 0-7: 0
              U0428 00 [047] - -
                        Mileage: 334948 km
                        Date: 2020.01.26
                        Time: 13:20:23
                        Voltage terminal 30: 13.180 V
    17158 - Databus
              U1123 00 [047] - Received Error Message
                        Mileage: 334948 km
                        Date: 2020.01.26
                        Time: 13:20:22
                        Engine speed: 771.50 /min
                        Drivetrain coordinator: brake fault status-Bits 0-7: 4
                        Drivetrain coordinator: brake function status-Bits 0-7: 0
                        Acceleration: 0.000 m/s
    5571 - ROD - Unknown Error Code
              - 00 [101]
                        Mileage: 335058 km
                        Date: 2020.01.27
                        Time: 02:21:15
                        Coolant temperature: 63 C
                        Intake air temperature: 55 C
                        Voltage terminal 30: 9.780 V
                        Air mass: specified value: 250.0 mg/stroke
                        Coolant temp. sensor 1 bank 1 at cylinder head: raw value: 2222.0 C
                        Heat delivery temperature in cooling system: -273.1 C
                        Extern.temp.sens.1 bank 1: raw value: 13.0 C
                        Coolant fan 2: activation: 0.00 %
                        Coolant fan 1: activation: 10.00 %
                        Fuel temp. sensor 1 bank 1: raw value: 36.8 C
    Readiness: 1 2 0 0 1
       Part No SW: 0CW 300 047 R    HW: 0AM 927 769 G
       Component: GSG DQ200-MQB H43 5210
       Revision: 00043014    Serial number: CU501411085892
       Shop #: WSC 04940 001 00001
       ROD: EV_TCMDQ200021_VW31.rod
       VCID: 4ACD64139C3E29E7573-801E
    21223 - No Communications with Power Steering Control Module
              U0131 00 [008] - -
                        Mileage: 335139 km
                        Date: 2020.01.27
                        Time: 21:41:38
                        Engine speed: 6.25 /min
                        Engine torque: -100 Nm
                        Vehicle speed: 77 km/h
                        Control Module temperature: 65 C
                        CURRENT pressure: -9.5 bar
                        selected gear: GANG_4
                        Driving position: N
                        Accelerator position: 0.4 %
                        DTC memory status: 9216
       Part No SW: 5Q0 907 379 A    HW: 5Q0 907 379 A
       Component: ESC           H75 0333
       Coding: 0000000000000000000000000000000000000000000000000000000000
       Shop #: WSC 73430 031 00063
       ASAM Dataset: EV_Brake1UDSContiMK100ESP 008020
       ROD: EV_Brake1UDSContiMK100ESP_008_SK37.rod
       VCID: 3A2D34D3CCDEB967C73-806E
    7 Faults Found:
    0195 - Control module not coded
              U1013 00 [137] - -
              [ECU marked as Not Configured because vehicle ID is invalid]
                        Reset counter: 6
                        Mileage: 335139 km
                        Date: 2020.01.27
                        Time: 22:46:58
    0279 - Brake Pressure Sensor 1
              C107A 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 6
                        Mileage: 335139 km
                        Date: 2020.01.27
                        Time: 22:46:58
    0295 - Steering angle sensor
                        Reset counter: 6
                        Mileage: 335139 km
                        Date: 2020.01.27
                        Time: 22:46:58
    8269 - Databus
              [FCAN: VIN_01 message is received with invalid length]
                        Reset counter: 46
                        Mileage: 335139 km
                        Date: 2020.01.27
                        Time: 22:47:03
    8290 - Coding Not Possible
              U10BC 00 [008] - -
              [FCAN: Unplausible VIN number]
                        Reset counter: 6
                        Mileage: 335139 km
                        Date: 2020.01.27
                        Time: 22:47:56
    8306 - Databus
                        Reset counter: 6
                        Mileage: 335139 km
                        Date: 2020.01.27
                        Time: 22:47:56
    8308 - Control Module Incorrectly Coded
              U1014 00 [009] - -
              [FCAN: StartStop not coded but MO_StartStopp_Status not equal 0]
                        Reset counter: 6
                        Mileage: 335139 km
                        Date: 2020.01.27
                        Time: 22:46:58
       Part No SW: 5E0 907 044     HW: 5E0 907 044
       Component: Climatronic   H02 0604
       Revision: 00001K06
       Coding: 00010104000100011005000000100000
       ROD: EV_ACClimaBHBVW37X_002_VW37.rod
       VCID: 629DACB304CE91A7BF3-8036
    263425 - Air Quality Sensor
              B10AF 04 [008] - Internal System Fault
                        Fault Frequency: 101
                        Reset counter: 44
                        Mileage: 333155 km
                        Date: 2020.01.10
                        Time: 03:02:35
              B10CD 00 [008] - -
                        Reset counter: 41
                        Mileage: 335058 km
                        Date: 2020.01.27
                        Time: 02:27:10
       Part No SW: 5Q0 937 084 N    HW: 5Q0 937 084 N
       Component: BCM MQBAB M   H14 0106
       Serial number: 00011306600594
       Coding: 0C001842424702FB07A04000000407080000000000000000000000000000
       Shop #: WSC 73430 790 00207
       ROD: EV_BCMBOSCH_010.rod
       VCID: 43D34937BB14F8AF945-8016
       Subsystem 1 - Part No SW: 5E1 955 119     HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS371 130302  041 0570
       Serial number:         130307002938
       Coding: 065DDD
       Component: RLFS  024 0042
       Serial number: Y13M03D16H21M00S00S4
       Coding: 02805D
    8 Faults Found:
    9482 - Statiionary Cornering Lamp Right
              B1222 15 [009] - Open or Short to Plus
                        Reset counter: 191
                        Mileage: 333165 km
                        Date: 2020.01.10
                        Time: 04:59:15
    10515 - Bulb for Left Tail Light
              B12BE 01 [008] - Electrical Failure
                        Fault Frequency: 17
                        Reset counter: 32
                        Mileage: 333239 km
                        Date: 2020.01.11
                        Time: 03:15:05
    11786 - Bulb for Rear Left Fog Light
              B12C7 15 [009] - Open or Short to Plus
                        Reset counter: 191
                        Mileage: 333155 km
                        Date: 2020.01.10
                        Time: 03:04:53
    12298 - License Plate Light
              B12CA 15 [009] - Open or Short to Plus
                        Reset counter: 191
                        Mileage: 333155 km
                        Date: 2020.01.10
                        Time: 03:04:53
    12554 - Bulb for Left Back-up Light
              B12CB 15 [009] - Open or Short to Plus
                        Reset counter: 191
                        Mileage: 333155 km
                        Date: 2020.01.10
                        Time: 03:10:13
    204546 - Remote key 2
              B147A 18 [008] - Current Too Low
                        Reset counter: 36
                        Mileage: 334788 km
                        Date: 2020.01.25
                        Time: 09:28:28
    539925 - Databus
              [Kombi_02 Datenbus fehlende Botschaft]
                        Reset counter: 43
                        Mileage: 333250 km
                        Date: 2020.01.11
                        Time: 09:26:51
    555285 - Databus
              [LWI_01_alt aktiv]
                        Reset counter: 46
                        Mileage: 335139 km
                        Date: 2020.01.27
                        Time: 21:41:38
       Part No SW: 5Q0 919 283 A    HW: 5Q0 919 283
       Component: PARKHILFE 4K  009 0026
       Revision: --------    Serial number: 60831306500776
       Coding: 0001050011
       ASAM Dataset: EV_EPHVA14AU3700000 002015
       VCID: 372B2DE7FFCCA40F38D-8062
    1079060 - Center Rear Left Parking Aid Sensor
              B1077 14 [008] - Open or Short to Ground
                        Reset counter: 191
                        Mileage: 333155 km
                        Date: 2020.01.10
                        Time: 03:10:13
    1079316 - Center Rear Right Parking Aid Sensor
              B1078 14 [008] - Open or Short to Ground
                        Reset counter: 191
                        Mileage: 333155 km
                        Date: 2020.01.10
                        Time: 03:10:13
    13637426 - Databus
                        Reset counter: 6
                        Mileage: 333155 km
                        Date: 2020.01.10
                        Time: 02:58:30
       Part No SW: 3Q0 959 655 AB    HW: 3Q0 959 655 AB
       Component: Airbag VW20   011 0188
       Revision: --------    Serial number: 003P3P53SCBT
       Coding: 98CCC0000C0000005C5400CC000800000065
       ROD: EV_AirbaVW20TS6VW48X.rod
       VCID: 7EA5F8C390765547BBB-802A
       Subsystem 1 - Part No SW: -----------    HW: 454 000 403 13
       Serial number: 3576U000000BCBF43C0X
       Subsystem 2 - Part No SW: -----------    HW: 454 000 503 13
       Serial number: 3586U00000030D3DBC0L
       Subsystem 3 - Part No SW: -----------    HW: 454 800 503 13
       Serial number: 3516R15A73201000000S
       Subsystem 4 - Part No SW: -----------    HW: 454 800 603 13
       Serial number: 3526RA7372101000000V
       Subsystem 5 - Part No SW: -----------    HW: 454 800 503 13
       Serial number: 3556V43B20E01000000%
       Pedestrian Protection Driver:
       Subsystem 6 - Part No SW: -----------    HW: 454 801 602 13
       Component: PedP_Sensor_D  114 0149
       Serial number: 2286VD822CD00000000D
       Subsystem 7 - Part No SW: -----------    HW: 454 801 502 13
       Component: PedP_Sensor_P  114 0149
       Serial number: 2296VE433CD00000000D
       Pedestrian Protection Center:
       Subsystem 8 - Part No SW: -----------    HW: 454 801 502 13
       Component: PedP_Sensor_C  114 0149
       Serial number: 2306VCD3AF900000000I
              B1000 1B [136] - Resistance Too High
                        Mileage: 334946 km
                        Date: 2020.01.26
                        Time: 12:36:44
    9451547 - Igniter 1 for pedestrian protection
              B1038 1B [137] - Resistance Too High
                        Mileage: 334758 km
                        Date: 2020.01.24
                        Time: 19:59:28
    9451803 - Igniter 2 for pedestrian protection
              B1039 1B [137] - Resistance Too High
                        Mileage: 334758 km
                        Date: 2020.01.24
                        Time: 19:59:28
    1050112 - Databus
              [NWD: 0x086 LWI_01 Timeout]
                        Reset counter: 46
                        Mileage: 335139 km
                        Date: 2020.01.27
                        Time: 21:41:38
    9682162 - Multiple collision brake
              B13BC F2 [137] - No function
                        Mileage: 335139 km
                        Date: 2020.01.27
                        Time: 22:07:15
       Part No SW: 5Q0 953 507 AJ    HW: 5Q0 953 549 A
       Revision: --------    Serial number: 18031304221317
       Coding: 1400
       Part No SW: 5E0 920 860 D    HW: 5E0 920 860 D
       Component: KOMBI         227 0555
       Coding: 07A402082180000801082A00040000
       VCID: 270BFDA72F6C348FA8D-8072
    16776973 - Databus
              [RKA_01 keine Kommunikation]
                        Reset counter: 6
                        Mileage: 335139 km
                        Date: 2020.01.27
                        Time: 21:59:15
       Part No SW: 5Q0 907 530 E    HW: 5Q0 907 530 E
       Component: GW MQB Mid    124 1109
       Revision: --------    Serial number: 0000452288
       Coding: 030100040B087300EF0002481C0F00010001000000000000000000000000
       ASAM Dataset: EV_GatewLear 006010
       ROD: EV_GatewLear_006.rod
       VCID: 333319F7EBB4482F045-8066
       Subsystem 2 - Part No SW: 5E0 919 719 A    HW: 5E0 919 719 A
       Component: E221__MFL-PR6  H04 0100
       Serial number: 000000000A0333270213
       Serial number: 5434670103
    197169 - Controls in Steering Wheel
              U108E 00 [008] - No Communications
              [MFL (LIN#2) Timeout]
                        Reset counter: 41
                        Mileage: 334946 km
                        Date: 2020.01.26
                        Time: 12:35:03
                        Supply voltage: Terminal 30: 12.4 V
                        Terminal 15: OFF
              U1101 00 [008] - Active
                        Reset counter: 28
                        Mileage: 334683 km
                        Date: 2020.01.23
                        Time: 23:29:14
                        Supply voltage: Terminal 30: 11.8 V
                        Terminal 15: On
       Part No SW: 5Q4 959 393     HW: 5Q4 959 393
       Component: TSG FS        007 0006
       Serial number: 0000055770042
       Coding: 001000208000020000001100
       VCID: 55F7876F4580761FCA1-8000
       Component: FOND_FHSG_DRV  005 0004
       Serial number: 00000000000000119081
       Coding: 010200
              B1487 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 42
                        Mileage: 334597 km
                        Date: 2020.01.23
                        Time: 21:13:01
    589833 - Window Regulator Switch; Rear Driver Side
              B1323 29 [009] - Signal Implausible
                        Reset counter: 6
                        Mileage: 333155 km
                        Date: 2020.01.10
                        Time: 02:58:15
       Component: EPS_MQB_ZFLS  126 1063
       Coding: 0002
       Shop #: WSC 73430 790 12345
       VCID: 44D14A2BBE1AFF97ADF-8010
    15873 - Steering angle sensor
                        Reset counter: 6
                        Mileage: 335139 km
                        Date: 2020.01.27
                        Time: 21:43:10
                        Motor status: 01
                        System status: Driving mode
                        Supply voltage: 13.25 V
                        Temperature: 35.0 C
                        KFC: 3E
                        KFA: 00 01
                        Environmental conditions: 5F
                        uioUdNotFilt_xdu16: 13.28 V
                        uAdSensI_SwitchedKl30_xdu16: 13.29 V
    19204 - Databus
              [ESP_02 Botschaft - SNA_Check]
                        Reset counter: 46
                        Mileage: 335139 km
                        Date: 2020.01.27
                        Time: 21:59:11
                        Motor status: 01
                        Supply voltage: 13.00 V
                        Temperature: 34.0 C
                        KFC: 4B
                        KFA: 00 04
                        Environmental conditions: 21
                        uioUdNotFilt_xdu16: 13.41 V
                        uAdSensI_SwitchedKl30_xdu16: 13.41 V
       Part No SW: 5Q4 959 392     HW: 5Q4 959 392
       Component: TSG BFS       007 0006
       Serial number: 0000055311973
       VCID: 7F5B05C7977C5C4FB0D-802A
       Component: FOND_FHSG_PSG  005 0004
       Serial number: 00000000000000133953
       Coding: 190200
              B122D 29 [008] - Signal Implausible
                        Reset counter: 24
                        Mileage: 333380 km
                        Date: 2020.01.12
                        Time: 15:13:36
    589853 - Window regulator motor; front passenger side
              B1322 29 [008] - Signal Implausible
                        Reset counter: 34
                        Mileage: 334780 km
                        Date: 2020.01.24
                        Time: 23:26:53
    Address 5F: Information Electr. (J794)       Labels:| 5E0-035-MIB-ENT1.clb
       Part No SW: 5E0 035 875     HW: 5E0 035 875
       Component: MU-E--ER      164 0141
       Revision: --------    Serial number: 000031094114000
       Coding: 03730100FF00000011110001000000002F0000840000010000
       Shop #: WSC 73430 790 00063
       ASAM Dataset: EV_MUEnt4CCONT 004052
       ROD: EV_MUEnt4CCONT.rod
       VCID: 6695B0A3E8E6ED8753B-8032
    1539 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
              [Function restriction due to insufficient voltage - lower limit value not reached]
                        Reset counter: 41
                        Mileage: 334401 km
                        Date: 2020.01.21
                        Time: 11:53:38
                        Voltage terminal 30: 8.6 V
    7175 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 6
                        Mileage: 335139 km
                        Date: 2020.01.27
                        Time: 22:07:17
                        Voltage terminal 30: 13.1 V
                        BAP-BAP_Function_ID: 02
    7206 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Brake (0x26) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 6
                        Mileage: 335139 km
                        Date: 2020.01.27
                        Time: 22:07:17
              U1101 00 [024] - Active
              [Anti-theft protection - component protection active (0xEA6200)]
              Intermittent - Confirmed - Not Tested Since Memory Clear
                        Reset counter: 28
                        Mileage: 334683 km
                        Date: 2020.01.23
                        Time: 23:29:14
                        Voltage terminal 30: 11.8 V
    End----------(Elapsed Time: 01:09, VBatt start/end: 12.4V/12.4V)-----------
    Oct 2014
    Arandjelovac, Serbia
    Lightbulb
    Based on VIS:
    1A07629120210A75007C060901CB245846045000608024F00048000040
    Please next and every time, firstly do Auto Scan.
  3. Likes iichel liked this post
    Jan 2020
    Israel
    thank you so much
    it worked
    Jan 2020
    Israel
    how did you get it ?
  6. Likes Boki Ar liked this post
    Oct 2014
    Click: https://diagnostics.vis4vag.com/
    You've Hex V2 and can send data to Auto Com Soft for account.
    Jan 2020
    Israel
    I'm sorry I quite understand, I'm new at this
    Quote Originally Posted by khaledabdulaziz View Post
    Read this thread https://forums.ross-tech.com/showthr...4-Introduction
  10. #8
    Oct 2014
    Here we go:
  12. #9
    Why don't you use the coding from your earlier Autoscan here.
    1A07629120210A75007C060901CB245846045000608024F000490020C0
  13. #10
    Oct 2014
    Lightbulb
    Thank You NEtech.
    Yes, this is a better and more secure solution, original coding.
