ABS coding lost
khaledabdulaziz
Israel
C?ID=394371
Hi
so i done resetting all adaptation values on MK100 abs and i lost its coding
here the autoscan
plz help
Saturday,15,February,2020,12:20:20:04619
VIN: TMBAG7NE9D0019598   License Plate:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: TMBAG7NE9D0019598   Mileage: 335139km-208245miles
Address 01: Engine (J623-CLHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 N    HW: 04L 907 309 B
   Component: R4 1,6L EDC   H22 4946
   Revision: 84H22---
   Coding: 01250012032401090000
   Shop #: WSC 73430 031 00207
   ASAM Dataset: EV_ECM16TDI01104L906021N 002007
   ROD: EV_ECM16TDI01104L906021N_002.rod
   VCID: 303916FB1AA27337797-8064
8 Faults Found:
5188 - Diesel Particle Filter
          P2463 00 [175] - Excessive Soot Accumulation
                    Mileage: 334948 km
                    Date: 2020.01.26
                    Time: 13:20:23
                    Engine speed: 769.00 /min
                    Normed load value: 20.8 %
                    Coolant temperature: 90 °C
                    Intake air temperature: 66 °C
                    Voltage terminal 30: 13.240 V
                    Counter for regeneration time of diesel particle filter: 0.00 s
                    Particle filter: kilometers since last regeneration: 1983741 m
                    Particle filter: soot mass measured: 9.59 g
                    Particle filter: soot mass calculated: 50.00 g
                    Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: 1 hPa
4814 - System Voltage
          P0562 00 [032] - Too Low
                    Mileage: 335057 km
                    Date: 2020.01.27
                    Time: 02:12:19
                    Engine speed: 74.00 /min
                    Coolant temperature: 66 °C
                    Intake air temperature: 61 °C
                    Voltage terminal 30: 5.480 V
                    Unlearning counter according OBD: 36
                    Limitation: torque: 9.6 Nm
                    Limitation: accelerator pedal: 97.5 Nm
                    Cruise Control System (CCS): status-Bits 0-7: 0
                    Accelerator pedal travel: raw value: 0.00 %
                    Engine torque: 120.0 Nm
                    Generator: load signal: 0.02 %
5250 - Function Restriction due to Faults in Other Modules
          U1113 00 [032] - -
                    Mileage: 335139 km
                    Date: 2020.01.27
                    Time: 21:59:11
                    Engine speed: 766.00 /min
                    Normed load value: 20.4 %
                    Coolant temperature: 94 °C
                    Intake air temperature: 72 °C
                    Voltage terminal 30: 13.160 V
                    Longitudinal acceleration: raw value: 32.767 m/s²
                    Vehicle inclination acceleration angle: raw value: 0.000 m/s²
                    Status: incline angle-Bits 0-7: 1
                    Longitudinal acceleration: 0.107 m/s²
                    Longitudinal acceleration sensor: status-Bits 0-7: 1
                    Vehicle lateral acceleration: raw value: -0.01 g
                    Vehicle lateral acceleration: 0.00 g
20557 - Heater support pump
          P16C7 00 [175] - locked
                    Fault Frequency: 47
                    Mileage: 334948 km
                    Date: 2020.01.26
                    Time: 13:20:28
                    Engine speed: 769.50 /min
                    Voltage terminal 30: 13.200 V
                    Heater support pump 1 bank 1 second.circuit: activat.: 95.00 %
                    Extern.temp.sens.1 bank 1: raw value: 23.0 °C
                    Shut-off timer: last engine shut-off time: 3 s
5608 - No Communications with Steering Angle Sender (G85)
          U0126 00 [032] - -
                    Mileage: 335139 km
                    Date: 2020.01.27
                    Time: 21:41:38
                    Normed load value: 20.0 %
                    Coolant temperature: 84 °C
                    Intake air temperature: 62 °C
                    selected gear-Bits 0-7: 0
          U0428 00 [047] - -
                    Mileage: 334948 km
                    Date: 2020.01.26
                    Time: 13:20:23
                    Voltage terminal 30: 13.180 V
17158 - Databus
          U1123 00 [047] - Received Error Message
                    Mileage: 334948 km
                    Date: 2020.01.26
                    Time: 13:20:22
                    Engine speed: 771.50 /min
                    Drivetrain coordinator: brake fault status-Bits 0-7: 4
                    Acceleration: 0.000 m/s²
5571 - ROD - Unknown Error Code
          - 00 [101]
                    Mileage: 335058 km
                    Date: 2020.01.27
                    Time: 02:21:15
                    Coolant temperature: 63 °C
                    Intake air temperature: 55 °C
                    Voltage terminal 30: 9.780 V
                    Air mass: specified value: 250.0 mg/stroke
                    Coolant temp. sensor 1 bank 1 at cylinder head: raw value: 2222.0 °C
                    Heat delivery temperature in cooling system: -273.1 °C
                    Extern.temp.sens.1 bank 1: raw value: 13.0 °C
                    Coolant fan 2: activation: 0.00 %
                    Coolant fan 1: activation: 10.00 %
                    Fuel temp. sensor 1 bank 1: raw value: 36.8 °C
Readiness: 1 2 0 0 1
   Part No SW: 0CW 300 047 R    HW: 0AM 927 769 G
   Component: GSG DQ200-MQB H43 5210
   Revision: 00043014    Serial number: CU501411085892
   Shop #: WSC 04940 001 00001
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 4ACD64139C3E29E7573-801E
21223 - No Communications with Power Steering Control Module
          U0131 00 [008] - -
                    Mileage: 335139 km
                    Date: 2020.01.27
                    Time: 21:41:38
                    Engine speed: 6.25 /min
                    Engine torque: -100 Nm
                    Vehicle speed: 77 km/h
                    Control Module temperature: 65 °C
                    CURRENT pressure: -9.5 bar
                    selected gear: GANG_4
                    Driving position: N
                    Accelerator position: 0.4 %
                    DTC memory status: 9216
   Part No SW: 5Q0 907 379 A    HW: 5Q0 907 379 A
   Component: ESC           H75 0333
   Coding: 0000000000000000000000000000000000000000000000000000000000
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 008020
   ROD: EV_Brake1UDSContiMK100ESP_008_SK37.rod
   VCID: 3A2D34D3CCDEB967C73-806E
7 Faults Found:
0195 - Control module not coded
          U1013 00 [137] - -
          [ECU marked as Not Configured because vehicle ID is invalid]
                    Reset counter: 6
                    Mileage: 335139 km
                    Date: 2020.01.27
                    Time: 22:46:58
0279 - Brake Pressure Sensor 1
          C107A 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 6
                    Mileage: 335139 km
                    Date: 2020.01.27
                    Time: 22:46:58
0295 - Steering angle sensor
                    Reset counter: 6
                    Mileage: 335139 km
                    Date: 2020.01.27
                    Time: 22:46:58
8269 - Databus
          [FCAN: VIN_01 message is received with invalid length]
                    Reset counter: 46
                    Mileage: 335139 km
                    Date: 2020.01.27
                    Time: 22:47:03
8290 - Coding Not Possible
          U10BC 00 [008] - -
          [FCAN: Unplausible VIN number]
                    Reset counter: 6
                    Mileage: 335139 km
                    Date: 2020.01.27
                    Time: 22:47:56
8306 - Databus
                    Reset counter: 6
                    Mileage: 335139 km
                    Date: 2020.01.27
                    Time: 22:47:56
8308 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [FCAN: StartStop not coded but MO_StartStopp_Status not equal 0]
                    Reset counter: 6
                    Mileage: 335139 km
                    Date: 2020.01.27
                    Time: 22:46:58
   Part No SW: 5E0 907 044     HW: 5E0 907 044
   Component: Climatronic   H02 0604
   Revision: 00001K06
   Coding: 00010104000100011005000000100000
   ROD: EV_ACClimaBHBVW37X_002_VW37.rod
   VCID: 629DACB304CE91A7BF3-8036
263425 - Air Quality Sensor
          B10AF 04 [008] - Internal System Fault
                    Fault Frequency: 101
                    Reset counter: 44
                    Mileage: 333155 km
                    Date: 2020.01.10
                    Time: 03:02:35
          B10CD 00 [008] - -
                    Reset counter: 41
                    Mileage: 335058 km
                    Date: 2020.01.27
                    Time: 02:27:10
   Part No SW: 5Q0 937 084 N    HW: 5Q0 937 084 N
   Component: BCM MQBAB M   H14 0106
   Serial number: 00011306600594
   Coding: 0C001842424702FB07A04000000407080000000000000000000000000000
   Shop #: WSC 73430 790 00207
   ROD: EV_BCMBOSCH_010.rod
   VCID: 43D34937BB14F8AF945-8016
   Subsystem 1 - Part No SW: 5E1 955 119     HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 130302  041 0570
   Serial number:         130307002938
   Coding: 065DDD
   Component: RLFS  024 0042
   Serial number: Y13M03D16H21M00S00S4
   Coding: 02805D
8 Faults Found:
9482 - Statiionary Cornering Lamp Right
          B1222 15 [009] - Open or Short to Plus
                    Reset counter: 191
                    Mileage: 333165 km
                    Date: 2020.01.10
                    Time: 04:59:15
10515 - Bulb for Left Tail Light
          B12BE 01 [008] - Electrical Failure
                    Fault Frequency: 17
                    Reset counter: 32
                    Mileage: 333239 km
                    Date: 2020.01.11
                    Time: 03:15:05
11786 - Bulb for Rear Left Fog Light
          B12C7 15 [009] - Open or Short to Plus
                    Reset counter: 191
                    Mileage: 333155 km
                    Date: 2020.01.10
                    Time: 03:04:53
12298 - License Plate Light
          B12CA 15 [009] - Open or Short to Plus
                    Reset counter: 191
                    Mileage: 333155 km
                    Date: 2020.01.10
                    Time: 03:04:53
12554 - Bulb for Left Back-up Light
          B12CB 15 [009] - Open or Short to Plus
                    Reset counter: 191
                    Mileage: 333155 km
                    Date: 2020.01.10
                    Time: 03:10:13
204546 - Remote key 2
          B147A 18 [008] - Current Too Low
                    Reset counter: 36
                    Mileage: 334788 km
                    Date: 2020.01.25
                    Time: 09:28:28
539925 - Databus
          [Kombi_02 Datenbus fehlende Botschaft]
                    Reset counter: 43
                    Mileage: 333250 km
                    Date: 2020.01.11
                    Time: 09:26:51
555285 - Databus
          [LWI_01_alt aktiv]
                    Reset counter: 46
                    Mileage: 335139 km
                    Date: 2020.01.27
                    Time: 21:41:38
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 A    HW: 5Q0 919 283
   Component: PARKHILFE 4K  009 0026
   Revision: --------    Serial number: 60831306500776
   Coding: 0001050011
   ASAM Dataset: EV_EPHVA14AU3700000 002015
   VCID: 372B2DE7FFCCA40F38D-8062
1079060 - Center Rear Left Parking Aid Sensor
          B1077 14 [008] - Open or Short to Ground
                    Reset counter: 191
                    Mileage: 333155 km
                    Date: 2020.01.10
                    Time: 03:10:13
1079316 - Center Rear Right Parking Aid Sensor
          B1078 14 [008] - Open or Short to Ground
                    Reset counter: 191
                    Mileage: 333155 km
                    Date: 2020.01.10
                    Time: 03:10:13
13637426 - Databus
                    Fault Frequency: 8
                    Reset counter: 6
                    Mileage: 333155 km
                    Date: 2020.01.10
                    Time: 02:58:30
   Part No SW: 3Q0 959 655 AB    HW: 3Q0 959 655 AB
   Component: Airbag VW20   011 0188
   Revision: --------    Serial number: 003P3P53SCBT
   Coding: 98CCC0000C0000005C5400CC000800000065
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7EA5F8C390765547BBB-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 000 403 13
   Serial number: 3576U000000BCBF43C0X
   Subsystem 2 - Part No SW: -----------    HW: 454 000 503 13
   Serial number: 3586U00000030D3DBC0L
   Subsystem 3 - Part No SW: -----------    HW: 454 800 503 13
   Serial number: 3516R15A73201000000S
   Subsystem 4 - Part No SW: -----------    HW: 454 800 603 13
   Serial number: 3526RA7372101000000V
   Subsystem 5 - Part No SW: -----------    HW: 454 800 503 13
   Serial number: 3556V43B20E01000000%
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 454 801 602 13
   Component: PedP_Sensor_D  114 0149
   Serial number: 2286VD822CD00000000D
   Subsystem 7 - Part No SW: -----------    HW: 454 801 502 13
   Component: PedP_Sensor_P  114 0149
   Serial number: 2296VE433CD00000000D
   Pedestrian Protection Center:
   Subsystem 8 - Part No SW: -----------    HW: 454 801 502 13
   Component: PedP_Sensor_C  114 0149
   Serial number: 2306VCD3AF900000000I
9437211 - Igniter for Driver's Airbag
          B1000 1B [136] - Resistance Too High
                    Mileage: 334946 km
                    Date: 2020.01.26
                    Time: 12:36:44
9451547 - Igniter 1 for pedestrian protection
          B1038 1B [137] - Resistance Too High
                    Mileage: 334758 km
                    Date: 2020.01.24
                    Time: 19:59:28
9451803 - Igniter 2 for pedestrian protection
          B1039 1B [137] - Resistance Too High
                    Mileage: 334758 km
                    Date: 2020.01.24
                    Time: 19:59:28
1050112 - Databus
          [NWD: 0x086 LWI_01 Timeout]
                    Reset counter: 46
                    Mileage: 335139 km
                    Date: 2020.01.27
                    Time: 21:41:38
          B13BC F2 [137] - No function
                    Mileage: 335139 km
                    Date: 2020.01.27
                    Time: 22:07:15
   Part No SW: 5Q0 953 507 AJ    HW: 5Q0 953 549 A
   Revision: --------    Serial number: 18031304221317
   Coding: 1400
   Part No SW: 5E0 920 860 D    HW: 5E0 920 860 D
   Component: KOMBI         227 0555
   Coding: 07A402082180000801082A00040000
   VCID: 270BFDA72F6C348FA8D-8072
16776973 - Databus
          [RKA_01 keine Kommunikation]
                    Reset counter: 6
                    Mileage: 335139 km
                    Date: 2020.01.27
                    Time: 21:59:15
   Part No SW: 5Q0 907 530 E    HW: 5Q0 907 530 E
   Component: GW MQB Mid    124 1109
   Revision: --------    Serial number: 0000452288
   Coding: 030100040B087300EF0002481C0F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 006010
   ROD: EV_GatewLear_006.rod
   VCID: 333319F7EBB4482F045-8066
   Subsystem 2 - Part No SW: 5E0 919 719 A    HW: 5E0 919 719 A
   Component: E221__MFL-PR6  H04 0100
   Serial number: 000000000A0333270213
   Serial number: 5434670103
197169 - Controls in Steering Wheel
          U108E 00 [008] - No Communications
          [MFL (LIN#2) Timeout]
                    Reset counter: 41
                    Mileage: 334946 km
                    Date: 2020.01.26
                    Time: 12:35:03
                    Supply voltage: Terminal 30: 12.4 V
                    Terminal 15: OFF
          U1101 00 [008] - Active
                    Reset counter: 28
                    Mileage: 334683 km
                    Date: 2020.01.23
                    Time: 23:29:14
                    Supply voltage: Terminal 30: 11.8 V
                    Terminal 15: On
   Part No SW: 5Q4 959 393     HW: 5Q4 959 393
   Serial number: 0000055770042
   Coding: 001000208000020000001100
   VCID: 55F7876F4580761FCA1-8000
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  005 0004
   Serial number: 00000000000000119081
   Coding: 010200
65588 - Motor for Window Regulator
          B1487 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 42
                    Mileage: 334597 km
                    Date: 2020.01.23
                    Time: 21:13:01
589833 - Window Regulator Switch; Rear Driver Side
          B1323 29 [009] - Signal Implausible
                    Reset counter: 6
                    Mileage: 333155 km
                    Date: 2020.01.10
                    Time: 02:58:15
   Component: EPS_MQB_ZFLS  126 1063
   Coding: 0002
   Shop #: WSC 73430 790 12345
   VCID: 44D14A2BBE1AFF97ADF-8010
15873 - Steering angle sensor
                    Reset counter: 6
                    Mileage: 335139 km
                    Date: 2020.01.27
                    Time: 21:43:10
                    Motor status: 01
                    System status: Driving mode
                    Supply voltage: 13.25 V
                    Temperature: 35.0 °C
                    KFC: 3E
                    KFA: 00 01
                    Environmental conditions: 5F
                    uioUdNotFilt_xdu16: 13.28 V
                    uAdSensI_SwitchedKl30_xdu16: 13.29 V
19204 - Databus
          [ESP_02 Botschaft - SNA_Check]
                    Reset counter: 46
                    Mileage: 335139 km
                    Date: 2020.01.27
                    Time: 21:59:11
                    Motor status: 01
                    Supply voltage: 13.00 V
                    Temperature: 34.0 °C
                    KFC: 4B
                    KFA: 00 04
                    Environmental conditions: 21
                    uioUdNotFilt_xdu16: 13.41 V
                    uAdSensI_SwitchedKl30_xdu16: 13.41 V
   Part No SW: 5Q4 959 392     HW: 5Q4 959 392
   Serial number: 0000055311973
   VCID: 7F5B05C7977C5C4FB0D-802A
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  005 0004
   Serial number: 00000000000000133953
   Coding: 190200
65593 - Switch for Central Locking
          B122D 29 [008] - Signal Implausible
                    Reset counter: 24
                    Mileage: 333380 km
                    Date: 2020.01.12
                    Time: 15:13:36
589853 - Window regulator motor; front passenger side
          B1322 29 [008] - Signal Implausible
                    Reset counter: 34
                    Mileage: 334780 km
                    Date: 2020.01.24
                    Time: 23:26:53
Address 5F: Information Electr. (J794)       Labels:| 5E0-035-MIB-ENT1.clb
   Part No SW: 5E0 035 875     HW: 5E0 035 875
   Component: MU-E--ER      164 0141
   Revision: --------    Serial number: 000031094114000
   Coding: 03730100FF00000011110001000000002F0000840000010000
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_MUEnt4CCONT 004052
   ROD: EV_MUEnt4CCONT.rod
   VCID: 6695B0A3E8E6ED8753B-8032
1539 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [Function restriction due to insufficient voltage - lower limit value not reached]
                    Reset counter: 41
                    Mileage: 334401 km
                    Date: 2020.01.21
                    Time: 11:53:38
                    Voltage terminal 30: 8.6 V
          U1111 00 [009] - -
                    Reset counter: 6
                    Mileage: 335139 km
                    Date: 2020.01.27
                    Time: 22:07:17
                    Voltage terminal 30: 13.1 V
                    BAP-BAP_Function_ID: 02
7206 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Brake (0x26) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 6
                    Mileage: 335139 km
                    Date: 2020.01.27
                    Time: 22:07:17
          U1101 00 [024] - Active
          [Anti-theft protection - component protection active (0xEA6200)]
                    Reset counter: 28
                    Mileage: 334683 km
                    Date: 2020.01.23
                    Time: 23:29:14
                    Voltage terminal 30: 11.8 V
End----------(Elapsed Time: 01:09, VBatt start/end: 12.4V/12.4V)-----------
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Based on VIS:
1A07629120210A75007C060901CB245846045000608024F00048000040
Please next and every time, firstly do Auto Scan.
khaledabdulaziz
Israel
C?ID=394371
thank you so much
it worked
khaledabdulaziz
Israel
C?ID=394371
I'm sorry I quite understand, I'm new at this
Boki Ar
C?ID=57300
Here we go:
Boki Ar
C?ID=57300
Thank You NEtech. :thumbs: :cool:
Yes, this is a better and more secure solution, original coding. :thanks:
khaledabdulaziz
Israel
C?ID=394371
Here the after scan
But there is still a problem, I will try to put the original coding
[Back]
Sunday,08,March,2020,13:31:05:04619
VIN: TMBAG7NE9D0019598   Mileage: 186302km-115762miles
   Revision: 84H22---
   VCID: 303916FB1AA27337795-8064
                    Mileage: 185227 km
                    Date: 2020.02.08
                    Time: 06:55:01
                    Engine speed: 105.50 /min
                    Normed load value: 100.0 %
                    Coolant temperature: 34 °C
                    Intake air temperature: 27 °C
                    Voltage terminal 30: 5.560 V
                    Unlearning counter according OBD: 11
                    Limitation: torque: 13.1 Nm
                    Limitation: accelerator pedal: 91.8 Nm
17158 - Databus
                    Mileage: 185000 km
                    Date: 2020.02.07
                    Time: 00:01:36
                    Coolant temperature: 82 °C
                    Intake air temperature: 64 °C
                    Voltage terminal 30: 12.440 V
21125 - Implausible Data Received from Airbag Control Module
          U0452 00 [032] - -
                    Mileage: 185891 km
                    Date: 2020.02.14
                    Time: 23:59:23
                    Engine speed: 2072.00 /min
                    Normed load value: 46.3 %
                    Vehicle speed: 37 km/h
                    Coolant temperature: 88 °C
                    Intake air temperature: 47 °C
                    Voltage terminal 30: 13.340 V
                    Unlearning counter according OBD: 31
                    Limitation: accelerator pedal: 78.4 Nm
                    selected gear-Bits 0-7: 3
4710 - No Communications with Airbag Control Module
          U0151 00 [040] - -
                    Mileage: 186281 km
                    Date: 2020.02.17
                    Time: 23:35:47
                    Coolant temperature: 65 °C
                    Intake air temperature: 49 °C
                    Voltage terminal 30: 12.240 V
                    Limitation: accelerator pedal: 111.0 Nm
Readiness: 0 0 0 0 X
   VCID: 4ACD64139C3E29E7571-801E
   Coding: 1A07629120210A75007C060901CB245846045000608024F00048000040
   VCID: 3A2D34D3CCDEB967C71-806E
                    Reset counter: 70
                    Mileage: 186302 km
                    Date: 2020.02.18
                    Time: 01:19:16
8277 - Databus
          [FCAN: EPS_DSR_Status signal is invalid]
                    Reset counter: 70
                    Mileage: 186302 km
                    Date: 2020.02.18
                    Time: 01:19:16
8299 - Databus
          [FCAN: Anhaenger_01_alt veraltet bit is set]
                    Reset counter: 70
                    Mileage: 186302 km
                    Date: 2020.02.18
                    Time: 01:19:16
   Revision: 00001K06
   VCID: 629DACB304CE91A7BF1-8036
459009 - Databus
          [Airbagsteuergerät - kein Signal/Kommunikation]
                    Reset counter: 110
                    Mileage: 186281 km
                    Date: 2020.02.17
                    Time: 23:35:53
                    Fault Frequency: 132
                    Reset counter: 110
                    Mileage: 185000 km
                    Date: 2020.02.07
                    Time: 00:06:40
          B10CD 00 [008] - -
                    Reset counter: 86
                    Mileage: 185262 km
                    Date: 2020.02.09
                    Time: 21:06:38
   VCID: 43D34937BB14F8AF947-8016
   Coding: 065DDD
   Coding: 02805D
10506 - Bulb for Left Tail Light
          B12BE 15 [008] - Open or Short to Plus
                    Reset counter: 88
                    Mileage: 185227 km
                    Date: 2020.02.08
                    Time: 06:59:08
                    Fault Frequency: 15
                    Reset counter: 107
                    Mileage: 185028 km
                    Date: 2020.02.07
                    Time: 05:28:59
12810 - Bulb for Right Back-up Light
          B12CC 15 [009] - Open or Short to Plus
                    Reset counter: 55
                    Mileage: 185559 km
                    Date: 2020.02.12
                    Time: 03:10:05
558101 - Databus
          [Airbag_02 Datenbus fehlende Botschaft]
                    Reset counter: 110
                    Mileage: 186281 km
                    Date: 2020.02.17
                    Time: 23:35:52
   Coding: 0001050011
   VCID: 372B2DE7FFCCA40F38F-8062
                    Reset counter: 39
                    Mileage: 185000 km
                    Date: 2020.02.07
                    Time: 00:03:05
                    Reset counter: 39
                    Mileage: 185000 km
                    Date: 2020.02.07
                    Time: 00:03:05
13637426 - Databus
                    Reset counter: 40
                    Mileage: 185000 km
                    Date: 2020.02.07
                    Time: 00:01:37
   VCID: 7EA5F8C390765547BB9-802A
9498451 - Igniter for Pedestrian Protection
          B10EF 53 [009] - Deactivated
                    Mileage: 186295 km
                    Date: 2020.02.18
                    Time: 00:22:14
   Coding: 1400
   Coding: 07A402082080000801082A00040000
   VCID: 270BFDA72F6C348FA8F-8072
16776962 - Databus
          [Airbag_01 keine Kommunikation]
                    Reset counter: 110
                    Mileage: 186281 km
                    Date: 2020.02.17
                    Time: 23:35:47
   VCID: 333319F7EBB4482F047-8066
131605 - No Communications with Airbag Control Module
          U0151 00 [008] - -
          [Timeout Knoten 0x15 / 15 - Steuergerät für Airbag]
                    Reset counter: 110
                    Mileage: 186281 km
                    Date: 2020.02.17
                    Time: 23:35:53
                    Supply voltage: Terminal 30: 12.0 V
                    Terminal 15: On
   Coding: 005000209000020000001100
   VCID: 55F7876F4580761FCA3-8000
   Coding: 010200
458752 - Databus
          [Airbag_01 Datenbus fehlende Botschaft]
                    Reset counter: 110
                    Mileage: 186281 km
                    Date: 2020.02.17
                    Time: 23:35:55
                    Fault Frequency: 191
                    Reset counter: 70
                    Mileage: 185000 km
                    Date: 2020.02.07
                    Time: 00:01:37
   Coding: 0002
   VCID: 44D14A2BBE1AFF97ADD-8010
   VCID: 7F5B05C7977C5C4FB0F-802A
   Coding: 190200
                    Reset counter: 110
                    Mileage: 185262 km
                    Date: 2020.02.09
                    Time: 21:06:29
458752 - Databus
                    Reset counter: 110
                    Mileage: 186281 km
                    Date: 2020.02.17
                    Time: 23:35:55
   VCID: 6695B0A3E8E6ED87539-8032
6697 - Databus
          [Airbag: no communication]
                    Reset counter: 110
                    Mileage: 186281 km
                    Date: 2020.02.17
                    Time: 23:35:50
                    Voltage terminal 30: 9.9 V
                    Network diagnosis-Status: Enabled
          U1111 00 [009] - -
                    Reset counter: 39
                    Mileage: 185000 km
                    Date: 2020.02.07
                    Time: 00:01:41
                    Voltage terminal 30: 12.3 V
End----------(Elapsed Time: 01:07, VBatt start/end: 14.2V/13.7V)-----------
