Results 1 to 7 of 7
Thread: Attempt to recode instruments to turn off brake pads warning made dash go nuts!
    Feb 2020
    I have an '06 Audi A3 8p with 2.0T FSI motor. I'm familiar with using VCDS-Lite with my prior '01 GTI VR6, but purchased the Ross-Tech HEX-V2 and am using VCDS 19 to work on my Audi.
    I was recoding the instruments to remove the brake pad warning. The pads/brakes are good, but there's obviously the common fault in the wiring, so I wanted to disable it rather than cut and splice the harness. I thought recoding would better allow allow a repair later. In any case, I changed the code by reducing by 1 the 5th digit. Below you can see the screen showing the codes before changing anything. I changed the code from 0002263 to 0002163. After accepting the code the fuel gauge showed no gas (tank is full), and a series of warning symbols started complaining about number plate lights, brake lights, rear lightbulbs, out of gas and still the brakes warnings. I changed the value back, the warnings went away (but the brake pad warning is of course still there) and the fuel gauge is very slowly rising.
    This is the screen before changing anything.
    I turned off and stepped away. Having set the code back the I now noticed the equipment number is missing it's last digit.
    I changed it to put back that missing digit, and it says recode OK, but still shows the shorter code number. Not sure if this is relevant to my issue.
    What did I do wrong and how can I turn off the brake pad warning light without screwing up everything?
    Here's my complete scan output:
    Friday,14,February,2020,09:04:32:39323
    VIN: WAUMF78P16A171124   License Plate:
    Mileage: 295180km-183416mi   Repair Order:
    Chassis Type: 8P (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
    VIN: WAUMF78P16A171124   Mileage: 295180km-183416miles
    08-Auto HVAC -- Status: Sporadic communication error 1000
       Part No SW: 8P0 907 115 B    HW: 8P0 907 115 B
       Component: 2.0l R4/4V TFSI     0080
       Revision: --H14---    Serial number: AUX7Z0F1FNK0E3
       Coding: 0103010A1C070160
       Shop #: WSC 26105 444 82971
       VCID: 313F13802D20C33F769-8064
    000280 - Engine Coolant Temp. Sensor (G62)
                   P0118 - 002 - Signal too High - Intermittent
                        Mileage: 294970 km
                        Date: 2020.02.09
                        Time: 13:46:02
                        RPM: 806 /min
                        Load: 18.0 %
                        Temperature: -40.0°C
                        Temperature: 14.0°C
                        Absolute Pres.: 920.0 mbar
                        Voltage: 13.716 V
       Part No SW: 02E 300 043 C    HW: 02E 927 770 AE
       Component: GSG DSG         070 1125
       Revision: 04507000    Serial number: 00000602080984
       Shop #: WSC 06314 000 00000
       VCID: 1471BA14B27216177DF-8040
    Address 03: ABS Brakes        Labels:. 1K0-614-517-MK60AT.clb
       Part No SW: 1K0 614 517 AC    HW: 1K0 614 517 AC
       Component: ESP FRONT MK60-AT   0102
       Revision: 00H13001
       Coding: 0053890
       VCID: 6889BEE4DE7A42F7617-803C
       Part No SW: 8P0 820 043 M    HW: 8P0 820 043 M
       Component: KlimavollautomatH18 0260
       Revision: 306332      Serial number: 8P0820043M
       VCID: 3635209CC44EE40723B-8062
    Address 09: Cent. Elect.        Labels:. 8P0-907-279-23-H.lbl
       Part No SW: 8P0 907 279 F    HW: 8P0 907 279 F
       Component: Bordnetz-SG     H43 1201
       Revision: 00H43000    Serial number: 00000005484621
       Coding: 018C4F81C014100000181800180000000028FE175C1100
       Shop #: WSC 06314 000 08192
       VCID: 40D94644968A5AB7897-8014
       Subsystem 1 - Part No: 8P1 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer AU350   H01 0130
       Coding: 00062736
       Shop #: WSC 06314
    8 Faults Found:
                        Reset counter: 9
                        Mileage: 287775 km
                        Date: 2019.06.23
                        Time: 00:57:00
                        Voltage: 12.15 V
                        Reset counter: 9
                        Mileage: 287775 km
                        Date: 2019.06.23
                        Time: 00:57:00
                        Voltage: 12.15 V
                        Fault Status: 01111100
                        Reset counter: 9
                        Mileage: 292041 km
                        Date: 2019.12.30
                        Time: 14:48:00
                        Voltage: 10.90 V
    01117 - Generator Terminal DF Load Signal
                        Reset counter: 49
                        Mileage: 287788 km
                        Date: 2019.06.26
                        Time: 18:45:00
                        Voltage: 12.45 V
                        Reset counter: 45
                        Mileage: 294970 km
                        Date: 2020.02.08
                        Time: 13:49:00
                        Voltage: 12.50 V
    02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
                        Fault Status: 00100110
                        Reset counter: 49
                        Mileage: 287784 km
                        Date: 2019.06.23
                        Time: 05:48:00
                        Voltage: 11.80 V
                        Fault Frequency: 38
                        Reset counter: 9
                        Mileage: 287775 km
                        Date: 2019.06.23
                        Time: 00:57:00
                        Voltage: 12.15 V
                        Reset counter: 9
                        Mileage: 287775 km
                        Date: 2019.06.23
                        Time: 00:57:00
                        Voltage: 12.15 V
    Address 15: Airbags        Labels: 8P0-959-655-94.lbl
       Part No SW: 8P0 959 655 A    HW: 8P0 959 655 A
       Component:    Airbag 9.41  H12 3890
       Revision: 91H12389    Serial number: 0035W000DU0/
       Coding: 0032605
       Subsystem 1 - Part No: 8P0 910 339
       Component: BF-Gewichtsens. 001 0020
       Subsystem 2 - Serial number: 35KHV
       Subsystem 3 - Serial number: 0001.01.000000100000000000ÿ†63
       Subsystem 4 - Serial number: 000000ÿ†6332DRB402E9C80F0ÿ†63
       Subsystem 5 - Serial number: 9C80F0ÿ†6342DRB402E9CC0B1ÿ†63
       Subsystem 6 - Serial number: 9CC0B1ÿ†63528RB400FEB29B%ÿ†63
       Subsystem 7 - Serial number: EB29B%ÿ†63628RB40107D2A0Eÿ†63
       Subsystem 8 - Serial number: 7D2A0Eÿ†63729RB400F3A472Oÿ†63
       Subsystem 9 - Serial number: 3A472Oÿ†63829RB400F398FB2ÿ
       Subsystem 10 - Serial number: 398FB2ÿ
    Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
       Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
       Component: J0527           H34 0070
       Coding: 0012122
       VCID: 41DF43409D8053BF869-8014
       Component: E0221           H07 0090
    01304 - Radio
       Part No SW: 8P0 920 981 E    HW: 8P0 920 981 E
       Component: KOMBIINSTR. VDO H80 0420
       Revision: D06         Serial number: 2241FD06008809
       Coding: 0002263
       Shop #: WSC 58152 001 1048576
       VCID: 3A2D34ACF0560067C73-806E
    16346 - Control Module - ROM Error
                014 - Defective
                        Fault Status: 00000011
                        Mileage: 171032 km
                        Date: 2014.11.04
                        Time: 20:45:40
       Part No SW: 1K0 907 530 G    HW: 1K0 907 951
       Component: J533__Gateway   H10 0140
       Revision:   H10       Serial number: 300010621194D8
       Coding: 3F3F034207002102
       VCID: 2B0301E80F0CA9EF4C5-807E
    01304 - Radio
                        Reset counter: 9
                        Mileage: 291831 km
                        Date: 2019.12.22
                        Time: 16:16:48
                        Reset counter: 45
                        Mileage: 294970 km
                        Date: 2020.02.08
                        Time: 13:49:26
       Revision: D06         Serial number: AUX7Z0F1FNK0E3
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN2.lbl
       Part No: 8P0 959 801 H
       Component: Tuer-SG         020 0090
       Coding: 0001177
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 233    3201
       Revision: 00H20000
       Shop #: WSC 26105 444 999999
       VCID: 34311A94D232F6171DF-8060
       Part No: 8P0 959 433 D
       Component: 02 KSG          H04 0050
       Coding: 9AC003382D08850FC88F047300
       Shop #: WSC 26105 444 68434
       VCID: 3D273FB0E178375FE21-8068
       Part No SW: 8P4 035 382     HW: 8P4 035 382
       Component: AB2 SUBWOOFERBOXH04 0180
       Revision: 00003       Serial number: 30674548472080
       VCID: 71BFD380EDA0833F369-8024
    Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN2.lbl
       Part No: 8P0 959 802 H
       Coding: 0001177
    Address 56: Radio
    Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
       Part No: 8P4 959 801 D
       Component: Tuer-SG         020 0070
       Coding: 0001176
    Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
       Part No: 8P4 959 802 D
       Coding: 0001176
    End----------(Elapsed Time: 01:11, VBatt start/end: 12.2V/12.2V)-----------
    Thanks in advance for the help.
    According to the Ross-Tech Wiki that coding change tells the instruments the car is RoW(LHD) instead of US (see http://wiki.ross-tech.com/wiki/index...Cluster#Coding) where did you see that would disable the brake pad warning?
  3. Likes Uwe liked this post
    There doesn't appear to be an option in that cluster to remove the brake pad warning. Some clusters have that option, others do not.
    Quote Originally Posted by hondaman900 View Post
    014 - Defective
    Mileage: 171032 km
    Date: 2014.11.04
    Time: 20:45:40
    Not a nice DTC.
    What value do you have in [17-Instrument] > Adaptation > Channel 37 ?
    Feb 2020
    I was following this: https://www.audiworld.com/forums/tt-.../#post23439087 thinking Golf V and '08 TT were close enough/same family.
    Thank you both for the quick response and the definitive word on that option in my cluster. I'll brake out the soldering iron and take care of it manually.
    Next up is figuring out how to restore functionality of the key fob remote....
    Jun 2014
    If you had "hoovered" the mouse-cursor over the coding you would have had a pop-up telling you the options you have and what can be changed for what... Never change coding without knowing what you are doing, strange things can happen, now you need help to clean-up the mess...
    Golf VII, 1.6TDI BM Ed. 40 - 110 PK
  8. Likes Boki Ar liked this post
    Feb 2020
    Quote Originally Posted by Mari View Post
    Thanks for that tip. I didn't realize that was a complete list in the pop-up, thought it more of a hint/examples. Good to know.
