Results 1 to 3 of 3
Thread: Audi Q7 4M LED not working after replacing LCM
    Feb 2020
    Hi everyone,
    i'm new to the forum and I hope somebody can help me. I have 2019 Audi Q7 which was involved in right side accident so I had to change the headlight along with the LED module (part # 4M0907397AC), other module (part # 7PP941572AB is from original light for the car). I did match part # to the correct module for the car but I believe the new module (4M0907397AC) needs programming as the only thing that works on the RH headlight is low beams. I did read few other posts related to my issue but none of them seems to help me or had instructions how to program that module.
    I hope someone can provide instructions of how to program the new module to the car.
    Thanks in advanced.
    Bellow is the full scan of my car (apologize in advanced if i'm giving you too much info), please disregard the other errors as I haven't put the car together yet. I'm mostly interested in programming the LED module on the right side light (part # 4M0907397AC)
    p.s.: just bought "VCDS/VCDS-Mobile with HEX-NET Pro" interface.
    Friday,14,February,2020,16:53:33:44945
    VCDS Version: 19.6.2.0  HEX-NET CB: 0.4508.4
    VIN: WA1LAAF77KD006677   License Plate:
    Mileage: 6059km-3764mi   Repair Order:
    Chassis Type: F7-AU73 (80A)
    Scan: 01 02 03 08 09 15 16 17 19 29 36 39 3C 42 44 46 47 50 52 5F
              69 6C 6D 75 81 A5 BB BC CA CF D6 D7
    VIN: WA1LAAF77KD006677   Mileage: 6059km-3764miles
    39-Right Light -- Status: Malfunction 0010
    3C-Lane Change -- Status: Cannot be reached 0100
    50-Seat Adj. 3rd row -- Status: OK 0000
    CA-Sunroof -- Status: OK 0000
    CF-Lane Chge Asst 2 -- Status: Cannot be reached 0100
    Address 01: Engine (J623-CREC)       Labels:. 06E-907-551-CGW.clb
       Part No SW: 4M0 907 551 A    HW: 06E 907 425
       Component: 3.0l V6 TFSI  H10 0005
       Revision: --H10---
       Coding: 2A2A00320536010D74280000000000000000000000000000
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_ECM30TFS0214M0907551A 001007
       ROD: EV_ECM30TFS0214M0907551A.rod
       VCID: 2D122F4E7CBEAF273C-8078
    17181 - Databus
              U1123 00 [036] - Received Error Message
                        Mileage: 6059 km
                        Date: 2020.02.14
                        Time: 14:37:12
                        Engine speed: 680.00 /min
                        Normed load value: 23.5 %
                        Coolant temperature: 56 °C
                        Intake air temperature: 16 °C
                        Voltage terminal 30: 14.785 V
                        Engine status: Idling
                        Cruise control switch actuation-Main switch: not activated
                        Cruise control switch actuation-Setting: not activated
                        Cruise control switch actuation-Activation: not activated
                        Cruise control switch actuation-Status: OK
                        Cruise control switch actuation-Accelerate: not activated
                        Cruise control switch actuation-Decelerate: not activated
                        Cruise control switch actuation-Cancel: not activated
                        Cruise control switch actuation-Main switch hardware: operated
                        Cruise control switch actuation-Coding: plausible
                        Cruise control switch actuation-Limit function: not selected
                        Cruise control switch actuation-Limit button: not activated
                        Cruise control switch actuation-Main switch CAN: operated
                        Cruise control switch actuation-Large increment: not activated
                        Cruise control switch actuation-Control component verified: Yes
                        CCS Switch: CCS operating unit
                        ACC variants (coding): CCS
    26388 - Lane change assistant control module
              U1045 00 [047] - No communication
                        Mileage: 6059 km
                        Date: 2020.02.14
                        Time: 14:34:17
                        Engine speed: 746.50 /min
                        Normed load value: 29.0 %
                        Coolant temperature: 18 °C
                        Intake air temperature: 14 °C
                        Voltage terminal 30: 14.902 V
                        LF_MVB_PDU_INTC_DIAG_7: 24576
                        LF_MVB_PDU_INTC_DIAG_8: 199
                        LF_MVB_PDU_INTC_DIAG_9: 14336
                        LF_MVB_PDU_INTC_DIAG_10: 0
                        LF_MVB_BUS_INTC_DIAG: 256
    Readiness: 1010 0101
    Address 02: Auto Trans        Labels:| 0BK-927-156.clb
       Part No SW: 4M0 927 158 L    HW: 0D5 927 156 H
       Component: 0D5  30TSIUSA H05 1006
       Revision: --H05---
       Coding: 100000
       ASAM Dataset: EV_TCMALX52011 002010
       ROD: EV_TCMALX52011.rod
       VCID: 3D321F0EACDE3FA78C-8068
       Part No SW: 4M0 907 379 T    HW: 4M0 907 379 T
       Component: ESP9 Premium  H14 0861
       Coding: 28AA149C30A20A9C91A4589800845292E5369A14280C50891A004A49A76C59
       ROD: EV_ESP9BOSCHCMP_004_AU49.rod
       VCID: 48DC7EDAF31C6A0F2F-801C
    451328 - Databus
              U1121 00 [047] - Missing Message
              [ComScl:_Signal_Group_SG_RCTA_01_-_Timeout_error]
                        Mileage: 6059 km
                        Date: 2020.02.14
                        Time: 14:34:17
                        95 00 80 00 CA 24 00 00 00 00
                        Unlearning counter according OBD-OBD unlearning counter: 28
       Part No SW: 4M0 820 043 R    HW: 4M0 820 043 R
       Component: Klima Zone 3  H52 0112
       Coding: 6608090C5148000D10200280000000000000000000000000000000000000
       ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
       ROD: EV_AirCondiFrontBHTCAU736.rod
       VCID: 34243A2A9F94FEEF73-8060
       Subsystem 1 - Part No SW: 4M1 820 021 B    HW: 4M1 820 021 B
       Component: J126 FLuftV  H09 0003
       Serial number: 00000000000002725022
       Subsystem 2 - Part No SW: 4G0 907 658 B    HW: 4G0 907 658 B
       Component: Humidity_Sens  H02 0007
       Serial number: 22115E3900PAG0FSA002
       Subsystem 3 - Part No SW: 8W0 919 158 A    HW: 8W0 919 158 A
       Component: E265 Kli Fond  H40 0080
       Part No SW: 8W0 907 063 DG    HW: 8W0 907 063 BG
       Component: BCM1 MLBevo   H13 0313
       Coding: 07500363E0081CCD450D871558BE9CB911033D01900000000000000020001A0108630122025709
       ASAM Dataset: EV_BCM1BOSCHAU736 019008
       ROD: EV_BCM1BOSCHAU736_019.rod
       VCID: 0346A9F68ABA8957BA-8056
       Subsystem 1 - Part No SW: 4M8 955 119     HW: 4N1 955 119
       Component: J400FRWISCH  052 0997
       Serial number: 904753F0401818400894
       Coding: 7DC727
       Serial number: 21560393X81A955547A0
       Coding: 02006E
       Subsystem 3 - Part No SW: 4M0 941 531 AG    HW: 4M0 941 531 AG
       Component: E1 - LDS  H06 0008
       Serial number: 31 07 2018  01569216
       Subsystem 4 - Part No SW: 4N0 907 410 B    HW: 4M0 907 410 A
       Component: USHL5  H10 0100
       Serial number: 0000009600368Z01B102
       Coding: 350000
       Garage Door Opener Operating Unit:
       Subsystem 5 - Part No SW: 4M0 959 719 A    HW: 4M0 959 719 A
       Component: GTO BF  H01 0010
       Serial number: 20180731025419 00274
       Subsystem 6 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
       Component: Y7_Innenspieg  H01 0002
       Serial number: GX1CE129051823611701
       Interior Light Module:
       Subsystem 7 - Part No SW: 4M0 947 135 DM    HW: 4M0 947 135 DM
       Component: Dachmodul  H42 0413
       Serial number: Q00607264
       Coding: 0D0305
       Electrically Adjustable Steering Column:
       Subsystem 8 - Part No SW: 80A 907 705     HW: 80A 907 705
       Component: J866-EVLS-SG  H03 0100
       Serial number: WA133581000053317256
       Coding: 0A0100
       Subsystem 9 - Part No SW: 4M0 925 301 K    HW: 4M0 925 301 K
       Component: SL-Q7NF/AU736  H10 0013
       Serial number: 00000000000000220100
    65915 - Databus
              [Side assist control module: no signal/communication]
                        Reset counter: 172
                        Mileage: 6059 km
                        Date: 2020.02.14
                        Time: 16:22:47
                        average_Voltage_terminals: 14.70 V
                        Outside air temperature sensor-Resistance: 0.00 kOhm
                        Outside air temperature sensor-Outside air temperature on CAN: 18.00 °C
                        interior_temperature: 28.50 °C
                        Vehicle speed: 0.00 km/h
                        Terminal control-Terminal 75 status: On
                        Terminal control-Terminal 15 status signal: On
                        Terminal control-Terminal 15 via CAN: On
                        Terminal control-Term 75: qualification: OFF
    66679 - Databus
              [Right LCM: implausible data record]
                        Reset counter: 172
                        Mileage: 6059 km
                        Date: 2020.02.14
                        Time: 16:22:49
    66964 - Databus
              [Right LCM: turn signal faulty]
                        Reset counter: 172
                        Mileage: 6059 km
                        Date: 2020.02.14
                        Time: 16:22:49
       Part No SW: 4M0 959 655 L    HW: 4M0 959 655 L
       Component: Airbag10.44   H02 0108
       Serial number: 003YS000J3EF
       Coding: AECCFCC000800000A0F00033D24C00000000
       Shop #: WSC 63256 001 1048576
       ASAM Dataset: EV_AirbaAU10BPAAU736 006016
       ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
       VCID: 44C46AEACF344E6FC3-8010
       Belt Pretensioner left:
       Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
       Component: BeltPretRevFL  205 2040
       Serial number: 4M0857705N0228S00365
       Coding: 88001B
       Belt Pretensioner right:
       Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
       Component: BeltPretRevFR  205 2040
       Serial number: 4M0857706N0226S00274
       Coding: 88001B
       Occupant Detection:
       Subsystem 3 - Part No SW: 4M0 959 339     HW: 4M0 959 339
       Component: BF-Gewichtss.  H11 0022
       Serial number: IBH0000J180009YTO806
       Subsystem 4 - Part No SW: -----------    HW: 442 062 707 18
       Component: SideSensor_Df  1E2 0887
       Serial number: 3577Y00B72752503926T
       Subsystem 5 - Part No SW: -----------    HW: 442 062 707 18
       Component: SideSensor_Pf  1E2 0887
       Serial number: 3587Y00A52845264C1F2
       Subsystem 6 - Part No SW: -----------    HW: 442 0B2 807 18
       Component: SideSensor_Dr  1C7 0148
       Serial number: 3517700AD2AF5801D30H
       Subsystem 7 - Part No SW: -----------    HW: 442 0B2 807 18
       Component: SideSensor_Pr  1C7 0148
       Serial number: 3527700B12AF580071EC
       Subsystem 8 - Part No SW: -----------    HW: 442 0C2 207 18
       Component: FrontSensor_D  1C5 014A
       Serial number: 3557500A52B05121524U
    9444115 - Front Passenger's Front Airbag Crash Sensor
              B101B 13 [137] - Open Circuit
                        Mileage: 6059 km
                        Date: 2019.11.01
                        Time: 15:43:07
    1050624 - Databus
              [NWD: 0x322 PCR_01 Timeout]
                        Reset counter: 172
                        Mileage: 6059 km
                        Date: 2020.02.14
                        Time: 14:34:43
    1056768 - Databus
              [NWD: 0x17F PCR_02 Timeout]
                        Reset counter: 172
                        Mileage: 6059 km
                        Date: 2020.02.14
                        Time: 14:34:43
    1062656 - Databus
              [NWD: 0x189 SWA_Header Timeout]
                        Reset counter: 172
                        Mileage: 6059 km
                        Date: 2020.02.14
                        Time: 14:34:43
       Part No SW: 4N0 907 129 K    HW: 4N0 907 129 K
       ROD: EV_SMLSKLOAU736_007_AU49.rod
       VCID: 393A0B1EB8F60387A0-806C
       Part No SW: 4M0 920 890 D    HW: 4M0 920 890 D
       Component: FBenUSA       H20 0414
       Coding: 09E600C12888CF05022369601800200008000000
       ASAM Dataset: EV_DashBoardAU736 001032
       ROD: EV_DashBoardAU736_AU49.rod
       VCID: 312A333E6086CBC718-8064
    16776982 - Databus
              [SWA_01 communication error can_error_timeout]
                        Reset counter: 172
                        Mileage: 6059 km
                        Date: 2020.02.14
                        Time: 14:32:35
       Part No SW: 80A 907 468 A    HW: 80A 907 468 A
       Component: Gateway       H05 0117
       Serial number: 14F01002544001
       Coding: 030100010000064054070000005900324C1A0007100000000175078E10000000
       ASAM Dataset: EV_Gatew31xAU65x 003160
       ROD: EV_Gatew31xAU65x_AU49.rod
       VCID: 2C14224A47A4A62F2B-8078
       Subsystem 1 - Part No SW: 4M0 951 523 A    HW: 4M0 951 523 A
       Component: J453 MFL  H06 0004
       Serial number: 20180822095749 30129
       Serial number: 8698858504
    131662 - Lane change assistant control module
              U1045 00 [009] - No communication
              [Timeout_Node_0x4E_DiagAdress_3C_MRR_HR]
                        Reset counter: 172
                        Mileage: 6059 km
                        Date: 2020.02.14
                        Time: 14:32:36
    131722 - Control Module 2 for Lane Change Assistance
              U10A5 00 [009] - No Communications
              [Timeout_Node_0x8A_DiagAdress_CF_MRR_HL]
                        Reset counter: 172
                        Mileage: 6059 km
                        Date: 2020.02.14
                        Time: 14:32:36
    Address 29: Left Light (J1018)       Labels: 4M0-907-397.clb
       Part No SW: 4M0 907 397 AC    HW: 4M0 907 397 C
       Component: LCM_MLBevoH05 0024
       ROD: EV_LCMLeftHELLAAU736_VW48.rod
       VCID: 78BCCE1AC37CDA8F9F-802C
       Part No SW: 4M4 959 760     HW: 4M4 959 760
       Component: MEM-FS        009 0042
       Serial number: 00000339427096
       Coding: 005C1B000000B0010000010101010000000000000000000000000000000000
       ROD: EV_SCMDriveSideCONTIAU736_AU49.rod
       VCID: 79BACB1EF876C387E0-802C
    Address 39: Right Light (J1023)       Labels: 4M0-907-397.clb
    0019 - Headlamp Type
              C119F 00 [009] - Implausible
                        Reset counter: 172
                        Mileage: 6059 km
                        Date: 2020.02.14
                        Time: 14:35:19
    0352 - Temperature sensor
              C11C1 01 [009] - Electrical Failure
                        Reset counter: 172
                        Mileage: 6059 km
                        Date: 2020.02.14
                        Time: 14:35:19
    Address 3C: Lane Change
       Part No SW: 4M0 959 793 H    HW: 4M0 959 793 F
       Component: TSG FS        005 0130
       Serial number: 0000337959977
       Coding: 005F8B005E00108000012030
       ROD: EV_DCU2DriveSideMAXHCONT_AU49.rod
       VCID: 43C669F6CA3A4957FA-8016
    524420 - Databus
              [Message SWA_01 missing]
                        Reset counter: 172
                        Mileage: 6059 km
                        Date: 2020.02.14
                        Time: 14:32:38
       Part No SW: 4N0 909 144 D    HW: 4N0 909 144 A
       Component: EPS_MLBEVO2BS H21 0504
       Coding: 90000001000100
       ASAM Dataset: EV_EPSVWBSAU426 009015
       ROD: EV_EPSVWBSAU426_009.rod
       Part No SW: 8W0 907 064 ED    HW: 8W0 907 064 DD
       Component: BCM2 MLBevo   025 0387
       Coding: 01341E00492100C0650BA0006C01580203024000810004502F0400000F04803F001E0001000000
       Shop #: WSC 00003 444 00000
       ASAM Dataset: EV_BCM2HellaAU736 014014
       ROD: EV_BCM2HellaAU736_014_AU49.rod
       VCID: 0248ACF295A0805FB1-8056
       Subsystem 1 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
       Component: Sirene, DWA  004 0007
       Serial number: 00000000000000161951
    643585 - Bulb for Brake/Tail/Turn Signal; Left
              B142E 13 [009] - Open Circuit
                        Reset counter: 172
                        Mileage: 6059 km
                        Date: 2020.02.14
                        Time: 14:37:14
                        Supply voltages-Supply voltage: Terminal 30: 15.150 V
                        Supply voltages-Supply voltage Terminal 30 - 2: 15.109 V
                        Supply voltages-Supply voltage Terminal 30 - 3: 15.109 V
                        general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 °C
                        general_additional_freeze_frame-coprocessor_spi_status: 00000000
                        general_additional_freeze_frame-dataflash_status: 00000000
                        general_additional_freeze_frame-interior_temperature: -50.0 °C
                        general_additional_freeze_frame-Operating_Status: 00000000 00000000
                        general_additional_freeze_frame-production_mode: not active
                        general_additional_freeze_frame-reset_cause: 00000000
                        general_additional_freeze_frame-Reset_counter: 0
                        general_additional_freeze_frame-Stall_current_cutoff_level: Deactivation stage 0
                        general_additional_freeze_frame-Stall_Current_Measuring_Mode: not active
                        general_additional_freeze_frame-subnetwork_status: 00000000 00000000
                        general_additional_freeze_frame-terminal_control_intern_status: 1B 02 5A 90 02 E0
                        general_additional_freeze_frame-Transport_Mode: not active
                        general_additional_freeze_frame-Vehicle speed: 0.00 km/h
                        light_freeze_frame: 11111111 11111111 11111111 11111111
    643841 - Bulb for Brake/Tail/Turn Signal; Right
              B142F 13 [009] - Open Circuit
                        Reset counter: 172
                        Mileage: 6059 km
                        Date: 2020.02.14
                        Time: 14:37:10
                        Supply voltages-Supply voltage: Terminal 30: 15.136 V
    644097 - Bulb 2 for Brake/Tail/Turn Signal; Left
              B1430 13 [009] - Open Circuit
                        Reset counter: 172
                        Mileage: 6059 km
                        Date: 2020.02.14
                        Time: 14:37:14
    644353 - Bulb 2 for Brake/Tail/Turn Signal; Right
              B1431 13 [009] - Open Circuit
                        Reset counter: 172
                        Mileage: 6059 km
                        Date: 2020.02.14
                        Time: 14:37:10
    65896 - Databus
              [Climatronic control module: Klima_03: no signal/communication]
                        Reset counter: 212
                        Mileage: 6059 km
                        Date: 2020.02.14
                        Time: 14:40:56
                        Supply voltages-Supply voltage: Terminal 30: 12.365 V
                        Supply voltages-Supply voltage Terminal 30 - 2: 12.337 V
                        Supply voltages-Supply voltage Terminal 30 - 3: 12.337 V
                        general_additional_freeze_frame-terminal_control_intern_status: 40 04 5A 12 02 98
                        can_lin_communication_freeze_frame: 00000000 00000000 00000000 00000000
    65915 - Local Data Bus 3
              U10C8 00 [009] - No Communications
                        Reset counter: 172
                        Mileage: 6059 km
                        Date: 2020.02.14
                        Time: 14:33:59
                        Supply voltages-Supply voltage Terminal 30 - 2: 15.095 V
                        Supply voltages-Supply voltage Terminal 30 - 3: 15.082 V
       Part No SW: 4M0 035 223 C    HW: 4M0 035 223
       Component: MIB2_amp_PD   H03 0440
       Serial number: 00000000113594
       Coding: 0135060A008AF53AAF0000010000
       ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
       ROD: EV_AMPMst16C4Gen2BOSE_AU73.rod
       VCID: 2306C9762A7A69579A-8076
    Address 50: Seat Adj. 3rd row (J857)       Labels:* None
       Part No SW: 4M1 959 760 G    HW: 4M1 959 760 G
       Component: MEM-SR3       008 0016
       Serial number: 00000339260989
       Coding: FF041020F1000000000F000000000900000021210900000000000000440000
       ASAM Dataset: EV_SCM3rdRowCONTIAU736 005007
       ROD: EV_SCM3rdRowCONTIAU736.rod
       Part No SW: 4M0 959 792 H    HW: 4M0 959 792 F
       Component: TSG BFS       005 0130
       Serial number: 0000335791104
       ROD: EV_DCU2PasseSideMAXHCONT_AU49.rod
       VCID: 42C86CF2D520405FF1-8016
    524420 - Databus
                        Reset counter: 172
                        Mileage: 6059 km
                        Date: 2020.02.14
                        Time: 14:32:38
    Address 5F: Information Electr. (J794)       Labels:* 4M0-035-MIB-HGH2.clb
       Part No SW: 4M1 035 880 C    HW: 4M1 035 880
       Component: MU-P-LNS-US   035 1316
       Serial number: A724H0JB070917
       Coding: 013706020000000051220002041A00332F001BE401700904FE
       Subsystem 1 - Part No SW: V03 959 802 DK    HW: -----------
       Component: NAR 2018/2019  --- 0066
       Subsystem 2 - Part No SW: 4M0 919 605     HW: 4M0 919 605
       Component: AU536_DU_HIGH  H43 0008
       Serial number: AUZ8Z9JJ40790Y
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 4M0 919 615 M    HW: 4M0 919 615 M
       Component: ControlUnit_P  H15 0306
       Serial number: 22081800000000001116
       Component: Gracenote2  --- 3013
    7194 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Side assist (0x1A) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 172
                        Mileage: 6059 km
                        Date: 2020.02.14
                        Time: 14:32:38
                        Voltage terminal 30: 11.4 V
                        BAP-BAP_Function_ID: 02
       Part No SW: 4M0 907 383 E    HW: 4M0 907 383
       Component: Anhaenger     H27 0253
       Revision: 9C001003    Serial number: 0489988134
       Coding: 0210000200000000
       Part No SW: 4M0 907 428 F    HW: 4M0 907 428
       Component: Areaview 2    H13 0318
       Serial number: C854607JG069692
       Coding: 02350602BB0FA10038004004
       ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 005015
       ROD: EV_CamSysRVAV2CE2MLBEv_005.rod
       VCID: 3522072E94EEE7E744-8060
    9598995 - Video Signal Line for Front Surroundings Camera
              B1278 01 [009] - Electrical Failure
                        Reset counter: 172
                        Mileage: 6059 km
                        Date: 2020.02.14
                        Time: 14:32:38
    13706029 - Voltage Supply for Camera; Front
              B1862 01 [009] - Electrical Failure
                        Reset counter: 172
                        Mileage: 6059 km
                        Date: 2020.02.14
                        Time: 14:33:26
       Part No SW: 8W8 959 107 D    HW: 8W8 959 107
       Component: HDSG-Modul    H13 0170
       Revision: --------    Serial number: A2-C744-8781-0
       Coding: 00B0
       ASAM Dataset: EV_DeckLidCONTIAU736 001016
       ROD: EV_DeckLidCONTIAU736_AU73.rod
       VCID: 4AD844D2ED10981F39-801E
       Part No SW: 4K1 035 283     HW: 4K1 035 283
       Component: ConBox        H07 0100
       Serial number: 005CCA12F040049
       Coding: 01C020FE4040800000
       ASAM Dataset: EV_ConBoxAU651 001004
       ROD: EV_ConBoxAU651_001_AU49.rod
       VCID: 6582976E64CE576734-8030
    Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
       Part No SW: 4M1 713 041 H    HW: 4M1 713 041 G
       Component: GSM-LL        H10 0077
       Revision: 0L0D5012    Serial number: 18072448461903
       ASAM Dataset: EV_GSMWaehlZFAU736 001017
       ROD: EV_GSMWaehlZFAU736.rod
       VCID: 2A1824524D50B81FD9-807E
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
       Part No SW: 4M0 907 217 F    HW: 4M0 907 217 E
       Component: BVS           H17 0052
       Coding: 0407030600000201022023A3A50000B400F0C020C000
       ROD: EV_BVSMLBevKOSTAAU736_AU73.rod
    1122656 - Databus
              [TIMEOUT_SWA_Objekt_01_02]
                        Reset counter: 172
                        Mileage: 6059 km
                        Date: 2020.02.14
                        Time: 14:32:35
                        Control Module temperature: 64 °C
                        Voltage terminal 15: 11.50 V
    1123714 - Databus
              [Airbag_01_AB_Systemfehler]
                        Reset counter: 172
                        Mileage: 6059 km
                        Date: 2020.02.14
                        Time: 14:32:38
       Part No SW: 4M0 959 795 H    HW: 4M0 959 795 F
       Component: TSG HFS       005 0130
       Serial number: 0000340159818
       Coding: 004F8B000000108040002020
       ROD: EV_DCU2RearDriveMAXHCONT_AU49.rod
       VCID: 45C277EEC40E7767D4-8010
       Component: TSG HBFS      005 0130
       Serial number: 0000340159696
       ROD: EV_DCU2RearPasseMAXHCONT_AU49.rod
       Part No SW: 4M0 907 594 G    HW: 4M0 907 594
       Coding: 2A8000053602
       VCID: 3A381412BDF0089FA9-806E
    Address CF: Lane Chge Asst 2
       Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
       Component: LED1L         H09 0003
       VCID: 1660E0A2E9280CFF6D-8042
       Component: LED1R         H09 0003
    End----------(Elapsed Time: 02:24, VBatt start/end: 14.7V/14.8V)-----------
    Scratching head. I see nothing that can be "programmed" in this module:
                        Reset counter: 172
                        Mileage: 6059 km
                        Date: 2020.02.14
                        Time: 14:35:19
                        Reset counter: 172
                        Mileage: 6059 km
                        Date: 2020.02.14
                        Time: 14:35:19
    Those fault codes make me think there are still hardware issues there.
    Tartu, Estonia
    It could be programmable, but that would mean it is dataset with ODIS.
    Alos P/N AC is dropped and was only available suggestion in the ETKA catalogue for Chineese Audi A4L.
    The world is my oyster...
  4. Likes Uwe liked this post
