Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Problem with clutch a3 8p
    Nov 2014
    New Zealand
    Is the over-centre spring still in position behind the clutch pedal too?
    It actually pushes the pedal DOWN when it's past a certain point, and only pushes it back UP, for the top part of it's travel.
    Allan
    The R32ran Thread
    How to post a full Auto-Scan
  2. Likes Stopro92 liked this post
  3. #12
    Jan 2020
    Yes, I compared the old clutch with the new one, both are the same, the pedal spring has also been changed. I think only the snake remains. Today, when I was riding, the pedal worked ok, but several times there was a problem with switching the gear, so maybe this hose is actually damaged.
  4. #13
    Dallas (McKinney) ,TX ,USA
    The Question is it is 5 or 6 speed?
    Is it clutch brand new good brand or used and if is 6 speed did you replace clutch bearing assembly ( this will be slave cylinder and bearing assembly)?
    Also when you aid clutch pump , do you mean Master cylinder ?
    Immobilizer/ECU
    email : marinmm2001@gmail.com
  5. Likes Jack@European_Parts, Stopro92 liked this post
  6. #14
    Jan 2020
    At the beginning I bought a new clutch Luk probably was defective, now I bought a second complete new Sachs clutch, when I installed the Sachs clutch the problem was slightly reduced, but not quite, now the pedal is fine, but from time to time I do not bounce. When stationary, sometimes I can not change to 1 gear or reverse, while gears easily enter while driving. I also replaced the clutch pedal pump (2x).
  7. #15
    This is an indication of incorrect flywheel/plate offset or inadequate reach of Throw out fork.
    This is why you have to measure stuff and not blindly install anything anymore?
    The old days of trusting a brand is over!
    Is not all just re-boxed shit and thrown together from cheapest supplier to hit a price point & reality now?
    Marin makes a good point too, that's why I love emm, even if we disagree from time to time!
  8. Likes Stopro92 liked this post
  9. #16
    Jan 2020
    I measured both clutches from the original one and comes out the same, I will try to replace this hose as soon as possible, maybe it will help. I will let know after the exchange. Thanks all for help and suggestions.
  10. #17
    I still did not get all answers, Read my post again?
    Immobilizer/ECU
  11. Likes Jack@European_Parts liked this post
  12. #18
    Jan 2020
    I replaced this hose, the clutch finally returned to normal! Thanks all for help and all suggestions.
