Results 1 to 4 of 4
Thread: Stalling issues with cold engine in my 2017 alltrack TSI
    Jan 2016
    Hi Folks--I'm posting the relevant portion from my scan below. There are a couple of odd symptoms = like I said I get stalling issues when starting from a stop while the engine is cold.
    Also--not sure it's related to the above issue, but my traction control light also flashes intermittently and I get a loss of power. This also seems to happen when cold and the loss of power is alleviated when I turn the traction control off. This started happening after recently replacing my tires.
    Would welcome any advice. Thanks!
    Address 01: Engine (J623-CXBB) Labels:. 06K-907-425-V1.clb
    Part No SW: 8V0 906 264 L HW: 06K 907 425 B
    Component: 1.8l R4 TFSI H13 0002
    Revision: --H13---
    Coding: 311D00122426002F0000
    Shop #: WSC 00066 790 00202
    ASAM Dataset: EV_ECM18TFS0208V0906264L 001003
    ROD: EV_ECM18TFS0208V0906264L.rod
    VCID: 45819B70C44FAF67EA-8011
    15101 - MAP/MAF <-> Throttle Position Correlation
    P0068 00 [096] - -
    26372 - Leak in Air Intake System
    P2279 00 [096] - -
    23126 - Fuel Level Sensor Circuit
    P0461 00 [096] - Implausible Signal
    Quote Originally Posted by fenderblender View Post
    P2279 00 [096] - -
    I would start here...
    Hmm... All those faults are "Intermittent - Not Confirmed".
    Please post the whole Auto-Scan for context. There may be more clues in other modules and/or the Gateway Installation List.
  5. Likes Jack@European_Parts liked this post
  6. #4
    How many ground straps do you want to buy?
