Results 1 to 5 of 5
Thread: 2013 Audi S5 Cabriolet
    Feb 2020
    Hello Everyone.
    Hope someone can help me with this:
    Background: I purchased my first Audi in September of last year due to totaling of last car. About 6 weeks after purchase there was an icestorm and I slid into a curb going about 2mph. Immediately my power steering went out. After some research I figured it was probably the steering rack or the steering control module. Upon recommendation from family member I went to a non dealership mechanic. After getting the car back with the steering rack replaced along with steering control module I found that there were more errors lights showing up. These included ESP, Dynamic Steering Fault(ok to drive it says), Sports Differential not working, Adaptive Headlight control failure. The mechanic stated that they should go away after a few days driving. I doubted this and I was correct. The errors remained, after talking to the mechanic, he stated it would have to be programmed at the dealership. After paying the mechanic I really do not have the cash to take to dealer. I had already planned on purchasing vagcom and thought maybe I could fix myself. I would appreciate any help on this, basically, just need to know if there is a way to fix the issues using Vagcom or if I need to take to authorized dealer.
    So now for some information:
    2013 Audi S5 Prestige Cabriolet
    PR Codes
    E0A 7GB 4UB 6XM 5SG 5RW
    1KE J0Z 1LJ           1AT  1BD
    3FT               5TG  7X7
    F0A        9G3 0G7 0YM 0JJ
    TC6 3KA 8EH U1B X9A QZ7
    2PK        8Q5 9Q8 8Z6 D11
    7T6 CP7 7K6 4X1 2K4
    3L4                     4I3 5D2
    1SA              Q4Q      4GQ
    And the autoscan:
    VIN: WAUVGAFH7DN008235   License Plate:
    Mileage: 92260km-57327mi   Repair Order:
    Chassis Type: FH-AU48 (8R0)
    Scan: 01 02 03 05 06 08 09 15 16 17 19 22 26 36 3C 42 44 46 47 52
              53 56 5F 62 6C 72 A9
    VIN: WAUVGAFH7DN008235   Mileage: 92260km-57327miles
    26-Auto Roof -- Status: Cannot be reached 1100
    Address 01: Engine (J623-CGXC)       Labels:. 06E-907-551-CGW.clb
       Part No SW: 8K5 907 551 E    HW: 4G0 907 551 A
       Component: 3.0l V6 TFSIH07 0004
       Revision: --H07---
       Coding: 1A250034052600060000
       ASAM Dataset: EV_ECM30TFS0218K5907551E 001004
       ROD: EV_ECM30TFS0218K5907551E.rod
       VCID: 38292EBFA2D39E17315-806C
    6201 - Function Restriction due to Faults in Other Modules
              U1113 00 [039] - -
                        Mileage: 92263 km
                        Date: 2020.02.13
                        Time: 17:43:10
                        Engine speed: 701.00 /min
                        Normed load value: 11.4 %
                        Coolant temperature: 69 °C
                        Intake air temperature: 24 °C
                        Voltage terminal 30: 13.405 V
                        Engine speed: actual: 672 /min
                        MAF_ENVD: 114.38823 mg/stroke
                        Coolant temperature (unfiltered): 69.75 °C
                        Engine: operating status: IS
                        Engine load: 11.328125 %
                        Vehicle speed: actual: 0 km/h
    7888 - Implausible Data Received from Steering Angle Sensor Module (G85)
              U0428 00 [039] - -
                        Mileage: 92263 km
                        Date: 2020.02.13
                        Time: 17:43:35
                        Engine speed: 708.00 /min
                        Normed load value: 10.6 %
                        Voltage terminal 30: 13.609 V
                        Engine speed: actual: 704 /min
                        Battery voltage: 13.609375 V
    Readiness: 1110 1101
       Part No SW: 8K2 927 156 M    HW: 0B5 927 156 J
       Component: 0B5 30TFSINAR H01 0006
       Revision: --H01---
       Coding: 000001
       ASAM Dataset: EV_TCMDL501021 001010
       ROD: EV_TCMDL501021.rod
       VCID: 40D9465FFA03D6D7895-8014
       Part No SW: 8K0 907 379 CK    HW: 8K0 907 379 CK
       Coding: 291D1A
       VCID: 04518A4FAE1B0AF7EDD-8050
       Part No SW: 8K0 907 064 GP    HW: 8K0 907 064 FP
       Component: BCM2 2.0      H11 0621
       Coding: 0D834F00000000000000
       Subsystem 1 - Part No SW: 8K0 959 754 AB    HW: 8K0 959 754 AB
       Serial number: 0512000079242006
       Subsystem 2 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
       Serial number: 2312000256743011
       Part No SW: 8T0 959 760 E    HW: 8T0 959 760 E
       Component: MEM-BFS       H10 0076
       Revision: AA000000    Serial number: 00000045198993
       Coding: 00037025002C00000000
       VCID: 45D7574BE5A1F3FFBA3-8010
       Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
       Revision: C1000000    Serial number: 01281120120448
       Coding: 6603228000
       VCID: 392F2BBB9959871FCEB-806C
    00830 - Convertible Top Control Module (J256)
                        Reset counter: 20
                        Mileage: 92263 km
                        Date: 2020.02.13
                        Time: 17:43:05
       Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
       Revision: 09016001    Serial number: 00000501313302
       Coding: 26000091863CAFE0210048C300003D0D0F9CD288A2090221000008004000010200040070000000
       Shop #: WSC 28660 002 1048576
       VCID: 7AADF4B7DCDF4C07871-802E
       Subsystem 1 - Part No SW: 8F1 955 119     HW: 8K1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 241112  H07 0080
       Serial number: SWF12110245035
       Coding: 00FD11
       Serial number: 20766405
       Coding: 02005D
       Component: E1 - LDS  H03 0031
       Serial number: 00000000001911121325
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555R40Y102
       Subsystem 5 - Part No SW: 8K5 941 329     HW: 8K5 941 329
    H01 0031
       Subsystem 6 - Part No SW: 8K5 941 329     HW: 8K5 941 329
    H01 0031
       Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Serial number: 3D29CB56000000000001
                        Reset counter: 20
                        Mileage: 92263 km
                        Date: 2020.02.13
                        Time: 17:43:05
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 20
                        Mileage: 92263 km
                        Date: 2020.02.13
                        Time: 17:43:10
    Address 15: Airbags (J234)       Labels:| 8F0-959-655.clb
       Part No SW: 8F0 959 655 E    HW: 8F0 959 655 E
       Component: AirbagVW-AU10 H12 0430
       Serial number: 003KKD80410Q
       Coding: 303741353731303030304A55304C38463053
       ASAM Dataset: EV_AirbaAU10SMEAU485 001004
       ROD: EV_AirbaECUVWAUDI010.rod
       VCID: 3A2D34B79CDF8C07C71-806E
       Subsystem 1 - Part No SW: 8K0 959 339 A    HW: 8K0 959 339 A
       Component: BF-Gewichtss.  H02 0060
       Serial number: 5810000R120000C1A2
       Serial number: 6334MSME74036D23B
       Serial number: 6344MSME7304104E7
       Serial number: 6352QSME5A25326EO
       Serial number: 6362QSME03262440%
       Serial number: 63732SME2C6E516EG
       Serial number: 63832SME3428234C
       Revision: --------    Serial number: 90372LKJ0022Z
       Coding: 000036
       VCID: 44D14A4FEE9BCAF7ADD-8010
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 20
                        Mileage: 92263 km
                        Date: 2020.02.13
                        Time: 17:43:05
                        (no units): 41.0
                        Text: 29652D32001000EA02
                        Steig. Befuellungskennlinie: 2.250 l/mm
                        Raw, Form. N/A: 000 016 000
                        Text: 368D0000393FCFCF10
                        Work Shop Code: 81871
                        Raw, Index/Key Err.: 207 016 118
       Part No SW: 8T0 920 983 P    HW: 8T0 920 983 P
       Component: KOMBIINSTR.   H35 0556
       Revision: 00000000    Serial number: UUZ43WKCD
       Coding: 8BB719008B01D705020000
       VCID: 4BC36173C3C5058F6C7-801E
       Component: GW-BEM 5CAN-M H11 0055
       Revision: 1Z100027    Serial number: 2741Z12B11019B
       Coding: 80C303FF00
       Shop #: WSC 02391 823 56573
       VCID: 4CC1626FC6CB02B765D-8018
       Serial number: 0690688501
                        Reset counter: 20
                        Mileage: 92263 km
                        Date: 2020.02.13
                        Time: 17:43:07
                        Bin. Bits:    11111
                        Voltage: 13.10 V
                        Count: 6
                        Bin. Bits:    10000
                        Time: 25.40 s
    Address 22: AWD (J492)       Labels: 8K0-907-163.clb
       Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
       Component: 4 Wheel Drive H13 0100
       Serial number: 001311120001400
       ASAM Dataset: EV_AllWheelDiffeQSPCAN 003019
       VCID: 2F3B15E3579D59AF60F-807A
    0127 - Please Check Fault Codes in Control Module for Steering Wheel Electronics
              U1028 00 [137] - -
              [Lenkradwinkelsensor Bitte Fehlerspeicher auslesen DTC_CAN_LWI_INVALID_VALUE]
                        Reset counter: 20
                        Mileage: 92263 km
                        Date: 2020.02.13
                        Time: 17:43:08
    0059 - Please Check Fault Codes in Control Module for ABS Brakes
              U1017 00 [137] - -
              [ESP - Steuergerät nicht verfügbar DRC_CAN_ESP_01_SYS_ST]
                        Reset counter: 20
                        Mileage: 92263 km
                        Date: 2020.02.13
                        Time: 17:43:08
    Address 26: Auto Roof
       Component: MEM-FS        H10 0076
       Revision: AA000000    Serial number: 00000045232319
       Coding: 001B7B25002C00000000
       Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
       Component: SWA Master    H04 0060
       Serial number: 0188339073
       Coding: 010211
       VCID: 3FDB45A387FDA92FF0F-806A
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
       Component: SWA Slave  H04 0060
       Serial number: 0188079291
       Coding: 000102
       Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
       Component: TSG FA        H09 0304
       Coding: 011C53724E08332C03
       VCID: 56F5800708074867C39-8002
                        Reset counter: 20
                        Mileage: 92263 km
                        Date: 2020.02.13
                        Time: 17:43:05
       Component: RCEPS         H36 0507
       Revision: 00001000    Serial number: 0024399094
       Coding: 100000000001
       Shop #: WSC 21787 001 1048576
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 34311A8FBEBB7A771DD-8060
    4215044 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
              [Fehlerwert "Lenkradwinkel"]
                        Reset counter: 20
                        Mileage: 92263 km
                        Date: 2020.02.13
                        Time: 17:43:08
                        Write only channel
    4208000 - Steering Angle Sensor
              B1168 F1 [137] - Synchronization Failed
                        Reset counter: 20
                        Mileage: 92263 km
                        Date: 2020.02.13
                        Time: 17:43:08
                        Write only channel
              [Lenkungsendanschläge nicht angelernt]
                        Reset counter: 20
                        Mileage: 92263 km
                        Date: 2020.02.13
                        Time: 17:43:08
                        Write only channel
       Revision: 00002001    Serial number: 0188371774
       Coding: 010606BA00FA402180B0033200000000
       Subsystem 1 - Part No SW: 8F0 959 719 B    HW: 8K0 959 719
       Component: GTO BF  H01 0080
       Serial number: 00000000000000598182
                        Reset counter: 20
                        Mileage: 92263 km
                        Date: 2020.02.13
                        Time: 17:43:05
       Part No SW: 8F1 035 223 A    HW: 8F1 035 223 A
       Revision: 00005001    Serial number: 94833008237001
       VCID: 1F1BE52327BDC92FD0F-804A
    03278 - Functionality Limited due to Missing Messages
                        Reset counter: 20
                        Mileage: 92263 km
                        Date: 2020.02.13
                        Time: 17:43:10
                        Voltage: 13.60 V
                        Temperature: 21.0°C
                        Temperature: 24.0°C
                        Bin. Bits: 00000100
                        Bin. Bits: 00010000
                        Bin. Bits: 00000000
       Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
       Component: TSG BF        H09 0304
       Coding: 011C53324E08332C03
       VCID: 55F7870B1501437FCA3-8000
                        Reset counter: 20
                        Mileage: 92263 km
                        Date: 2020.02.13
                        Time: 17:43:05
       Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
       Component: EPB-4         H01 0003
       Revision: --------    Serial number: 20000000182776
       ROD: EV_ParkiBrake_AU48.rod
       Part No SW: 4G0 035 082 H    HW: 4G0 035 082
       Component: Radio U SIRIU H60 0138
       Revision: AB001007    Serial number: 156KW0C7670001
       Coding: 020007010000000101
       VCID: 2517F7CB05E113FF9A3-8070
                        Reset counter: 20
                        Mileage: 92263 km
                        Date: 2020.02.13
                        Time: 17:43:08
                        Bin. Bits: 00000000 00010000
       Part No SW: 8R1 035 746 K    HW: 8R1 035 746 B
       Component: H-BNT-NA      H44 1040
       Revision: --------    Serial number: 204K$0C7545706
       Coding: 140200030206A1EF55028B4E00000401150000000000000000
       Shop #: WSC 05338 002 1048576
       VCID: 3FDB45A3877DA92FF0F-806A
       Subsystem 1 - Part No: 8R0 060 884 BA
       Component: NAR 2013  0703
       Component: DU7 High  H41 0104
       Serial number: A130K%0C2589807
       Serial number: 00000001344503
       Component: CD-Database  4949
       Part No SW: 8T0 959 795 F    HW: 8T0 959 795 F
       Component: TSG HL        H08 0304
       Coding: 010C13304008372C03
       VCID: 4EC5686730D730A70B9-801A
       Part No SW: 8F0 907 441     HW: 4L0 907 441 B
       Revision: --H07---    Serial number: 525PA8-J2XB081
       Coding: 1000009
       VCID: 678BBDC3B36DC1EF68F-8032
                        Reset counter: 20
                        Mileage: 92263 km
                        Date: 2020.02.13
                        Time: 17:43:05
                            Reverse OFF
                        Count: 3
       Component: TSG HR        H08 0304
    Address A9: Struct. Borne Sound        Labels: None
       VCID: 55F7870B1581437FCA3-8000
    No ASAM data for: "Unknown" (AU48)
    End----------(Elapsed Time: 03:05, VBatt start/end: 13.8V/14.4V)-----------
    Thursday,13,February,2020,19:03:03:00349
    Gateway Installation List:  8R0 907 468 P
    5F-Information Electr. -- Status: Cannot be reached 1100
    Thanks in advance for any help anyone can give.
    BTW Absolutely love my Audi
  2. Likes Boki Ar liked this post
  3. #2
    Jan 2018
    Cheshire UK
    Looks like you mechanic has not done the job properly.The steering angle sensor needs calibrating for a start. You will need VCDS or a similar diagnostic tool to recalibrate the sensor. Not difficult to do and there are some ross tech guides on how to do this.
    Start there and reset the fault codes and see what comes back.
    A6 BiTdi Avant MTM
    Retrofitted: Full Led Headlights, DAB, Full Electric Seats, Power Tailgate, Surround View Cameras, Genuine RS6 Grille, RS6 Seats,Leather Door Armrests, Soft Close Doors, Rear Side Blinds, Electric Steering Column, LED Sill Plates, Ambient Lighting Pack, High Beam Assist, Eibach Springs, Led Roof Console, 4 Zone Climate, Rear Heated Seats, Head Up Display, Side assist, Alcantara Interior Retrim
    Hmm.. The steering column control module at address 16 says: "Steering Angle Sensor (G85) - Defective".
    I don't have much confidence that this can be fixed by any kind of calibration.
    Feb 2020
    So, even if I am getting good information from the sensor it can still be bad? Sensor says it is calibrated and when I turn steering wheel I get legit looking data from the angle sensor and from the torque sensor on the steering wheel. The issue is when I try to turn on Basic settings it keeps giving me message that group 1 error not availabe.
    Oct 2017
    Northwest UK
    Quote Originally Posted by SDD110 View Post
    Defective means it needs replacing.
