Results 1 to 2 of 2
Thread: Audi A4 B9 2016 - high beam assist?
    Sep 2019
    Croatia
    Auto scan: note that after clearing DTC's, no errors were present
    Thursday,13,February,2020,13:37:50:60999
    VIN: WAUZZZF41HA015198   License Plate: ZG8141HM
    Mileage: 137005km-85130mi   Repair Order:
    Chassis Type: F4-AU49 (4M1)
    Scan: 01 02 03 08 09 15 16 17 19 29 39 42 44 46 52 5F 81 A5 AC BB
              BC D6 D7
    VIN: WAUZZZF41HA015198   Mileage: 137005km-85130miles
    39-Right Light -- Status: Malfunction 0010
    Address 01: Engine (J623-CSWB)       Labels: None
       Part No SW: 8W0 907 311 B    HW: 059 907 309 F
       Component: 3.0l V6 TDI   H21 0003
       Revision: C7H21---
       Coding: 0A2540320324050324080000000000000000000000000000
       Shop #: WSC 52898 001 1048576
       ASAM Dataset: EV_ECM30TDI0118W0907311B 001004
       ROD: EV_ECM30TDI0118W0907311B.rod
       VCID: 3634DDE708C999C7239-8062
    21378 - Reductant Metering Module
              P20FE 00 [096] - Malfunction
    9645 - Reductant
              P20E8 00 [096] - Pressure too Low
       Part No SW: 8W0 927 155 H    HW: 0CK 927 156 S
       Component: 0CK 30TDI RdW H09 0005
       Revision: --H09---    Serial number: 0000000629
       Coding: 000001
       ASAM Dataset: EV_TCMDL382021 002023
       ROD: EV_TCMDL382021_AU49.rod
       VCID: 44D0B72F4E153B57ADD-8010
       Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
       Component: V553 MTFP  002 0572
       Serial number: 75117071160104001055
    Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PLU-V1.clb
       Part No SW: 8W0 907 379 E    HW: 8W0 907 379 J
       Component: ESP9 Plus     H06 0593
       Coding: 0CAA2C9910A30A9B159F489A00855292E6A59230340850A812004A4967A549
       Shop #: WSC 06324 790 00001
       ASAM Dataset: EV_ESP9BOSCHAU49X 012014
       ROD: EV_ESP9BOSCHAU49X_012.rod
       VCID: 47CAA0237F23104F48F-8012
    6 Faults Found:
    352772 - System Voltage
              P0562 00 [032] - Too Low
    143360 - Function Restricted due to Insufficient Voltage
              U1400 00 [032] - -
              [Undervoltage_dectected_in_network]
    420352 - TPMS Warning; Front Left Tire
              C1054 00 [032] - Pressure too Low
    416768 - TPMS Warning; Front Right Tire
              C1056 00 [032] - Pressure too Low
    420096 - TPMS Warning; Rear Left Tire
              C1058 00 [032] - Pressure too Low
    417024 - TPMS Warning; Rear Right Tire
              C105A 00 [032] - Pressure too Low
    Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
       Part No SW: 8W0 820 043 G    HW: 8W0 820 043 G
       Component: Klima Zone 3  H32 0071
       Coding: 1618002D5544400D02000100880000000000000000000000000000000000
       Shop #: WSC 06325 790 00001
       ROD: EV_AirCondiBHTCAU491.rod
       VCID: 372AD0E30FC360CF38F-8062
       Subsystem 1 - Part No SW: 4M1 820 021     HW: 4M1 820 021
       Component: J216 FLuftV  H05 0001
       Serial number: 00000000000000888830
       Component: AQ_Hum_Sensor  H01 0003
       Serial number: C4C8CC28000000000001
       Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
       Component: Klima Heck  H34 0073
       Part No SW: 8W0 907 063 BG    HW: 8W0 907 063 BG
       Component: BCM1 MLBevo   H13 0248
       Coding: 07501143E11800CD014D8714182C00B9110B3108000000000000000020001A810A450122025601
       ASAM Dataset: EV_BCM1BOSCHAU736 016006
       ROD: EV_BCM1BOSCHAU736_016.rod
       VCID: 015E7E3B1187EE7FC6B-8054
       Subsystem 1 - Part No SW: 8W1 955 119     HW: 8V1 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS491 160504  043 0813
       Serial number: 894353?0301612504960
       Coding: 5BC7F7
       Subsystem 2 - Part No SW: 81A 955 555     HW: 81A 955 555
       Component: G397_RLFSS  H06 0001
       Serial number: 20019889X81A95555500
       Coding: 02005D
       Light switch:
       Subsystem 3 - Part No SW: 4M0 941 531 AA    HW: 4M0 941 531 AA
       Component: E1 - LDS  H06 0008
       Serial number: 25 03 2016  00295154
       Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
       Serial number: GX1CE128031611520345
       Coding: 030000
       Interior Light Module:
       Subsystem 5 - Part No SW: 8W0 947 135 D    HW: 8W0 947 135
       Component: J528-Dachele  H13 0082
       Serial number: B10154713
       Subsystem 6 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
       Component: SL-B9/Q5NF  H16 0010
       Serial number: 2616000040239003
    66950 - Databus
              [LCM rechts - Tagfahrlicht defekt]
                        Reset counter: 49
                        Mileage: 134423 km
                        Date: 2019.10.30
                        Time: 17:29:40
                        average_Voltage_terminals: 11.70 V
                        Outside air temperature sensor-Resistance: 0.00 kOhm
                        Outside air temperature sensor-Outside air temperature on CAN: 6.50 °C
                        interior_temperature: 6.00 °C
                        Vehicle speed: 0.00 km/h
                        Terminal control-Terminal 75 status: OFF
                        Terminal control-Terminal 15 status signal: OFF
                        Terminal control-Terminal 15 via CAN: OFF
    66962 - Databus
              [LCM rechts - Standlicht defekt]
                        Reset counter: 49
                        Mileage: 134423 km
                        Date: 2019.10.30
                        Time: 17:29:40
    Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
       Part No SW: 8W0 959 655     HW: 8W0 959 655
       Component: Airbag10.44   H72 0086
       Serial number: 003M60045ZSH
       Coding: AACCF0C00C800000585400F3C00C00000000
       ASAM Dataset: EV_AirbaAU10BPAAU736 005012
       ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
       VCID: 06546D2738A9C947F39-8052
       Belt Pretensioner left:
       Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
       Component: BeltPretRevFL  205 2033
       Serial number: 8W0857705A0158Q00540
       Coding: 88001B
       Belt Pretensioner right:
       Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
       Component: BeltPretRevFR  205 2033
       Serial number: 8W0857706A0155Q00108
       Coding: 88001B
       Subsystem 3 - Part No SW: -----------    HW: 442 061 105 16
       Serial number: 3577Y00BD1F34384E28D
       Subsystem 4 - Part No SW: -----------    HW: 442 061 205 16
       Serial number: 3587Y00C31F34382E362
       Subsystem 5 - Part No SW: -----------    HW: 442 0B2 904 16
       Serial number: 3517700C31C81BC4F04K
       Subsystem 6 - Part No SW: -----------    HW: 442 0B2 904 16
       Serial number: 3527700C51C81BC6637M
       Subsystem 7 - Part No SW: -----------    HW: 442 0C0 605 16
       Serial number: 3557500A320DD1E02232
       Front Sensor Passenger:
       Subsystem 8 - Part No SW: -----------    HW: 442 0C0 605 16
       Component: FrontSensor_P  1C5 014A
       Serial number: 3567500A120DD1E33235
       Pedestrian Protection Center:
       Subsystem 9 - Part No SW: -----------    HW: 442 0C0 405 16
       Component: PedP_Sensor_C  1C5 014A
       Serial number: 2307500B720D8154134X
       Subsystem 10 - Part No SW: -----------    HW: 442 431 405 16
       Component: PedPSensor_D2  256 0887
       Serial number: I0M9M00C91DE13F3D24W
       Subsystem 11 - Part No SW: -----------    HW: 442 431 405 16
       Component: PedPSensor_P2  256 0887
       Serial number: I0N9M00C91DE13F4E19$
       Part No SW: 4M0 907 129 HA    HW: 4M0 907 129 HA
       Component: Lenks.Modul   H11 0009
       ROD: EV_SMLSKLOAU736_006.rod
       VCID: 76B41DE74849D9C7E39-8022
    Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
       Part No SW: 8W5 920 790 C    HW: 8W5 920 790 C
       Component: FBenRDW       H15 0299
       Coding: 04A450C0288000080020E9601000000000000000
       ASAM Dataset: EV_DashBoardAU736 001022
       VCID: 42DCB137540135679F1-8016
       Part No SW: 4M1 907 468 C    HW: 4M1 907 468 A
       Component: Gateway       H15 0098
       Revision: 4R040002    Serial number: 0244R009516520
       Coding: 0301000100000E407F070000005900124C100007000000000100000000000000
       ASAM Dataset: EV_GatewCONTIAU736 002060
       ROD: EV_GatewCONTIAU736_002_AU73.rod
       Subsystem 1 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
       Component: J453 MFL  H04 0002
       Serial number: 20160428020605 00059
       Serial number: 6971090404
    Address 29: Left Light (J1018)       Labels: 4M0-907-397.clb
       Part No SW: 4M0 907 397 AC    HW: 4M0 907 397 C
       Component: LCM_MLBevoH05 0023
       VCID: 78A813DF425DAFB7F15-802C
    Address 39: Right Light (J1023)       Labels: 4M0-907-397.clb
    0566 - LED DRL / Parking Lights
              C11BD F6 [008] - Output Voltage / Power Implausible
                        Reset counter: 49
                        Mileage: 134423 km
                        Date: 2019.10.30
                        Time: 17:29:37
       Part No SW: 8W0 959 593 G    HW: 8W0 959 593
       Component: TSG FS        005 0052
       Serial number: 0000202747070
       Coding: 001F1B215000008000001080
       VCID: 4EC495079059C1070B9-801A
       Part No SW: 8W0 909 144 F    HW: 8W0 909 144 B
       Component: EPS_MLBEVO_ZF H08 0407
       Coding: 09000380008000
       ASAM Dataset: EV_EPSZFAU49X 002015
       ROD: EV_EPSZFAU49X_002.rod
       VCID: 40D8BB3F5A0D2777895-8014
       Part No SW: 8W0 907 064 BC    HW: 8W0 907 064 C
       Component: BCM2 MLBevo   018 0327
       Coding: 01340000000000A0630980000E00000031024000004B02502F0400000104803F001F0001000000
       ASAM Dataset: EV_BCM2HellaAU736 011012
       ROD: EV_BCM2HellaAU736_011_AU49.rod
       VCID: 7EA405C760799187BB9-802A
       Subsystem 1 - Part No SW: 3AA 962 243 G    HW: 3AA 962 243 G
       Component: GEB.F.Heckoef  H16 0903
       Serial number: 84388316
       Part No SW: 8W0 959 592 G    HW: 8W0 959 592
       Component: TSG BFS       005 0052
       Serial number: 0000201649908
       Coding: 001F1B215C00008000001080
       VCID: 4DC6920B9D5FFA1F723-8018
    196630 - Heated Exterior Mirror
              B11F8 14 [008] - Open or Short to Ground
                        Fault Frequency: 49
                        Reset counter: 56
                        Mileage: 134981 km
                        Date: 2020.01.30
                        Time: 18:13:19
    Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
       Part No SW: 8W0 035 036 C    HW: 8W0 035 036 A
       Component: MU-P-LN-EU    052 0678
       Serial number: A792F0G7502883
       Coding: 01940101FF0A000013110001000A00332F0001E501700100DE
       VCID: 3332E4F31BBB8CEF047-8066
       Subsystem 1 - Part No SW: V03 959 801 PR    HW: -----------
       Component: ECE 2018  --- 0166
       Subsystem 2 - Part No SW: 8W0 919 605     HW: 8W0 919 605
       Component: AU49x_DU_HIGH  H40 0008
       Serial number: AUZ8Z9GBJ018LK
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8W0 919 614 T    HW: 8W0 919 614 T
       Serial number: APVAK128041600030190
       Component: Gracenote2---  --- 1013
    Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
       Part No SW: 8W1 713 041 E    HW: 8W1 713 041 E
       Component: GSM-LL        H08 0068
       Revision: 0L0D5012    Serial number: 20160523002302
       ASAM Dataset: EV_GSMWaehlZFAU736 001013
       ROD: EV_GSMWaehlZFAU736.rod
       VCID: 3536DAEB15CF92DF2A3-8060
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
       Part No SW: 8W0 907 217 B    HW: 8W0 907 217
       Component: BVS           H14 0042
       Coding: 0404090100000403022023A0A50000FC00F0C020C000
       ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
       VCID: 3B22CCD333EB44AFDC7-806E
    1123600 - predictive route data
              B1630 02 [008] - Signal Failure
                        Fault Frequency: 14
                        Reset counter: 36
                        Mileage: 134663 km
                        Date: 2020.01.23
                        Time: 13:25:58
                        Control Module temperature: 30 °C
                        Voltage terminal 15: 15.10 V
    Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
       Part No SW: 4M0 907 355     HW: 4M0 907 355
       Component: SCR-Stg-G3H10 0003
       ASAM Dataset: EV_RDCMINERGAU736 005009
       ROD: EV_RDCMINERGAU736_AU49.rod
       VCID: 6E8435873019E1072B9-803A
       Part No SW: 8W0 959 595 G    HW: 8W0 959 595
       Component: TSG HFS       005 0052
       Serial number: 0000201875319
       Coding: 000F19200000008000001080
       VCID: 50F88B7F8A6DD7F7195-8004
       Component: TSG HBFS      005 0052
       Serial number: 0000201875313
       VCID: 16743D67680979C7039-8042
    End----------(Elapsed Time: 01:41, VBatt start/end: 12.2V/12.0V)-----------
    How to activate high beam assist on this car? I'm following as coding tutorial : https://www.ascoding.ch/en/activate-...-light-assist/
    How to activate bit 5 and bit 6 when it looks like this:
    https://ibb.co/WV9h4kx
    and
    https://ibb.co/dQF8cz3
    Dec 2016
    DE
    Set it to „60 high_beam_functions,head_light_assistant“
