Results 1 to 4 of 4
Thread: Passat 3C (2006) ABS module coding help please
    Jan 2019
    Hi
    I have a Passat in the workshop today brought in by a chap who attempted to replace his parking brake module without first making a record of the ABS coding, and all is now lost. Please could some kind person let me the know the correct coding. Autoscan below;
    Incidentally, he replaced the module due to a fault with the drivers side caliper. He wound the calipers back using a Delphi scan tool to replace the pads, then when he went to close the calipers, the right side did not shut. I notice that there is a fault stored in the parking brake module relating to this (02433 - Supply Voltage for Right Parking Brake Motor (V283). Is this likely to be a fuse?
    Many thanks!
    Thursday,13,February,2020,11:38:53:06582
    VIN: WVWZZZ3CZ6E194633   License Plate: MJ06BXW
    Mileage: 234850km-145929mi   Repair Order:
    Chassis Type: 3C (3C0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72 7D
    VIN: WVWZZZ3CZ6E194633   Mileage: 234850km-145929miles
    Address 01: Engine        Labels: 03G-906-018-BKP.clb
       Part No SW: 03G 906 018 CD    HW: 03G 906 018 CD
       Component: R4 2.0l PPD1.5 G    9627
       Revision: --H05---    Serial number: VWZCZ000000000
       Coding: 0000072
       Shop #: WSC 00051 210 83201
       VCID: 699A40AE4060540710-803C
    18061 - Please check DTC Memory of ABS Controller
                P1653 - 008 -
                        Fault Status: 11011000
                        Reset counter: 229
                        Mileage: 234854 km
                        Time: 20:27:49
                        Text:      0    Nm
                        Text:  0.0    %
                        Voltage: 11.75 V
                        Bin. Bits: 00000100
                        Text:   1016    Nm
    Readiness: N/A
    Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
       Part No SW: 3C0 614 095 P    HW: 3C0 614 095 P
       Component: ESP 440 C2     H015 0003
       Revision:  H015       Serial number: 0667073821
       Coding: 0013569
       Shop #: WSC 05311 000 00000
       VCID: 2F2EEEB6BE04FA370E-807A
    6 Faults Found:
                        Mileage: 234854 km
                        Time: 20:35:31
                        Mileage: 234854 km
                        Time: 20:35:31
                        Mileage: 234854 km
                        Time: 20:35:31
    00810 - Sensor 1/2 for Brake Pressure
                        Mileage: 234854 km
                        Time: 20:35:31
    01542 - Yaw Rate Sensor (G202)
                        Mileage: 234854 km
                        Time: 20:35:31
                        Mileage: 234854 km
                        Time: 20:35:31
       Part No: 1K0 820 047 DP
       Component: Climatic PQ35   090 0505
       VCID: 75A21CDE1CD880E784-8020
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-M.lbl
       Part No SW: 3C0 937 049 H    HW: 3C0 937 049 H
       Component: Bordnetz-SG     H37 1301
       Revision: 00H37000    Serial number: 00000005320703
       Coding: 00880F0700041A00000A00000F000000000859435C0000
       VCID: 2E10F3B2B90EF33F05-807A
       Subsystem 1 - Part No: 3C2 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer VW461  012  0503
       Coding: 00063445
       Shop #: WSC 05311
       Part No SW: 3C0 909 605 J    HW: 3C0 909 605 J
       Component: 05 AIRBAG VW8   029 2521
       Revision: 09029000    Serial number: 003A2P1S3CZX
       Coding: 0012341
       VCID: 2D12F4BEB40888273C-8078
       Subsystem 1 - Serial number: 6332MSME0D422233
       Subsystem 2 - Serial number: 6342MSME0D0F0E58
       Subsystem 3 - Serial number: 6351HTS64IKILM23
       Subsystem 4 - Serial number: 6361HTS64IKESK52
    01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
                009 - Open or Short to Ground - MIL ON
       Part No SW: 3C0 953 549 A    HW: 3C0 953 549 A
       Component: Lenksäulenmodul 005 0010
       Revision: 00005000    Serial number: 3C9953507C
       Coding: 0000014
       VCID: 2A18FFA285E69F1FD9-807E
       Part No SW: 3C0 920 960 H    HW: 3C0 920 960 H
       Revision: X0014000    Serial number: 00000000000000
       Coding: 0007405
       Shop #: WSC 05311 067 57207
       VCID: 281C05AA9BEAAD0FCF-807C
    Address 19: CAN Gateway        Labels:. 3C0-907-530-V1.clb
       Revision: 00007000    Serial number: 0700C062110228
       Coding: 3DFD2C04C22003
       VCID: 210A188EF8D05C4788-8074
                        Reset counter: 229
                        Mileage: 234854 km
                        Time: 20:35:33
    01304 - Radio
                        Reset counter: 229
                        Mileage: 234854 km
                        Time: 20:35:36
       Part No SW: 3C0 959 433 K    HW: 3C0 959 433 K
       Component:    IMMO         038 0367
       Revision: 00038000    Serial number: VWZCZ000000000
       VCID: 3228E7C2AD36D7DF61-8066
       Subsystem 1 - Part No: 3C0 905 861 D
       Component:    ELV          024 0370
       3C0905861D     ELV          024 0370
       Part No: 1K0 959 701 K
       Component: Tuer-SG         024 2366
       Coding: 0000693
       VCID: 3620DBD2415ECBFF4D-8062
       Part No: 1K2 909 144 K
       VCID: 3424E1DA5722D9EF73-8060
       Component:    KSG PQ46 ELV 038 0455
       Coding: 0191020851030E763804941570085FCE103C80
       Subsystem 2 - Part No: 3C0 951 171 A
       Component: Neigungssensor  002 0508
       Subsystem 3 - Part No: 3C0 951 171 A
       Component: Innenraumueberw.002 0508
    01134 - Alarm Horn (H12)
                        Reset counter: 229
                        Mileage: 234854 km
                        Time: 20:33:52
       Part No: 1K0 959 702 K
       Coding: 0000692
       VCID: 373ED6D6465432F756-8062
       Revision:   013
       Coding: 0010000
                000 - - - MIL ON
                        Fault Status: 11100000
                        Reset counter: 229
                        Mileage: 234848 km
                        Time: 20:35:32
                        Voltage: 11.49 V
                        Count: 171
                        Fault Status: 11101101
                        Reset counter: 229
                        Mileage: 234848 km
                        Time: 20:35:31
                        Voltage: 11.49 V
                        Count: 236
                011 - Open Circuit - MIL ON
                        Fault Status: 11101011
                        Reset counter: 229
                        Voltage: 11.59 V
                        Count: 117
    02844 - Lamp for Automatic Parking Function
                        Fault Status: 11101001
                        Reset counter: 229
                        Voltage: 11.90 V
                        Count: 64
                000 - - - MIL ON
                        Reset counter: 229
                        Voltage: 11.90 V
                        Count: 170
    Address 56: Radio
       Part No: 3C9 959 703
       Component: Tuer-SG         021 2505
       Coding: 0000144
       VCID: 70AC2DCA63BAA5CF57-8024
       Part No: 3C9 959 704
       Coding: 0000144
       VCID: 71AA28CE68B0ACC758-8024
       Revision: 00800000    Serial number:
                014 - Defective
    End----(Elapsed Time: 01:30, VBatt start/end: 11.7V/11.7V. VIgn 11.8V)-----
    I thought I saw light at the end of the tunnel, but it turned out to be arc-eye...
  2. Likes Uwe, Jack@European_Parts liked this post
  3. #2
  4. Likes Jim Beagley liked this post
  5. #3
    Jan 2019
    Thankyou. I will try it this evening - although it's valentines day, and I may be banned from the workshop...
  6. #4
    Bahhhh Saint Valentine can kiss my ass!
