Results 1 to 10 of 14
Thread: Kline 2 short to ground
    Pirate
    Feb 2020
    Vw t5 4motion 2008 2.5
    When i stick my ross tech in i get this message
    Now i have an after market radio and worked after installed this also have done a test across pin 4 and 7 or the ground and k line 1 and get 6a
    Recently had a recon engine fitted and now im gettin that the k2 line is short to ground k1 line seems to be fine and check with multi meter and not exciding 9v
    Went near the obd to see k lines and if i unlink one of them i get a green light on my vcds plug but when all together get the red light
    Unplugged everything after market and still same any one have any advice???
    Jun 2014
    Swansea, UK
    Can you see which k-line you're disconnecting (i.e. which system it leads to)?
    The aftermarket radio fault would usually manifest as a k-line short to positive, as it's usually caused by radio harness adaptors linking the electric aerial output to the k-line.
  3. Likes Boki Ar, Uwe liked this post
    K1 - Pin 7
    K2 - Pin 15
    Is pin 15 even populated in the OBD-II socket of that van?
    Test your interface on another car.
    Pirate
    Feb 2020
    It has a k line running to p15 so guess so and that's the one causing the issue.... tried 2 cables on van and both not reading... took dash off as much as i can and the kline is running up and behind steering column and possible down past gearstick but still trying to locate it .
    My guess is that it goes to the airbag module. I'm not sure where that's located in this van though.
    Pirate
    Feb 2020
    Well the loom looks like its running towards the handbrake and thats where the airbag moduel is ill have a look ina bit
    Are there any wires to pins 6 & 14 on the OBD connector?
    If not then your T5 doesn't have any CAN diagnostics, so you could ignore that message.
  9. #8
    Pirate
    Feb 2020
    Yeah have wires into them pins
  10. #9
    And you are on the way to Hall of Shame..
  11. #10
    Would be good if you try to do an Auto-Scan and share it with us, even with those error messages you are getting.
