Results 1 to 10 of 13
Thread: 2013 Touareg Lux TDI Comfort Windows Enable.
    Feb 2020
    New to the forums. Have use VCDS off and on for the last few years, but never mine, only a friends from the local shop.
    I’m trying to enable the Comfort Windows on my T’Reg. I’ve done the coding and it shows in the radio now, but it doesn’t work. What am I missing?
    Scan-all below for the truck. I did the coding via a windows computer, but I’m out now and don’t have it.
    Thanks!
    VCDS Mobile 0.4508.0.4
    VIN: WVGEP9BP0DD004754
    Scan: 01 02 03 05 08 09 15 16 17 19 36 42 46 52 53 55 56 5F 62 65
    	 69 6C 6D 72
    Address 01: Engine  (CNRB J623)	Labels: 059-907-401-V2.clb
    	Part No SW: 7P0 907 401 K	HW: 7P0 907 401 K
    	Component: 3.0TDI FSA    H19 0011
    	Revision: 56H19---
    	Coding: 292A4012233600050000
    	Shop #: WSC 02146 444 00000
    	ASAM Dataset: EV_ECM30TDI0117P0907401K 001012
    	ROD: N/A
    	VCID: 3731B8DF74DD0CCCA538FC-8062
    	No ASAM data for: "EV_ECM30TDI0117P0907401K"
    No fault codes found.
    Address 02: Auto Trans  (J217)	Labels: 0C8-927-750.clb
    	Part No SW: 0C8 927 750 AK	HW: 0C8 927 750 AK
    	Component: AL1000 AISIN  001 3398
    	Coding: 001368
    	Shop #: WSC 21208 002 1048576
    	ASAM Dataset: EV_TCMAL991031 002115
    	ROD: N/A
    	VCID: 75AD72D72E51BEDC778496-8020
    	No ASAM data for: "EV_TCMAL991031"
    Address 03: ABS Brakes  (J104)	Labels: 7P0-907-379.clb
    	Part No SW: 7P0 907 379 M	HW: 7P0 907 379 A
    	Component: MK25A         H36 0436
    	Revision: --------
    	Coding: 5B7613C349242557DAFBC89892D6A4407300
    	Shop #: WSC 31414 790 00001
    	ASAM Dataset: EV_MK25AXT 008001
    	ROD: N/A
    	VCID: 47D1C81F043D7C4CD5D88C-8012
    	No ASAM data for: "EV_MK25AXT"
    Address 05: Acc/Start Auth.  (J393)	Labels: 8K0-907-064-05.clb
    	Part No SW: 4H0 907 064 CK	HW: 4H0 907 064 CK
    	Component: BCM2 2.0      H32 0421
    	Coding: 09860010000000000000
    	VCID: 74AB4FD3252BBFD4409A63-8021
    	Subsystem 1 - 	Part No SW: 7P6-959-754-AD
    	Component: FBSTOUAREGIDGH04 0051
    	Subsystem 2 - 	Part No SW: 4H0-905-852-B
    Address 08: Auto HVAC  (J255)	Labels: 7P6-907-040.clb
    	Part No SW: 7P6 907 040 BK	HW: 7P6 907 040 BK
    	Component: Klima 2 Zonen H20 1305
    	Coding: B606200A80
    	ROD: N/A
    	VCID: 7EBF6DFB1B67FD8426FEF1-802B
    	No ASAM data for: "EV_AirCondiFront"
    Address 09: Cent. Elect.  (J519)	Labels: 4H0-907-063-V1.clb
    	Part No SW: 4H0 907 063 BL	HW: 4H0 907 063 D
    	Component: BCM1 2.0      H12 0111
    	Revision: 15012002
    	Coding: 26001012973C5D010020180300005D0C431C660882010261000000020000
    	VCID: 73A94CCF2025B8EC599068-8026
    	Subsystem 1 - 	Part No SW: 7P0-955-119	Labels: 1Kx-955-119.clb
    	Component: WWS    12070831  0020
    	Coding: 004DBD
    	Subsystem 2 - 	Part No SW: 7P0-955-559-D	Labels: 8K0-955-559.clb
    	Component: RLFS         H09 0011
    	Coding: 025223
    	Subsystem 3 - 	Part No SW: 7P6-941-431-E
    	Component: E1 - LDS     H04 0031
    	Subsystem 4 - 	Part No SW: 4H0-907-410-A
    	Component: USHL4.2      H30 0020
    Address 15: Airbags  (J234)	Labels: 7P0-959-655.clb
    	Part No SW: 7P0 959 655 C	HW: 7P0 959 655 C
    	Component: VW10Airbag025 H05 0025
    	Revision: --------
    	Coding: 000000000000000000000000000000003235
    	ROD: N/A
    	VCID: 41C5D6072A19427C1B9C52-8014
    	No ASAM data for: "EV_AirbaVW10BPAVW526"
    	Subsystem 1 - 	Part No SW: 7P6-959-339
    	Component: BF-Gewichtss.003 0005
    	Serial Number: 5850000R1242708VGXªª
    	Subsystem 2 - 	Serial Number: 3575LRB40671EVLC9GD+
    	Subsystem 3 - 	Serial Number: 3585LRB404T1C4LGFGNA
    	Subsystem 4 - 	Serial Number: 3515RRB401A4UHC4OQ1/
    	Subsystem 5 - 	Serial Number: 3525RRB401A4UHC4G9V3
    	Subsystem 6 - 	Serial Number: 3555NRB40631GCDM5P8M
    Address 16: Steering wheel  (J527)	Labels: 4H0-953-568.clb
    	Part No SW: 4H0 953 568 F	HW: 7P6 953 507 L
    	Revision: --------
    	Coding: 000015
    	VCID: 362FB5DB73D7EDC4BE0EC9-8063
    	Subsystem 1 - 	Part No SW: 7P6-959-542
    	Component: E221__MFL-TASH03 0027
    Address 17: Instruments  (J285)	Labels: 7P6-920-xxx-17.clb
    	Part No SW: 7P6 920 981 F	HW: 7P6 920 981 F
    	Component: Kombi         H13 0318
    	Revision: 13240077
    	Coding: 837733022B00CF05020004
    	ASAM Dataset: EV_KombiUDSRBVW526 001017
    	ROD: N/A
    	VCID: 40C3D30321134B7414925F-8015
    	No ASAM data for: "EV_KombiUDSRBVW526"
    Address 19: CAN Gateway  (J533)	Labels: None
    	Part No SW: 7P6 907 530 F	HW: 7P6 907 530 F
    	Component: GW-CAN-L-MOST H11 6028
    	Revision: --------
    	Coding: 0001037500
    	ASAM Dataset: EV_GatewVW526UDS 001007
    	ROD: N/A
    	VCID: 3B39A4EF48F528AC414010-806E
    	No ASAM data for: "EV_GatewVW526UDS"
    	Subsystem 1 - 	Part No SW: 7P0-915-181-A
    	Serial Number: 00000000005650862695
    Address 36: Seat Mem. Drvr  (J136)	Labels: None
    	Part No SW: 4H0 959 760 D	HW: 4H0 959 760 D
    	Revision: AA000000
    	Coding: 0058130000004001000001010101202020202121202020
    	VCID: 342B8FD365ABFFD4801AA3-8061
    Address 42: Door Elect, Driver  (J386)	Labels: None
    	Part No SW: 4H0 959 793 N	HW: 4H0 959 793 F
    	Component: TSG FA        H07 0166
    	Revision: --------
    	Coding: 011D07205E00453005080000
    	VCID: 44CBDF13350B4F5430BA73-8011
    Address 46: Central Conv.  (J393)	Labels: 4H0-907-064-46.clb
    	Coding: 0186163A28B9509480A00620210000000000000000000000000000000000
    	Component: GTO BT       H19 0059
    	Subsystem 2 - 	Part No SW: 1K0-951-605-C
    	Component: LIN BACKUP HOH05 1501
    	Subsystem 3 - 	Part No SW: 7P0-959-591-B
    	Component: J245 PS30.055H01 0008
    	Coding: 191100
    	Subsystem 4 - 	Part No SW: 7P0-959-591-C
    	Component: J394 PS30.055H01 0008
    	Coding: 191100
    Address 52: Door Elect, Pass.  (J387)	Labels: None
    	Part No SW: 4H0 959 792 F	HW: 4H0 959 792 F
    	Component: TSG BF        H07 0166
    	Revision: --------
    	VCID: 3B39A4EF48F530AC414010-806E
    02111 - Motor for Window Regulator
    Address 53: Parking Brake  (J540-)	Labels: 7P0-907-801.clb
    	Part No SW: 7P0 907 801 F	HW: 7P0 907 801 F
    	Component: EPB           H51 1201
    	Revision: 00000000
    	Coding: 01040200
    	ROD: N/A
    	VCID: 362FB5DB73D7F5C4BE0EC9-8063
    	No ASAM data for: "EV_ParkbA7"
    	Subsystem 1 -
    Address 55: Xenon Range  (J745)	Labels: 7P6-907-357.clb
    	Part No SW: 7P6 907 357	HW: 7L6 907 357 C
    	Component: AFS-ECU       H04 0110
    	Revision: --------
    	Coding: 010A00011D000000
    	ROD: N/A
    	VCID: FCBBE7F38D7B6F9488CA4B-80A9
    	No ASAM data for: "EV_HeadlRegulVWAFS"
    Address 56: Radio  (R)	Labels: None
    	Part No SW: 4G0 035 082 D	HW: 4G0 035 082
    	Component: Radio U SIRIU H60 0112
    	Revision: AB001007
    	Coding: 020007020100000001
    	VCID: 21057687CA597A7C7B5CF2-8074
    Address 5F: Information Electr.  (J794)	Labels: 4E0-035-6xx-5F.clb
    	Part No SW: 7P6 035 664 C	HW: 7P6 035 664
    	Component: H-BN-NA       H45 0544
    	Revision: --------
    	Coding: 010200050040E1EE41022B0C00000003F0000100
    	VCID: 3833BBE379C31BB4AC22F7-806D
    	Subsystem 1 - 	Part No SW: 8R0-060-884-AM
    	Component: NAR 2012     0605
    	Subsystem 2 - 	Part No SW: 7P6-919-603-C
    	Component: DU8 SV Touch H26 0045
    	Subsystem 3 - 	Part No SW: 7P6-919-603-C
    	Subsystem 4 - 	Part No SW: 8R0-060-961
    	Component: CD-Database  1886
    Address 62: Door, Rear Left  (J388)	Labels: None
    	Part No SW: 4H0 959 795 B	HW: 4H0 959 795 B
    	Component: TSG HL        H09 0167
    	Revision: --------
    	Coding: 011C07200000253005080000
    	VCID: 3A37A1EB47CF09A45A561D-806F
    Address 65: Tire Pressure  (J502)	Labels: 3Y0-907-273.clb
    	Part No SW: 7P6 907 273 F	HW: 7P6 907 273 F
    	Component: RDKBERU25     H09 0008
    	Shop #: WSC 00000 000
    	ROD: N/A
    	VCID: 3FC1D0FF5CED348C6D6824-806A
    	No ASAM data for: "EV_RDKBERU25"
    Address 69: Trailer  (J345)	Labels: None
    	Part No SW: 7P0 907 383 F	HW: 7P0 907 383 B
    	Component: Anhaenger     H09 0110
    	Revision: 5A001001
    	Coding: 020D000000000000
    Address 6C: Back-up Cam.	Labels: 4L0-910-441.clb
    	Part No SW: 7P6 907 441 A	HW: 4H0907441
    	Component: SG Rueckfahrkamera   0020
    	Revision: 00H06000	Serial Number: 525 PA8J270279
    	Coding: 0110001
    	VCID: 3731B8DF74DD94CCA538FC-8062
    Address 6D: Trunk Elect.  (----)	Labels: 7N0-959-107.clb
    	Part No SW: 7P6 959 107 A	HW: 7P6 959 107
    	Component: HDSG-Modul    H10 0620
    	Revision: 22010001
    	Coding: 0533314003
    	ASAM Dataset: EV_HeckkTouar 202137
    	ROD: N/A
    	VCID: 3D3DAAF756E1269C7F743E-8068
    	No ASAM data for: "EV_HeckkTouar"
    Address 72: Door, Rear Right  (J389)	Labels: None
    	Component: TSG HR        H09 0167
    	Revision: --------
    End--(Elapsed Time: 02:56, VBatt start/end: 14.1/14.7 Vign: 0.0)-
    Feb 2020
    Ok.. So now I am totally confused!
    I gave up.. Came back after a few hours.. And the Down by remote works now. Just not the close by remote.. Maybe by morning, everything will work.. But I am doubtful..
    Any input would be greatly appreciated! This is the only coding that hasn't worked first time, the way it should..
    -Terry
    A delay before some tweaks work isn't a new thing, even back into the mid 2000's it wasn't unusual for some tweaks to require the CAN message header index to "overflow" before the tweak would work - the advice given then was to wait up to 24 hours and see if the tweak has taken.
    Feb 2020
    Thanks. I’ll wait and see as now neither works again. Only change from before to now was I turned the sunroof off, as I don’t want that to open.
    Quote Originally Posted by Netechsys View Post
    On older platforms even if you enabled sunroof open it didn't work, not sure if that's true of the newer platforms though
    Feb 2020
    Ok. So waiting for a bit. And the windows down is working fine. Not up. I can’t find it again, but I thought there was a bit to enable up and down separate somewhere else.
  7. #7
    What do you have in Adaptation Channels 061 and 062 of the Central Convenience module?
  8. Likes PetrolDave liked this post
  9. #8
    Feb 2020
    Uwe, 061 is 12287. 062 is 65535.
  10. #9
    Well, those both have "Power Windows via Remote Control" enabled for Opening (061) and closing (062).
    So I'm not sure what to make of your symptoms.
  11. #10
    Feb 2020
    Hmm. Thanks for checking. Not sure why it won’t work. Maybe I’ll play a bit. Is there anywhere that explains the adaptation values?
