Results 1 to 4 of 4
Thread: Automatic lights and rain sensor on volkswagen transporter.
    Jul 2019
    Belgium
    Hello guys,
    Retrofitted automatic lights and rain sensor on a volkswagen transporter year 2011, including bcm max upgrade and 10 pole light switch. Works great but I only have some problems, If the lights are in automatic the illumination of the dash doesn't work. If I put them manually on parking lights or low beam then it works. Also the illumination on the light switch doesnt work and also from the dimmer, the dimmer itselfs also doesnt work. Should there be any problem in the coding or should it be in the wires? And the last problem, if I pull the stalk for high beam then the high beams work but if I put it forward for continuous high beam they don't work. This should be a coding problem I think because the wiring works like it should be.
    Thanks you guys for the help in advance.
    Thursday,13,February,2020,21:05:07:02681
    VIN: WV2ZZZ7HZCH029917   License Plate: 1 SLF
    Mileage: 141150km-87706mi   Repair Order:
    Chassis Type: 7H-VN75 (6N0)
    Scan: 01 02 03 04 08 09 10 15 17 18 19 25 2E 37 56 69 0B
    VIN: WV2ZZZ7HZCH029917   Mileage: 141150km-87706miles
    Address 01: Engine (J623-CCHB)       Labels:. 03L-906-022-CAA.clb
       Part No SW: 03L 906 019 DN    HW: 03L 907 309 K
       Component: R4 2,0L EDC   H43 9122
       Revision: 26H43---    Serial number: 00000000000000
       Coding: 0125401A233400080000
       Shop #: WSC 01034 202 12345
       ASAM Dataset: EV_ECM20TDI01103L906019DN 002009
       ROD: EV_ECM20TDI01103L906019DG.rod
       VCID: FAB896377DD5A09F69-80AE
    4482 - Function Restriction due to Implausible Message(s)
              U1112 00 [032] - -
                        Mileage: 141108 km
                        Date: 2020.02.12
                        Time: 21:10:53
                        Engine speed: 1596.00 /min
                        Normed load value: 51.0 %
                        Vehicle speed: 31 km/h
                        Coolant temperature: 59 °C
                        Intake air temperature: 17 °C
                        Voltage terminal 30: 13.980 V
                        Cruise Control System (CCS): switch position-Bits 0-7: 00000010
                        Cruise Control System (CCS): status-Bits 0-7: 00001000
                        Cruise control switch-off: irreversible-Bits 0-7: 11111111
                        Cruise control switch-off: reversible-Bits 0-7: 11111111
                        Engine control module reset status-Bits 0-7: 00000000
                        Engine control module reset status-Bits 0-7: 00111011
                        Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 00000000
       Part No SW: 0BT 300 045 M    HW: 0BH 927 711 C
       Component: DSG DQ500-7F  H05 1712
       Revision: 00H05V01
       ROD: EV_TCMDQ500021_VW36.rod
       VCID: BFCE2723267745B71E-80EA
    Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
       Part No SW: 7E0 907 379 H    HW: 7E0 907 379 E
       Component: ESP MK25A XT  H43 0107
       Revision: 00H43001
       Coding: 208764AD09A6049E26AB90727A6510
       Shop #: WSC 02756 790 49152
       VCID: B73E4F0306477DF7D6-80E2
    Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
       Part No SW: 7E5 907 040 N    HW: 7E5 907 040 N
       Component: ClimatronicT5 H11 0304
       Revision: 00001002
       Coding: 0004000102
       Shop #: WSC 02756 790 50316
       ASAM Dataset: EV_ClimatronicT5 A01003
       ROD: EV_ClimaAutoT5Basis.rod
       VCID: B3267B131A3F91D7EA-80E6
       Slave 1:
       Subsystem 1 - Part No SW: 7E5 907 049 B    HW: 7E5 907 049 B
       Component: Heckbedienung  H10 0202
       Serial number: BHB-0011708110010166
    9474929 - Motor for Rear Air Distribution
              B1093 71 [008] - Actuator stuck
                        Fault Frequency: 46
                        Reset counter: 45
                        Mileage: 141105 km
                        Date: 2020.02.12
                        Time: 20:34:59
    13701936 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [Steuergerät für Bordnetz - bitte Fehlerspeicher auslesen]
                        Fault Frequency: 17
                        Reset counter: 45
                        Mileage: 141105 km
                        Date: 2020.02.12
                        Time: 20:42:07
    9479189 - Signal Line for Air Quality Sensor
              B10A4 15 [009] - Open or Short to Plus
                        Fault Frequency: 12
                        Reset counter: 5
                        Mileage: 141105 km
                        Date: 2020.02.12
                        Time: 20:34:59
       Part No SW: 7H0 937 090 D    HW: 7H0 937 090
       Component: BCM PQ25 Max4 H78 0725
       Revision: B9078001    Serial number: 0671 051151975
       Coding: B8A039BA4E23201301280ED07EEB9EDCB08041FF60842040300000000000
       VCID: AF2E7763FE17B5378E-80FA
       Component: RLS 120309 05  54  0402
       Coding: 0330AD
       Subsystem 2 - Part No SW: 7E0 959 801 A    HW: 7E0 959 801 A  Labels: 7E0-959-80X-V1.CLB
       Component: J386__TSG_FT  003 3311
       Coding: 040000
       Subsystem 3 - Part No SW: 7E0 959 802 A    HW: 7E0 959 802 A  Labels: 7E0-959-80X-V1.CLB
       Component: J387__TSG_BT  003 3311
       Coding: 040000
       Subsystem 4 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TK6  H07 0023
       Serial number: 70000000000000880044
       Coding: E20000
    03304 - Response Closing Status of Rear Right Door
                        Reset counter: 45
                        Mileage: 141115 km
                        Date: 2014.07.05
                        Time: 21:29:54
    00895 - Cruise Control Switch (E45)
                        Reset counter: 45
                        Mileage: 141114 km
                        Date: 2014.07.05
                        Time: 21:23:52
    02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
                        Fault Frequency: 11
                        Reset counter: 45
                        Mileage: 141114 km
                        Date: 2014.07.05
                        Time: 21:23:45
    Address 10: Park/Steer Assist (J446)       Labels:| 7E0-919-475.clb
       Part No SW: 7E0 919 475 E    HW: 7E0 919 475 A
       Component: PARKHILFE 8K  H11 0013
       Revision: --------    Serial number: 47401119501051
       Coding: 118101
       ASAM Dataset: EV_VW75XParkAssis8K A01005
       ROD: EV_VW75XParkAssis8K_A01.rod
       VCID: B424780F1F3196EFF3-80E0
       Part No SW: 7E0 959 655 C    HW: 7E0 959 655 C
       Component: VW10Airbag007 H06 0013
       Revision: --------    Serial number: 003HM001CW9A
       Coding: 000000000000000000000000000000003037
       Shop #: WSC 02754 790 50316
       VCID: B6204207094D84FFCD-80E2
       Serial number: 3495ZRB40630D6ISCHG2
       Serial number: 3505ZRB40690D6ISF0FS
       Part No SW: 7E0 920 870 E    HW: 7E0 920 870 E
       Component: KOMBI         H04 0305
       Coding: 160F01
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
       VCID: AB166373C20FC917A2-80FE
    Address 18: Aux. Heat        Labels: None
       Part No: 7E0 815 071 B
       Component: J737__Standheizung  0605
       Revision: 00085000    Serial number: 09019275F00000
       Coding: 0000031
       Shop #: WSC 02757 790 00000
       VCID: A404884F67D1066F63-80F0
       Part No SW: 6N0 909 901     HW: 7H0 937 090
       Component: GW-K-CAN TP20 H78 0725
       Revision: B9078001
       Coding: 042200
       VCID: F0ACB41F23A9EACFD7-80A4
                        Fault Frequency: 202
                        Reset counter: 5
                        Mileage: 141105 km
                        Date: 2014.07.05
                        Time: 00:54:57
    03605 - Control Module Auomatic Sliding Door, Rear Right
                        Reset counter: 5
                        Mileage: 141105 km
                        Date: 2014.07.05
                        Time: 00:54:58
       Component: IMMO          H04 0305
       VCID: EA98A6770D75101F99-80BE
    Address 2E: Media Player 3
       Part No SW: 7E0 035 680 A    HW: 7E0 035 680 A
       Component: RNS-MID       H55 3978
       Revision: AB001001    Serial number: VWZ6Z7L6222059
       Coding: 06000402040000810014
       VCID: A3068B53A2DF01571A-80F6
    00857 - CD Changer Unit (R41)
                        Fault Frequency: 36
                        Reset counter: 5
                        Mileage: 141104 km
                        Fault Frequency: 36
                        Reset counter: 5
                        Mileage: 141104 km
       Revision: 3A001001    Serial number: 00000154679125
       Coding: 410D000102000000
       Shop #: WSC 02756 790 00000
       VCID: B02C741FE329AACF97-80E4
    End----------(Elapsed Time: 02:31, VBatt start/end: 12.2V/12.2V)-----------
    Address 01: DTCs cleared
    Jul 2019
    Belgium
    Already found the solution,I did have to select the additional power source for the headlights and dimmer in the long coding helper.
    Now the only problem that remains is the canbus fault in the gateway. Does someone have an idea from where to look to fix the problem?
    Saturday,15,February,2020,18:38:55:02681
    UDS Adaptation Channel (2B): IDE80001-Analysis 1
    Stored value 00 00
    VIN: WV2ZZZ7HZCH029917   Mileage: 141230km-87756miles
       Revision: 00H05V01
       Revision: 00H43001
       Revision: 00001002
       Coding: 0004000102
       Slave 1:
                        Reset counter: 5
                        Mileage: 141236 km
                        Date: 2020.02.15
                        Time: 18:29:14
       Coding: B8A039BA4E23201301280ED07EEB9EDCB08060FF60A42041300000000000
       Coding: 0330AD
       Coding: 040000
       Coding: 040000
       Coding: E20000
       Coding: 118101
       Coding: 160F01
       Coding: 0000031
       Revision: B9078001
       Coding: 042200
                        Reset counter: 5
                        Mileage: 141236 km
                        Date: 2014.07.08
                        Time: 18:34:02
       Revision: A1001003    Serial number: 7660583697
       VCID: A91A997BC0F3DB0750-80FC
    03138 - Input AUX IN
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 5
                        Mileage: 141236 km
                        Date: 2014.07.08
                        Time: 16:32:07
                        Reset counter: 45
       Coding: 00000402040000810014
    End----(Elapsed Time: 02:18, VBatt start/end: 11.4V/11.4V. VIgn 11.4V)-----
    Jun 2014
    Did you make an autoscan before you made the changes? Then you know if this fault is triggered by the retrofit you did or not!
    If everything works like it should, ignore the faultcode
    Golf VII, 1.6TDI BM Ed. 40 - 110 PK
    Jul 2019
    Belgium
    Found the problem. I also installed a kufatec fistune dab+ integration and there was a problem with their wiring. Removed the wiring to the can bus and the problem was solved.
  5. Likes Uwe liked this post
