Results 1 to 5 of 5
Thread: HELP AUDI Q3 Address 44: Steering Assist
    Sep 2018
    Argentina
    HI
    I need to repair audi q3 dtc in module 44
    hard address
    dtc 03375 - Steering Motor
    TKS IN ADVANCE
    Brolk..
    Thursday,13,February,2020,10:24:02:48972
    VCDS Version: 19.6.2.0  HEX-NET CB: 0.4508.4
    VIN: WAUDFA8U7DR043262   License Plate:
    Mileage: 95280km-59204mi   Repair Order: AUDI-A3-2013
    Chassis Type: 8U-AU21 (8U0)
    Scan: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 52 53 55 5F 62
              72
    VIN: WAUDFA8U7DR043262   Mileage: 95280km-59204miles
    Address 01: Engine (CPS)       Labels:. 06J-907-115-CPS.clb
       Part No SW: 8U0 907 115 H    HW: 8U0 907 115 B
       Component: 2.0l R4/4V TFSI  04 0001
       Revision: PDH03---    Serial number:
       Coding: 0123000C244F0060
       Shop #: WSC 00049 770 00010
       VCID: 3C34C7D07FD4EBAFBB-8068
    Readiness: 1110 0101
       Part No SW: 0BH 300 011 T    HW: 0BH 927 711 C
       Component: DSG DQ500-7A  H07 1809
       Revision: 00H07V01
       VCID: 3326ECEC9A8A24D76A-8066
    Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
       Part No SW: 5N0 614 109 AF    HW: 5N0 614 109 AF
       Component: J104   C6 450M VD89 0120
       Revision: --H07---    Serial number: 00000006196682
       Coding: 0054392
       Shop #: WSC 00049 770 00154
       VCID: 6FAE209C7E2240374E-803A
                        Reset counter: 137
                        Mileage: 95281 km
                        Date: 2020.02.09
                        Time: 15:01:29
                        Hex Value: 0x0000
                        Bin. Bits: 00000000 00000000
                        Voltage: 12.00 V
                        Bin. Bits: 00011111
                        Count: 281
                        Hex Value: 0x0000
       Part No SW: 8U0 820 043 B    HW: 8U0 820 043 B
       Component: E87  Klimavoll      0050
       Revision: 00H03000    Serial number: 8U0820043B
       VCID: 302CE3E0A39C1FCF17-8064
                        Reset counter: 137
                        Mileage: 95281 km
                        Date: 2020.02.09
                        Time: 00:00:30
    Address 09: Cent. Elect. (J519)       Labels:. 8X0-907-063.clb
       Part No SW: 8X0 907 063 K    HW: 8X0 907 063 K
       Component: BCM PQ35  M   111 0715
       Revision: AH111715
       Coding: 06000A2FA805F3C0201841C02100094C53FF85AA216FD92AE408878400C5
       Shop #: WSC 28950 002 1048576
       VCID: 44C4BF30C724936FC3-8010
       Subsystem 1 - Part No SW: 8U1 955 119     HW: 8U1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS316 120822  H36 0085
       Serial number:         120919230810
       Coding: 0047F7
       Serial number: 20583798
       Coding: 02006E
       Subsystem 3 - Part No: 8X0 951 177
       Component: DWA-Sensor H0  H01 0020
    00532 - Supply Voltage B+
                        Fault Status: 00100001
                        Reset counter: 177
                        Mileage: 95281 km
                        Date: 2020.02.08
                        Time: 21:31:34
                        Voltage: 15.70 V
                            Term 50 On
    Address 10: Park/Steer Assist (J446)       Labels:| 8X0-919-475.clb
       Part No SW: 8X0 919 475 M    HW: 8X0 919 475
       Component: PARKHILFE 4K  H03 0051
       Revision: 11001001    Serial number: 37061227100887
       Coding: 0C0104
       Shop #: WSC 00049 770 00118
       ASAM Dataset: EV_EPHVA14AU21X0000 002005
       ROD: EV_EPHVA14AU21X0000_002.rod
       VCID: 50EC83600B5C7FCF77-8004
    Address 15: Airbags (J234)       Labels:| 8X0-959-655.clb
       Part No SW: 8U0 959 655 B    HW: 8U0 959 655 B
       Component: AirbagVW-AU10 H07 0520
       Serial number: 003LRR031Y3X
       Coding: 30363132313030303030554A304C38553053
       ASAM Dataset: EV_AirbaAU10SMEAU316 001005
       ROD: EV_AirbaAU10SMEAU316_001.rod
       VCID: 46C0A538F918A17FDD-8012
       Subsystem 1 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
       Serial number: 3496KSME4165621FZZZ-
       Subsystem 2 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
       Serial number: 3506KSME2E63621FZZZ.
       Serial number: 3516KSME6966621FZZZ/
       Serial number: 3526KSME36745B1FZZZ%
       Subsystem 5 - Part No SW: 8U0 959 651     HW: 8U0 959 651
       Serial number: 3555USME491E611EZZZ9
       Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
       Revision: --X01---    Serial number: 20191029100173
       Coding: 1994004000
       VCID: 0248792895B05D5FB1-8056
       Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
       Serial number: 17 09 2012  B0230285
    Address 17: Instruments (J285)       Labels:| 8X0-920-xxx-17.clb-SRI1
       Part No SW: 8U0 920 930 B    HW: 8U0 920 930 B
       Component: KOMBI_MEDIUM  H03 0251
       Coding: 12CF01
       ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04396
       VCID: 3620D5F889F831FF4D-8062
    Address 19: CAN Gateway (J533)       Labels: 8X0-907-468.clb
       Part No SW: 8U0 907 468 J    HW: 8U0 907 468 J
       Component: GAT 4CAN 2L M H13 0059
       Revision: 1R120034    Serial number: 3441R12916003E
       Coding: FBCF1A5A050B05610253
       VCID: 49DAAE04E0064E0730-801C
       Subsystem 1 - Part No SW: 8U0 959 591     HW: 8V3 959 591
       Component: J245 PS11.018  H02 0007
       Serial number:     WOO1791968F
       Coding: 901E00
       Subsystem 2 - Part No SW: 1K0 915 181 H    HW: 1K0 915 181 A
       Component: J367-BDM  H07 0180
       Serial number: 00000000008900268491
       Subsystem 3 - Part No SW: 8U0 959 591     HW: 8V3 959 591
       Component: J394 PS11.018  H02 0007
       Serial number:     WOO1791321+
       Coding: 801E00
       Subsystem 4 - Part No SW: 8K0 959 663     HW: 8K0 959 663
       Serial number: 12258001585011200181
                        Reset counter: 177
                        Mileage: 95281 km
                        Date: 2020.02.08
                        Time: 21:41:52
                        Bin. Bits:    10111
                        Voltage: 15.60 V
                        Count: 6
       Part No SW: 0BS 907 554 D    HW: 0BS 907 554 D
       Component: Haldex 4Motion      4017
       Coding: 0000005
       VCID: 47DEA83C3612B87726-8012
       Component: IMMO          H03 0251
       Coding: 000002
       ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04113
       ROD: EV_Immo_UDS_VDD_AU10.rod
    Address 42: Door Elect, Driver (J386)       Labels:. 8X0-959-793.clb
       Part No SW: 8X0 959 793 E    HW: 8X0 959 793 E
       Component: TSG FA        H09 0410
       Coding: 011E02201C00000000
       VCID: 4FEE801C1E6260376E-801A
                        Reset counter: 177
                        Mileage: 95281 km
                        Date: 2020.02.08
                        Time: 21:31:34
       Part No SW: 5N1 909 144 N    HW: 5N1 909 148 G
       Component: J500__APA-BS KL.376 1101
       Revision: 1AH03837    Serial number: 00122570193801
       Coding: 0000258
       Shop #: WSC 00999 444 64523
       VCID: 3D32CAD464CEE2A78C-8068
                003 - Mechanical Failure - MIL ON
                        Fault Status: 11100011
                        Reset counter: 121
                        Mileage: 95067 km
                        Date: 2020.01.28
                        Time: 00:15:24
                        (no units): 7.0
                        Steering Angle: 0.00°
                            OK
                        (no units): 5
    Address 52: Door Elect, Pass. (J387)       Labels:. 8X0-959-792.clb
       Part No SW: 8X0 959 792 E    HW: 8X0 959 792 E
       Component: TSG BF        H09 0410
       Coding: 011E02201E00000000
       VCID: 4ED09D181968693F65-801A
                        Reset counter: 177
                        Mileage: 95281 km
                        Date: 2020.02.08
                        Time: 21:31:34
       Revision:   H19       Serial number: 00000000451414
       Coding: 0025166
       VCID: 3620D5F841F831FF4D-8062
       Part No SW: 8X0 907 357 B    HW: 8X0 907 357 A
       Component: ****LWR12**** H02 0021
       Serial number: 120925-0004-120
       Coding: 1157A61010022500
       ROD: EV_HeadlRegulBasic.rod
       VCID: 41CAB624D0368647E8-8014
    114433 - Function Restricted due to Excessive Voltage
              U1401 00 [008] - -
              [Funktionseinschraenkung durch Überspannung]
                        Reset counter: 177
                        Mileage: 95281 km
                        Date: 2020.02.08
                        Time: 21:31:36
       Part No SW: 8U0 035 185 B    HW: 8U0 035 185 A
       Component: RMC Sound     H53 0775
       Coding: 0100060002C053070823020002010000010000
       VCID: 3522D2F49CFE3AE744-8060
       Subsystem 1 - Part No SW: 8U0 919 603     HW: 8U0 919 603
       Component: DUBasic AU316  H41 0018
       Serial number: AUZ8ZDC06023W9N
       Part No SW: 8X0 959 795 A    HW: 8X0 959 795 A
       Component: TSG HL        H06 0409
       Coding: 010E02200000000000
       VCID: 4DD29A14146E52271C-8018
                        Reset counter: 177
                        Mileage: 95281 km
                        Date: 2020.02.08
                        Time: 21:31:34
       Component: TSG HR        H06 0409
                        Reset counter: 177
                        Mileage: 95281 km
                        Date: 2020.02.08
                        Time: 21:31:34
    End----------(Elapsed Time: 01:33, VBatt start/end: 12.5V/12.3V)-----------
    Address 09: DTCs cleared
    Address 44: DTCs cleared
    16.4905° S, 151.7375° W
    According to my research, if the fault code 03375 does not clear and the power and ground to the J500-Power Steering Control Module are 100% correct, the J500 will need to be replaced as per the Official Factory Repair manuals.
    I do not know if the J500 can be taken apart and fixed, never tried that before.
    Hope this helps,
    drpeter
  3. Likes Jack@European_Parts, Uwe liked this post
    They can and pretty much with a good success rate if given the proper care, lots of parts interchangeable too..............
  5. Likes DrPeter liked this post
  6. #4
  7. Likes Uwe liked this post
  8. #5
    Sep 2018
    Argentina
