Service reset Passat B8 2016
Elki
Sweden
C?ID=149155
Hello!
I Can't do service reset with my new HEX-NEX Wifi unlimited.
I have done service and done service reset but when I start and shut down the engine it's always shows the remaining km and days.
I have now managed to do the service reset twice after regular service and each time it starts counting down from 30000km and 730 days.
With my old AI-USB + CAN there was no problem.
Hope you can help me.
/Erik
Please post an Auto-Scan for context, and also the values of the SRI-related channels.
Elki
Sweden
C?ID=149155
Wednesday,12,February,2020,11:01:08:60455
Mileage: 95753km-59498mi   Repair Order:
VCDS Release 19.6.2:  SRI Reset-SRI3.CLB
Control Module Part Number: 3G0 920 751 A       Labels:  .*5G0-920-XXX-17.clb-SRI3
Component:KOMBI         301 6421, Coding:07A409102F80000801882B011000000000000000
Operation: Reset FIX&ESI / INSP,(North America) or (Rest of World second service and later)
Channel        Description                                                 	Current val.                                                	New val.
IDE00342-ESI: Resetting ESI        ESI: Service Reminder Status                                	Warning active                                              	---
IDE00510-ESI: distance driven from inspection                                                       	ESI: Distance since Inspection                              	0 km                                                        	---
IDE00511-ESI: time from inspection        ESI: Time since Inspection                                  	0 d                                                         	---
IDE00515-ESI: oil quality        ESI: Oil Quality                                            	good oil quality                                            	---
IDE00517-ESI: soot entry        ESI: Soot Quantity                                          	0 km                                                        	---
IDE00518-ESI: thermal load        ESI: Thermal Load                                           	0 km                                                        	---
IDE01153-SIA: maximum value of distance to service                                                  	SIA: Maximum Distance to Service                            	30000 km                                                    	---
IDE01154-SIA: maximum value of time to service                                                      	SIA: Maximum Time to Service                                	365 d                                                       	---
IDE03349-FIX: Max. distance until next mileage-related inspection                                   	FIX: Maximum Distance to Inspection                         	30000 km                                                    	---
IDE03350-FIX: Maximum time until next time-dependent inspection                                     	FIX: Maximum Time to Inspection                             	730 d                                                       	---
IDE03351-FIX: Distance covered since last mileage-dependent inspection                              	FIX: Distance since Inspection                              	0 km                                                        	---
IDE03352-FIX: Time since last time-dependent inspection                                             	FIX: Time since Inspection                                  	0 d                                                         	---
Elki
Sweden
C?ID=149155
Sunday,09,February,2020,13:39:17:60455
VIN: WVWZZZ3CZGE199712   License Plate:
Tuesday,11,February,2020,09:23:15:60455
Thursday,13,February,2020,18:15:31:60455
VCDS Version: 19.6.2.2 (x64)  HEX-NET CB: 0.4508.4
Gateway Installation List:  5Q0 907 530 AJ
CA-Sunroof -- Status: OK 0000
Thursday,13,February,2020,18:18:45:60455
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 18 19 2B 42 44 47 52 55 5F 69
          6C 6D BB BC CA
VIN: WVWZZZ3CZGE199712   Mileage: 95753km-59498miles
Address 01: Engine (J623-DFCA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 FM    HW: 04L 907 309 M
   Component: R4 2.0l TDI   H23 1938
   Revision: B4H23---
   Coding: 0119001A045405083000
   Shop #: WSC 00015 115 08193
   ASAM Dataset: EV_ECM20TDI01104L906026FM 004002
   ROD: EV_ECM20TDI01104L906026FM_004_VW48.rod
   VCID: 7AB8EDF4FD337E9FEB-802E
   Part No SW: 3Q0 907 379 AF    HW: 3Q0 907 379 F
   Component: ESC           H42 0625
   Revision: 00000000    Serial number: 60676000000305
   Coding: 0FEC6A8F34290B75077E060141C549F0562CD0E0608292F51460F078C009
   VCID: 7EB0E1E4E11B52BFD7-802A
   Part No SW: 3Q0 959 435 C    HW: 3Q0 959 435 C
   Component: VWKESSYMQB    036 0710
   Revision: 00036000    Serial number: 0397302983
   Coding: 0F00000E03
   Shop #: WSC 05311 115 00321
   VCID: 3A382DF4BDB3BE9FAB-806E
   Subsystem 1 - Part No SW: 3G0 962 243     HW: 3G0 962 243
   Component: GEB.F.Heckoef  H17 0812
   Serial number: ;8045490
   Part No SW: 5G1 907 044 J    HW: 5G1 907 044 J
   Component: Climatronic   H04 1202
   Revision: 00001K10
   Coding: 12020124204101011015500C0010190A
   ASAM Dataset: EV_ACClimaBHBVW37X 005137
   VCID: 2F2E0CA076F16B370C-807A
   Air quality sensor:
   Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
   Component: BCM PQ37BOSCH 028 0163
   Revision: --------    Serial number: 865807031600YL
   Coding: 00930C46C2C102FF17844094B11C572C1C80000000000000000000000000
   ASAM Dataset: EV_BodyContrModul1UDSBosc 015001
   ROD: EV_BCMBOSCH_015.rod
   VCID: 034690108AF93F57B8-8056
   Component: WWS    160212  042 0607
   Serial number:         160218175010
   Subsystem 2 - Part No SW: 8UD 955 559 B    HW: 8UD 955 559 B  Labels: 8U0-955-559.CLB
   Serial number: 30038729
   Coding: 00006E
   Serial number: 06 12 2015  10000234
   Serial number: 000000000ZY113500L73
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000065170599
   Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0056
   Revision: --------    Serial number: 39391606501450
   Coding: 0071151901
   Shop #: WSC 05311 115 00089
   VCID: 44C4530CCF77F86FC1-8010
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Component: ACC BOSCH MQB H04 0192
   Coding: 2A00608A11FFC428949C804D
   ASAM Dataset: EV_ACCBOSCHVW48X 001008
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 342403CC9FD748EF71-8060
   Part No SW: 3Q0 959 655 BA    HW: 3Q0 959 655 BA
   Component: Airbag VW20   013 0195
   Revision: --------    Serial number: 003SSP4J6SX2
   Coding: 98FCC0C0008000005C5400CC000800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   Belt Pretensioner left:
   Serial number: 3G1857705G0071Q00563
   Coding: 80000D
   Belt Pretensioner right:
   Serial number: 3G1857706G0067Q01175
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 454 000 203 16
   Serial number: 3576U000000BABC4991W
   Subsystem 4 - Part No SW: -----------    HW: 454 002 802 16
   Serial number: 3586U00000084B64991I
   Subsystem 5 - Part No SW: -----------    HW: 454 800 602 16
   Serial number: 3516RBD48B209000000E
   Subsystem 6 - Part No SW: -----------    HW: 454 801 302 16
   Serial number: 3526R1570010A000000O
   Subsystem 7 - Part No SW: -----------    HW: 454 800 402 16
   Serial number: 3556VE169F309000000L
   Part No SW: 3Q0 953 521 EJ    HW: 5Q0 953 569 B
   Component: Lenks.Modul   100 0205
   Revision: FF035035    Serial number: 20160228500466
   Coding: 0400
   Shop #: WSC 00015 115 00001
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001005
   ROD: EV_SMLSVALEOMQBLRH.rod
   VCID: 7CB4EBECF70740AFF9-8028
   Part No SW: 3G0 920 751 A    HW: 3G0 920 751 A
   Component: KOMBI         301 6421
   Coding: 07A409102F80000801882B011000000000000000
   VCID: 2306F0902A39DF5798-8076
   Part No SW: 5Q0 963 272 E    HW: 5Q0 963 272 E
   Component: STH-MQB       007 0072
   Coding: 9309
   VCID: 383C37FC83BFAC8F5D-806C
   Subsystem 1 - Part No SW: 5Q0 963 513 A    HW: 5Q0 963 513 A
   Component: R149 T91-LIN  003 0301
   Serial number: 00000000000001348279
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 06031610801758
   Coding: 0B0300345F017300FB00025E080F00010001070000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 79BAF2F8F8357587E2-802C
   Serial number: 29160000447700056092
   Coding: 2EFFFF
   Subsystem 3 - Part No SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
   Serial number: 6263429103
   Power Converter DC AC:
   Subsystem 4 - Part No SW: 5Q0 907 155 C    HW: 5Q0 907 155 C
   Component: WECHSELRICHTE  H55 0033
   Serial number: 0213667
   Analog clock:
   Subsystem 5 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Serial number: 16000038771011
   Coding: 0000000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71AACAD8A0453DC75A-8024
   Serial number: 101115BK911998
   Coding: 003F1A208000028000001000
   VCID: 43C65010CA79FF57F8-8016
   Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2041
   Revision: 00000000    Serial number: 0000657858
   Coding: 01000010005001
   Shop #: WSC 00015 115 00321
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
   ROD: EV_SteerAssisVWBSMQBA_008_VW41.rod
   VCID: 3D3226E8AC9D89A78E-8068
Address 47: Sound System (J525)       Labels:| 3Q0-035-466.clb
   Part No SW: 3Q0 035 466 C    HW: 3Q0 035 466 C
   Component: MIB2_amp_P_VW H45 0210
   Revision: 00000001    Serial number: VWZ8Z1GAT00HEN-
   Coding: 1284020001AA0A2AAA0000000000
   ASAM Dataset: EV_AMPMst16C3Gen2ALPI 001016
   ROD: EV_AMPMst16C3Gen2ALPI_VW37.rod
   Serial number: 220116EAK00037
   Coding: 003F10208000028000001000
   VCID: 42C85514D563F65FF3-8016
   Component: AFS-ECU       H01 0120
   Coding: 039A00000F200200
   Shop #: WSC 05311 000 08193
   VCID: 3FCE5CE0A6919BB79C-806A
   Subsystem 1 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H09 0003
   Coding: E02400
   Subsystem 2 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H09 0003
   Coding: E02400
   Coding: E02400
   Component: LeiMo rechts  H02 0003
   Coding: E02400
   Part No SW: 3Q0 035 840 A    HW: 3Q0 035 840 A
   Component: MU-S--ER      620 0624
   Coding: 028402000000000051110002000808001F0100E40120010003
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 291AE2B848150507D2-807C
   Subsystem 1 - Part No SW: 3G0 919 605 B    HW: 3G0 919 605 B
   Component: ABT_Std-2  H43 4064
   Serial number: VWZ6Z9S0751193
   Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
   Component: Anhaenger     H21 0203
   Revision: 8A001003    Serial number: 0397718545
   Coding: 0100000202000000
   VCID: 3B3628F0B2898797B0-806E
   Part No SW: 5Q0 980 556     HW: 5Q0 980 556
   Component: RVC Compact   H09 0170
   Coding: 0184020143002017000040
   ROD: EV_CamSysRVRVCPANAMQBAB_005_VW48.rod
   VCID: 77BEF4C0CE2163F794-8022
   Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0253
   Revision: --------    Serial number: 30549110800000
   Coding: 0288
   Serial number: 230216EBN1231B
   Coding: 000E10200100028000001000
   VCID: 45C24E08C44DC167D6-8010
   Serial number: 230216EBN0915B
   Part No SW: 4M0 907 594 D    HW: 4M0 907 594
   Component: SAD_STG_1     011 0003
   Coding: 208040748202
   ASAM Dataset: EV_SunRoofCONTIAU736 004008
   ROD: EV_SunRoofCONTIAU736_004.rod
   VCID: 373E34C08EA1A3F754-8062
End----------(Elapsed Time: 02:21, VBatt start/end: 12.1V/12.1V)-----------
Thursday,13,February,2020,18:26:58:60455
IDE00511-ESI: time from inspection        ESI: Time since Inspection                                  	1 d                                                         	---
IDE03352-FIX: Time since last time-dependent inspection                                             	FIX: Time since Inspection                                  	1 d                                                         	---
Thursday,13,February,2020,18:31:06:60455
          6C 6D BB BC CA
   Revision: B4H23---
   Coding: 0F00000E03
   Revision: 00001K10
   Air quality sensor:
   Coding: 00006E
   Coding: 0071151901
   Coding: 80000D
   Coding: 80000D
   Coding: 0400
   Coding: 9309
   Coding: 2EFFFF
   Analog clock:
   Coding: E02400
   Coding: E02400
   Coding: E02400
   Coding: E02400
   Coding: 0288
End----------(Elapsed Time: 02:20, VBatt start/end: 12.1V/12.1V)-----------
Dana
Western PA, USA
Thanks for posting here.
Per the SRILog.txt files via e-mail the cluster hasn't shown a reset status (ingen varning) since fredag,07,Februari,2020,09:48:57:60455. The logs with time stamp fredag,07,Februari,2020,09:49:08:60455 and newer show Varning aktiv / Warning active in both the EN and SW versions. For that reason I believe something is preventing IDE00342-ESI: Resetting ESI from changing.
Please post the English Adaptation function control module map from 17 here.
[Applications]
[Controller Channels Map]
Address: 17
Function: Adaptation
Output: CSV File
[Start]
Doing so will result in a CSV file in the Logs folder that you can open with Notepad and paste here.
Also, please check the Debug folder in the VCDS AER installation for a file named AdpLog.CSV. I think we should check it to see if any changes are shown between the Dec 2019 and Feb 2020 time frame. You can post that here in plain text if you see changes to address 17 listed.
Elki
Sweden
C?ID=149155
;SW:3G0-920-751-A   HW:3G0-920-751-A ---  Instruments
;Component:KOMBI         301 6421; Coding:07A409102F80000801882B011000000000000000
;EV_DashBoardVDDMQBAB;009046;EV_DashBoardVDDMQBAB_009_VW37,rod
;Thursday;13;February;2020;21:10:44:60455
;VCDS Version: Release 19,6,2 (x64)  Data version: 20200210 DS308,0
;VCID: 2306F0902A39DF5798-8076
IDE00295-Oil temperature display;On ;1
IDE00301-Distance;95753 km;3
IDE00342-ESI: Resetting ESI;Warning active ;1
IDE00343-Language version;Swedish ;1
IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK;Manual reset: not possible ;3
IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel;MFA3-Reset ;3
IDE00345-MAS05464-MFA3-Reset-Refuel detection gas;MFA3-Reset ;3
IDE00345-MAS12879-MFA3-Reset-Electrical refueling detection;MFA3-Reset ;3
IDE00499-Display correction of consumptions and operating range;100 %;1
IDE00500-Hour;21 H;1
IDE00501-Minute;9 min;1
IDE00502-Year;2020 yr;2
IDE00503-Month;2 mon;1
IDE00504-Day;13 d;1
IDE00510-ESI: distance driven from inspection;0 km;3
IDE00511-ESI: time from inspection;1 d;2
IDE00512-ESI: minimum value km-driving distance/inspection;15000 km;2
IDE00513-ESI: maximum value km-driving distance/inspection;30000 km;2
IDE00514-ESI: maximum value of time between inspections;730 d;2
IDE00515-ESI: oil quality;good oil quality ;1
IDE00517-ESI: soot entry;0 km;2
IDE00518-ESI: thermal load;0 km;2
IDE00711-Trip recorder;not installed ;1
IDE00819-Day counter;1424 d;2
IDE00820-Activating and deactivating all development messages;not active ;1
IDE00827-ESI: minimum value of time between inspections;365 d;2
IDE01153-SIA: maximum value of distance to service;30000 km;2
IDE01154-SIA: maximum value of time to service;365 d;2
IDE02489-Display depiction;Version 1 ;1
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration;-12,8 l;5
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1;-12,8 l;5
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2;12,7 l;5
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3;12,7 l;5
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4;12,7 l;5
IDE03329-Driving profiled for range remaining;4,8 l/100km;2
IDE03346-IDE00301-Units adjusted-Distance;Kilometers ;3
IDE03346-MAS01230-Units adjusted-Date;dd_mm_yy ;3
IDE03346-MAS01456-Units adjusted-Speed;Kilometers per hour ;3
IDE03346-MAS02201-Units adjusted-Temperature;Degrees Celsius ;3
IDE03346-MAS02957-Units adjusted-Time;24h ;3
IDE03346-MAS03032-Units adjusted-Volume;Liter ;3
IDE03346-MAS03034-Units adjusted-Pressure;bar ;3
IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas);kg per 100 km ;3
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas);Liters per 100 km ;3
IDE03346-MAS05875-Units adjusted-Average consumption: electric drive;kWh per 100 km ;3
IDE03346-MAS13665-Units adjusted-Trailer/support load ground;kilogram (kg) ;3
IDE03348-MAS01456-Speed warning-Speed;0 ;2
IDE03348-MAS01561-Speed warning-Unit;Kilometers per hour ;2
IDE03348-Speed warning-;not active ;2
IDE03349-FIX: Max, distance until next mileage-related inspection;30000 km;2
IDE03350-FIX: Maximum time until next time-dependent inspection;730 d;2
IDE03351-FIX: Distance covered since last mileage-dependent inspection;0 km;2
IDE03352-FIX: Time since last time-dependent inspection;1 d;2
IDE03372-Source for synchronization of time;internal clock ;1
IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function;On ;5
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time;10 s;5
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic;On ;5
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless;On ;5
IDE03568-ENG102611-Service-key settings-p_write_delay_speed;20 km/h;5
IDE03568-ENG103545-Service-key settings-p_write_delay_time;40 s;5
IDE03568-ENG104099-Service-key settings-p_write_distance;20 km;5
IDE03867-Deactivate seat belt warning;Yes ;1
IDE04169-Display correction of consumption and operating range: gas;100 %;1
IDE05930-Service notification in days;30 d;1
IDE05931-FIX: Reset value for next mileage-dependent inspection;0 km;2
IDE05932-FIX: Reset value for next time-dependent inspections;0 d;2
IDE05971-Vehicle Positioning System Interface Control Module;not installed ;1
IDE06425-Roller test bench mode: functional;not activated ;1
IDE06588-Ignition active message: actuator;Driver door ;1
IDE06922-No-voltage display;Unknown (2);1
IDE07221-Cylinder shut-off;Display ;1
IDE08140-Driving profiled for range remaining CNG;6,0 kg/100 km;2
IDE08247-Driving profile for range remaining LPG;10,0 l/100km;2
IDE11086-Service notification;30 d;1
MAS03685-Digital speedometer;Display ;1
ENG117917-BAP_Debug_Mode_Release;not_released ;1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1;OFF ;20
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10;OFF ;20
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11;OFF ;20
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12;OFF ;20
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13;OFF ;20
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14;OFF ;20
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15;OFF ;20
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16;OFF ;20
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17;OFF ;20
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18;OFF ;20
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19;OFF ;20
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2;OFF ;20
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20;OFF ;20
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21;OFF ;20
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22;OFF ;20
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23;OFF ;20
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24;OFF ;20
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25;OFF ;20
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26;OFF ;20
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27;OFF ;20
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28;OFF ;20
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29;OFF ;20
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3;OFF ;20
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30;OFF ;20
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31;OFF ;20
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32;OFF ;20
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33;OFF ;20
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34;OFF ;20
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35;OFF ;20
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36;OFF ;20
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37;OFF ;20
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38;OFF ;20
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39;OFF ;20
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4;OFF ;20
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5;OFF ;20
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6;OFF ;20
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7;OFF ;20
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8;OFF ;20
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9;OFF ;20
ENG119875-defuel_threshold;9 l;1
ENG105831-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_day-X1;00 ;12
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2;32 ;12
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3;66 ;12
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4;96 ;12
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5;DC ;12
ENG105831-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_day-X6;FD ;12
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1;00 ;12
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2;00 ;12
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3;00 ;12
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4;05 ;12
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5;14 ;12
ENG105831-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_day-Y6;64 ;12
ENG105832-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_night-X1;00 ;12
ENG105832-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_night-X2;0A ;12
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3;32 ;12
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4;64 ;12
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5;96 ;12
ENG105832-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_night-X6;FD ;12
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1;02 ;12
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2;02 ;12
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3;17 ;12
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4;32 ;12
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5;46 ;12
ENG105832-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_night-Y6;64 ;12
ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1;00 ;12
ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2;0A ;12
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3;32 ;12
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4;64 ;12
ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5;DC ;12
ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6;FD ;12
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1;03 ;12
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2;03 ;12
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3;08 ;12
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4;20 ;12
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5;55 ;12
ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6;64 ;12
ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1;00 ;12
ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2;0A ;12
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3;32 ;12
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4;64 ;12
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5;96 ;12
ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6;FD ;12
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1;05 ;12
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2;05 ;12
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3;0C ;12
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4;17 ;12
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5;32 ;12
ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6;64 ;12
ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1;00 00 ;20
ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2;00 32 ;20
ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3;00 64 ;20
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4;00 C8 ;20
ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5;01 F4 ;20
ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1;00 00 ;20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2;00 0E ;20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3;00 41 ;20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4;00 C8 ;20
ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5;00 FD ;20
ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1;00 ;12
ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2;0A ;12
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3;32 ;12
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4;64 ;12
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5;96 ;12
ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6;FD ;12
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1;01 ;12
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2;01 ;12
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3;07 ;12
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4;12 ;12
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5;1E ;12
ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6;64 ;12
ENG119874-Gas_functionality;not active ;1
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim;terminal_58xd_log_bus_parkinglight ;1
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm;parking_light ;1
ENG119882-init_fuel_algorithm;No ;1
ENG130585-Leaving_warning_delay;1,6 s;1
ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0;15 s;16
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature;4 °C;16
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature;6 °C;16
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta;25 °C;16
ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0;5,0 km;16
ENG102605-ENG103631-outside_temperature-P_speed_threshold;20 km/h;16
ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off;180 min;16
ENG102605-ENG104179-outside_temperature-p_tendency_damping;15 s;16
ENG102605-ENG103335-outside_temperature-p_tendency_threshold;1,0 °C;16
ENG102605-ENG100500-outside_temperature-p_time_constant_pt1;40 s;16
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping;2,0 ;16
ENG119825-Picture_Upload_Download;not active ;1
ENG119876-Service_Key_Clear_All_Counter;Yes ;1
ENG130584-Statistic_phev_mileage;5 km;1
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms;2,0 s;18
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms;5 s;18
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt;35 s;18
ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF;300 ms;18
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms;255 s;18
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms;5 s;18
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms;6 s;18
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms;20 s;18
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms;900 s;18
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms;10 s;18
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms;3 s;18
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms;10 s;18
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ;0,20 s;18
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse;3 ;18
ENG109442-ENG101663-time_parameter_display-tDD15_off;0,30 ;18
ENG109442-ENG103975-time_parameter_display-tDD15_on;0,00 ;18
ENG109442-ENG100026-time_parameter_display-tDDWUP;0,00 ;18
ENG112418-ENG112412-total_range_gas-consumption_factor;0,000 ;4
ENG112418-ENG112411-total_range_gas-consumption_profile;consumption_profile_calculation ;4
ENG112418-ENG112410-total_range_gas-selection_consumption_factor;consumption_factor_CAN ;4
ENG112418-ENG99298-total_range_gas-State;not active ;4
Elapsed Time: 00:27
ÿÿ
Elki
Sweden
C?ID=149155
Address 17,3G0 920 751 A,channel IDE00342-ESI: Resetting ESI,adapted from,Warning active ,to,Reset ,Sunday,09,February,2020,13:25:07:60455
Address 17,3G0 920 751 A,channel IDE00342-ESI: Resetting ESI,adapted from,Warning active ,to,Reset ,Sunday,09,February,2020,13:25:32:60455
Address 17,3G0 920 751 A,channel IDE00342-ESI: Resetting ESI,adapted from,Warning active ,to,Reset ,Sunday,09,February,2020,13:26:15:60455
Address 17,3G0 920 751 A,channel IDE00342-ESI: Resetting ESI,adapted from,Warning active ,to,Reset ,Sunday,09,February,2020,13:29:20:60455
Address 17,3G0 920 751 A,channel IDE00342-ESI: Resetting ESI,adapted from,Warning active ,to,Reset ,Sunday,09,February,2020,13:29:39:60455
Address 17,3G0 920 751 A,channel IDE03351-FIX: Distance covered since last mileage-dependent inspection,adapted from,900 km,to,0 km,Sunday,09,February,2020,13:29:40:60455
Address 17,3G0 920 751 A,channel IDE03352-FIX: Time since last time-dependent inspection,adapted from,2 d,to,0 d,Sunday,09,February,2020,13:29:40:60455
Address 17,3G0 920 751 A,channel IDE00342-ESI: Resetting ESI,adapted from,Warning active ,to,Reset ,Sunday,09,February,2020,13:36:48:60455
Address 17,3G0 920 751 A,channel IDE00342-ESI: Resetting ESI,adapted from,Warning active ,to,Reset ,Sunday,09,February,2020,13:37:11:60455
Address 17,3G0 920 751 A,channel IDE03351-FIX: Distance covered since last mileage-dependent inspection,adapted from,0 km,to,0 km,Sunday,09,February,2020,13:37:12:60455
Address 17,3G0 920 751 A,channel IDE03352-FIX: Time since last time-dependent inspection,adapted from,0 d,to,0 d,Sunday,09,February,2020,13:37:12:60455
Address 17,3G0 920 751 A,channel IDE00342-ESI: Resetting ESI,adapted from,Warning active ,to,Reset ,Sunday,09,February,2020,13:56:43:60455
Address 17,3G0 920 751 A,channel IDE00342-ESI: Resetting ESI,adapted from,Warning active ,to,Reset ,Tuesday,11,February,2020,08:50:59:60455
Address 17,3G0 920 751 A,channel IDE00342-ESI: Resetting ESI,adapted from,Warning active ,to,Reset ,Tuesday,11,February,2020,08:51:21:60455
Address 17,3G0 920 751 A,channel IDE00342-ESI: Resetting ESI,adapted from,Warning active ,to,Reset ,Tuesday,11,February,2020,08:52:38:60455
Address 17,3G0 920 751 A,channel IDE00342-ESI: Resetting ESI,adapted from,Warning active ,to,Reset ,Tuesday,11,February,2020,08:58:17:60455
Address 17,3G0 920 751 A,channel IDE00342-ESI: Resetting ESI,adapted from,Warning active ,to,Reset ,Tuesday,11,February,2020,08:58:36:60455
Address 17,3G0 920 751 A,channel IDE03351-FIX: Distance covered since last mileage-dependent inspection,adapted from,0 km,to,0 km,Tuesday,11,February,2020,08:58:36:60455
Address 17,3G0 920 751 A,channel IDE03352-FIX: Time since last time-dependent inspection,adapted from,2 d,to,0 d,Tuesday,11,February,2020,08:58:37:60455
Address 17,3G0 920 751 A,channel IDE00342-ESI: Resetting ESI,adapted from,Warning active ,to,Reset ,Tuesday,11,February,2020,09:01:09:60455
Address 17,3G0 920 751 A,channel IDE00342-ESI: Resetting ESI,adapted from,Warning active ,to,Reset ,Tuesday,11,February,2020,09:01:28:60455
Address 17,3G0 920 751 A,channel IDE03351-FIX: Distance covered since last mileage-dependent inspection,adapted from,0 km,to,0 km,Tuesday,11,February,2020,09:01:28:60455
Address 17,3G0 920 751 A,channel IDE03352-FIX: Time since last time-dependent inspection,adapted from,0 d,to,0 d,Tuesday,11,February,2020,09:01:29:60455
Address 17,3G0 920 751 A,channel IDE00342-ESI: Resetting ESI,adapted from,Warning active ,to,Reset ,Tuesday,11,February,2020,09:23:51:60455
Address 17,3G0 920 751 A,channel IDE00342-ESI: Resetting ESI,adapted from,Warning active ,to,Reset ,Tuesday,11,February,2020,09:24:15:60455
Address 17,3G0 920 751 A,channel IDE03351-FIX: Distance covered since last mileage-dependent inspection,adapted from,0 km,to,0 km,Tuesday,11,February,2020,09:24:16:60455
Address 17,3G0 920 751 A,channel IDE03352-FIX: Time since last time-dependent inspection,adapted from,0 d,to,0 d,Tuesday,11,February,2020,09:24:16:60455
Address 17,3G0 920 751 A,channel IDE00342-ESI: Resetting ESI,adapted from,Warning active ,to,Reset ,Tuesday,11,February,2020,09:27:25:60455
Address 17,3G0 920 751 A,channel IDE00342-ESI: Resetting ESI,adapted from,Warning active ,to,no warning ,Tuesday,11,February,2020,09:31:26:60455
Address 17,3G0 920 751 A,channel IDE00342-ESI: Resetting ESI,adapted from,no warning ,to,Reset ,Tuesday,11,February,2020,09:32:01:60455
Address 17,3G0 920 751 A,channel IDE00342-ESI: Resetting ESI,adapted from,Warning active ,to,Reset ,Tuesday,11,February,2020,09:33:31:60455
Address 17,3G0 920 751 A,channel IDE00342-ESI: Resetting ESI,adapted from,Warning active ,to,Reset ,Tuesday,11,February,2020,09:39:21:60455
Address 17,3G0 920 751 A,channel IDE00342-ESI: Resetting ESI,adapted from,Warning active ,to,Reset ,Tuesday,11,February,2020,09:40:59:60455
Address 17,3G0 920 751 A,channel IDE00342-ESI: Resetting ESI,adapted from,Warning active ,to,Reset ,Tuesday,11,February,2020,09:41:26:60455
Address 17,3G0 920 751 A,channel IDE00342-ESI: Resetting ESI,adapted from,Warning active ,to,Reset ,Tuesday,11,February,2020,09:42:07:60455
Address 17,3G0 920 751 A,channel IDE00342-ESI: Resetting ESI,adapted from,Warning active ,to,Reset ,Tuesday,11,February,2020,09:42:56:60455
Address 17,3G0 920 751 A,channel IDE00342-ESI: Resetting ESI,adapted from,Warning active ,to,Reset ,Wednesday,12,February,2020,10:53:33:60455
Address 17,3G0 920 751 A,channel IDE00342-ESI: Resetting ESI,adapted from,Warning active ,to,Reset ,Wednesday,12,February,2020,11:00:12:60455
Address 17,3G0 920 751 A,channel IDE00342-ESI: Resetting ESI,adapted from,Warning active ,to,Reset ,Wednesday,12,February,2020,11:00:30:60455
Address 17,3G0 920 751 A,channel IDE03351-FIX: Distance covered since last mileage-dependent inspection,adapted from,0 km,to,0 km,Wednesday,12,February,2020,11:00:30:60455
Address 17,3G0 920 751 A,channel IDE03352-FIX: Time since last time-dependent inspection,adapted from,1 d,to,0 d,Wednesday,12,February,2020,11:00:31:60455
Elki
Sweden
C?ID=149155
You give me difficult missions.)))
NEtech
C?ID=56995
For a start, these are wrong and should be corrected.
IDE01153-SIA: maximum value of distance to service;30000 km > 15000
IDE05931-FIX: Reset value for next mileage-dependent inspection;0 km > 30000
IDE05932-FIX: Reset value for next time-dependent inspections;0 d > 365
> "Correct value"
Dana
Western PA, USA
Thanks Niels! I believe you determined the cause of the conflicts. I don't see any other issues.
Elki, if that doesn't fix the problem and allow you to reset the IDE00342-ESI: Resetting ESI channel please post another (new) Adaptation map from address 17.
Elki
Sweden
C?ID=149155
Friday,14,February,2020,08:21:12:60455
VCDS Version: Release 19.6.2 (x64) Running on Windows 10 x64
                Address 18: Aux. Heat       Labels: 5Q0-963-272.clb
Control Module Part Number: 5Q0 963 272 E    HW: 5Q0 963 272 E
  Component and/or Version: STH-MQB       007 0072
           Software Coding: 9309
            Work Shop Code: WSC 00015 115 00001
              ASAM Dataset: EV_AuxilParkiHeateWOS 002018 (VW48)
0386 - Heating Time Exceeded
          B1971 00 [009] - -
                    Reset counter: 236
                    Mileage: 95753 km
                    Date: 2020.02.14
                    Time: 08:16:51
                    Operating condition of parking heater: OFF
                    71
                    Coolant temperature of parking heater: -2 °C
                    Coolant temperature: -1 °C
                    Engine running status: not recognized
                    Fuel level: 23 l
                    Heater output: 0 W
Elki
Sweden
C?ID=149155
;Component:KOMBI         301 6421, Coding:07A409102F80000801882B011000000000000000
;EV_DashBoardVDDMQBAB,009046,EV_DashBoardVDDMQBAB_009_VW37.rod
;Friday,14,February,2020,08:30:02:60455
;VCDS Version: Release 19.6.2 (x64)  Data version: 20200210 DS308.0
IDE00295-Oil temperature display,On ,1
IDE00301-Distance,95753 km,3
IDE00342-ESI: Resetting ESI,Warning active ,1
IDE00343-Language version,Swedish ,1
IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK,Manual reset: not possible ,3
IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel,MFA3-Reset ,3
IDE00345-MAS05464-MFA3-Reset-Refuel detection gas,MFA3-Reset ,3
IDE00345-MAS12879-MFA3-Reset-Electrical refueling detection,MFA3-Reset ,3
IDE00499-Display correction of consumptions and operating range,100 %,1
IDE00500-Hour,8 H,1
IDE00501-Minute,28 min,1
IDE00502-Year,2020 yr,2
IDE00503-Month,2 mon,1
IDE00504-Day,14 d,1
IDE00510-ESI: distance driven from inspection,0 km,3
IDE00511-ESI: time from inspection,0 d,2
IDE00512-ESI: minimum value km-driving distance/inspection,15000 km,2
IDE00513-ESI: maximum value km-driving distance/inspection,30000 km,2
IDE00514-ESI: maximum value of time between inspections,730 d,2
IDE00515-ESI: oil quality,good oil quality ,1
IDE00517-ESI: soot entry,0 km,2
IDE00518-ESI: thermal load,0 km,2
IDE00711-Trip recorder,not installed ,1
IDE00819-Day counter,1424 d,2
IDE00827-ESI: minimum value of time between inspections,365 d,2
IDE01153-SIA: maximum value of distance to service,15000 km,2
IDE01154-SIA: maximum value of time to service,365 d,2
IDE02489-Display depiction,Version 1 ,1
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,-12.8 l,5
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-12.8 l,5
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,12.7 l,5
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.7 l,5
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.7 l,5
IDE03329-Driving profiled for range remaining,4.8 l/100km,2
IDE03346-IDE00301-Units adjusted-Distance,Kilometers ,3
IDE03346-MAS01230-Units adjusted-Date,dd_mm_yy ,3
IDE03346-MAS01456-Units adjusted-Speed,Kilometers per hour ,3
IDE03346-MAS02201-Units adjusted-Temperature,Degrees Celsius ,3
IDE03346-MAS02957-Units adjusted-Time,24h ,3
IDE03346-MAS03032-Units adjusted-Volume,Liter ,3
IDE03346-MAS03034-Units adjusted-Pressure,bar ,3
IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,3
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,3
IDE03346-MAS05875-Units adjusted-Average consumption: electric drive,kWh per 100 km ,3
IDE03346-MAS13665-Units adjusted-Trailer/support load ground,kilogram (kg) ,3
IDE03348-MAS01456-Speed warning-Speed,0 ,2
IDE03348-MAS01561-Speed warning-Unit,Kilometers per hour ,2
IDE03348-Speed warning-,not active ,2
IDE03349-FIX: Max. distance until next mileage-related inspection,30000 km,2
IDE03350-FIX: Maximum time until next time-dependent inspection,730 d,2
IDE03351-FIX: Distance covered since last mileage-dependent inspection,0 km,2
IDE03352-FIX: Time since last time-dependent inspection,0 d,2
IDE03372-Source for synchronization of time,internal clock ,1
IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function,On ,5
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time,10 s,5
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,On ,5
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless,On ,5
IDE03568-ENG102611-Service-key settings-p_write_delay_speed,20 km/h,5
IDE03568-ENG103545-Service-key settings-p_write_delay_time,40 s,5
IDE03568-ENG104099-Service-key settings-p_write_distance,20 km,5
IDE03867-Deactivate seat belt warning,Yes ,1
IDE04169-Display correction of consumption and operating range: gas,100 %,1
IDE05930-Service notification in days,30 d,1
IDE05931-FIX: Reset value for next mileage-dependent inspection,30000 km,2
IDE05932-FIX: Reset value for next time-dependent inspections,365 d,2
IDE05971-Vehicle Positioning System Interface Control Module,not installed ,1
IDE06588-Ignition active message: actuator,Driver door ,1
IDE06922-No-voltage display,Unknown (2),1
IDE07221-Cylinder shut-off,Display ,1
IDE08140-Driving profiled for range remaining CNG,6.0 kg/100 km,2
IDE08247-Driving profile for range remaining LPG,10.0 l/100km,2
IDE11086-Service notification,30 d,1
MAS03685-Digital speedometer,Display ,1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,20
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,20
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,20
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,20
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,20
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,20
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,20
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,20
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,20
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,20
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,20
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,20
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,20
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,20
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,20
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,20
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,20
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,20
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,20
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,20
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,20
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,20
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,20
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,20
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,20
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,20
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,20
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF ,20
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF ,20
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF ,20
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF ,20
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF ,20
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF ,20
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,20
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,20
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,20
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,20
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,20
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF ,20
ENG119875-defuel_threshold,9 l,1
ENG105831-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_day-X1,00 ,12
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,32 ,12
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,66 ,12
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,96 ,12
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,DC ,12
ENG105831-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_day-X6,FD ,12
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,00 ,12
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,00 ,12
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,00 ,12
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,05 ,12
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,14 ,12
ENG105831-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_day-Y6,64 ,12
ENG105832-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_night-X1,00 ,12
ENG105832-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_night-X2,0A ,12
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,32 ,12
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4,64 ,12
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,96 ,12
ENG105832-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_night-X6,FD ,12
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,02 ,12
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,02 ,12
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,17 ,12
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,32 ,12
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,46 ,12
ENG105832-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_night-Y6,64 ,12
ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1,00 ,12
ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2,0A ,12
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,32 ,12
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,64 ,12
ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5,DC ,12
ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6,FD ,12
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,03 ,12
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,03 ,12
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,08 ,12
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,20 ,12
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,55 ,12
ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6,64 ,12
ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1,00 ,12
ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2,0A ,12
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,32 ,12
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,64 ,12
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,96 ,12
ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6,FD ,12
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,05 ,12
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,05 ,12
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,0C ,12
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,17 ,12
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,32 ,12
ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6,64 ,12
ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1,00 00 ,20
ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2,00 32 ,20
ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3,00 64 ,20
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 C8 ,20
ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5,01 F4 ,20
ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1,00 00 ,20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 0E ,20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 41 ,20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8 ,20
ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5,00 FD ,20
ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1,00 ,12
ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2,0A ,12
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,32 ,12
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,64 ,12
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,96 ,12
ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6,FD ,12
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,01 ,12
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,01 ,12
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,07 ,12
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,12 ,12
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,1E ,12
ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6,64 ,12
ENG119874-Gas_functionality,not active ,1
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xd_log_bus_parkinglight ,1
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,parking_light ,1
ENG119882-init_fuel_algorithm,No ,1
ENG130585-Leaving_warning_delay,1.6 s,1
ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0,15 s,16
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4 °C,16
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6 °C,16
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25 °C,16
ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0,5.0 km,16
ENG102605-ENG103631-outside_temperature-P_speed_threshold,20 km/h,16
ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off,180 min,16
ENG102605-ENG104179-outside_temperature-p_tendency_damping,15 s,16
ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.0 °C,16
ENG102605-ENG100500-outside_temperature-p_time_constant_pt1,40 s,16
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.0 ,16
ENG119825-Picture_Upload_Download,not active ,1
ENG119876-Service_Key_Clear_All_Counter,Yes ,1
ENG130584-Statistic_phev_mileage,5 km,1
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms,2.0 s,18
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s,18
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt,35 s,18
ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF,300 ms,18
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms,255 s,18
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s,18
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,6 s,18
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms,20 s,18
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms,900 s,18
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms,10 s,18
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms,3 s,18
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms,10 s,18
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ,0.20 s,18
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse,3 ,18
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.30 ,18
ENG109442-ENG103975-time_parameter_display-tDD15_on,0.00 ,18
ENG109442-ENG100026-time_parameter_display-tDDWUP,0.00 ,18
ENG112418-ENG112412-total_range_gas-consumption_factor,0.000 ,4
ENG112418-ENG112411-total_range_gas-consumption_profile,consumption_profile_calculation ,4
ENG112418-ENG112410-total_range_gas-selection_consumption_factor,consumption_factor_CAN ,4
ENG112418-ENG99298-total_range_gas-State,not active ,4
Elapsed Time: 00:26
annsofie
VCDS.SE
Sweden
Joining the thread since Elki is a Swedish customer and I am curious about the progress. :-)
/A
Dana
Western PA, USA
The OP is still unable to reset the service reminder and he sent the AER installation AdpLog.CSV file to Support. It doesn't go back very far so I fear these aren't the original values but that data included:
Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, Varning aktiv , till, Återställning ,  fredag,01,November,2019,17:41:19:60455
Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, Varning aktiv , till, Återställning ,  fredag,01,November,2019,17:54:10:60455
Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, Varning aktiv , till, Återställning ,  fredag,01,November,2019,17:54:27:60455
Adress 17,3G0 920 751 A,  kanal IDE03351-FIX:Körsträcka sedan senaste körstäcksberoende inspektion, ändrad från, 29700 km, till, 0 km,  fredag,01,November,2019,17:54:28:60455
Adress 17,3G0 920 751 A,  kanal IDE03352-FIX: Tid som gått sedan senaste tidsberoende inspektion, ändrad från, 420 d, till, 0 d,  fredag,01,November,2019,17:54:28:60455
Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, Varning aktiv , till, ingen varning ,  tisdag,17,December,2019,12:24:14:60455
Adress 17,3G0 920 751 A,  kanal IDE02489-Display, ändrad från, Variant 1 , till, Variant 4 ,  måndag,30,December,2019,11:23:37:60455
Adress 17,3G0 920 751 A,  kanal IDE02489-Display, ändrad från, Variant 1 , till, Variant 3 ,  måndag,30,December,2019,11:23:48:60455
Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, ingen varning , till, ingen varning ,  måndag,30,December,2019,11:26:30:60455
Adress 17,3G0 920 751 A,  kanal IDE00345-MAS00234-Reset färddator 3-Färddator-knapp RESET / OK, ändrad från, Manuell reset: inte möjlig , till, Manuell reset: möjlig ,  måndag,30,December,2019,11:27:32:60455
Adress 17,3G0 920 751 A,  kanal IDE00345-MAS00234-Reset färddator 3-Färddator-knapp RESET / OK, ändrad från, Manuell reset: möjlig , till, Manuell reset: inte möjlig ,  måndag,30,December,2019,11:28:34:60455
Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, ingen varning , till, Återställning ,  måndag,30,December,2019,11:36:09:60455
Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, Varning aktiv , till, ingen varning ,  måndag,30,December,2019,11:44:34:60455
Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, ingen varning , till, Återställning ,  måndag,20,Januari,2020,09:15:20:60455
Adress 17,3G0 920 751 A,  kanal IDE03351-FIX:Körsträcka sedan senaste körstäcksberoende inspektion, ändrad från, 4100 km, till, 0 km,  måndag,20,Januari,2020,09:15:21:60455
Adress 17,3G0 920 751 A,  kanal IDE03352-FIX: Tid som gått sedan senaste tidsberoende inspektion, ändrad från, 80 d, till, 0 d,  måndag,20,Januari,2020,09:15:21:60455
Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, Varning aktiv , till, Återställning ,  måndag,20,Januari,2020,09:15:54:60455
Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, Varning aktiv , till, ingen varning ,  måndag,20,Januari,2020,09:25:42:60455
Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, ingen varning , till, Återställning ,  måndag,20,Januari,2020,09:26:34:60455
Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, Varning aktiv , till, ingen varning ,  måndag,20,Januari,2020,09:28:27:60455
Adress 18,5K0 963 272 E,  kanal 42, ändrad från, 0, till, 1,  tisdag,21,Januari,2020,08:54:21:60455
Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, ingen varning , till, Återställning ,  fredag,07,Februari,2020,08:33:39:60455
Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, Varning aktiv , till, Återställning ,  fredag,07,Februari,2020,08:34:22:60455
Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, Varning aktiv , till, Återställning ,  fredag,07,Februari,2020,08:35:12:60455
Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, Varning aktiv , till, Återställning ,  fredag,07,Februari,2020,08:58:15:60455
Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, Varning aktiv , till, Återställning ,  fredag,07,Februari,2020,08:58:53:60455
Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, Varning aktiv , till, ingen varning ,  fredag,07,Februari,2020,08:59:08:60455
Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, ingen varning , till, Återställning ,  fredag,07,Februari,2020,09:48:58:60455
Adress 17,3G0 920 751 A,  kanal IDE03351-FIX:Körsträcka sedan senaste körstäcksberoende inspektion, ändrad från, 900 km, till, 0 km,  fredag,07,Februari,2020,09:48:59:60455
Adress 17,3G0 920 751 A,  kanal IDE03352-FIX: Tid som gått sedan senaste tidsberoende inspektion, ändrad från, 18 d, till, 0 d,  fredag,07,Februari,2020,09:49:00:60455
Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, Varning aktiv , till, Återställning ,  fredag,07,Februari,2020,09:49:44:60455
Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, Varning aktiv , till, Återställning ,  fredag,07,Februari,2020,10:01:42:60455
Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, Varning aktiv , till, Återställning ,  fredag,07,Februari,2020,10:02:01:60455
Adress 17,3G0 920 751 A,  kanal IDE03351-FIX:Körsträcka sedan senaste körstäcksberoende inspektion, ändrad från, 0 km, till, 0 km,  fredag,07,Februari,2020,10:02:02:60455
Adress 17,3G0 920 751 A,  kanal IDE03352-FIX: Tid som gått sedan senaste tidsberoende inspektion, ändrad från, 0 d, till, 0 d,  fredag,07,Februari,2020,10:02:02:60455
Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, Varning aktiv , till, Återställning ,  fredag,14,Februari,2020,12:28:29:60455
Similar to the English condition files is appears as if DE00342 is stuck on Warning Active (Varning aktiv). VCDS was uninstalled at one point so I don't believe we will be able to obtain older information. For that reason I searched the Reference scans and maps sub-forum and found a 2018 Superb Combi with this Engine code:
https://forums.ross-tech.com/showth...oda-Superb-Wagon-Estate-140Kw-TDI-(Australia)
I would prefer to compare VW Passat specific maps but I haven't found one yet. So, working with that information I see both cars use the same PR-Codes:
QI6 Service indicator 30 000 km or 2 years ( variable )
QG1 LongLife Service Regime​
.. however the Skoda is set to: IDE00515-ESI: oil quality poor oil quality
I was always under the impression that oil quality had to be set to good on a RoW car however that specific channel does directly cause service warnings when set incorrectly.
Hopefully someone else spots a discrepancy but my only suggestion at this point is to try changing IDE00515-ESI: oil quality to poor oil quality to see if a reset is possible. If not I believe saving a map in that condition might be a good idea before changing it back.
NEtech
C?ID=56995
I can not that is the cause of the problem, but the channel values have been changed way to often!
Also this is strange:
It showed No warning and that is then changed anyway:confused:
Please post Blockmap with the measuring values.
I guess all history blocks (IDE0391x) are filled.
Seatbelt warning is removed, that should not be a problem, but who knows.
If it was my car I would then try this.
Disconnect Battery an hour maybe.
Also maybe do coding with the same coding.
Then do these adaptations (yes I know most values are the same), just once, in a row, then ignition OFF and drive for some time.
IDE00342-ESI: Resetting ESI > Reset
IDE00515-ESI: oil quality > good oil quality
IDE00512-ESI: minimum value km-driving distance/inspection > 15000
IDE00513-ESI: maximum value km-driving distance/inspection > 30000
IDE00514-ESI: maximum value of time between inspections > 730
IDE00827-ESI: minimum value of time between inspections > 365
IDE03351-FIX: Distance covered since last mileage-dependent inspection > 0
IDE03352-FIX: Time since last time-dependent inspection > 0
Elki
Sweden
C?ID=149155
Now I have tried everything you suggest and some more but the warning still remains. Much can be changed but reset service warning is not accepted. I have also tested with my Autel but it does not remove the warning either. With my old VCDS cable it was never a problem.
Dana
Western PA, USA
Thanks for the update Elki. This sounds like a vehicle side issue rather than a scan tool/communication problem. Even if you had the old HEX-USB+CAN I'm confident the results would be the same.
The mentioned Blockmap may shed light. Rather than choosing Adaptations as the Function, select Measuring Values. Doing so will result in a blockmap file in the Logs folder and the contents may help us understand the problem.
