Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Service reset Passat B8 2016
    Jun 2015
    Sweden
    Friday,14,February,2020,08:21:12:60455
    VCDS Version: Release 19.6.2 (x64) Running on Windows 10 x64
                    Address 18: Aux. Heat       Labels: 5Q0-963-272.clb
    Control Module Part Number: 5Q0 963 272 E    HW: 5Q0 963 272 E
      Component and/or Version: STH-MQB       007 0072
               Software Coding: 9309
                Work Shop Code: WSC 00015 115 00001
                  ASAM Dataset: EV_AuxilParkiHeateWOS 002018 (VW48)
                          VCID: 383C37FC83BFAC8F5D-806C
    0386 - Heating Time Exceeded
              B1971 00 [009] - -
                        Reset counter: 236
                        Mileage: 95753 km
                        Date: 2020.02.14
                        Time: 08:16:51
                        Operating condition of parking heater: OFF
                        71
                        Coolant temperature of parking heater: -2 °C
                        Coolant temperature: -1 °C
                        Engine running status: not recognized
                        Fuel level: 23 l
                        Heater output: 0 W
  2. #12
    Jun 2015
    Sweden
    ;SW:3G0-920-751-A   HW:3G0-920-751-A ---  Instruments
    ;Component:KOMBI         301 6421, Coding:07A409102F80000801882B011000000000000000
    ;EV_DashBoardVDDMQBAB,009046,EV_DashBoardVDDMQBAB_009_VW37.rod
    ;Friday,14,February,2020,08:30:02:60455
    ;VCDS Version: Release 19.6.2 (x64)  Data version: 20200210 DS308.0
    ;VCID: 2306F0902A39DF5798-8076
    IDE00295-Oil temperature display,On ,1
    IDE00301-Distance,95753 km,3
    IDE00342-ESI: Resetting ESI,Warning active ,1
    IDE00343-Language version,Swedish ,1
    IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK,Manual reset: not possible ,3
    IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel,MFA3-Reset ,3
    IDE00345-MAS05464-MFA3-Reset-Refuel detection gas,MFA3-Reset ,3
    IDE00345-MAS12879-MFA3-Reset-Electrical refueling detection,MFA3-Reset ,3
    IDE00499-Display correction of consumptions and operating range,100 %,1
    IDE00500-Hour,8 H,1
    IDE00501-Minute,28 min,1
    IDE00502-Year,2020 yr,2
    IDE00503-Month,2 mon,1
    IDE00504-Day,14 d,1
    IDE00510-ESI: distance driven from inspection,0 km,3
    IDE00511-ESI: time from inspection,0 d,2
    IDE00512-ESI: minimum value km-driving distance/inspection,15000 km,2
    IDE00513-ESI: maximum value km-driving distance/inspection,30000 km,2
    IDE00514-ESI: maximum value of time between inspections,730 d,2
    IDE00515-ESI: oil quality,good oil quality ,1
    IDE00517-ESI: soot entry,0 km,2
    IDE00518-ESI: thermal load,0 km,2
    IDE00711-Trip recorder,not installed ,1
    IDE00819-Day counter,1424 d,2
    IDE00827-ESI: minimum value of time between inspections,365 d,2
    IDE01153-SIA: maximum value of distance to service,15000 km,2
    IDE01154-SIA: maximum value of time to service,365 d,2
    IDE02489-Display depiction,Version 1 ,1
    IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,-12.8 l,5
    IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-12.8 l,5
    IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,12.7 l,5
    IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.7 l,5
    IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.7 l,5
    IDE03329-Driving profiled for range remaining,4.8 l/100km,2
    IDE03346-IDE00301-Units adjusted-Distance,Kilometers ,3
    IDE03346-MAS01230-Units adjusted-Date,dd_mm_yy ,3
    IDE03346-MAS01456-Units adjusted-Speed,Kilometers per hour ,3
    IDE03346-MAS02201-Units adjusted-Temperature,Degrees Celsius ,3
    IDE03346-MAS02957-Units adjusted-Time,24h ,3
    IDE03346-MAS03032-Units adjusted-Volume,Liter ,3
    IDE03346-MAS03034-Units adjusted-Pressure,bar ,3
    IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,3
    IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,3
    IDE03346-MAS05875-Units adjusted-Average consumption: electric drive,kWh per 100 km ,3
    IDE03346-MAS13665-Units adjusted-Trailer/support load ground,kilogram (kg) ,3
    IDE03348-MAS01456-Speed warning-Speed,0 ,2
    IDE03348-MAS01561-Speed warning-Unit,Kilometers per hour ,2
    IDE03348-Speed warning-,not active ,2
    IDE03349-FIX: Max. distance until next mileage-related inspection,30000 km,2
    IDE03350-FIX: Maximum time until next time-dependent inspection,730 d,2
    IDE03351-FIX: Distance covered since last mileage-dependent inspection,0 km,2
    IDE03352-FIX: Time since last time-dependent inspection,0 d,2
    IDE03372-Source for synchronization of time,internal clock ,1
    IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function,On ,5
    IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time,10 s,5
    IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,On ,5
    IDE03568-ENG102414-Service-key settings-p_main_switch_keyless,On ,5
    IDE03568-ENG102611-Service-key settings-p_write_delay_speed,20 km/h,5
    IDE03568-ENG103545-Service-key settings-p_write_delay_time,40 s,5
    IDE03568-ENG104099-Service-key settings-p_write_distance,20 km,5
    IDE03867-Deactivate seat belt warning,Yes ,1
    IDE04169-Display correction of consumption and operating range: gas,100 %,1
    IDE05930-Service notification in days,30 d,1
    IDE05931-FIX: Reset value for next mileage-dependent inspection,30000 km,2
    IDE05932-FIX: Reset value for next time-dependent inspections,365 d,2
    IDE05971-Vehicle Positioning System Interface Control Module,not installed ,1
    IDE06588-Ignition active message: actuator,Driver door ,1
    IDE06922-No-voltage display,Unknown (2),1
    IDE07221-Cylinder shut-off,Display ,1
    IDE08140-Driving profiled for range remaining CNG,6.0 kg/100 km,2
    IDE08247-Driving profile for range remaining LPG,10.0 l/100km,2
    IDE11086-Service notification,30 d,1
    MAS03685-Digital speedometer,Display ,1
    ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,20
    ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,20
    ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,20
    ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,20
    ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,20
    ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,20
    ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,20
    ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,20
    ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,20
    ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,20
    ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,20
    ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,20
    ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,20
    ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,20
    ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,20
    ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,20
    ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,20
    ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,20
    ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,20
    ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,20
    ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,20
    ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,20
    ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,20
    ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,20
    ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,20
    ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,20
    ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,20
    ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF ,20
    ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF ,20
    ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF ,20
    ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF ,20
    ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF ,20
    ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF ,20
    ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,20
    ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,20
    ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,20
    ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,20
    ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,20
    ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF ,20
    ENG119875-defuel_threshold,9 l,1
    ENG105831-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_day-X1,00 ,12
    ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,32 ,12
    ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,66 ,12
    ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,96 ,12
    ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,DC ,12
    ENG105831-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_day-X6,FD ,12
    ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,00 ,12
    ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,00 ,12
    ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,00 ,12
    ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,05 ,12
    ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,14 ,12
    ENG105831-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_day-Y6,64 ,12
    ENG105832-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_night-X1,00 ,12
    ENG105832-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_night-X2,0A ,12
    ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,32 ,12
    ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4,64 ,12
    ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,96 ,12
    ENG105832-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_night-X6,FD ,12
    ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,02 ,12
    ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,02 ,12
    ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,17 ,12
    ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,32 ,12
    ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,46 ,12
    ENG105832-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_night-Y6,64 ,12
    ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1,00 ,12
    ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2,0A ,12
    ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,32 ,12
    ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,64 ,12
    ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5,DC ,12
    ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6,FD ,12
    ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,03 ,12
    ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,03 ,12
    ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,08 ,12
    ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,20 ,12
    ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,55 ,12
    ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6,64 ,12
    ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1,00 ,12
    ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2,0A ,12
    ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,32 ,12
    ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,64 ,12
    ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,96 ,12
    ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6,FD ,12
    ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,05 ,12
    ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,05 ,12
    ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,0C ,12
    ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,17 ,12
    ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,32 ,12
    ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6,64 ,12
    ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1,00 00 ,20
    ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2,00 32 ,20
    ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3,00 64 ,20
    ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 C8 ,20
    ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5,01 F4 ,20
    ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1,00 00 ,20
    ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 0E ,20
    ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 41 ,20
    ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8 ,20
    ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5,00 FD ,20
    ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1,00 ,12
    ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2,0A ,12
    ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,32 ,12
    ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,64 ,12
    ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,96 ,12
    ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6,FD ,12
    ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,01 ,12
    ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,01 ,12
    ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,07 ,12
    ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,12 ,12
    ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,1E ,12
    ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6,64 ,12
    ENG119874-Gas_functionality,not active ,1
    ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xd_log_bus_parkinglight ,1
    ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,parking_light ,1
    ENG119882-init_fuel_algorithm,No ,1
    ENG130585-Leaving_warning_delay,1.6 s,1
    ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0,15 s,16
    ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4 °C,16
    ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6 °C,16
    ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25 °C,16
    ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0,5.0 km,16
    ENG102605-ENG103631-outside_temperature-P_speed_threshold,20 km/h,16
    ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off,180 min,16
    ENG102605-ENG104179-outside_temperature-p_tendency_damping,15 s,16
    ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.0 °C,16
    ENG102605-ENG100500-outside_temperature-p_time_constant_pt1,40 s,16
    ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.0 ,16
    ENG119825-Picture_Upload_Download,not active ,1
    ENG119876-Service_Key_Clear_All_Counter,Yes ,1
    ENG130584-Statistic_phev_mileage,5 km,1
    ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms,2.0 s,18
    ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s,18
    ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt,35 s,18
    ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF,300 ms,18
    ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms,255 s,18
    ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s,18
    ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,6 s,18
    ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms,20 s,18
    ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms,900 s,18
    ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms,10 s,18
    ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms,3 s,18
    ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms,10 s,18
    ENG109442-ENG119803-time_parameter_display-hmi_t_USZ,0.20 s,18
    ENG109442-ENG119806-time_parameter_display-rollierblockgroesse,3 ,18
    ENG109442-ENG101663-time_parameter_display-tDD15_off,0.30 ,18
    ENG109442-ENG103975-time_parameter_display-tDD15_on,0.00 ,18
    ENG109442-ENG100026-time_parameter_display-tDDWUP,0.00 ,18
    ENG112418-ENG112412-total_range_gas-consumption_factor,0.000 ,4
    ENG112418-ENG112411-total_range_gas-consumption_profile,consumption_profile_calculation ,4
    ENG112418-ENG112410-total_range_gas-selection_consumption_factor,consumption_factor_CAN ,4
    ENG112418-ENG99298-total_range_gas-State,not active ,4
    Elapsed Time: 00:26
  3. #13
    VCDS.SE annsofie's Avatar
    Dec 2016
    Sweden
    Joining the thread since Elki is a Swedish customer and I am curious about the progress. :-)
    /A
  4. Likes Dana liked this post
  5. #14
    United States
    The OP is still unable to reset the service reminder and he sent the AER installation AdpLog.CSV file to Support. It doesn't go back very far so I fear these aren't the original values but that data included:
    Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, Varning aktiv , till, Återställning ,  fredag,01,November,2019,17:41:19:60455
    Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, Varning aktiv , till, Återställning ,  fredag,01,November,2019,17:54:10:60455
    Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, Varning aktiv , till, Återställning ,  fredag,01,November,2019,17:54:27:60455
    Adress 17,3G0 920 751 A,  kanal IDE03351-FIX:Körsträcka sedan senaste körstäcksberoende inspektion, ändrad från, 29700 km, till, 0 km,  fredag,01,November,2019,17:54:28:60455
    Adress 17,3G0 920 751 A,  kanal IDE03352-FIX: Tid som gått sedan senaste tidsberoende inspektion, ändrad från, 420 d, till, 0 d,  fredag,01,November,2019,17:54:28:60455
    Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, Varning aktiv , till, ingen varning ,  tisdag,17,December,2019,12:24:14:60455
    Adress 17,3G0 920 751 A,  kanal IDE02489-Display, ändrad från, Variant 1 , till, Variant 4 ,  måndag,30,December,2019,11:23:37:60455
    Adress 17,3G0 920 751 A,  kanal IDE02489-Display, ändrad från, Variant 1 , till, Variant 3 ,  måndag,30,December,2019,11:23:48:60455
    Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, ingen varning , till, ingen varning ,  måndag,30,December,2019,11:26:30:60455
    Adress 17,3G0 920 751 A,  kanal IDE00345-MAS00234-Reset färddator 3-Färddator-knapp RESET / OK, ändrad från, Manuell reset: inte möjlig , till, Manuell reset: möjlig ,  måndag,30,December,2019,11:27:32:60455
    Adress 17,3G0 920 751 A,  kanal IDE00345-MAS00234-Reset färddator 3-Färddator-knapp RESET / OK, ändrad från, Manuell reset: möjlig , till, Manuell reset: inte möjlig ,  måndag,30,December,2019,11:28:34:60455
    Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, ingen varning , till, Återställning ,  måndag,30,December,2019,11:36:09:60455
    Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, Varning aktiv , till, ingen varning ,  måndag,30,December,2019,11:44:34:60455
    Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, ingen varning , till, Återställning ,  måndag,20,Januari,2020,09:15:20:60455
    Adress 17,3G0 920 751 A,  kanal IDE03351-FIX:Körsträcka sedan senaste körstäcksberoende inspektion, ändrad från, 4100 km, till, 0 km,  måndag,20,Januari,2020,09:15:21:60455
    Adress 17,3G0 920 751 A,  kanal IDE03352-FIX: Tid som gått sedan senaste tidsberoende inspektion, ändrad från, 80 d, till, 0 d,  måndag,20,Januari,2020,09:15:21:60455
    Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, Varning aktiv , till, Återställning ,  måndag,20,Januari,2020,09:15:54:60455
    Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, Varning aktiv , till, ingen varning ,  måndag,20,Januari,2020,09:25:42:60455
    Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, ingen varning , till, Återställning ,  måndag,20,Januari,2020,09:26:34:60455
    Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, Varning aktiv , till, ingen varning ,  måndag,20,Januari,2020,09:28:27:60455
    Adress 18,5K0 963 272 E,  kanal 42, ändrad från, 0, till, 1,  tisdag,21,Januari,2020,08:54:21:60455
    Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, ingen varning , till, Återställning ,  fredag,07,Februari,2020,08:33:39:60455
    Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, Varning aktiv , till, Återställning ,  fredag,07,Februari,2020,08:34:22:60455
    Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, Varning aktiv , till, Återställning ,  fredag,07,Februari,2020,08:35:12:60455
    Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, Varning aktiv , till, Återställning ,  fredag,07,Februari,2020,08:58:15:60455
    Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, Varning aktiv , till, Återställning ,  fredag,07,Februari,2020,08:58:53:60455
    Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, Varning aktiv , till, ingen varning ,  fredag,07,Februari,2020,08:59:08:60455
    Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, ingen varning , till, Återställning ,  fredag,07,Februari,2020,09:48:58:60455
    Adress 17,3G0 920 751 A,  kanal IDE03351-FIX:Körsträcka sedan senaste körstäcksberoende inspektion, ändrad från, 900 km, till, 0 km,  fredag,07,Februari,2020,09:48:59:60455
    Adress 17,3G0 920 751 A,  kanal IDE03352-FIX: Tid som gått sedan senaste tidsberoende inspektion, ändrad från, 18 d, till, 0 d,  fredag,07,Februari,2020,09:49:00:60455
    Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, Varning aktiv , till, Återställning ,  fredag,07,Februari,2020,09:49:44:60455
    Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, Varning aktiv , till, Återställning ,  fredag,07,Februari,2020,10:01:42:60455
    Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, Varning aktiv , till, Återställning ,  fredag,07,Februari,2020,10:02:01:60455
    Adress 17,3G0 920 751 A,  kanal IDE03351-FIX:Körsträcka sedan senaste körstäcksberoende inspektion, ändrad från, 0 km, till, 0 km,  fredag,07,Februari,2020,10:02:02:60455
    Adress 17,3G0 920 751 A,  kanal IDE03352-FIX: Tid som gått sedan senaste tidsberoende inspektion, ändrad från, 0 d, till, 0 d,  fredag,07,Februari,2020,10:02:02:60455
    Adress 17,3G0 920 751 A,  kanal IDE00342-Serviceintervall: Återställning av serviceintervall, ändrad från, Varning aktiv , till, Återställning ,  fredag,14,Februari,2020,12:28:29:60455
    Similar to the English condition files is appears as if DE00342 is stuck on Warning Active (Varning aktiv). VCDS was uninstalled at one point so I don't believe we will be able to obtain older information. For that reason I searched the Reference scans and maps sub-forum and found a 2018 Superb Combi with this Engine code:
    https://forums.ross-tech.com/showthr...DI-(Australia)
    I would prefer to compare VW Passat specific maps but I haven't found one yet. So, working with that information I see both cars use the same PR-Codes:
    QI6 Service indicator 30 000 km or 2 years ( variable )
    QG1 LongLife Service Regime
    .. however the Skoda is set to: IDE00515-ESI: oil quality poor oil quality
    I was always under the impression that oil quality had to be set to good on a RoW car however that specific channel does directly cause service warnings when set incorrectly.
    Hopefully someone else spots a discrepancy but my only suggestion at this point is to try changing IDE00515-ESI: oil quality to poor oil quality to see if a reset is possible. If not I believe saving a map in that condition might be a good idea before changing it back.
  6. Likes Uwe, annsofie liked this post
  7. #15
    I can not that is the cause of the problem, but the channel values have been changed way to often!
    Also this is strange:
    It showed No warning and that is then changed anyway
    Please post Blockmap with the measuring values.
    I guess all history blocks (IDE0391x) are filled.
    Seatbelt warning is removed, that should not be a problem, but who knows.
    If it was my car I would then try this.
    Disconnect Battery an hour maybe.
    Also maybe do coding with the same coding.
    Then do these adaptations (yes I know most values are the same), just once, in a row, then ignition OFF and drive for some time.
    IDE00342-ESI: Resetting ESI > Reset
    IDE00515-ESI: oil quality > good oil quality
    IDE00512-ESI: minimum value km-driving distance/inspection > 15000
    IDE00513-ESI: maximum value km-driving distance/inspection > 30000
    IDE00514-ESI: maximum value of time between inspections > 730
    IDE00827-ESI: minimum value of time between inspections > 365
    IDE03351-FIX: Distance covered since last mileage-dependent inspection > 0
    IDE03352-FIX: Time since last time-dependent inspection > 0
  8. Likes Dana, Uwe, annsofie, PetrolDave, Andy liked this post
  9. #16
    Jun 2015
    Sweden
    Now I have tried everything you suggest and some more but the warning still remains. Much can be changed but reset service warning is not accepted. I have also tested with my Autel but it does not remove the warning either. With my old VCDS cable it was never a problem.
  10. #17
    United States
    Thanks for the update Elki. This sounds like a vehicle side issue rather than a scan tool/communication problem. Even if you had the old HEX-USB+CAN I'm confident the results would be the same.
    The mentioned Blockmap may shed light. Rather than choosing Adaptations as the Function, select Measuring Values. Doing so will result in a blockmap file in the Logs folder and the contents may help us understand the problem.
  11. Likes Uwe liked this post
