Results 1 to 6 of 6
Thread: 2015 Audi Q3 no response from Block 46
    Jun 2017
    Hi all
    Just trying to add the "beep" to the above when you lock/unlock the doors.
    I have auto scanned and no problems communicating with 46 on auto scan but when I request to enter 46 I am getting no response from the controller.
    VCDS has updated about half an hour ago to latest version and codes.
    Any ideas what the problem could be here?
    MAS
    Jun 2017
    I have read somewhere that block 46 and block 09 have been merged and block 46 is no longer accessible and I have to go through block 09, is this correct?
    MAS
    Jun 2017
    So I have found this "guide" to activate the "beep" on a 2015 S3:
    - Doors closed but not locked
    - Windows closed
    - Ignition in 1st position
    - MMI on Radio
    - Revert All your alarm related changes
    - Reset MMI
    - Ignition off for 5 mins
    - Make sure all changes have been reverted
    - Windows closed
    - MMI on Radio
    - 09 > Security Access > 31347
    - 09 > Adaptation > (2) - Acknowledgement Signals - Akustische Rueckmeldung Verriegeln = Active
    - 09 > Adaptation > (1) - Acknowledgement Signals - Akustische Rueckmeldung entriegen = Active
    - 09 > Adaptation > (7) - Menuesteuerung akustische Rueckmeldung = Active
    - Reset MMI
    - Ignition off
    - Wait 1 min
    - Activate "Tone when Locking" via MMI menu: Menu > Car > Systems > Vehicle Settings > Central Locking / Tone When Locking
    - Ignition Off
    - Exit car and test
    I have not tried this as I am assuming the security access code is different for the Q3, but this way looks like I am activating something within the MMI to then change the "beep" setting via the MMI and not VCDS.
    So a couple of other questions:
    1. Does/will this guide work for the Q3 with the correct security key?
    2. Are the security keys already there I just need to pull them via VCDS or do I need to get the security code from Audi?
    3. If this guide will not work, is there another guide, other than the Block 46 one, that does work?
    MAS
    Jun 2017
    Here is the Auto Scan, I forgot to save it previously, so this has just been done now.
    Thursday,13,February,2020,13:56:53:24562
    VCDS Version: 19.6.2.2
    Dealer/Shop Name: Marshall Auto Services
    VIN: WAUZZZ8U1FRxxxxxxx   License Plate: LY64 XXX
    Mileage: 113190km-70333mi   Repair Order:
    Chassis Type: 8U-AU21 (8U0)
    Scan: 01 02 03 08 09 10 15 16 17 19 20 22 25 42 44 46 47 52 55 56
              5F 62 6C 6D 72
    VIN: WAUZZZ8U1FR006044   Mileage: 113190km-70333miles
    Address 01: Engine (J623-CUWA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 016 BH    HW: 04L 907 309 K
       Component: R4 2.0l TDI   H20 2916
       Revision: 8AH20---
       Coding: 01250032043701080000
       Shop #: WSC 17974 002 1048576
       ASAM Dataset: EV_ECM20TDI01104L906016BH 004003
       ROD: EV_ECM20TDI01104L906016BE_004.rod
       VCID: 70EF6E0FABFCE1CF55-8024
       Part No SW: 0BH 300 012 K    HW: 0BH 927 711 G
       Component: DSG DQ500-7A  H11 4704
       Revision: 00H11V01
       VCID: 2B55B963425AC21720-807E
    Address 03: ABS Brakes (J104)       Labels: 5N0-614-109-V1.clb
       Part No SW: 5N0 614 109 CA    HW: 5N0 614 109 BS
       Component: ESC-EBC460iV1 H08 0004
       Serial number: A00O9O5
       Coding: 21F124A1CB20E3722077840424C7D3C704365700508B4885
       Shop #: WSC 00049 770 00156
       ASAM Dataset: EV_Brake1ESCEPBTRW 003039
       ROD: EV_Brake1ESCEPBTRW_003.rod
       VCID: 6CD77A7F87D4052F69-8038
       Part No SW: 8U0 820 043 F    HW: 8U0 820 043 F
       Component: E87  Klimavoll      0210
       Revision: 00H05000    Serial number: 8U0820043F
       VCID: 3467A21F57649DEF71-8060
    01810 - Actuating Motor for Temperature Flap; Right (V159)
                        Fault Status: 00100011
                        Reset counter: 128
                        Mileage: 112594 km
                        Date: 2020.01.26
                        Time: 15:24:18
                        Voltage: 14.50 V
                        Temperature: 12.5°C
                        (no units): 28.0
                        (no units): 52.0
                        Temperature: 8.0°C
    00710 - Defroster Flap Positioning Motor (V107)
                        Fault Frequency: 13
                        Reset counter: 133
                        Mileage: 112669 km
                        Date: 2020.01.28
                        Time: 16:12:08
                        Voltage: 14.30 V
                        Temperature: 11.5°C
                        (no units): 23.0
                        (no units): 54.0
                        Temperature: 5.5°C
    Address 09: Cent. Elect. (J519)       Labels:. 8X0-907-063.clb
       Part No SW: 8X0 907 063 AB    HW: 8X0 907 063 AB
       Component: BCM PQ35  M   113 0817
       Revision: AB113817
       Coding: 0E000A2CA805F1C0201849C82184014C53F327AA216F812BE408878400C5
       Shop #: WSC 00049 770 00099
       VCID: 7CF74A3FFFB495AFF9-8028
       Subsystem 1 - Part No SW: 8U2 955 119     HW: 8U2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS316 141028  H37 0090
       Serial number:         141105215028
       Coding: 0047F7
       Serial number: 23427472
       Coding: 02006E
       Subsystem 3 - Part No: 8X0 951 177
       Component: DWA-Sensor H0  H01 0020
    Address 10: Park/Steer Assist (J791)       Labels:* None
       Part No SW: 8U0 919 475 A    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0050
       Revision: --------    Serial number: 56231431904387
       Coding: B81309
       Shop #: WSC 00049 770 00119
       ASAM Dataset: EV_EPHVA2CAU3160000 003004
       ROD: EV_EPHVA2CAU3160000_003.rod
       VCID: 4189FBCBD0D63847EA-8014
    Address 15: Airbags (J234)       Labels:| 8X0-959-655.clb
       Part No SW: 8U0 959 655 C    HW: 8U0 959 655 C
       Component: AirbagVW-AU10 H09 0900
       Serial number: 003PAR09LCG.
       Coding: 30523232333030303030554A305238553053
       ASAM Dataset: EV_AirbaAU10SMEAU316 001010
       ROD: EV_AirbaAU10SMEAU316_001.rod
       VCID: 479DE5D3FEF2067724-8012
       Subsystem 1 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
       Serial number: 3496KSME6C391533ZZZ
       Subsystem 2 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
       Serial number: 3506KSME1A013C33ZZZL
       Serial number: 3516KSME051B1533ZZZI
       Serial number: 3526KSME40637031ZZZE
       Subsystem 5 - Part No SW: 8U0 959 651     HW: 8U0 959 651
       Serial number: 3555USME07197030ZZZT
    Address 16: Steering wheel (J527)       Labels:| 8X0-953-569.clb
       Part No SW: 8X0 953 521 D    HW: 5K0 953 569 AE
       Component: LENKS.MODUL   016 0162
       Revision: FF010018    Serial number: 20141115201026
       Coding: 1894204000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 3D71873BAC2E5CA78E-8068
       Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
       Serial number: 14 11 2014  E0043791
    Address 17: Instruments (J285)       Labels:| 8X0-920-xxx-17.clb-SRI1
       Part No SW: 8U0 920 990 H    HW: 8U0 920 990 H
       Component: KOMBI_COLOUR  H02 0350
       Coding: 42CF01
       ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
       VCID: 428BF4C7D5D0235FF3-8016
    Address 19: CAN Gateway (J533)       Labels: 8X0-907-468.clb
       Part No SW: 8U0 907 468 AQ    HW: 8U0 907 468 G
       Component: GAT 4CAN 1L M H13 0090
       Revision: 1P140041    Serial number: 4141P14B0705EC
       Coding: FBCF1A5A000108610353
       VCID: 11290B8BC83688C73A-8044
       Component: J367-BDM  H07 0180
       Serial number: 41317H45371491089191
       Serial number: 14316002840011200410
                        Reset counter: 106
                        Mileage: 113191 km
                        Date: 2020.02.13
                        Time: 12:13:17
                        Bin. Bits:    10111
                        Voltage: 11.30 V
                        Count: 6
       Part No SW: 8U0 857 511 B    HW: 8U0 857 511 B
       Component: FLA           H03 0012
       Revision: AA002001
       Coding: 04020A64747464545425363E00
       VCID: 3A7B8C27B5006B9FAB-806E
       Part No SW: 0AY 907 554 J    HW: 0AY 907 554 J
       Component: Haldex4Motion H52 7522
       Serial number: HA1-00022.10.14
       Coding: 0001
       VCID: 52ABC48705B0B3DF43-8006
       Component: IMMO          H02 0350
       Coding: 000002
       ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04113
       ROD: EV_Immo_UDS_VDD_AU10.rod
    Address 42: Door Elect, Driver (J386)       Labels:. 8X0-959-793.clb
       Part No SW: 8X0 959 793 H    HW: 8X0 959 793 H
       Component: TSG FA        H11 0415
       Coding: 011E06201C01000000
       VCID: 52ABC4870DB0B3DF43-8006
       Part No: 5N0 909 144 R
       Component: EPS_ZFLS Kl. 296    3501
       Revision: 00H22000
       VCID: 408FFECF13DC314FE5-8014
    Address 47: Sound System (J525)       Labels: Redir Fail!
       Part No SW: 8X0 035 223 D    HW: 8X0 035 223 B
       Component: BOSE-G3-A1Q3  H05 0160
       Revision: CK005201    Serial number: 00000000022825
       Coding: 030000
       Shop #: WSC 02421 002 1048576
       VCID: 3365A103926A9AD768-8066
    Address 52: Door Elect, Pass. (J387)       Labels:. 8X0-959-792.clb
       Part No SW: 8X0 959 792 H    HW: 8X0 959 792 H
       Component: TSG BF        H11 0415
       Coding: 011E06201E01000000
       VCID: 51A9CB8B08B6C8C77A-8004
    Address 55: Headlight Range (J745)       Labels:| 5M0-907-357-V3.clb
       Part No SW: 5M0 907 357 G    HW: 7P6 907 357 B
       Component: AFS-ECU       H01 0031
       Coding: 08AE00102B230200
       ASAM Dataset: EV_HeadlRegulLEDAFSPt 001001
       ROD: EV_HeadlRegulLEDAFSPt.rod
       VCID: 387F962F830C798F5D-806C
       Subsystem 1 - Part No SW: 7PP 941 572 AA    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo li.  H08 0002
       Coding: E02500
       Subsystem 2 - Part No SW: 7PP 941 572 AA    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo re.  H08 0002
       Coding: E02500
       Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
       Component: LeiMo links  H01 7050
       Coding: E02500
       Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 7050
       Coding: E02500
       Part No SW: 4G0 035 061 Q    HW: 4G0 035 061
       Component: Radio U DAB   H60 0150
       Revision: AB001007    Serial number: 109K20E7991710
       Coding: 010105010000000002
       VCID: 2B55B9634A5AC21720-807E
       Part No SW: 8U1 035 670     HW: 8U1 035 670
       Component: H-BNT-EU      H40 0898
       Revision: --------    Serial number: 486K30E7500177
       Coding: 0E010106000AE1EB0580033600000001000000000000000000
       VCID: 73E56103D2EADAD7A8-8026
       Subsystem 1 - Part No: 8R0 060 884 CH
       Component: EUR 2014  2004
       Subsystem 2 - Part No SW: 8U0 919 604 A    HW: 8U0 919 604 A
       Component: DU High AU316  H42 0018
       Serial number: AUZ8ZDEG900QK56
       Subsystem 3 - Part No: 8R0 060 961 G
       Component: CD-Database  5950
                        Reset counter: 146
                        Mileage: 113191 km
                        Date: 2020.02.13
                        Time: 12:11:17
                        Bin. Bits: 00000000 10000000
                        Bin. Bits: 00000000 00000000
       Part No SW: 8X0 959 795 C    HW: 8X0 959 795 C
       Component: TSG HL        H08 0415
       Coding: 010E06200001000000
       VCID: 4FADCDF31E82DE376C-801A
       Part No SW: 8U0 907 441     HW: 8U0 907 441
       Component: SG Rueckfahrkamera  0031
       Revision: --H09---    Serial number: 525 PA8J4XH2GX
       Coding: 1080015
       Shop #: WSC 02391 785 00012
       VCID: 76E358170198CFFF8F-8022
       Part No SW: 8U0 959 107     HW: 8U0 959 107
       Component: HDSG-Modul    H01 0549
       Revision: 15001001    Serial number: 315400562
       Coding: 183307C002
       ASAM Dataset: EV_HDSGAU316 001001
       ROD: EV_HDSGAU316.rod
       VCID: 7CF74A3FF7B495AFF9-8028
       Component: TSG HR        H08 0415
    End-------------------------(Elapsed Time: 04:36)--------------------------
    There is no 46 in this vehicle.
    Quote Originally Posted by MASLtd View Post
    No. A 2015 S3 is based on the MQB (Mk.7) platform and systems. Your Q3 still has Mk.6 style systems.
    Try Long Coding in the BCM (at address 09), Byte 5, Bit 1 should be "Locking Confirmation via Horn active", and Bit 4 should be "Unlocking Confirmation via Horn active".
    PS: Moving to Tweaks.
