Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 45
Thread: Address 02: Auto Trans Cannot be reached
    Feb 2020
    Quote Originally Posted by MartinsX View Post
    Can You access modules 02, 03 and 37 directly?
    I had similar issues in autoscan mode with different cars, mainly when I use my old slow Win XP laptop. Directly modules communicate without any problems.
    Tried direct. No dice. I think the AS module is stopping comms to the Transmission Controller.
  2. #12
    Threads merged.
  3. #13
    TCU under water but CAN is indeed operational on 125 in aforementioned log?
  4. #14
    Feb 2020
    The car runs fine. No Dash lights. When the VCDS autoscan is running, the ABS/traction lights come on when it tries the ABS module.
    The main ECU is reporting the existance of the TCU and ABS? Correct?
    Address 01: Engine (07C 906 018 FQ)
    09:48:51 Group 125: CAN-Databus Communication (Powertrain)
    Transm. 1 Transmission Electronics (J217)
    ABS 1 Brake Electronics (J104)
    Instruments 1 Instrument Cluster (J285)
    HVAC 1 Heating/Air Condition (J255)
    On Audi's, the ABS error stops the TCU from being read, somehow.
  5. #15
    Did you unplug ABS module to see if things wake up and did you know sometimes a 1 in block 125 values isn't always a guarantee that a module is actually communicating in ME 7?
  6. #16
    Feb 2020
    Hi Jack, Not yet. Just waiting for Storm Dennis to pass. I am assuming the ABS pump is under the scuttle... Which means getting the wipers off... Which are being stubborn at the moment!
  7. #17
    LOL those dam W12's..............
    Let us know when Stormy Daniels blows by okay?
  8. #18
    Feb 2020
    Well I unplugged the ABS and it made no difference.
    No comms at all to the transmission. There is something happening when I try to talk to the ABS unit as the ABS lights go on but eventually VCDS says that there have been too many comms errors.
    Any ideas what I can try next?
    Are there any comms logs that will show me what VCDS is doing while it's trying to communicate to the ABS module?
  9. #19
    So when you unplug ABS do you still have COM in 125?
    Are you sure you dont need to check for FOD water ingress in ESP and Trans controllers in the lower catacombs?
  10. #20
    Feb 2020
    Will check what 125 says when I unplug the ABS, but it certainly flagged up on the dash and when I scanned the engine. Also when I scanned the ABS it said no comms immediately instead of trying to connect for ages.
    As the car is running OK, I have no reason to suspect any actual faults in the TCM. But I might have a look at the module anyway... Not too easy to get at though. I don't have a lift. I have a pit but there's another vehicle on there at the moment.
    Maybe there is some cable fault somewhere? Could a fault exist between the OBD connector and the transmission/ABS but not between the ECU and transmisson/ABS?
