Results 1 to 4 of 4
Thread: Audi A3 2000 1.8t Camshaft position error
    Pirate
    Feb 2020
    Bulgaria
    Hello guys,
    i have Audi A3 8l 2000 1.8t AUM 150bhp.
    At the local car service they found this fault code:
    16395-Bank 1: Camshaft A (Intake)
    P0011 - 35-10 - Retard Setpoint not Reached (Over-Advanced) - Intermittent
    After that they scan blocks 90,91,93, which they say show timing belt and camshaft chain alignment. The Measuring block 93, Phase Position Bank 1 read -5.0 degrees KW and they say that this means the chain has stretched and/or the chain tensioner is going bad, becouse that spec should be 0. Measuring block 90 and 91, Adjustment bank 1 reads -1.0 degrees.
    The timing belt and tensioner was changed before 2000km, and if i understand correctly, blocks 90 and 91 show that the belt is aligned correctly.
    What is the tolerance for block 93 phase position? And should i replace the cams chain and tensioner asap, or i could drive this way (and for how long)?
    Please post a full unedited VCDS Auto-Scan (using the English version of VCDS) so we can see how your A3 is equipped.
  3. Likes Uwe liked this post
    Pirate
    Feb 2020
    Bulgaria
    Here it is:
    Removed.   Data from a clone/pirate copy of VCDS is not acceptable here.
  6. #4
    Getting help in this forum requires the use of a legitimate VCDS system.
    http://www.ross-tech.com/distributors.php
    Let us know if/when you get one and we'll adjust your forum status.
