Eos multifonction steering wheel retrofit issue
Laurentlux1976
France
C?ID=344103
Hi all,
I have a 2010 Eos GT Sport DSG (phase 1.5 - phase 1 with the phase 2 interior).
I did the retrofit of the multifunction steering wheel.
All is working fine, no errors in vcds.
As part of the retrofit, I changed the steering wheel module based on the "Ross-Tech Steering Wheel Control Module Versions". Previous was 5K0 953 569 - new one is 5K0 953 569 E (which is apparently compatible with MFD, CCS, MFSW & AT).
The issue i have is that in module 16 - steering wheel, I can't tick the box for byte 0 / bit 3 (Automatic transmission (ignition key removal lock) installed). I get the Error 31 message.
I also tried with VCP -> same issue.
Does it mean that the steering module 5K0 953 569 E is not compatible with DSG?
Which module should it take? A "T"? An "AL"?
Here is my scan:
Sunday,02,February,2020,12:32:34:59253
VCDS Version: 19.6.2.0 (x64)  HEX-V2 CB: 0.4513.4
VIN: WVWZZZ1FZAV018055   License Plate:
Chassis Type: 1F-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 26 42 44 46 52 55 5F 62 72
VIN: WVWZZZ1FZAV018055   Mileage: 142570km-88588miles
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 PL    HW: 03L 906 022 G
   Component: R4 2.0l TDI G000AG  9980
   Revision: 13H03---    Serial number:
   Coding: 0000078
   Shop #: WSC 66565 257 00032
   VCID: 7EA4083C3CF902A7BBB-802A
   Part No SW: 02E 300 052 T    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2112
   Revision:    51112    Serial number: 00001001271349
   Shop #: WSC 00020 000 90108
   VCID: 25160750F9EF717F9A1-8070
   Part No SW: 1K0 907 379 AJ    HW: 1K0 907 379 AJ
   Revision: 00H30001
   Coding: 543B6008092300022A0B06E9901E0042350000
   Shop #: WSC 00020 790 00000
   VCID: 7AAC042C2CD12E87873-802E
   Part No SW: 5K0 907 044 BT    HW: 5K0 907 044 BT
   Revision: 00003001
   Coding: 0000000002
   Shop #: WSC 00020 999 00000
   VCID: 7EA4083C307902A7BBB-802A
   Part No SW: 5K0 937 087 D    HW: 5K0 937 087 D
   Component: BCM PQ35 H    011 0028
   Revision: BE011001
   Coding: 46000A3B8A25F260400800803400092443555488712085605C8000000000
   Shop #: WSC 00020 790 12345
   VCID: 3634D01C58490AE723B-8062
   Subsystem 1 - Part No: 1Q1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 02031  22  0512
   Coding: 009795
   Component: RLS 260210 05  54  0403
   Coding: 0330CD
   Subsystem 3 - Part No: 1Q0 951 177 C
   Component: Innenraumuebe  200 0203
   Subsystem 4 - Part No: 1K8 951 605
   Component: LIN BACKUP HO  H09 9002
   Subsystem 5 - Part No: 1K0 907 719 C
   Component: Neigungssenso  005 0003
Address 10: Park/Steer Assist (J446)       Labels:. 1K0-919-475.clb
   Part No SW: 1K0 919 475 K    HW: 1K0 919 475 K
   Component: PARKHILFE     005 1706
   Revision: 00005000    Serial number: 0 263 004 388
   Coding: 101101
   VCID: 3A2CC42C6C51EE87C73-806E
Address 15: Airbags        Labels: 1Q0-959-655.lbl
   Part No SW: 1Q0 959 655 A    HW: 1Q0 959 655 A
   Component: A6 Airbag VW8C      0180
   Revision: 92010018    Serial number: 003B3004UPA0
   Coding: 0016694
   VCID: 3A2CC42C6051EE87C73-806E
   Subsystem 1 - Serial number: 6332SRB40AFB5398G
   Subsystem 2 - Serial number: 6342SRB40AFD9521B
   Subsystem 3 - Serial number: 637  RB4        8
   Subsystem 4 - Serial number: 638  RB4        9
   Part No SW: 1K5 953 521 AR    HW: 5K0 953 569 E
   Component: LENKS.MODUL   009 0135
   Revision: FF010037    Serial number: 20100723200446
   Coding: 008A140000
   Shop #: WSC 01608 666 28888
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7DA60F303D7F19BFA21-8028
   Coding: E20000
   Part No SW: 1Q0 920 874 K    HW: 1Q0 920 874 K
   Component: KOMBI         H05 0305
   Coding: 171F00
   VCID: 3B22C12863EBD78FDC5-806E
   Part No SW: 7N0 907 530 BC    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1663
   Revision:   H56       Serial number: 141015F1000195
   Coding: 355000
   VCID: 72BC2C0C74A156C7CF3-8026
   Component: IMMO          H05 0305
   VCID: 6A8C346C5CF19E07773-803E
Address 26: Auto Roof        Labels: 1Q0-959-255.clb
   Part No SW: 1Q0 959 255 E    HW: 1Q0 959 255 E
   Component: Verdecksteuergeraet 0842
   Revision: 0033100N    Serial number: 100400027
   Coding: 0655366
   Part No SW: 1Q0 959 701 H    HW: 1Q0 959 701 H
   Component: Tuer-SG         009 2121
   Coding: 0020663
   VCID: 392EDB206557E59FCE9-806C
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 71     3001
   Revision: 00H17000
   VCID: 313EE300BD272DDF769-8064
   Part No SW: 1Q0 959 702 H    HW: 1Q0 959 702 H
   Coding: 0020918
   Component: AFS-Steuergeraet    0142
   Coding: 2507971
   VCID: 3430EA14423518F71DF-8060
   Subsystem 1 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    0004
   Coding: 00000038
   Subsystem 2 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Coding: 00000038
   Part No SW: 5C0 035 680 B    HW: 5C0 035 680 B
   Component: MU-S-N-ER     H20 0245
   Serial number: --------------
   Coding: 02230401FF00000011110001000808001F0100C40020010006
   Shop #: WSC 00066 790 00071
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 20181644EA4D9457E97-8074
0527 - Rear Left Bass Speaker
          B1065 13 [009] - Open Circuit
          [Tieftonlautsprecher Kanal 4: Unterbrechung (DC-Diagnose)]
                    Reset counter: 195
                    Mileage: 142575 km
                    Date: 2020.02.02
                    Time: 12:30:15
                    Voltage terminal 30: 11.8 V
   Part No SW: 1Q0 959 811 B    HW: 1Q0 959 811 B
   Component: Tuer-SG         004 0602
   Coding: 0000144
   Shop #: WSC 00020 790 1012544
   VCID: 3536D710494F01FF2A1-8060
   Part No SW: 1Q0 959 812 B    HW: 1Q0 959 812 B
   Coding: 0000144
   VCID: 3634D01C54490AE723B-8062
End----(Elapsed Time: 01:41, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
Thanks a lot,
Laurent
Laurentlux1976
France
C?ID=344103
Nobody had the same issue?
m87a
Bosnia and Herzegovina
C?ID=156900
You're right E doesn't support DSG Automatic transmission (ignition key removal lock)
you can choose
5K0 953 569 B (which supports GRA, DSG, MFSW, no G85)
5K0 953 569 AE & BD same as B
Laurentlux1976
France
C?ID=344103
Thanks a lot :)
Are you sure that the Eos doesn't have G85?
Dana
Western PA, USA
5K0-953-569-E edit on Wiki Steering Wheel Control Module Versions page
Update. I went through all of our local scans containing HW# 5K0 953 569 E and none of them included Coding 00/3 Automatic Transmission (Ignition Key Removal Lock) installed [NOT with KESSY] coding. Some were 02E DSGs but with KESSY so that bit doesn't apply.
Based on that -and- the feedback in this thread I edited that to include Yes* with new note at the bottom as well:
Part Number 5K0-953-569 section
5K0-953-569-E appears to support Automatic transmission only with KESSY. This module does not appear to support the coding for Automatic Transmission (Ignition Key Removal Lock) installed per this thread.
Laurentlux1976
France
C?ID=344103
Thanks a lot to both of you.
A friend of mine gave me a "BD" to test, I'll try this weekend as it should normally be compatible to my Eos.
Laurentlux1976
France
C?ID=344103
Hi all,
I've replaced the steering wheel module 5K0-953-569-E with the 5K0-953-569-BD and I've been able to tick the box for Automatic Transmission (Ignition key removal lock) in module 16.
But now, two error messages appeared in module 1:
050217 - Implausible Data Received from Steering Column Control Module
005784 - Please Check DTC Memory of Steering Wheel Electronics
Coding is exactly the same as for my previous steering wheel module (except for ignition lock).
I've looked on internet but didn't find any solution.
Would you know what I have to do?
Here is my scan:
 Saturday,22,February,2020,14:14:21:59253
VCDS Version: 19.6.2.2 (x64)  HEX-V2 CB: 0.4513.4
VIN: WVWZZZ1FZAV018055   Mileage: 142600km-88607miles
   Coding: 0000078
   VCID: 7EA4083C3CF902A7BB9-802A
               U0429 - 000 -  - Intermittent
                    Mileage: 142603 km
                    Date: 2014.07.15
                    Time: 02:17:04
                    (no units): 255.0
                    (no units): 255.0
                    Bin. Bits: 01000000
               P1698 - 000 -  - Intermittent
                    Mileage: 142603 km
                    Date: 2014.07.15
                    Time: 02:17:04
                    (no units): 255.0
                    (no units): 255.0
                    Bin. Bits: 01000000
   VCID: 25160750F9EF717F9A3-8070
   Revision: 00H30001
   VCID: 7AAC042C2CD12E87871-802E
   Part No SW: 3AA 907 044 AG    HW: 3AA 907 044 AG
   Component: Climatronic   H03 0303
   Revision: 00001K02
   Coding: 0000000002
   Shop #: WSC 00015 115 12345
   VCID: 75B61710054F41FFEA3-8020
   Revision: BE011001
   VCID: 3634D01C58490AE7239-8062
   Coding: 009795
   Coding: 0330CD
   Coding: 101101
   VCID: 3A2CC42C6C51EE87C71-806E
   Coding: 0016694
   VCID: 3A2CC42C6051EE87C71-806E
Address 16: Steering wheel (J527)       Labels:| 8X0-953-569.clb
   Part No SW: 8X0 953 521 AF    HW: 5K0 953 569 BD
   Component: LENKS.MODUL   018 0230
   Revision: FF010018    Serial number: 20151215200892
   Coding: 088A140000
   Shop #: WSC 00046 412 12345
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 005876C44A8D7457C95-8054
   Serial number: 40000000000000133390
   Coding: E20000
   Coding: 171F00
   VCID: 3B22C12863EBD78FDC7-806E
   Coding: 355000
   VCID: 72BC2C0C74A156C7CF1-8026
   VCID: 6A8C346C5CF19E07771-803E
   Coding: 0655366
   Coding: 0020663
   VCID: 392EDB206557E59FCEB-806C
   Revision: 00H17000
   VCID: 313EE300BD272DDF76B-8064
   Coding: 0020918
   Coding: 2507971
   VCID: 3430EA14423518F71DD-8060
   Coding: 00000038
   Coding: 00000038
   VCID: 20181644EA4D9457E95-8074
   Subsystem 1 - Part No SW: 5NA 919 866 S    HW: -----------
   Component: ECE1 2020  --- 1310
          B1066 13 [009] - Open Circuit
          [Hochtonlautsprecher Kanal 4: Unterbrechung (AC-Diagnose)]
                    Reset counter: 196
                    Mileage: 142603 km
                    Date: 2020.02.22
                    Time: 02:20:23
                    Voltage terminal 30: 11.4 V
   Coding: 0000144
   VCID: 3536D710494F01FF2A3-8060
   Coding: 0000144
   VCID: 3634D01C54490AE7239-8062
End----------(Elapsed Time: 01:41, VBatt start/end: 12.1V/12.0V)-----------
Thanks a lot for your help
Laurent
Laurentlux1976
France
C?ID=344103
No one has an idea of those error codes?
All plugs to the module are correctly inserted...
Thank you
m87a
C?ID=156900
did you try to go to 01 engine directly and try clearing dtc's, because sometimes 01 refuses to delete errors when you clear them all at once.
Laurentlux1976
France
C?ID=344103
Thanks, I'll try that solution.
