Results 1 to 2 of 2
Thread: Audi TT MK1 Climate Control strange behavior, or should it be so, maybe?
    Sep 2016
    Riga, Latvia
    Car is TT MK1, MY 2000.
    Problem is that air from center vents of dash comes much warmer than from side vents (both).
    Does not matter, what mode is used - auto, econ, recirculation, what flow direction is set etc.
    At the moment of measurements outside T is approx +3 degrees C, in workshop, where car is located is approx +10 degrees, climate control is set to 22 degrees, engine is at working T, average T in passenger compartment is maintained +/- ok as set value, only from side vents comes approx +20, but from center vents approx +30. If set value is increased, difference increases, too.
    No fault codes. Recirculation flap motor was faulty, but I replaced it before. All flaps are where commanded, according position sensor data. According RTFB there are no any separate air distribution or temperature regulation between center and side outlets.
    Any comments from TT MK1 owners or repairers are welcome.
    Autoscan and MVB map below.
    P.S. Permanent airbag disable switch fault is stored because glove box is still removed for recirculation motor replacement.
    Thursday,13,February,2020,02:05:02:32442
    VCDS Version: 19.6.1.0
    Chassis Type: 8N - Audi TT (1999 > 2007)
    Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
       Mileage: 237050km-147296miles
    Address 01: Engine        Labels: 06A-906-032-AJQ.clb
       Part No: 8N0 906 018 A
       Component: 1.8L R4 5VT         0010
       Coding: 05500
       Shop #: WSC 01236
       VCID: 2F6D7983ED63F63730-5140
    Address 03: ABS Brakes        Labels: 8N0-907-379-MK20.lbl
       Part No: 8N0 907 379
       Component: ASR     20 IE CAN  0001
       Coding: 13204
       Shop #: WSC 01236
       VCID: 79F987DB63A7E887DE-4B00
    Address 08: Auto HVAC        Labels: 8N0-820-043.lbl
       Part No: 8N0 820 043
       Component: TT-KLIMAVOLLAUTOMAT D02
       Coding: 00040
       Shop #: WSC 01236
       VCID: 67DDD1A305136E7738-2580
    Address 15: Airbags        Labels: 8N8-909-601.lbl
       Part No: 8N8 909 601
       Component: Airbag Front+Seite 0005
       Coding: 10102
       Shop #: WSC 01236
       VCID: 77FD81E355B3FEF7A8-5140
    01228 - Airbag Cut-Off Switch for Passenger Side (E224)
                30-00 - Open or Short to Plus
    Address 17: Instruments        Labels: 8Nx-919-xxx-17.lbl
       Part No: 8N1 919 860 C
       Component: KOMBI+WEGFAHRS. M73 D30
       Coding: 00144
       Shop #: WSC 00558
       VCID: 3B755DD3291B1A978C-4B00
       Subsystem 1 - Part No: Ident
       Component: Nr. Wegfahrs.:AUZ5Z0E9075010
       Ident.-Nr. Wegfahrs.:AUZ5Z0E9075010
    Address 35: Centr. Locks        Labels:. 8Nx-962-267.lbl
       Part No: 8N8 962 267
       Component: Zentralverrieg.,DWA D04
       Coding: 04682
       VCID: 7EF394C77A89CFBFEB-4EEA
    Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
       Part No: 8N8 951 177
       Component: Innenraumueberw.    D09
       Coding: 00001
       VCID: 7CF79ECF6C95DDAFC5-51B6
    Address 56: Radio        Labels: 8D0-035-1xx-56.lbl
       Part No: 4B0 035 186 B
       Component:  Radio              D04
       Coding: 00201
       Shop #: WSC 01236
       VCID: 1F4D89439DC366B780-4B1A
    End-------------------------(Elapsed Time: 03:42)--------------------------
    ;SW:8N0-820-043   HW: ---  Auto HVAC
    ;Component:TT-KLIMAVOLLAUTOMAT D02, Coding:00040
    ;Thursday,13,February,2020,02:05:55:32442
    ;VCDS Version: Release 19.6.1  Data version: 20190529 DS308.0
    ;VCID: 67DDD1A305136E7738-2580
    Group,Field 1,Data type,Field 2,Data type,Field 3,Data type,Field 4,Data type,
    1,0.0,(no units),0.0,(no units),13.90 V,Voltage,240.0,(no units),
    2,81.0,(no units),82.0,(no units),215.0,(no units),38.0,(no units),
    3,221.0,(no units),226.0,(no units),222.0,(no units),40.0,(no units),
    4,113.0,(no units),114.0,(no units),212.0,(no units),40.0,(no units),
    5,24.0,(no units),19.0,(no units),227.0,(no units),23.0,(no units),
    6,9.0C,Temperature,20.0C,Temperature,12.0C,Temperature,0.0 %,Load,
    7,0.0,(no units),35.0C,Temperature,20.0C,Temperature,85.0C,Temperature,
    8,6.70 V,Voltage,6.70 V,Voltage,18.8 %,Load,4.0 %,Load,
    9,760 /min,RPM,0.0 km/h,Speed,0.0,(no units),N/A,,
    10,0.0,(no units),1.0,(no units),0.0,(no units),0.0,(no units),
  2. Likes Uwe, Jack@European_Parts liked this post
  3. #2
    Blend door Flap in box broken or with foam delaminated allowing a mix in any position.
  4. Likes Uwe liked this post
