Not an actual fault I believe? But my car seem to not display this warning light at all even at ignition cycles. I visually check my oil level so no biggie just wondering if it is working as indented, carrying out an Output test on the instruments shows this as working. I'm just curious apologies if this has been covered before
Wednesday,12,February,2020,21:46:30:10909
VCDS Version: 19.6.2.2 (x64) HEX-V2 CB: 0.4508.4
VIN: WVWZZZ1KZ6W179825 License Plate: GTI
Adaptation Channel 039:
Stored value 1
Test value 1
Oil Level Sensor Adaptation
Oil
Reading
evaluation
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72
VIN: WVWZZZ1KZ6W179825 Mileage: 183370km-113940miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 J HW: 1K0 907 115 F
Component: 2.0l R4/4V TFSI 0030
Revision: --H14--- Serial number: VWZ7Z0F3753105
Coding: 0403000318070060
Shop #: WSC 00464 210 91410
VCID: 2D06FB76C11397BF523-8078
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Component: ESP FRONT MK60 0102
Revision: 00H13001
Coding: 0004738
Shop #: WSC 01279 785 00200
VCID: 71BE27061DABB35F36B-8024
Part No: 1K0 907 044 BE
Component: ClimatronicPQ35 090 0808
VCID: 6B82356E3F87598F0C7-803E
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000005630488
Coding: E78F8F27001415000014000014000000000B7F075C
Shop #: WSC 12345 785 00200
VCID: 2B02F56EFF07998F4C7-807E
Subsystem 1 - Part No: 1K2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 013 0402
Coding: 00063445
Shop #: WSC 12345
Subsystem 2 - Part No: 1K0 955 559 T Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 011 1110
Coding: 00469790
Shop #: WSC 12345
Part No SW: 1K0 909 605 P HW: 1K0 909 605 P
Component: 12 AIRBAG VW8R 032 7900
Revision: 03032000 Serial number: 0038FD05DU67
Coding: 0012594
VCID: 392EDF26055B3B1FCEB-806C
Subsystem 1 - Serial number: 6332MSME1136263A3
Subsystem 2 - Serial number: 6342MSME111D006C6
Subsystem 3 - Serial number: 6352QSME0C2B3371G
Subsystem 4 - Serial number: 6362QSME0C23223FH
Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF
Component: Lenksäulenmodul 634 0070
Coding: 0000012
VCID: 76B4141A74C59467E39-8022
Part No: 1K6 920 962 DX
Component: KOMBIINSTRUMENT VDD 4312
Coding: 0007403
Shop #: WSC 61584 001 1048576
VCID: 0A4C50EA103DE087971-805E
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K088090C02
Coding: E9817F060002020003
Shop #: WSC 06435 000 00000
VCID: 3536D3162943DF7F2A3-8060
Component: IMMO VDD 4312
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2374
Coding: 0000692
VCID: 3634D41A3445D467239-8062
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K2 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 3430EE122239C6771DD-8060
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 09C802087F2D8405485FC69010CC
Shop #: WSC 51728 001 104857
VCID: 79AE1F2645DBFB1F8EB-802C
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 1K0 951 177 A
Component: Innenraumueberw.005 0202
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0000692
VCID: 372AD91E334F2D6F38F-8062
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74B02E1262B98677DDD-8020
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 3C8 035 195 HW: 3C8 035 195
Component: Radio RCD510 036 0126
Revision: 00000001 Serial number: VWZ1Z3H3250193
Coding: 0700040004
Shop #: WSC 05314 000 00000
VCID: 65964356D5636FFF5A3-8030
03138 - Input AUX IN
Fault Status: 01101011
Reset counter: 170
Mileage: 183371 km
Time: 21:36:20
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 F
Component: Tuer-SG 021 2438
Coding: 0000144
VCID: 3332ED0E2737C14F047-8066
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 F
Coding: 0000144
End----------(Elapsed Time: 01:02, VBatt start/end: 14.2V/14.1V)-----------
Address 01: Engine (1K0 907 115 J)
21:58:52 Group 009: Service Interval Extension
63.0 mm Oil Level
40.0 mm Oil Warning Threshold
1956 Fuel Consumption Signal
30 Fuel Consumption Equivalent
