Results 1 to 4 of 4
Thread: MK5 golf low oil warning light (yellow)
    Oct 2017
    Not an actual fault I believe? But my car seem to not display this warning light at all even at ignition cycles. I visually check my oil level so no biggie just wondering if it is working as indented, carrying out an Output test on the instruments shows this as working. I'm just curious apologies if this has been covered before
    Wednesday,12,February,2020,21:46:30:10909
    VIN: WVWZZZ1KZ6W179825   License Plate: GTI
    Adaptation Channel 039:
    Stored value 1
    Test value 1
    Oil Level Sensor Adaptation
      Oil
      Reading
      evaluation
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72
    VIN: WVWZZZ1KZ6W179825   Mileage: 183370km-113940miles
       Part No SW: 1K0 907 115 J    HW: 1K0 907 115 F
       Component: 2.0l R4/4V TFSI     0030
       Revision: --H14---    Serial number: VWZ7Z0F3753105
       Coding: 0403000318070060
       Shop #: WSC 00464 210 91410
       VCID: 2D06FB76C11397BF523-8078
       Part No SW: 1K0 907 379 AA    HW: 1K0 907 379 AA
       Revision: 00H13001
       Coding: 0004738
       Shop #: WSC 01279 785 00200
       VCID: 71BE27061DABB35F36B-8024
       Part No: 1K0 907 044 BE
       Component: ClimatronicPQ35 090 0808
       VCID: 6B82356E3F87598F0C7-803E
       Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
       Component: Bordnetz-SG     H37 1002
       Revision: 00H37000    Serial number: 00000005630488
       Coding: E78F8F27001415000014000014000000000B7F075C
       Shop #: WSC 12345 785 00200
       VCID: 2B02F56EFF07998F4C7-807E
       Subsystem 1 - Part No: 1K2 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer VW350  013  0402
       Coding: 00063445
       Shop #: WSC 12345
       Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 011  1110
       Coding: 00469790
       Shop #: WSC 12345
       Part No SW: 1K0 909 605 P    HW: 1K0 909 605 P
       Component: 12 AIRBAG VW8R  032 7900
       Revision: 03032000    Serial number: 0038FD05DU67
       Coding: 0012594
       VCID: 392EDF26055B3B1FCEB-806C
       Subsystem 1 - Serial number: 6332MSME1136263A3
       Subsystem 2 - Serial number: 6342MSME111D006C6
       Subsystem 3 - Serial number: 6352QSME0C2B3371G
       Subsystem 4 - Serial number: 6362QSME0C23223FH
       Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
       Component: Lenksäulenmodul 634 0070
       Coding: 0000012
       VCID: 76B4141A74C59467E39-8022
       Part No: 1K6 920 962 DX
       Component: KOMBIINSTRUMENT VDD 4312
       Coding: 0007403
       Shop #: WSC 61584 001 1048576
       VCID: 0A4C50EA103DE087971-805E
       Component: J533__Gateway   H16 0202
       Revision:   H16       Serial number: 2700K088090C02
       Coding: E9817F060002020003
       Shop #: WSC 06435 000 00000
       VCID: 3536D3162943DF7F2A3-8060
       Component: IMMO            VDD 4312
       Part No: 1K0 959 701 K
       Component: Tuer-SG         024 2374
       Coding: 0000692
       VCID: 3634D41A3445D467239-8062
       Part No: 1K2 909 144 K
       VCID: 3430EE122239C6771DD-8060
    Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 AK
       Coding: 09C802087F2D8405485FC69010CC
       Shop #: WSC 51728 001 104857
       VCID: 79AE1F2645DBFB1F8EB-802C
       Component: Neigungssensor  005 0003
       Subsystem 3 - Part No: 1K0 951 177 A
       Component: Innenraumueberw.005 0202
       Part No: 1K0 959 702 K
       Coding: 0000692
       VCID: 372AD91E334F2D6F38F-8062
       Part No: 1T0 907 357
       Coding: 0000003
       VCID: 74B02E1262B98677DDD-8020
       Part No SW: 3C8 035 195     HW: 3C8 035 195
       Component: Radio RCD510  036 0126
       Revision: 00000001    Serial number: VWZ1Z3H3250193
       Coding: 0700040004
       Shop #: WSC 05314 000 00000
       VCID: 65964356D5636FFF5A3-8030
    03138 - Input AUX IN
                        Reset counter: 170
                        Mileage: 183371 km
                        Time: 21:36:20
       Part No: 1K0 959 703 F
       Component: Tuer-SG         021 2438
       Coding: 0000144
       VCID: 3332ED0E2737C14F047-8066
       Part No: 1K0 959 704 F
       Coding: 0000144
    End----------(Elapsed Time: 01:02, VBatt start/end: 14.2V/14.1V)-----------
                    Address 01: Engine  (1K0 907 115 J)
    21:58:52 Group 009: Service Interval Extension
      63.0 mm  Oil Level
      40.0 mm  Oil Warning Threshold
      1956  Fuel Consumption Signal
      30  Fuel Consumption Equivalent
    Jun 2014
    Not seeing a light when cycle ignition will not say light isn't there or will not work!
    ... warning level 40.0mm, oil level 63.00mm --> NO warning... drain some oil and get below the warning level and check again if it works or not
    Golf VII, 1.6TDI BM Ed. 40 - 110 PK
    Also check the bonnet switch is working.
    Check shared tracks using WD in RTFB yet or grounds?
