Results 1 to 2 of 2
Thread: 2014 Passat TDI; fuel pump doesn't turn on. Code: B103E
    New User
    Jan 2020
    Ontario, CA, USA
    Long story short, I swapped the motor on my 2014 Passat TDI due to a timing failure that caused all of the rockers to break and bent valves.
    I have the new motor in now and ready to go. New filters and fluids are in. Quadruple checked all of the lines and ground and everything seems good.
    I am trying to prime the pump to get all of the air out of the lines and fuel ready to go. It's the last thing now before I can attempt to crank it. I can't seem to get the pumps to turn on. I noticed that my fuel gauge does not move and it shows empty. I know I have at least half a tank of diesel in there. I keep getting the code B103E. I wonder if that has anything to do. Maybe a bad sensor? Thoughts?
    When I did hook the battery up to the charger, the positive and negative wires touched for a second, which blew a fuse. I replaced the fuse. All fuses are good now. Could blowing the fuse blown something with the fuel pump too?
    Any help would greatly be appreciated!
    Tuesday,11,February,2020,15:07:14:01727
    VCDS Version: 19.6.2.0 (x64)
    VIN: 1VWCN7A39EC036871   License Plate:
    Mileage: 202470km-125809mi   Repair Order:
    Chassis Type: A3-VW41 (7N0)
    Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
              52 56 62 72 75 77
    VIN: 1VWCN7A39EC036871   Mileage: 202470km-125809miles
    Address 01: Engine (J623-CKRA)       Labels:. 03L-906-022-CFC.clb
       Part No SW: 03L 997 009 J    HW: 03L 907 309 S
       Component: R4 2.0l TDI   X24 9982
       Revision: 71X24---    Serial number:
       Coding: 001D0012042400008000
       ASAM Dataset: EV_ECM20TDI01103L997009J 004005
       ROD: EV_ECM20TDI01103L997009J.rod
       VCID: 3B5BE0ACB2631F97B2-806E
    Readiness: 0 0 0 X 1
       Part No SW: 02E 300 062 B    HW: 02E 927 770 AT
       Component: GSG DSG AG6     541 9437
       Revision: 06454104    Serial number: 00001711111559
       Coding: 0000024
       Shop #: WSC 01286 386 08256
       VCID: 14096B10377D30EF13-8040
       Revision: 00H31001
       Coding: C54BC0F549258000A31303EB921A0142A71000
       Shop #: WSC 09003 957 00200
       VCID: 7DDF2EB4E4F7D1A7CC-8028
                        Reset counter: 213
                        Mileage: 202475 km
                        Date: 2014.07.04
                        Time: 11:07:46
                        Count: 3
                        Count: 14
                        Count: 20480
                        Count: 16390
                        Count: 41984
                        Count: 261
       Part No SW: 5K0 959 434 B    HW: 5K0 959 434
       Component: VWKESSYPQ35GP 086 1101
       Revision: 00086000    Serial number: 0194028681
       Coding: 130C0C
       VCID: 3449CB909F3DD0EF73-8060
       Part No SW: 561 907 044 AB    HW: 561 907 044 AB
       Component: Climatronic   H03 0505
       Revision: 00001K01
       Coding: 0030019012
       VCID: 57935C1C2E0BDBF7B6-8002
              B10AB F0 [009] - Too Low
                        Reset counter: 213
                        Mileage: 202475 km
                        Date: 2020.02.11
                        Time: 10:42:02
       Part No SW: 5K0 937 087 AE    HW: 5K0 937 087 AE
       Component: BCM PQ35 H+   122 0173
       Revision: BL122001
       Coding: EF200E1B982B08D4098802003600818800F1A086458015B064806000BC70
       VCID: 78D13FA0CBD5F48F9F-802C
    10 Faults Found:
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 213
                        Mileage: 202475 km
                        Date: 2014.07.04
                        Time: 11:11:23
                            Term 15 On
                        Voltage: 11.60 V
                        Reset counter: 213
                        Mileage: 202475 km
                        Date: 2014.07.04
                        Time: 11:11:23
                            Term 15 On
                        Voltage: 11.60 V
                        Reset counter: 213
                        Mileage: 202475 km
                        Date: 2014.07.04
                        Time: 11:11:23
                            Term 15 On
                        Voltage: 11.60 V
                        Reset counter: 213
                        Mileage: 202475 km
                        Date: 2014.07.04
                        Time: 11:11:23
                            Term 15 On
                        Voltage: 11.60 V
                        Reset counter: 213
                        Mileage: 202475 km
                        Date: 2014.07.04
                        Time: 11:11:23
                            Term 15 On
                        Voltage: 11.60 V
                        Reset counter: 213
                        Mileage: 202475 km
                        Date: 2014.07.04
                        Time: 11:11:23
                            Term 15 On
                        Voltage: 11.60 V
                        Reset counter: 213
                        Mileage: 202475 km
                        Date: 2014.07.04
                        Time: 11:11:23
                            Term 15 On
                        Voltage: 11.60 V
                        Reset counter: 213
                        Mileage: 202475 km
                        Date: 2014.07.04
                        Time: 11:11:23
                            Term 15 On
                        Voltage: 11.60 V
    03188 - Bulb for Side Marker Light; Front Left
                        Reset counter: 213
                        Mileage: 202475 km
                        Date: 2014.07.04
                        Time: 11:11:24
                            Term 15 On
                        Voltage: 11.60 V
    03189 - Bulb for Side Marker Light; Front Right
                        Reset counter: 213
                        Mileage: 202475 km
                        Date: 2014.07.04
                        Time: 11:11:24
                            Term 15 On
                        Voltage: 11.60 V
       Part No SW: 5C0 959 655 AE    HW: 5C0 959 655 AE
       Component: AirbagVW10G   014 0851
       Serial number: 003MWM02X4B0
       Coding: 00005033
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 75CF3694D4C789E784-8020
       Serial number: 6940000Y130000Y1PN0B
       Coding: 303047
       Serial number: 3572MSME012F157DZZZ.
       Serial number: 3582MSME4876217DZZZ%
       Serial number: 3516KSME72374027ZZZL
       Serial number: 3526KSME72084A27ZZZU
    9443861 - Driver's Front Airbag Crash Sensor
              B101A 15 [137] - Open or Short to Plus
                        Mileage: 202475 km
                        Date: 2020.02.11
                        Time: 11:08:23
    9444117 - Front Passenger's Front Airbag Crash Sensor
              B101B 15 [137] - Open or Short to Plus
                        Mileage: 202475 km
                        Date: 2020.02.11
                        Time: 11:08:23
       Part No SW: 1K5 953 521 AR    HW: 5K0 953 569 E
       Revision: FF010042    Serial number: 20130724101549
       Coding: 000A140000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 7DDF2EB4ECF7D1A7CC-8028
       Subsystem 1 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS  H31 0037
       Coding: 820000
    Address 17: Instruments (J285)       Labels:| 5K0-920-XXX-17.clb-SRI1
       Part No SW: 561 920 970 G    HW: 561 920 970 G
       Component: KOMBI         H04 0811
       Coding: 231E01
       VCID: 1E1D093801B16ABFB5-804A
    9453074 - Fuel Level Sensor 1
              B103E 1B [009] - Resistance Too High
                        Reset counter: 213
                        Mileage: 202475 km
                        Date: 2020.02.11
                        Time: 11:08:52
       Part No SW: 7N0 907 530 AM    HW: 7N0 907 530 AM
       Component: J533  Gateway H55 1642
       Revision:   H55       Serial number: 22091303001059
       Coding: 461000
       VCID: 7BDB20ACFAE3DF97F2-802E
       Component: IMMO          H04 0811
       Coding: 000007
       VCID: 6AF515E88D79561F19-803E
       Revision: 00000000    Serial number: 13000153738004
       Coding: 4900000000000000
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 3041C7806B25ECCF17-8064
    Address 2E: Media Player 3
       Part No SW: 561 959 760 B    HW: 561 959 760 B
       Component: MEM-FS        H04 0182
       Revision: AA000000    Serial number: 00000073459042
       VCID: 22653DC83DC94E5F91-8076
       Part No SW: 3C0 035 684 K    HW: 3C0 035 684 K
       Component: RNS-MID       H30 5382
       Revision: AB001001    Serial number: VWZ6Z7U9215004
       Coding: 04090042010000A6000B
       Shop #: WSC 12835 002 1048576
       VCID: 2B7BD0EC4A038F1722-807E
       Component: NAR V6  7963
       Part No SW: 561 959 701 A    HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0525
       Revision: 12110009    Serial number: 0007297260
       Coding: 0405FD
       ROD: EV_TSGFPQ25BRFVW46X.rod
       VCID: 1C19033017AD78AF5B-8048
       Slave Driver:
       Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG_HL  006 5470
       Serial number: 14102630130924083353
       Coding: 800000
              B11EE 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 213
                        Mileage: 202475 km
                        Date: 2020.02.11
                        Time: 11:09:50
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 290    3501
       Revision: 00H22000
       VCID: 3957FAA4705F2D87A0-806C
                000 - - - MIL ON
                        Fault Status: 11100000
                        Mileage: 202475 km
                        Date: 2014.07.04
                        Time: 11:10:07
                        Battery Volts: 11.7 V
                            DD
                        Temperature: 30.0∞C
                        Count: 2
                        Steering Angle: 0.00∞
                            SteerAng n.Init
       Part No SW: 5C6 035 456 A    HW: 5C6 035 456 A
       Component: KonzernAmp10K H07 6813
       Revision: --------    Serial number: EAA098A0068803
       VCID: 266D21D859E1B27FFD-8072
       Part No SW: 7N0 907 532     HW: 7N0 907 530 AM
       Component: EZE_2         H55 1642
       Coding: 01030108
       VCID: 6FC304FCBE9BB3374E-803A
       Subsystem 1 - Part No SW: 561 959 591     HW: 561 959 591
       Component: J245 P05 FFD7  H07 0004
       Serial number: 53388786011310301199
       Coding: 181100
       Subsystem 2 - Part No SW: 561 919 204 B    HW: 561 919 204 B
       Component: Analoguhr  008 0005
       Part No SW: 561 959 702 A    HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0525
       Revision: 14110009    Serial number: 0007326046
       Coding: 0405FC
       ROD: EV_TSGBPQ25BRFVW46X.rod
       VCID: 1D1F0E340CB771A7AC-8048
       Slave Passenger:
       Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG_HR  006 5470
       Serial number: 14202631130923211956
       Coding: 800000
                        Reset counter: 213
                        Mileage: 202475 km
                        Date: 2020.02.11
                        Time: 11:10:22
       Component: OCULowUSA     014 0086
       Serial number: 000003554140506
       Coding: 02140102C2423A007F1606000000
       ROD: EV_OCULow_001.rod
       VCID: 538BA80C3AF3F7D74A-8006
    2103041 - Control Module
                        Fault Priority: 8
                        Reset counter: 213
                        Mileage: 202475 km
                        Date: 2020.02.11
                        Time: 11:11:07
       Revision: 1B001001    Serial number: 00007665083935
       Coding: 0A10030080010110
       ROD: EV_UHVUMI.rod
       VCID: 2E7DD9F87111FA3F05-807A
    End-------------------------(Elapsed Time: 02:45)--------------------------
    Fyi, the car is currently on jack stands with the front wheels off and the front bumper off as well, which is why the other codes come up.
    New User
    Jan 2020
    Ontario, CA, USA
    Update:
    I put the new level sensor on it but kept the lift pump outside the tank because I didn’t want to get the new sensor dirty in the event it didn’t work and I could just return it. I plugged the connector on it to see if I could get it to start and clear the code. Still nothing.
    So I decided to put the old sensor back on, put the lift pump back into the tank and plug it back in. I manually, with the 12v battery, turned the pump on for a few minutes to get fuel flowing.
    At this point I figured I’d try to crank it.
    Immediately when trying to crank it, the fuel gauge switched on and the lift pump turned on its own the second I pushed the on button.
    I could now activate the pump through VCDS.
    Weird that it wouldn’t before trying to crank it.
    I cleared the code and it went away!
    I then bled the injectors and the car started right away!
    All is good now.
    I still find it weird that I couldn’t turn the pump on before but oh well, it works now!
  3. Likes NZDubNurd, PetrolDave, Uwe, Jetta ,97 liked this post
