joshferrer
New Member
- Jan 5, 2020
- 2
- 4
- Ontario, CA, USA
- hcnb00a-00b7e8-a306bf-9c0a09-unjahh-5f7b
Long story short, I swapped the motor on my 2014 Passat TDI due to a timing failure that caused all of the rockers to break and bent valves.
I have the new motor in now and ready to go. New filters and fluids are in. Quadruple checked all of the lines and ground and everything seems good.
I am trying to prime the pump to get all of the air out of the lines and fuel ready to go. It's the last thing now before I can attempt to crank it. I can't seem to get the pumps to turn on. I noticed that my fuel gauge does not move and it shows empty. I know I have at least half a tank of diesel in there. I keep getting the code B103E. I wonder if that has anything to do. Maybe a bad sensor? Thoughts?
When I did hook the battery up to the charger, the positive and negative wires touched for a second, which blew a fuse. I replaced the fuse. All fuses are good now. Could blowing the fuse blown something with the fuel pump too?
Any help would greatly be appreciated!
Fyi, the car is currently on jack stands with the front wheels off and the front bumper off as well, which is why the other codes come up.
Tuesday,11,February,2020,15:07:14:01727
VCDS Version: 19.6.2.0 (x64)
VIN: 1VWCN7A39EC036871 License Plate:
Mileage: 202470km-125809mi Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
52 56 62 72 75 77
VIN: 1VWCN7A39EC036871 Mileage: 202470km-125809miles
Address 01: Engine (J623-CKRA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 997 009 J HW: 03L 907 309 S
Component: R4 2.0l TDI X24 9982
Revision: 71X24--- Serial number:
Coding: 001D0012042400008000
ASAM Dataset: EV_ECM20TDI01103L997009J 004005
ROD: EV_ECM20TDI01103L997009J.rod
VCID: 3B5BE0ACB2631F97B2-806E
Readiness: 0 0 0 X 1
Part No SW: 02E 300 062 B HW: 02E 927 770 AT
Component: GSG DSG AG6 541 9437
Revision: 06454104 Serial number: 00001711111559
Coding: 0000024
Shop #: WSC 01286 386 08256
VCID: 14096B10377D30EF13-8040
Revision: 00H31001
Coding: C54BC0F549258000A31303EB921A0142A71000
Shop #: WSC 09003 957 00200
VCID: 7DDF2EB4E4F7D1A7CC-8028
Reset counter: 213
Mileage: 202475 km
Date: 2014.07.04
Time: 11:07:46
Count: 3
Count: 14
Count: 20480
Count: 16390
Count: 41984
Count: 261
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Component: VWKESSYPQ35GP 086 1101
Revision: 00086000 Serial number: 0194028681
Coding: 130C0C
VCID: 3449CB909F3DD0EF73-8060
Part No SW: 561 907 044 AB HW: 561 907 044 AB
Component: Climatronic H03 0505
Revision: 00001K01
Coding: 0030019012
VCID: 57935C1C2E0BDBF7B6-8002
B10AB F0 [009] - Too Low
Reset counter: 213
Mileage: 202475 km
Date: 2020.02.11
Time: 10:42:02
Part No SW: 5K0 937 087 AE HW: 5K0 937 087 AE
Component: BCM PQ35 H+ 122 0173
Revision: BL122001
Coding: EF200E1B982B08D4098802003600818800F1A086458015B064806000BC70
VCID: 78D13FA0CBD5F48F9F-802C
10 Faults Found:
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 213
Mileage: 202475 km
Date: 2014.07.04
Time: 11:11:23
Term 15 On
Voltage: 11.60 V
Reset counter: 213
Mileage: 202475 km
Date: 2014.07.04
Time: 11:11:23
Term 15 On
Voltage: 11.60 V
Reset counter: 213
Mileage: 202475 km
Date: 2014.07.04
Time: 11:11:23
Term 15 On
Voltage: 11.60 V
Reset counter: 213
Mileage: 202475 km
Date: 2014.07.04
Time: 11:11:23
Term 15 On
Voltage: 11.60 V
Reset counter: 213
Mileage: 202475 km
Date: 2014.07.04
Time: 11:11:23
Term 15 On
Voltage: 11.60 V
Reset counter: 213
Mileage: 202475 km
Date: 2014.07.04
Time: 11:11:23
Term 15 On
Voltage: 11.60 V
Reset counter: 213
Mileage: 202475 km
Date: 2014.07.04
Time: 11:11:23
Term 15 On
Voltage: 11.60 V
Reset counter: 213
Mileage: 202475 km
Date: 2014.07.04
Time: 11:11:23
Term 15 On
Voltage: 11.60 V
03188 - Bulb for Side Marker Light; Front Left
Reset counter: 213
Mileage: 202475 km
Date: 2014.07.04
Time: 11:11:24
Term 15 On
Voltage: 11.60 V
03189 - Bulb for Side Marker Light; Front Right
Reset counter: 213
Mileage: 202475 km
Date: 2014.07.04
Time: 11:11:24
Term 15 On
Voltage: 11.60 V
Part No SW: 5C0 959 655 AE HW: 5C0 959 655 AE
Component: AirbagVW10G 014 0851
Serial number: 003MWM02X4B0
Coding: 00005033
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 75CF3694D4C789E784-8020
Serial number: 6940000Y130000Y1PN0B
Coding: 303047
Serial number: 3572MSME012F157DZZZ.
Serial number: 3582MSME4876217DZZZ%
Serial number: 3516KSME72374027ZZZL
Serial number: 3526KSME72084A27ZZZU
9443861 - Driver's Front Airbag Crash Sensor
B101A 15 [137] - Open or Short to Plus
Mileage: 202475 km
Date: 2020.02.11
Time: 11:08:23
9444117 - Front Passenger's Front Airbag Crash Sensor
B101B 15 [137] - Open or Short to Plus
Mileage: 202475 km
Date: 2020.02.11
Time: 11:08:23
Part No SW: 1K5 953 521 AR HW: 5K0 953 569 E
Revision: FF010042 Serial number: 20130724101549
Coding: 000A140000
ROD: EV_SMLSNGVOLWS.rod
VCID: 7DDF2EB4ECF7D1A7CC-8028
Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0037
Coding: 820000
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 970 G HW: 561 920 970 G
Component: KOMBI H04 0811
Coding: 231E01
VCID: 1E1D093801B16ABFB5-804A
9453074 - Fuel Level Sensor 1
B103E 1B [009] - Resistance Too High
Reset counter: 213
Mileage: 202475 km
Date: 2020.02.11
Time: 11:08:52
Part No SW: 7N0 907 530 AM HW: 7N0 907 530 AM
Component: J533 Gateway H55 1642
Revision: H55 Serial number: 22091303001059
Coding: 461000
VCID: 7BDB20ACFAE3DF97F2-802E
Component: IMMO H04 0811
Coding: 000007
VCID: 6AF515E88D79561F19-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 13000153738004
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X.rod
VCID: 3041C7806B25ECCF17-8064
Address 2E: Media Player 3
Part No SW: 561 959 760 B HW: 561 959 760 B
Component: MEM-FS H04 0182
Revision: AA000000 Serial number: 00000073459042
VCID: 22653DC83DC94E5F91-8076
Part No SW: 3C0 035 684 K HW: 3C0 035 684 K
Component: RNS-MID H30 5382
Revision: AB001001 Serial number: VWZ6Z7U9215004
Coding: 04090042010000A6000B
Shop #: WSC 12835 002 1048576
VCID: 2B7BD0EC4A038F1722-807E
Component: NAR V6 7963
Part No SW: 561 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0525
Revision: 12110009 Serial number: 0007297260
Coding: 0405FD
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 1C19033017AD78AF5B-8048
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 B HW: 561 959 811 B Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 006 5470
Serial number: 14102630130924083353
Coding: 800000
B11EE 54 [009] - Missing Calibration / Basic Setting
Reset counter: 213
Mileage: 202475 km
Date: 2020.02.11
Time: 11:09:50
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 290 3501
Revision: 00H22000
VCID: 3957FAA4705F2D87A0-806C
000 - - - MIL ON
Fault Status: 11100000
Mileage: 202475 km
Date: 2014.07.04
Time: 11:10:07
Battery Volts: 11.7 V
DD
Temperature: 30.0∞C
Count: 2
Steering Angle: 0.00∞
SteerAng n.Init
Part No SW: 5C6 035 456 A HW: 5C6 035 456 A
Component: KonzernAmp10K H07 6813
Revision: -------- Serial number: EAA098A0068803
VCID: 266D21D859E1B27FFD-8072
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1642
Coding: 01030108
VCID: 6FC304FCBE9BB3374E-803A
Subsystem 1 - Part No SW: 561 959 591 HW: 561 959 591
Component: J245 P05 FFD7 H07 0004
Serial number: 53388786011310301199
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 008 0005
Part No SW: 561 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0525
Revision: 14110009 Serial number: 0007326046
Coding: 0405FC
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 1D1F0E340CB771A7AC-8048
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 B HW: 561 959 812 B Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 006 5470
Serial number: 14202631130923211956
Coding: 800000
Reset counter: 213
Mileage: 202475 km
Date: 2020.02.11
Time: 11:10:22
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 HW: 561 035 285
Component: OCULowUSA 014 0086
Serial number: 000003554140506
Coding: 02140102C2423A007F1606000000
ROD: EV_OCULow_001.rod
VCID: 538BA80C3AF3F7D74A-8006
2103041 - Control Module
Fault Priority: 8
Reset counter: 213
Mileage: 202475 km
Date: 2020.02.11
Time: 11:11:07
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 A HW: 5N0 035 729 A
Component: TELEFON H05 0315
Revision: 1B001001 Serial number: 00007665083935
Coding: 0A10030080010110
ROD: EV_UHVUMI.rod
VCID: 2E7DD9F87111FA3F05-807A
End-------------------------(Elapsed Time: 02:45)--------------------------
