Results 1 to 7 of 7
Thread: Golf gte high voltage battery
    Apr 2017
    Hi all,
    quick one, i got a golf GTE HV battery off the car which i am testing on the bench. i have connected to address 8C and can view error code but it wont let me clear them. do you need a security code or something to do this ?
    Quote Originally Posted by golfdubcrazy View Post
    No, clearing fault codes should not require a security access.
    What fault codes does it have? Hint: There is a [Copy Codes] button on the Fault Codes screen.
    Apr 2017
    Sorry Uwe attached
    Wednesday,12,February,2020,18:14:10:02338
    VIN:    License Plate: HYBRID BATT
                    Address 8C: Hybrid Battery       Labels: None
    Control Module Part Number: 5Q0 915 182 D    HW: 5Q0 915 182 C
      Component and/or Version: BECM          H05 0921
               Software Coding: 00000000
                Work Shop Code: WSC 00000 000 00000
                  ASAM Dataset: EV_BECM09620115Q0915182 006041 (VW37)
                           ROD: EV_BECM09620115Q0915182.rod
                          VCID: 342411779F324DEF73-8060
    23 Faults Found:
    26601 - No Communications with Battery Charger Control Module
              U019B 00 [039] - -
              [Diag_C_HCAN_HVLM_03_TO]
                        Mileage: 31450 km
                        Date: 2019.05.10
                        Time: 00:00:30
                        Pack Voltage: 346.0 V
                        Pack Current: 0.10 A
                        Isolation Resistance: 5080 kOhm
                        Maxumum charge current limit: 0 A
                        Maximum discharge current limit: 0.0 A
                        Contactor Voltage: 0 V
                        OBD unlearned counter: 40
                        Crash status: 00
                        Pilot Line Status: 01
                        Fuse Status: 00
                        (Minus) Contactor Status: 00
                        (Plus) Contactor Status: 00
                        Terminal 15 status: 01
                        Max Cell Temperature: 17 C
                        Min Cell Temperature: 16 C
                        Air inlet temperature: 18 C
                        Air outlet temperature: 18 C
                        LV Battery Voltage: 10.7 V
                        Min.cell voltage: 3.601 V
                        Max.cell Voltage: 3.606 V
                        Max.cell SOC: 31 %
                        Min.cell SOC: 30 %
                        Hybrid Battery Pack Remaining Life: 31.0 %
                        Max Charge Pack Current(10s duration): 0 A
                        Max Discharge Pack Current(10s duration): 0.0 A
                        Max Pack Voltage(10s duration): 346 V
                        Min Pack Voltage(10s duration): 344 V
                        Max.cell Voltage(10s duration): 3.607 V
                        Min.cell Voltage(10s duration): 3.600 V
                        Accelerator Pedal Position D: 100.0 %
                        Calculated LOAD Value: 100.0 %
                        Engine coolant temperature: 215 C
                        Engine RPM: 16383.75 /min
                        Vehicle Speed Sensor: 255 km/h
                        Ambient Air Temperature: 215 C
                        Hybrid Battery Pack Remaining Life: 30.98 %
                        control module system voltage: 10.798 V
                        absolute load: 25700.0 %
                        Time After Engine Start: 0 s
    26580 - No Communication with Engine Control Module (SAE ECM/PCM)
              U0100 00 [039] - -
              [Diag_C_ACAN_Motor_14_TO]
                        Mileage: 31450 km
                        Date: 2019.05.10
                        Time: 00:00:26
                        Pack Current: -0.00 A
                        Crash status: 00
                        Fuse Status: 00
                        LV Battery Voltage: 10.9 V
                        Max.cell SOC: 31 %
                        Min.cell SOC: 30 %
                        control module system voltage: 10.960 V
    26584 - No Communication with Engine Control Module (SAE ECM/PCM)
              U0100 00 [039] - -
              [Diag_C_ACAN_Motor_EV_01_TO]
                        Mileage: 31450 km
                        Date: 2019.05.10
                        Time: 00:00:26
                        Crash status: 00
                        Fuse Status: 00
                        Max.cell SOC: 31 %
                        Min.cell SOC: 30 %
    29705 - No Communication with Engine Control Module (SAE ECM/PCM)
              U0100 00 [039] - -
              [Diag_C_ACAN_TMM_02_TO]
                        Mileage: 31450 km
                        Date: 2019.05.10
                        Time: 00:00:30
                        Crash status: 00
                        Fuse Status: 00
                        Max.cell SOC: 31 %
                        Min.cell SOC: 30 %
    26599 - No Communications with Battery Charger Control Module
              U019B 00 [039] - -
              [Diag_C_HCAN_HVLM_01_TO]
                        Mileage: 31450 km
                        Date: 2019.05.10
                        Time: 00:00:26
                        Crash status: 00
                        Fuse Status: 00
                        Max.cell SOC: 31 %
                        Min.cell SOC: 30 %
    26604 - No Communications with Battery Charger Control Module
              U019B 00 [039] - -
              [Diag_C_HCAN_LAD_01_TO]
                        Mileage: 31450 km
                        Date: 2019.05.10
                        Time: 00:00:30
                        Crash status: 00
                        Fuse Status: 00
                        Max.cell SOC: 31 %
                        Min.cell SOC: 30 %
    26552 - No Communication with ESP (Vehicle Dynamics) Control Module
              U0122 00 [039] - -
              [Diag_C_ACAN_ESP_21_TO]
                        Mileage: 31450 km
                        Date: 2019.05.10
                        Time: 00:00:25
                        Pack Voltage: 345.9 V
                        Crash status: 00
                        Fuse Status: 00
                        LV Battery Voltage: 11.0 V
                        Max.cell SOC: 31 %
                        Min.cell SOC: 30 %
                        control module system voltage: 11.001 V
    26586 - No Communication with Engine Control Module (SAE ECM/PCM)
              U0100 00 [039] - -
              [Diag_C_ACAN_OBD_01_TO]
                        Mileage: 31450 km
                        Date: 2019.05.10
                        Time: 00:00:26
                        Crash status: 00
                        Fuse Status: 00
                        Max.cell SOC: 31 %
                        Min.cell SOC: 30 %
    26578 - No Communication with Engine Control Module (SAE ECM/PCM)
              U0100 00 [039] - -
              [Diag_C_ACAN_Motor_12_TO]
                        Mileage: 31450 km
                        Date: 2019.05.10
                        Time: 00:00:25
                        Crash status: 00
                        Fuse Status: 00
                        Max.cell SOC: 31 %
                        Min.cell SOC: 30 %
    26582 - No Communication with Engine Control Module (SAE ECM/PCM)
              U0100 00 [039] - -
              [Diag_C_ACAN_Motor_Code_01_TO]
                        Mileage: 31450 km
                        Date: 2019.05.10
                        Time: 00:00:30
                        Crash status: 00
                        Fuse Status: 00
                        Max.cell SOC: 31 %
                        Min.cell SOC: 30 %
    26642 - High Voltage Service Disconnect
              P0B37 00 [038] - Open Circuit
                        Mileage: 31450 km
                        Date: 2019.05.10
                        Time: 00:00:00
                        Isolation Resistance: 5100 kOhm
                        Maxumum charge current limit: 255 A
                        Maximum discharge current limit: 382.5 A
                        Contactor Voltage: 118 V
                        Crash status: 00
                        Fuse Status: 00
                        Terminal 15 status: 00
                        Max Cell Temperature: 155 C
                        Min Cell Temperature: 155 C
                        LV Battery Voltage: 11.2 V
                        Max.cell Voltage: 3.607 V
                        Max.cell SOC: 31 %
                        Min.cell SOC: 30 %
                        Max Charge Pack Current(10s duration): 255 A
                        Max Discharge Pack Current(10s duration): 382.5 A
                        Max Pack Voltage(10s duration): 510 V
                        Min Pack Voltage(10s duration): 510 V
                        Max.cell Voltage(10s duration): 65.535 V
                        Min.cell Voltage(10s duration): 65.535 V
                        control module system voltage: 11.286 V
    26590 - No Communication with Engine Control Module (SAE ECM/PCM)
              U0100 00 [039] - -
              [Diag_C_ACAN_TMM_01_TO]
                        Mileage: 31450 km
                        Date: 2019.05.10
                        Time: 00:00:30
                        Crash status: 00
                        Fuse Status: 00
                        Max.cell SOC: 31 %
                        Min.cell SOC: 30 %
    26622 - HV Selft-Test Incomplete after minor crash
              P329B 00 [100] - -
    26721 - Proximity Sensing
              P0D59 00 [239] - Short to Plus
                        Mileage: 31450 km
                        Date: 2019.04.18
                        Time: 00:30:30
                        Pack Voltage: 346.8 V
                        Maxumum charge current limit: 126 A
                        Maximum discharge current limit: 261.0 A
                        Crash status: 00
                        Pilot Line Status: 00
                        Fuse Status: 00
                        Max Cell Temperature: 18 C
                        Min Cell Temperature: 17 C
                        LV Battery Voltage: 11.8 V
                        Min.cell voltage: 3.610 V
                        Max.cell Voltage: 3.617 V
                        Max.cell SOC: 34 %
                        Min.cell SOC: 32 %
                        Hybrid Battery Pack Remaining Life: 32.5 %
                        Min Pack Voltage(10s duration): 346 V
                        Max.cell Voltage(10s duration): 3.618 V
                        Min.cell Voltage(10s duration): 3.610 V
                        Accelerator Pedal Position D: 15.3 %
                        Calculated LOAD Value: 0.0 %
                        Engine coolant temperature: 19 C
                        Engine RPM: 0.00 /min
                        Vehicle Speed Sensor: 0 km/h
                        Hybrid Battery Pack Remaining Life: 32.55 %
                        control module system voltage: 11.815 V
                        absolute load: 0.0 %
    27140 - Temperature Sensor for Battery Charger Coupling
              P0D9B 00 [039] - Short to GND
                        Mileage: 31450 km
                        Date: 2019.04.18
                        Time: 00:30:30
                        Crash status: 00
                        Fuse Status: 00
                        Max.cell SOC: 34 %
                        Min.cell SOC: 32 %
    27146 - Position Sensor for Battery Charger Coupling Lock
              P0DA1 00 [102] - Short to Plus
    27148 - Position Sensor for Battery Charger Coupling Lock
              P0D9F 00 [039] - Implausible Signal
                        Mileage: 31450 km
                        Date: 2019.04.18
                        Time: 00:30:30
                        Crash status: 00
                        Fuse Status: 00
                        Max.cell SOC: 34 %
                        Min.cell SOC: 32 %
    26606 - No Communications with Battery Charger Control Module
              U019B 00 [039] - -
              [Diag_C_HCAN_LAD_CALID_CVN_TO]
                        Mileage: 31450 km
                        Date: 2019.05.10
                        Time: 00:00:30
                        Crash status: 00
                        Fuse Status: 00
                        Max.cell SOC: 31 %
                        Min.cell SOC: 30 %
    26694 - No Communications with Battery Charger Control Module
              U019B 00 [039] - -
              [Diag_C_HCAN_LAD_Komponentenfehler_01_TO]
                        Mileage: 31450 km
                        Date: 2019.05.10
                        Time: 00:00:30
                        Crash status: 00
                        Fuse Status: 00
                        Max.cell SOC: 31 %
                        Min.cell SOC: 30 %
    26696 - No Communications with Battery Charger Control Module
              U019B 00 [039] - -
              [Diag_C_HCAN_LAD_Komponentenfehler_02_TO]
                        Pack Voltage: 6553.5 V
                        Pack Current: 455.35 A
                        Contactor Voltage: 510 V
                        Crash status: 01
                        Fuse Status: 01
                        (Minus) Contactor Status: 01
                        (Plus) Contactor Status: 01
                        Max.cell SOC: 31 %
                        Min.cell SOC: 30 %
                        absolute load: 25667.1 %
                        Time After Engine Start: 256 s
    26608 - No Communication with Engine Control Module (SAE ECM/PCM)
              U0100 00 [039] - -
              [Diag_C_ACAN_Motor_31_TO]
    26635 - High Voltage System Interlock
              P0A0A 00 [038] - Open Circuit
                        Crash status: 00
                        Fuse Status: 00
                        LV Battery Voltage: 11.3 V
                        Max.cell SOC: 31 %
                        Min.cell SOC: 30 %
                        control module system voltage: 11.327 V
    26835 - High Voltage System Interlock Circuit
              P0A0B 00 [167] - Implausible Signal
                        Pack Voltage: 344.7 V
                        Pack Current: -0.10 A
                        Contactor Voltage: 248 V
                        Crash status: 00
                        Fuse Status: 00
                        Max Cell Temperature: 6 C
                        Min Cell Temperature: 6 C
                        Air inlet temperature: 7 C
                        Air outlet temperature: 7 C
                        LV Battery Voltage: 13.2 V
                        Min.cell voltage: 3.592 V
                        Max.cell Voltage: 3.599 V
                        Max.cell SOC: 29 %
                        Min.cell SOC: 28 %
                        control module system voltage: 13.239 V
    I think every one of those fault codes is one that I would expect to come back (i.e. a fault condition that still exists) with the battery sitting by itself, outside the car.
  5. Likes MartinsX liked this post
    Apr 2017
    i connected up the hv interlock so it was removed thus intermittent error. when i hit clear code. vcds reply with control refused to clear codes.
    Tartu, Estonia
    You most likely need to clear them using OBD2 mode.
    I am a VW Freak - Le WV Freaks OR Come visit me at my work with ODIS concerns - FORSS ODIS GeKo/FaZit access for VW/AUDI/koda
    The world is my oyster...
  8. Likes Uwe liked this post
    Apr 2017
    Big Thanks golfi_vend. I tried that and it worked awesome managed to remove 95% of the error codes. find it abit odd having to go thru OBD2 mode to clear it.
