Results 1 to 10 of 10
Thread: 09 A4 2.0t Adaptations that need to be reset after chain failure/replacement?
    Feb 2020
    Is there any adaptations that should be reset after a chain failure and replacement? Car is missing at idle but runs smooth above 1100 rpms.
    HQ
    Jef
  3. Likes Jack@European_Parts, Uwe, dieseldub liked this post
    Feb 2020
    See next post
    Feb 2020
    Will need to get another I cant figure out how to copy it from my other thread.
    Feb 2020
    Thursday,06,February,2020,10:03:31:60802 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4508.4 Data version: 20190930 DS308.0 www.Ross-Tech.com VIN: WAULF78K59N068768 License Plate: Chassis Type: 8K-AU48 (8T0) Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 56 62 65 72 77 VIN: WAULF78K59N068768 Mileage: 206820km-128511miles 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: Malfunction 0010 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 2E-Media Player 3 -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: Malfunction 0010 53-Parking Brake -- Status: Malfunction 0010 56-Radio -- Status: Malfunction 0010 62-Door, Rear Left -- Status: Malfunction 0010 65-Tire Pressure -- Status: Malfunction 0010 72-Door, Rear Right -- Status: Malfunction 0010 77-Telephone -- Status: Malfunction 0010 ------------------------------------------------------------------------------- Address 01: Engine (DL0MA-CAEB) Labels:| 06H-907-115-CAB.clb Part No SW: 8K2 907 115 AL HW: 8K2 907 115 D Component: 2.0l R4/4V TF H14 0001 Revision: E1H14--- Coding: 0104010A190F0160 Shop #: WSC 09396 002 1048576 ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001 ROD: EV_ECM20TFS0118K2907115AL.rod VCID: 79BACD3FF834D087E0-802C 4 Faults Found: 7225 - Cam Adjustment Actuator A; Cylinder 4 P11AD 00 [109] - Elec. Malf. or Open Circuit Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 206827 km Date: 2020.02.05 Time: 09:15:11 Engine speed: 178.00 /min Normed load value: 42.4 % Vehicle speed: 0 km/h Coolant temperature: 5 °C Intake air temperature: 3 °C Ambient air pressure: 950 mbar Voltage terminal 30: 11.049 V Unlearning counter according OBD: 40 4060 - Cylinder 3 P0303 00 [101] - Misfire Detected Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 206827 km Date: 2020.02.05 Time: 09:39:24 Engine speed: 754.50 /min Normed load value: 12.9 % Vehicle speed: 0 km/h Coolant temperature: 75 °C Intake air temperature: 10 °C Ambient air pressure: 950 mbar Voltage terminal 30: 13.782 V Unlearning counter according OBD: 80 4057 - Cylinder 2 P0302 00 [101] - Misfire Detected Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 206827 km Date: 2020.02.05 Time: 09:39:24 Engine speed: 754.50 /min Normed load value: 12.9 % Vehicle speed: 0 km/h Coolant temperature: 75 °C Intake air temperature: 10 °C Ambient air pressure: 950 mbar Voltage terminal 30: 13.782 V Unlearning counter according OBD: 80 4051 - Random/Multiple Cylinder Misfire Detected P0300 00 [101] - - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 206827 km Date: 2020.02.05 Time: 09:38:18 Engine speed: 747.00 /min Normed load value: 12.5 % Vehicle speed: 0 km/h Coolant temperature: 75 °C Intake air temperature: 9 °C Ambient air pressure: 950 mbar Voltage terminal 30: 13.735 V Unlearning counter according OBD: 80 Readiness: 1110 0101 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels:| 0B6-927-156.clb Part No SW: 8K0 927 158 C HW: 0B6 927 156 Component: 0B6 20TFSIUSA H04 0050 Revision: --H04--- Coding: 001002 Shop #: WSC 02145 785 00200 ASAM Dataset: EV_TCMAL651 A01004 ROD: EV_TCMAL651.rod VCID: 3620060389AAFFFF4D-8062 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb Part No SW: 8K0 907 379 AF HW: 8K0 907 379 AF Component: ESP8 quattro H04 0210 Revision: -------- Serial number: -------------- Coding: 150500 Shop #: WSC 02391 823 56573 VCID: 7DB2D92FE41CECA7CC-8028 2 Faults Found: 00473 - Control Module for Elect. Park/Hand Brake (J540) 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 9 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:28:34 Freeze Frame: Hex Value: 0x00C0 Hex Value: 0x0082 Hex Value: 0x002E Hex Value: 0x0286 Hex Value: 0x00FF 01314 - Engine Control Module 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 47 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 18:45:13 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x4082 Hex Value: 0x0025 Hex Value: 0x46AA Hex Value: 0x00FF ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb Part No SW: 8K0 907 064 F HW: 8K0 907 064 F Component: BCM2 1.1 H80 0145 Revision: 00002001 Coding: 090100 Shop #: WSC 02399 823 56573 VCID: 33263F1792D8EAD76A-8066 Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A Component: FBSAUDIB8 IDG H37 0060 Serial number: 0509000010202006 Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: ELVAUDIB8 H36 0041 Serial number: 0209000012848015 3 Faults Found: 00956 - Key 2 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 46 Mileage: 206827 km Time Indication: 0 Date: 2019.12.27 Time: 09:41:23 00447 - Function Limitation due to Over-Voltage 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 9 Reset counter: 47 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:32:21 01330 - Central Control Module for Central Convenience (J393) 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 46 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:32:51 ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: Redir Fail! Part No SW: 8T1 820 043 AA HW: 8T1 820 043 AA Component: KLIMA 1 ZONE H06 0150 Revision: A1000000 Serial number: 01130320090031 Coding: 64002000 Shop #: WSC02391 823 56573 VCID: 70ACF01BA34E91CF57-8024 3 Faults Found: 00457 - Central Electronics Control Module / BCM (J519) 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 6 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:28:32 00256 - A/C Pressure/Temperature Sensor (G395) 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 6 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:28:49 Freeze Frame: Temperature: 6.0°C 00447 - Function Limitation due to Over-Voltage 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 46 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:37:14 ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb Part No SW: 8K0 907 063 D HW: 8K0 907 063 D Component: BCM1 1.0 H24 0253 Revision: 05024001 Serial number: 00000000225447 Coding: 690000B1063C00010000080300007F5F0F1452080000000100 0000 Shop #: WSC 02391 823 56573 VCID: 302C301B63CED1CF17-8064 Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB Component: WWS 180309 H06 0070 Serial number: SWF09030185532 Coding: 00FD11 Subsystem 2 - Part No SW: 8K0 941 531 T HW: 8K0 941 531 T Component: E1 - LDS H07 0090 Serial number: 00000000001203091159 9 Faults Found: 03351 - Bulb for DRL and Marker Light; Left 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 6 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:28:00 03354 - Bulb for DRL and Marker Light; Right 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 6 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:28:00 00978 - Lamp for Low Beam; Left (M29) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 8 Mileage: 206827 km Time Indication: 0 Date: 2020.02.04 Time: 13:05:00 00979 - Lamp for Low Beam; Right (M31) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 8 Mileage: 206827 km Time Indication: 0 Date: 2020.02.04 Time: 13:05:00 01497 - Bulb for Blinkers; Front Right (M7) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 8 Mileage: 206827 km Time Indication: 0 Date: 2020.02.05 Time: 09:17:00 03188 - Bulb for Side Marker Light; Front Left 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 8 Mileage: 206827 km Time Indication: 0 Date: 2020.02.04 Time: 13:05:00 03189 - Bulb for Side Marker Light; Front Right 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 8 Mileage: 206827 km Time Indication: 0 Date: 2020.02.04 Time: 13:05:00 02745 - Bulb for Daytime Running Light; Left 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 6 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:28:00 02746 - Bulb for Daytime Running Light; Right 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 6 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:28:00 ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:* 8K0-959-655.clb Part No SW: 8K0 959 655 F HW: 8K0 959 655 F Component: AirbagVW-AU10 H27 0410 Serial number: 0039KD14XSN5 Coding: 303836354230303030304A55304C384B3053 Shop #: WSC 02135 785 00200 ASAM Dataset: EV_AirbaECUVWAUDI010 A02007 ROD: EV_AirbaECUVWAUDI010_A02.rod VCID: 40CC60DBDB6E414FE7-8014 Seat occupied recognition: Subsystem 1 - Part No SW: 8K0 959 339 B HW: 8K0 959 339 B Component: BF-Gewichtss. H01 0030 Serial number: 5810000R0900003JA6 Crash sensor for side airbag: driver side: Serial number: 6334MSME46340C1BE Crash sensor for side airbag: front passenger side: Serial number: 6344MSME4463086EJ Crash sensor for side airbag: rear: driver side: Serial number: 6352QSME621E520EL Crash sensor for side airbag: rear: passenger side: Serial number: 6362QSME461F0922H 2 Faults Found: 9443859 - Driver's Front Airbag Crash Sensor B101A 15 [137] - Open or Short to Plus MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 206827 km Date: 2020.02.02 Time: 15:28:25 9444115 - Front Passenger's Front Airbag Crash Sensor B101B 15 [137] - Open or Short to Plus MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 206827 km Date: 2020.02.02 Time: 15:28:25 ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb Part No SW: 8K0 953 568 F HW: 8K0 953 568 F Component: Lenks.Modul H16 0014 Revision: -------- Serial number: 90304ICD0004X Coding: 000034 Shop #: WSC 02391 823 56573 VCID: 3D32192FA49C2CA78C-8068 Component: E221 - MFL H02 0003 2 Faults Found: 00447 - Function Limitation due to Over-Voltage 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 6 Fault Frequency: 2 Reset counter: 47 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:38:59 00888 - Wiper Switch for Intermittent Operation (E22) 014 - Defective - Intermittent Freeze Frame: Fault Status: 00101110 Fault Priority: 2 Fault Frequency: 12 Reset counter: 10 Mileage: 205825 km Time Indication: 0 Date: 2019.12.03 Time: 05:38:09 ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb Part No SW: 8K0 920 950 A HW: 8K0 920 950 A Component: KOMBIINSTR. H18 0224 Revision: 00000000 Serial number: 9DR1EGC39 Coding: 8B1209000300D705020000 Shop #: WSC 02391 823 56573 VCID: 2D12296F74FCBC273C-8078 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb Part No SW: 8T0 907 468 M HW: 8T0 907 468 H Component: GW-BEM 5CAN H06 0095 Revision: GB300043 Serial number: 4300G0930686F2 Coding: 000303 Shop #: WSC 02391 823 56573 VCID: 4BD647F7EA28921702-801E Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E Component: J367-BDM H06 0160 Serial number: 19068C5E110209 2 Faults Found: 03041 - Energy Management Active 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 10 Reset counter: 48 Mileage: 206827 km Time Indication: 0 Date: 2020.01.16 Time: 18:47:00 02256 - Quiescent Current 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 7 Fault Frequency: 3 Reset counter: 48 Mileage: 206827 km Time Indication: 0 Date: 2020.02.03 Time: 04:06:00 ------------------------------------------------------------------------------- Address 2E: Media Player 3 (R199) Labels:. 8T0-035-785.clb Part No SW: 8T0 035 785 HW: 8T0 035 785 Component: SG ext.Player H06 0210 Revision: 00000000 Coding: 020302 Shop #: WSC 02391 823 56573 VCID: 78BCC83BCB3EC98F9F-802C 1 Fault Found: 00447 - Function Limitation due to Over-Voltage 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 6 Fault Frequency: 2 Reset counter: 255 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:32:18 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb Part No SW: 8K0 959 793 D HW: 8K0 959 793 D Component: TSG FA H11 0250 Revision: Serial number: 0000008591368 Coding: 011C03204000410001 Shop #: WSC 02391 823 56573 VCID: 41CA65DFD8644847E8-8014 3 Faults Found: 02115 - Locking Unit for Central Locking 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 254 Reset counter: 46 Mileage: 200391 km Time Indication: 0 Date: 2019.08.09 Time: 16:25:38 00447 - Function Limitation due to Over-Voltage 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 3 Fault Frequency: 4 Reset counter: 47 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:36:22 00532 - Supply Voltage B+ 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 2 Reset counter: 46 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:37:15 ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb Part No SW: 8K0 907 064 F HW: 8K0 907 064 F Component: BCM2 1.1 H80 0145 Revision: 00002001 Serial number: 0117171294 Coding: 0106023A007A000400B001 Shop #: WSC 02391 823 56573 VCID: 33263F1792D8EAD76A-8066 Subsystem 1 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H03 1301 Subsystem 2 - Part No SW: 8K0 959 591 HW: 8K0 959 591 Component: J245 PS034 H06 0037 3 Faults Found: 02615 - Fuel Tank Cap; Lock 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 214 Mileage: 196167 km Time Indication: 0 Date: 2019.03.18 Time: 09:45:51 02616 - Fuel Tank Cap; Unlock 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 214 Mileage: 196167 km Time Indication: 0 Date: 2019.03.18 Time: 09:46:32 00532 - Supply Voltage B+ 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 3 Fault Frequency: 1 Reset counter: 47 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:32:51 ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels:. 8T0-035-223-ASC.clb Part No SW: 8T0 035 223 AB HW: 8T0 035 223 Component: DSP STD H07 0220 Revision: S2100000 Coding: 0203010102 Shop #: WSC 02391 823 56573 VCID: 6E90EE63B97A873F45-803A 2 Faults Found: 02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 74 Reset counter: 49 Mileage: 196240 km Time Indication: 0 Date: 2019.03.19 Time: 22:50:20 Freeze Frame: Voltage: 11.80 V Temperature: -2.0°C Bin. Bits: 00000000 02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 74 Reset counter: 49 Mileage: 196240 km Time Indication: 0 Date: 2019.03.19 Time: 22:50:20 Freeze Frame: Voltage: 11.80 V Temperature: -2.0°C Bin. Bits: 00000000 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb Part No SW: 8K0 959 792 D HW: 8K0 959 792 D Component: TSG BF H11 0250 Revision: Serial number: 0000008606952 Coding: 011C03204000410001 Shop #: WSC 02391 823 56573 VCID: 40CC60DBD36E414FE7-8014 2 Faults Found: 00447 - Function Limitation due to Over-Voltage 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 3 Fault Frequency: 4 Reset counter: 47 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:36:21 00532 - Supply Voltage B+ 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 2 Reset counter: 46 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:37:15 ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb Part No SW: 8K0 907 801 G HW: 8K0 907 801 G Component: EPB Audi B8 H08 0080 Revision: 00000003 Serial number: 10000000194622 Shop #: WSC 00000 000 00000 VCID: 33263F1792D8EAD76A-8066 2 Faults Found: 01321 - Control Module for Airbags (J234) 013 - Check DTC Memory - MIL ON Freeze Frame: Fault Status: 11101101 Fault Priority: 4 Fault Frequency: 1 Reset counter: 6 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:28:34 Freeze Frame: Voltage: 10.80 V Count: 80 Speed: 0.0 km/h Hex Value: 0x02E0 Hex Value: 0x0001 Hex Value: 0x0101 01314 - Engine Control Module 013 - Check DTCMemory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 4 Fault Frequency: 1 Reset counter: 47 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 18:45:14 Freeze Frame: Voltage: 14.00 V Count: 58 Speed: 0.0 km/h Hex Value: 0x0270 Hex Value: 0x0001 Hex Value: 0x0101 ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb Part No SW: 8T1 035 186 R HW: 8T1 035 186 R Component: Con3 Sirius H01 0301 Revision: 00000003 Serial number: AUZ5Z6I1188533 Coding: 04020002010185004119070800 Shop #: WSC 02391 823 56573 VCID: 46C076C3F14A6F7FDD-8012 Subsystem 1 - Part No SW: 8T0 919 603 E HW: 8T0 919 603 E Component: Display 2 Faults Found: 02635 - Tuner Not Enabled/Activated 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 214 Mileage: 196167 km Time Indication: 0 Date: 2019.03.18 Time: 09:36:54 03157 - Functionality limited due to Communications Disruption 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 6 Fault Frequency: 165 Reset counter: 47 Mileage: 196207 km Time Indication: 0 Date: 2019.03.18 Time: 17:56:09 Freeze Frame: Bin. Bits: 00000000 Bin. Bits: 00000000 Bin. Bits: 00000000 Bin. Bits: 00000000 Bin. Bits: 00000000 Bin. Bits: 10000000 Bin. Bits: 00000000 Bin. Bits: 00000000 ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb Part No SW: 4F0 959 795 N HW: 8K0 959 795 C Component: TSG HL H10 0251 Revision: Serial number: 0000100819785 Coding: 010C03204000210001 Shop #: WSC 02391 823 56573 VCID: 44C46CCBC7765D6FC3-8010 2 Faults Found: 00447 - Function Limitation due to Over-Voltage 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 3 Fault Frequency: 4 Reset counter: 47 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:36:22 00532 - Supply Voltage B+ 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 46 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:37:16 ------------------------------------------------------------------------------- Address 65: Tire Pressure (J502) Labels: 8K0-907-273.clb Part No SW: 8K0 907 273 A HW: 8K0 907 273 A Component: J502-RDK H03 0250 Revision: 00001001 Serial number: 13374790243434 Coding: 0CD154 Shop #: WSC02391 823 56573 VCID: 302C301B63CED1CF17-8064 2 Faults Found: 02214 - Tire Pressure Warning 000 - - - MIL ON Freeze Frame: Fault Status: 11100000 Fault Priority: 1 Fault Frequency: 1 Reset counter: 9 Mileage: 206827 km Time Indication: 0 Date: 2020.02.05 Time: 09:50:26 Freeze Frame: 0.00 Bin. Bits: 00001000 01001000 Voltage: 12.60 V Text: 01,0°C; 7,67bar;3390855650;00h;-50°C 01521 - Sensor for Tire Pressure 004 - No Signal/Communication - MIL ON Freeze Frame: Fault Status: 11100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 8 Mileage: 206827 km Time Indication: 0 Date: 2020.02.05 Time: 09:33:13 Freeze Frame: 0.00 Bin. Bits: 00001000 11001001 Voltage: 14.00 V Text: 01,0°C;n.erkannt;3390855811;--h;---°C ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb Part No SW: 4F0 959 795 N HW: 8K0 959 795 C Component: TSG HR H10 0251 Revision: Serial number: 0000100819719 Coding: 010C03204000210001 Shop #: WSC 02391 823 56573 VCID: 44C46CCBC7765D6FC3-8010 2 Faults Found: 00447 - Function Limitation due to Over-Voltage 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 3 Fault Frequency: 6 Reset counter: 47 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:32:32 00532 - Supply Voltage B+ 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 2 Reset counter: 46 Time Indication: 0 ------------------------------------------------------------------------------- Address 77: Telephone Labels: 8P0-862-335.lbl Part No SW: 8T0 862 336 C HW: 8T0 862 336 C Component: FSE_256x BT H33 0550 Revision: 00000000 Serial number: 00000005034728 Coding: 0010370 Shop #: WSC 02335 785 00200 VCID: 3B3617377A882297B2-806E 1 Fault Found: 00532 - Supply Voltage B+ 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 7 Fault Frequency: 1 Reset counter: 46 Mileage: 206827 km Time Indication: 0 Date: 2020.02.02 Time: 15:32:18 End----------(Elapsed Time: 01:39, VBatt start/end: 12.1V/12.1V)
    Feb 2020
    I know how to auto scan thanks but you probably know that because your were responding on the last thread I posted yesterday with the auto scan on it. Cant get it to copy from my other thread to this one and I'm not near the car right now. I will just figure it out myself. thanks.
  9. #8
    Okay........
  10. #9
    Quote Originally Posted by VinceI View Post
    Due to the lack of line breaks, this is essentially illegible. What intermediate software was this text passed through?
  11. Likes Jack@European_Parts liked this post
  12. #10
    Isn't Vince too busy dismissing the obvious and trying to argue or do tests when not ready too commence with them and makes a point in multiple threads versus work on a solution over an alleged "pigtail" brick wall & he hits his head on calling me being negative?
    If someone dismisses everyone & can't be told they are doing something wrong, how HTF can you correct them?
    https://forums.ross-tech.com/showthr...over-1100-rpms
