Skoda Octavia (MY2017) Memory Seat Saga
harwood27
C?ID=340116
Firstly apologies as i am new here. Had VCDS a while but this has finally got me scratching my head so in need of assistance.
The car is a UK registered 2016 Skoda Octavia VRS 230 (MY2017). I recently discovered that the previous owner had removed the drivers seat memory buttons ( i suspect they were damaged and the car was returned on lease) and fitted a blank panel to hide the hole and avoid any charges. erWin stated it as factory fit, and reviewing old brochures confirmed this.
On investigation the wiring was found and a new memory button purchased and fitted. VCDS talks to the module however it is stating invalid data and although completes the basic setting calibration, all sensors report a loss of basic settings. Looking at the coding it appears to be confused and stated it being LHD when its actually RHD. Also it stated memory was saved through the keys. This would explain the Seat menu in the infotainment which mentioned personalised key settings and a tick option, however this did not allow you to select it. This vehicle is not equipped with Kessy, and as far as i'm aware this was the system that the seat memory saved to when using the key memory.
My understanding is that the module code or software is all out of shape for whatever reason. A bit of research would appear this isn't uncommon with owners returning the car to dealers for re-installation of software. This car is out of warranty so if you guys/gals and VCDS can help that would be fantastic!
Tuesday,11,February,2020,17:43:05:11380
VIN: TMBKE7NE8H0XXXXXX
Chassis Type: NE-SK37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 32 36 42 44 52 55 5F A5 A9
VIN: TMBKE7NE8H0025716   Mileage: 113526km-70541miles
Address 01: Engine (J623-CHHA)       Labels:. 06K-907-425-V1.clb
   Revision: --H13---
   Coding: 0C1D00124424010B0000
   Shop #: WSC 73430 031 00000
   ROD: EV_ECM20TFS0205G0906259C.rod
   VCID: 2E05F277F09582376BB-807A
Readiness: 1010 0001
   Part No SW: 0D9 300 020 L    HW: 02E 927 770 AQ
   Component: DQ250-6V MQB  H54 4901
   Revision: 06354004    Serial number: TFK01606020811
   Shop #: WSC 73430 031 00063
   ROD: EV_TCMDQ250021.rod
   VCID: 1E6522B7803512B7DBB-804A
10657 - RPM Signal from ECU
          P0726 00 [002] - Implausible Signal
          P1734 00 [002] - -
Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 AF    HW: 5Q0 614 517 AF
   Component: ESC           H62 0398
   Revision: 00000000    Serial number: 51486000000547
   Coding: 1C07939154221971407E060141C92938C92A98026082947610410071C02903
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 035019
   ROD: EV_Brake1UDSContiMK100ESP_035_SK37.rod
   VCID: 75B71D1B5543F1EFEA1-8020
   Part No SW: 5E0 907 044 AC    HW: 5E0 907 044 AC
   Revision: 00001K07
   Coding: 02110004000110011005000000101002
   VCID: 66954A5718E50A7753B-8032
   Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
   Revision: --------    Serial number: 865812061602MW
   Coding: 0F001B46C24722FB07A04082B10C07280000000000000000000000000000
   Shop #: WSC 73430 790 12345
   ROD: EV_BCMBOSCH_015.rod
   VCID: 035373C30B97DF5FD45-8056
   Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 160515  041 0570
   Serial number:         160527090358
   Coding: 0E5DFD
   Component: RLHS  042 0105
   Serial number: S5Y16M06D15H20M38S29
   Coding: 00885D
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY161171GF5
   Serial number: 00000000000066143423
203016 - Unlock Switch in Rear Lid Handle
          B140B 29 [009] - Signal Implausible
                    Reset counter: 193
                    Mileage: 113526 km
                    Date: 2020.02.11
                    Time: 17:16:23
   Revision: --------    Serial number: 39331615306548
   Coding: 0031051051
   Shop #: WSC 73430 790 00063
   VCID: 43D3B3C34B171F5F945-8016
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
   Component: ACC Bosch MQB H05 0400
   Serial number: 20051604381603
   Coding: 00001600FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
   VCID: 3A2DCE273CDD5E97C73-806E
   Part No SW: 3Q0 959 655 AS    HW: 3Q0 959 655 AS
   Component: Airbag VW20   013 0200
   Revision: --------    Serial number: 003SQPBKGR7Y
   Coding: 98CCC000000000005C5400CC008800000065
   Shop #: WSC 73430 790 00000
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 0F7B4FF357DFAB3F40D-805A
   Subsystem 1 - Part No SW: -----------    HW: 454 002 205 16
   Serial number: 3576U00000067B595B1K
   Subsystem 2 - Part No SW: -----------    HW: 454 002 105 16
   Serial number: 3586U000000405795B18
   Subsystem 3 - Part No SW: -----------    HW: 454 802 805 16
   Serial number: 3516R32AA860A0000005
   Subsystem 4 - Part No SW: -----------    HW: 454 802 805 16
   Serial number: 3526RDFF7850A000000U
   Subsystem 5 - Part No SW: -----------    HW: 454 802 805 16
   Serial number: 3556V992D460B000000I
   Part No SW: 5Q0 953 521 T    HW: 5Q0 953 569 A
   Revision: FF034034    Serial number: 20160615500621
   Coding: 1410
   ROD: EV_SMLSVALEOMQB.rod
   Part No SW: 5E0 920 956 C    HW: 5E0 920 956 C
   Component: KOMBI         305 8311
   Coding: 27AD09086984A600018A6A031000000000000000
   Shop #: WSC 73430 031 12345
   VCID: 2C01F87FC689F02745F-8078
1048578 - No Basic Setting
          B2010 00 [009] - -
          [Steuergerät keine oder falsche Grundeinstellung]
                    Reset counter: 193
                    Mileage: 113526 km
                    Date: 2020.02.11
                    Time: 17:18:25
   Revision: --------    Serial number: 0004948516
   Coding: 030100047F085900EB00026B1C0F00010001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 7CA1083F7669A0A795F-8028
   Subsystem 2 - Part No SW: 3V0 919 719 B    HW: 3V0 919 719 B
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000A3035310516
   Serial number: 75410803001606023790
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
   Component: Quersperre    H52 8042
   Serial number: HA1-00003.05.16
   Coding: 0201
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   VCID: 47CBA7D37F2F337F48D-8012
   Part No SW: 5Q0 959 760 C    HW: 5Q0 959 760 C
   Component: Sitzmemory    H09 0024
   Serial number: Y0007SDJ23344
   Coding: 0014000000000100012281808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   VCID: 3D27C53B2DF369AFE21-8068
9654868 - Motor for Lumbar Support Fore/Aft Adjustment
          B1352 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 193
                    Mileage: 113526 km
                    Date: 2020.02.11
                    Time: 17:37:10
9654612 - Motor for Lumbar Support Height Adjustment
          B1351 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 193
                    Mileage: 113526 km
                    Date: 2020.02.11
                    Time: 17:37:10
10487040 - invalid data record
          B2005 00 [009] - -
                    Reset counter: 193
                    Mileage: 113526 km
                    Date: 2020.02.11
                    Time: 17:37:10
10489856 - No Basic Setting
          B2010 00 [009] - -
          [keine oder falsche Grundeinstellung/Adaption]
                    Reset counter: 193
                    Mileage: 113526 km
                    Date: 2020.02.11
                    Time: 17:37:10
   Serial number: 0000204417946
   Coding: 001D0020DE01040000001100
   Serial number: 00000000000010371636
   Coding: 1D0200
   Coding: 9107
   ROD: EV_SteerAssisMQB_013.rod
   Serial number: 0000204293167
   VCID: 46D5AAD778252A77B3B-8012
   Serial number: 00000000000010347045
   Coding: 050200
   Coding: 03DE00003F000000
   VCID: 40D9BCCF5A010447897-8014
   Coding: 3E0000
   Coding: 3E0000
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-STD2.clb
   Part No SW: 5Q0 035 874 B    HW: 5Q0 035 874 B
   Component: MU-S-ND-ER    H30 0353
   Serial number: SKZAZ2S5097274
   Coding: 03735201FF00000011111201008800002F0101C601200100CE
   ROD: EV_MUStd4CTSAT_VW41.rod
   VCID: 3333E3031BB7AFDF045-8066
   Subsystem 1 - Part No SW: 5E0 919 605 J    HW: 5E0 919 605 J
   Component: ABT_Std-2_Nav  H43 1031
   Serial number: SKZ8Z9SLH00WX2
   Subsystem 2 - Part No SW: 5L0 051 236 H    HW: -----------
   Component: ECE 2016  --- 0521
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H07 0060
   Serial number: 10000571482
   Coding: 0101010001030306000400000100010100
   ROD: EV_MFKBoschAU370.rod
   VCID: 3C21C83F36E960A7D5F-8068
   Part No SW: 5E0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0001
   Serial number: 160505201804
   VCID: 698F416B09FB250F7E9-803C
End----------(Elapsed Time: 01:40, VBatt start/end: 13.2V/13.2V)-----------
darkchina811
ITALY
C?ID=333184
you don't need KESSY, seat memory is associated to whatever keyfob is in the ignition when you store the seat settings. so if your wife has another keyfob, when she unlocks the car the seat will move to her setting.
with that being said, your module 36 has an "invalid data record" error. it means that it has lots parameterization, and this means that:
1) VCDS cannot upload parameters so you need to go to the dealer;
2) you'll never be able to perform basic settings, and thus to use seat memories, until you fix the "invalid data record".
sorry buddy...
harwood27
C?ID=340116
Ah right. I thought on my particular car it would just be on the three memory buttons on the seat base.
Thanks for the description on the invalid data record though. Although I can’t fix it myself at least it’s a definitive ‘must go to Škoda’. Always worth a try first I say.
Much appreciated and I’ll see if the dealer can work out if mine is equipped with the key memory option as I notice in the code there was a non key option hence me thinking it was only for kessy.
Many thanks!!
darkchina811
ITALY
C?ID=333184
my parents have an Octavia with no Kessy and it works like that, any of the 3 memories you store gets remembered to the current keyfob.
the official scan tool of a dealer, named ODIS, has a guided fault finding function and will take care of everything. if they can't sort it out, go to another dealer :D
harwood27
C?ID=340116
Fab thanks for the info. I imagine it’s pretty common so I’ll head on over there when I get a chance. Just a shame they are all not very close
