Results 1 to 10 of 13
Thread: Audi a3 abs coding
    Oct 2016
    Audi a3 abs coding
    i have fitted a secondhand abs module to this a3. has original had no comunnication and handbrake would not work as handbrake module is incorporated in abs module. can someone help with coding abs please.original module had a part number of AR at end of part number new module ends in R. full scan of car attached.
    Tuesday,11,February,2020,16:06:47:28694
    Dealer/Shop Name: autoelec
    VIN: WAUZZZ8V0HA045881   License Plate: PJ66OKB
    Mileage: 133330km-82847mi   Repair Order: JUSTIN.NEW
    Chassis Type: 8V-AU37 (5Q0)
    Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F BB BC
    VIN: WAUZZZ8V0HA045881   Mileage: 133330km-82847miles
    Address 01: Engine (J623-DBKA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 CA    HW: 04L 907 309 R
       Component: R4 1,6L EDC   H23 1662
       Revision: B5H23---
       Coding: 02190012032501092000
       Shop #: WSC 06314 790 00021
       ASAM Dataset: EV_ECM16TDI01104L906026CA 002004
       ROD: EV_ECM16TDI01104L906026CA_002.rod
       VCID: 6B83C0C3B302F13F0C5-803E
    10065 - Mass Air Flow Sensor (G70)
              P0104 00 [167] - Intermittent
                        Mileage: 133330 km
                        Date: 2020.02.08
                        Time: 03:46:43
                        Coolant temperature: 6 °C
                        Intake air temperature: 6 °C
                        Voltage terminal 30: 12.360 V
                        Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
                        Standardized airflow ratio: filtered: 3.9999
                        Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 0.00 %
                        Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 0.00 %
                        Charge air pressure specified value: 0 hPa
                        Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 986.0 hPa
                        Mean injection quantity: 0.00 mg/stroke
    25195 - Intake Air Temp. Sensor (G42)
              P0113 00 [039] - Signal too High
                        Mileage: 133330 km
                        Date: 2020.02.08
                        Time: 03:46:43
    4716 - No Communications with Parking Brake Control Module
              U0128 00 [039] - -
                        Mileage: 133330 km
                        Date: 2020.02.08
                        Time: 03:46:42
                        Voltage terminal 30: 12.300 V
                        Cruise Control System (CCS): status-Bits 0-7: 7
                        selected gear-Bits 0-7: 0
       Part No SW: 5Q0 907 379 CK    HW: 5Q0 907 379 G
       Component: ESC           H31 0472
       Revision: 00000000    Serial number: 62223000000394
       VCID: 074B9C738FAA355F88D-8052
    14 Faults Found:
    0195 - Control module not coded
              U1013 00 [137] - -
              [ECU marked as Not Configured because vehicle ID is invalid]
                        Reset counter: 240
                        Date: 2020.02.08
                        Time: 03:47:36
    0212 - Longitudinal Acceleration Sensor
              C1017 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 240
                        Date: 2020.02.08
                        Time: 03:47:36
    0270 - Lateral Acceleration Sensor
              C1079 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 240
                        Date: 2020.02.08
                        Time: 03:47:36
    0279 - Brake Pressure Sensor 1
              C107A 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 240
                        Date: 2020.02.08
                        Time: 03:47:36
    0295 - Steering angle sensor
                        Reset counter: 240
                        Date: 2020.02.08
                        Time: 03:47:36
    8278 - Control Module Incorrectly Coded
              U1014 00 [137] - -
              [FCAN: Mismatch between bytecoding and Lenkerposition signal]
                        Reset counter: 240
                        Date: 2020.02.08
                        Time: 03:47:36
    8290 - Coding Not Possible
              U10BC 00 [137] - -
              [FCAN: Unplausible VIN number]
                        Reset counter: 240
                        Mileage: 133330 km
                        Date: 2020.02.08
                        Time: 03:47:41
    8306 - Databus
              U1122 00 [137] - Implausible Message
                        Reset counter: 240
                        Mileage: 133330 km
                        Date: 2020.02.08
                        Time: 03:47:41
    8307 - Databus
              U1122 00 [009] - Implausible Message
              [FCAN: PLA_Status_PLA_ESP signal is invalid]
                        Reset counter: 240
                        Date: 2020.02.08
                        Time: 03:47:36
    8308 - Control Module Incorrectly Coded
              U1014 00 [009] - -
              [FCAN: StartStop not coded but MO_StartStopp_Status not equal 0]
                        Reset counter: 240
                        Date: 2020.02.08
                        Time: 03:47:36
    8314 - Check Coding of ECUs on Powertrain Data Bus
              P1647 00 [009] - -
              [FCAN: Coding of ESP and TSK does not fit together]
                        Reset counter: 240
                        Date: 2020.02.08
                        Time: 03:47:36
    32848 - Control Module for Electric Parking Brake
              C10E2 F1 [137] - Switches/Motors Detected
                        Reset counter: 240
                        Date: 2020.02.08
                        Time: 03:47:36
    32900 - Left Parking Brake Motor Voltage Supply
              C100D 13 [137] - Electrical Malfunction
                        Reset counter: 240
                        Date: 2020.02.08
                        Time: 03:47:36
    32901 - Right Parking Brake Motor Voltage Supply
              C100E 13 [137] - Electrical Malfunction
                        Reset counter: 240
                        Date: 2020.02.08
                        Time: 03:47:36
    Address 08: Auto HVAC (E87)       Labels:| 8V0-820-047.clb
       Part No SW: 8V0 820 047 F    HW: 8V0 820 047 F
       Component: AC Manuell el H03 0110
       Revision: 20001000    Serial number: 00000000244919
       Coding: 03100104002000001000000000000000
       ASAM Dataset: EV_AirCondiFrontManAU37X 008018
       ROD: EV_AirCondiFrontManAU37X.rod
       VCID: 392F2A8B89DE93AFCE9-806C
       Part No SW: 5Q0 937 084 CG    HW: 5Q0 937 084 CG
       Component: BCM MQBAB H   H34 0236
       Serial number: 02001623800597
       ROD: EV_BCMBOSCH_017.rod
       VCID: 7F5B0493D77A7D9FB0D-802A
       Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS370 160810  043 0580
       Serial number:         160817183816
       Coding: 0A47F7
       Subsystem 2 - Part No SW: 8U0 955 559 D    HW: 8U0 955 559 A  Labels: 8U0-955-559.CLB
       Component: G397_RLS  H06 0004
       Serial number: 50066833
       Coding: 00006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
       Serial number: 30 06 2016  00000255
       Serial number: 000000000ZY162041M86
       Serial number: 00000000000036271688
       Part No SW: 5QA 919 283     HW: 5QA 919 283
       Component: PDC 4 KanalH07 0031
       Serial number: 000308419616239
       Coding: 0700040001
       ASAM Dataset: EV_EPHVA14AU3700000 009027
       ROD: EV_EPHVA14AU3700000_009.rod
    12658704 - Databus
              [Steuergerät für elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation]
                        Reset counter: 240
                        Mileage: 133330 km
                        Date: 2020.02.08
                        Time: 03:46:41
    13637426 - Databus
                        Reset counter: 240
                        Mileage: 133330 km
                        Date: 2020.02.08
                        Time: 03:46:40
       Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
       Component: AirbagVW21    003 0315
       Serial number: 003TDR22KSD8
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 1079B72FFAE472E7597-8044
       Subsystem 1 - Part No SW: -----------    HW: 480 003 108 16
       Serial number: 357000000002509C2C1F
       Subsystem 2 - Part No SW: -----------    HW: 480 003 108 16
       Serial number: 358000000008509C2C1M
       Subsystem 3 - Part No SW: -----------    HW: 480 402 908 16
       Serial number: 3510001A72216EE2A798
       Subsystem 4 - Part No SW: -----------    HW: 480 402 908 16
       Serial number: 35200019B2216EE2471+
       Subsystem 5 - Part No SW: -----------    HW: 480 402 507 16
       Serial number: 3550002B3211FA32211O
       Pedestrian Protection Driver:
       Subsystem 6 - Part No SW: -----------    HW: 480 401 908 16
       Component: PedP_Sensor_D  000 6149
       Serial number: 2280001A320F2B2512E.
       Subsystem 7 - Part No SW: -----------    HW: 480 401 908 16
       Component: PedP_Sensor_P  000 6149
       Serial number: 22900019D20F2B22031V
       Subsystem 8 - Part No SW: -----------    HW: 480 000 508 16
       Serial number: I0M00000000F53816D16
       Subsystem 9 - Part No SW: -----------    HW: 480 000 508 16
       Serial number: I0N00000000A8B09DC1J
    9682162 - Multiple collision brake
              B13BC F2 [137] - No function
                        Mileage: 133330 km
                        Date: 2020.02.08
                        Time: 03:46:40
       Part No SW: 8V0 953 521 HB    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 31081608490097
       Coding: A408
       VCID: 015F826BA18E0B6FC69-8054
       Part No SW: 8V0 920 972 L    HW: 8V0 920 972 L
       Component: KOMBI         H04 8316
       Coding: 27A40A002B8026000100E8001001000000000000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009054
       VCID: 47CB5C73CF2AF55F48D-8012
    16776967 - Databus
              [EPB_02 keine Kommunikation]
                        Reset counter: 240
                        Mileage: 133330 km
                        Date: 2020.02.08
                        Time: 03:46:40
    16776973 - Databus
              [RKA_01 keine Kommunikation]
                        Reset counter: 240
                        Mileage: 133330 km
                        Date: 2020.02.08
                        Time: 03:46:40
       Part No SW: 5Q0 907 530 AL    HW: 5Q0 907 530 E
       Component: GW MQB Mid    127 1265
       Revision: --------    Serial number: 0005260751
       Coding: 030100041F0873005B000248080B00000001010000000000000000000000
       ROD: EV_GatewLear_013.rod
       VCID: 7BA3F083C36261BF9C5-802E
       Subsystem 2 - Part No SW: 81A 951 523     HW: 81A 951 523
       Component: J453 MFL  H04 0003
       Serial number: 20160811080501 20915
       Serial number: 75410803001608235553
       Serial number: 210816EHL04561
       Coding: 00108A204001040000001002
       VCID: 43D34863FB12D97F945-8016
       Component: EPS_MQB_ZFLS  128 1072
       Coding: 0107
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 45D7567BF526E74FBA1-8010
       Serial number: 100616EFA05309
       Coding: 001082204001040000001002
       VCID: 42DD4D67E408D0779F3-8016
    Address 5F: Information Electr. (J794)       Labels:* Redir Fail!
       Part No SW: 81A 035 192     HW: 81A 035 192
       Component: MU-HS-LND-EU  045 0148
       Coding: 01730301FF00000011111101000A00102F002AC601F00100CE
       ASAM Dataset: EV_MUHigScl6C3DELP 001011
       ROD: EV_MUHigScl6C3DELP.rod
       VCID: 5EE5991770B094979BB-800A
       Subsystem 1 - Part No SW: 8W0 919 866 C    HW: -----------
       Component: ECE 2016  --- 0009
       Component: DU High  H49 0014
       Serial number: AUZ8Z9GY2075GV
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8V0 919 614 BE    HW: 8V0 919 614 BE
       Component: ControlUnit_B  H50 0103
       Serial number: ALJAL122081600010260
    7175 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 240
                        Mileage: 133330 km
                        Date: 2020.02.08
                        Time: 03:46:44
                        Voltage terminal 30: 12.2 V
                        BAP-BAP_Function_ID: 02
       Serial number: 220816CHF05967
       Coding: 000082204001040000001002
       Serial number: 220816CHF05748
    End----------(Elapsed Time: 01:25, VBatt start/end: 12.4V/12.5V)-----------
    May 2017
    Try this as ABS coding :
    13FF6A9234242871017F030881C429C8562C5080C08194B4004100780208
  3. Likes Uwe liked this post
    Oct 2016
    Coding rejected. Request out of range
    May 2017
    Okey, let’s iterate then. I’ll check the coding when I get home
    May 2017
    Try number 2, this should go in
    13FF6AA234240A71017F060841C429C8562C5080608294B4004100380208
    Oct 2016
    Wrong code. Request out of range
    There is not so much information on this ABS type, but maybe this is close.
    12F182A224240A71017F060841C42548412450806082A4F2024100788008
  9. #8
    Oct 2016
    Wrong coding still
  10. #9
    Oct 2016
    Quote Originally Posted by Radiosolutions View Post
    Wrong coding still
    Any other suggestions please
  11. #10
    Mar 2019
    London, United Kingdom
    Audi A3 8V ABS Long Coding: 13F18AA22423227189780E0960C928C8512444917006147202 2150748208420000000012121212B835351919323200
    Audi A3 8V ABS Long Coding: 12F18AA224252274897D0E0560CA2448512444917006247202 21F0748208420000000012121212B835351919323200
