Adaptive cruise inop, distance sensor issues
goohdaddy
C?ID=391631
Tuesday,11,February,2020,02:39:05:24843
VCDS Version: 19.6.2.0  HEX-V2 CB: 0.4508.4
VIN: WVWWF7AU1HW041832   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 05 08 09 13 14 15 16 17 19 22 2B 3C 42 44 47 52 55 5F
          75 A9
VIN: WVWWF7AU1HW041832   Mileage: 93330km-57992miles
Address 01: Engine (J623-CYFB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 K    HW: 06K 907 425 E
   Component: 2.0l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 091900122446000E3004
   ASAM Dataset: EV_ECM20TFS0208V0906259K 001005
   ROD: EV_ECM20TFS0208V0906259K.rod
   VCID: 48C95FD11235EBF7417-801C
15211 - Oil Pressure Regulating Valve
          P164E 00 [047] - Electrical Malfunction
                    Mileage: 93195 km
                    Date: 2020.02.04
                    Time: 18:27:35
                    Engine speed: 1039.50 /min
                    Normed load value: 15.7 %
                    Coolant temperature: 57 °C
                    Intake air temperature: 5 °C
                    Ambient air pressure: 800 mbar
                    Voltage terminal 30: 14.648 V
                    Engine oil temperature: 18.0 °C
                    Time since engine start: 394.1 s
                    T_ES: 0 min
                    MAP_MES_SAE: 25 kPa
                    Engine: operating status: IS
                    T_AST_SAE: 0 s
                    ECU_STATE: SYN_ENG_IGK_ON
22008 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [047] - -
                    Mileage: 93195 km
                    Date: 2020.02.04
                    Time: 18:27:33
                    Engine speed: 1032.75 /min
                    Normed load value: 16.1 %
                    Voltage terminal 30: 14.628 V
                    Time since engine start: 392.2 s
                    T_ES: 0 min
                    Cruise control switch actuation-Main switch: not activated
                    Cruise control switch actuation-Setting: not activated
                    Cruise control switch actuation-Activation: not activated
                    Cruise control switch actuation-Status: OK
                    Cruise control switch actuation-Accelerate: not activated
                    Cruise control switch actuation-Decelerate: not activated
                    Cruise control switch actuation-Cancel: not activated
                    Cruise control switch actuation-Main switch hardware: not activated
                    Cruise control switch actuation-Coding: plausible
                    Cruise control switch actuation-Limit function: not selected
                    Cruise control switch actuation-Limit button: not activated
                    Cruise control switch actuation-Main switch CAN: not activated
                    Cruise control switch actuation-Large increment: not activated
                    Cruise control switch actuation-Control component verified: Yes
                    T_AST_SAE: 0 s
Readiness: 0000 0100
   Part No SW: 5Q0 614 517 BJ    HW: 5Q0 614 517 AG
   Component: ESC           H62 0636
   Revision: 00000000    Serial number: 91766000003790
   Coding: 01FA6BA15424096D457F030341C56980D62A90A2C0829637144050D4C08803
   VCID: 7AADF5191C594967873-802E
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0411431250
   Coding: 032C0C
   VCID: 3B23301D53E3B06FDC5-806E
   Part No SW: 5G0 907 044 BL    HW: 5G0 907 044 BL
   Component: Climatronic   H04 1601
   Revision: 00001K08
   Coding: 00020004200100000005000012111402
   VCID: 72BDDD3944293127CF3-8026
   Air quality sensor:
   Part No SW: 5Q0 937 085 BL    HW: 5Q0 937 085 AF
   Component: BCM MQBAB HNA H24 0175
   Serial number: 01061617600377
   Coding: 00010A46C041A2E169E44000091C07201800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 04518BE16E9D0F97EDF-8050
   Component: WWS    160625  043 0551
   Serial number:         160704040805
   Component: RLHS  037 0059
   Serial number: S4Y16M07D12H05M42S00
   Coding: 90A8DD
   Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
   Component: ACC BOSCH MQB H10 0571
   Coding: 000000000000000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 001005
   ROD: EV_ACCBOSCHVW416_001_VW37.rod
10 Faults Found:
0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [009] - -
          [FAULT_ALIGNMENT_NOT_OK]
                    Reset counter: 183
                    Mileage: 93246 km
                    Date: 2020.02.05
                    Time: 13:36:13
                    Control Module temperature: 30 °C
                    Voltage terminal 15: 12.1 V
1810 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [FAULT_AWV_CODING_IMPLAUSIBLE]
                    Reset counter: 174
                    Mileage: 93246 km
                    Date: 2020.02.05
                    Time: 13:35:55
0839 - Control Module Incorrectly Coded
          U1014 00 [008] - -
          [FAULT_CODING_DIRECTION_OF_TRAVEL_SENSOR]
                    Fault Frequency: 143
                    Reset counter: 223
                    Mileage: 93246 km
                    Date: 2020.02.05
                    Time: 15:22:55
                    Control Module temperature: 8 °C
                    Voltage terminal 15: 14.6 V
                    Velocity_vehicle_reference: 5.30 m/s
                    Longitudinal_acceleration_vehicle_reference: 2.50 m/s²
1811 - Control module not coded
          U1013 00 [009] - -
          [FAULT_ECU_NO_CODING]
                    Reset counter: 174
                    Mileage: 93246 km
                    Date: 2020.02.05
                    Time: 13:35:55
2143 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [FAULT_ENGINE_PLAUS_FAIL]
                    Reset counter: 174
                    Mileage: 93246 km
                    Date: 2020.02.05
                    Time: 13:35:55
                    Voltage terminal 15: 12.0 V
1807 - No Enable Indentifications Active
          B2032 00 [009] - -
          [FAULT_SWAP_NO_FSID_ACTIVE]
                    Reset counter: 174
                    Mileage: 93246 km
                    Date: 2020.02.05
                    Time: 13:35:55
0268 - Dynamometer Mode Detected
          C10A7 00 [008] - -
          [FAULT_SYC_ROLLERMODE_ACTIVE]
                    Reset counter: 214
                    Mileage: 93246 km
                    Date: 2020.02.05
                    Time: 14:06:59
                    Control Module temperature: 34 °C
                    Voltage terminal 15: 12.2 V
15361024 - Component Protection
          U1101 00 [009] - Active
          [FAULT_THP_EC_OTHER_ERROR]
                    Reset counter: 174
                    Mileage: 93246 km
                    Date: 2020.02.05
                    Time: 13:35:55
13762560 - Component protection
          U1114 00 [009] - GFA key
          [FAULT_THP_GFA_KEY]
                    Reset counter: 174
                    Mileage: 93246 km
                    Date: 2020.02.05
                    Time: 13:35:55
13697024 - Component Protection
          U1100 00 [009] - No Basic Setting
          [FAULT_THP_START_KEY]
                    Reset counter: 174
                    Mileage: 93246 km
                    Date: 2020.02.05
                    Time: 13:35:55
   Serial number: 26061641350304
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 38292F1162D59B77317-806C
   Serial number: 003GCR054AYP
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 47CB5CED1F2BE48F48D-8012
   Occupant Detection:
   Component: BF-Gewichtss.  H12 0021
   Serial number: IBH0000000000058N1VS
   Coding: 30324E
   Subsystem 2 - Part No SW: -----------    HW: 480 000 907 16
   Serial number: 3570000000069AD0AC1X
   Subsystem 3 - Part No SW: -----------    HW: 480 000 907 16
   Serial number: 3580000000086051DC1J
   Subsystem 4 - Part No SW: -----------    HW: 480 400 707 16
   Serial number: 35100029920F195440D$
   Subsystem 5 - Part No SW: -----------    HW: 480 400 607 16
   Serial number: 3520002B920FC7455332
   Subsystem 6 - Part No SW: -----------    HW: 480 400 407 16
   Serial number: 3550002B320FC743830/
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 407 16
   Serial number: 3560002AF20F195282A9
   Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 08071604400853
   Coding: 0400
   VCID: 074B9CED5FAB248F88D-8052
   Part No SW: 5G1 920 858 B    HW: 5G1 920 858 B
   Component: KOMBI         303 8311
   Coding: 03AD0812BF88CF0502886B295400000000000000
   VCID: 2F3B144D979B5CCF60D-807A
16776996 - Databus
          [FCW_01 keine Kommunikation]
                    Reset counter: 183
                    Mileage: 93330 km
                    Date: 2020.02.10
                    Time: 02:16:21
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1265
   Revision: --------    Serial number: 0005104044
   Coding: 0101000838085900FB00023A880F00000001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 7CA1F301166D775795F-8028
   Subsystem 2 - Part No SW: 5G0 959 442 S    HW: 5G0 959 442 S  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0040
   Serial number: 29160000962240036211
   Coding: 34FFFF
65798 - Extended CAN in One-Wire Mode
          U0054 00 [008] - -
          [Eindrahtfehler CAN-Extended]
                    Fault Frequency: 82
                    Reset counter: 219
                    Mileage: 93197 km
                    Date: 2020.02.04
                    Time: 19:05:42
                    Supply voltage: Terminal 30: 14.0 V
                    Terminal 15: On
                    Reset counter: 171
                    Mileage: 93195 km
                    Date: 2020.02.04
                    Time: 18:27:32
                    Supply voltage: Terminal 30: 14.5 V
                    Terminal 15: On
   Serial number: HA1-00001.06.16
   Coding: 3829
   Shop #: WSC 12345 123 61029
   VCID: 4ACD65D90C3919E7573-801E
   Revision: 00000000    Serial number: 16000111197008
   Coding: 5500000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 34311B217EBD7F171DF-8060
   Serial number: 0410682641
   Coding: 01011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3C21330156EDB757D5F-8068
   Component: HRE_Slave  H12 0071
   Serial number: 0407473932
   Coding: 010111
   Serial number: 050716EG508003
   Coding: 003E13208000040000000000
   VCID: 43D348FD2B13C8AF945-8016
   Subsystem 1 - Part No SW: 5Q0 959 811     HW: 5Q0 959 811   Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000010799137
   Coding: 111000
   Coding: 8102
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2D35195CD98967C73-806E
Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
   Part No SW: 5Q0 035 456     HW: 5Q0 035 456
   Component: MIB2_lite_amp H20 0150
   Revision: 00000001    Serial number: VWZ8Z1GBA022TGD
   VCID: 6D87CE455D17EEDF121-8038
   Serial number: 080716EG714547
   Coding: 003E13208000040000800000
   VCID: 42DD4DF93409C1A79F3-8016
   Subsystem 1 - Part No SW: 5Q0 959 812     HW: 5Q0 959 812   Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000010672251
   Coding: 091000
   Coding: 022202010B000400
   VCID: 40D947F13A05D3B7897-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0002
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0002
   Coding: 2E0000
   Part No SW: 3Q0 035 876 A    HW: 3Q0 035 876 A
   Component: MU-S-NS-US    840 0751
   Coding: 027300020000000051220002001808009F0207F401200105C6
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 323D1D3984A971270F3-8066
   Subsystem 1 - Part No SW: 5GM 919 605     HW: 5GM 919 605
   Component: ABT_Std-2_Nav  H53 1031
   Serial number: VWZ8Z9SJX006RW
   Subsystem 2 - Part No SW: 3G0 919 866 AC    HW: -----------
   Component: NAR 2016/17  --- 0445
7173 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 171
                    Mileage: 93195 km
                    Date: 2020.02.04
                    Time: 18:27:35
                    Voltage terminal 30: 14.5 V
                    BAP-BAP_Function_ID: 02
   Component: OCULowMQBUS   007 0568
   Coding: 02730002C2821A017F1E06020000
   ROD: EV_OCULowMQB.rod
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0001
   Serial number: 160505203343
End----------(Elapsed Time: 01:39, VBatt start/end: 14.9V/14.8V)-----------
goohdaddy
C?ID=391631
My distance sensor was hit by a chunk of ice/snow. Tried to program it out (adaptive cruise) but couldn't. Took to dealer they told me sensor was bad... not really sure as I messed with coding. I replaced the sensor anyway, but the coding is all zeros, wasn't, shouldn't be. I have replaced this sensor before and there was no issue, self calibrated in less than 100 miles. I would really like some guidance here, there is something obvious I'm missing.
2017 golf R 6mt
Check any previous scans (which VCDS auto saves) for the correct coding.
Even if it was coded correct, with those Component Protection faults, it's not gonna work properly (if at all).
darkchina811
ITALY
C?ID=333184
ok you replaced the radar, now there is nothing you can do with VCDS. go back to dealer to clear Component Protection and have the FeC restored into the new radar. until you do this it will NEVER work.
most probably you'll need calibration too.
goohdaddy
C?ID=391631
I would love to, but I don't have any. I got vcds recently because to hell with obd11.
I'm just confused by what the dealer must have done. The last time I lost one of these I replaced it and scheduled the realignment for the distance sensor. On the way there the warning light went out and i turned the cruise on and had 2 trouble free years of operation.
goohdaddy
C?ID=391631
Nonetheless, this is what I was guessing.
It would figure the thing that was pressing me to get vcds would be proprietary and untouchable by it.
goohdaddy
C?ID=391631
thanks everyone for the input and direction.
