Results 1 to 8 of 8
Thread: Adaptive cruise inop, distance sensor issues
    Feb 2020
    Tuesday,11,February,2020,02:39:05:24843
    VIN: WVWWF7AU1HW041832   License Plate:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 03 05 08 09 13 14 15 16 17 19 22 2B 3C 42 44 47 52 55 5F
              75 A9
    VIN: WVWWF7AU1HW041832   Mileage: 93330km-57992miles
    Address 01: Engine (J623-CYFB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 8V0 906 259 K    HW: 06K 907 425 E
       Component: 2.0l R4 TFSI  H13 0003
       Revision: --H13---
       Coding: 091900122446000E3004
       ASAM Dataset: EV_ECM20TFS0208V0906259K 001005
       ROD: EV_ECM20TFS0208V0906259K.rod
       VCID: 48C95FD11235EBF7417-801C
    15211 - Oil Pressure Regulating Valve
              P164E 00 [047] - Electrical Malfunction
                        Mileage: 93195 km
                        Date: 2020.02.04
                        Time: 18:27:35
                        Engine speed: 1039.50 /min
                        Normed load value: 15.7 %
                        Coolant temperature: 57 °C
                        Intake air temperature: 5 °C
                        Ambient air pressure: 800 mbar
                        Voltage terminal 30: 14.648 V
                        Engine oil temperature: 18.0 °C
                        Time since engine start: 394.1 s
                        T_ES: 0 min
                        MAP_MES_SAE: 25 kPa
                        Engine: operating status: IS
                        T_AST_SAE: 0 s
                        ECU_STATE: SYN_ENG_IGK_ON
    22008 - No Communications with Cruise Control (Front) Distance Sensor
              U0235 00 [047] - -
                        Mileage: 93195 km
                        Date: 2020.02.04
                        Time: 18:27:33
                        Engine speed: 1032.75 /min
                        Normed load value: 16.1 %
                        Voltage terminal 30: 14.628 V
                        Time since engine start: 392.2 s
                        T_ES: 0 min
                        Cruise control switch actuation-Main switch hardware: not activated
                        Cruise control switch actuation-Main switch CAN: not activated
                        T_AST_SAE: 0 s
    Readiness: 0000 0100
       Part No SW: 5Q0 614 517 BJ    HW: 5Q0 614 517 AG
       Component: ESC           H62 0636
       Revision: 00000000    Serial number: 91766000003790
       Coding: 01FA6BA15424096D457F030341C56980D62A90A2C0829637144050D4C08803
       VCID: 7AADF5191C594967873-802E
       Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
       Revision: 00021000    Serial number: 0411431250
       Coding: 032C0C
       VCID: 3B23301D53E3B06FDC5-806E
       Part No SW: 5G0 907 044 BL    HW: 5G0 907 044 BL
       Revision: 00001K08
       Coding: 00020004200100000005000012111402
       VCID: 72BDDD3944293127CF3-8026
       Part No SW: 5Q0 937 085 BL    HW: 5Q0 937 085 AF
       Component: BCM MQBAB HNA H24 0175
       Serial number: 01061617600377
       Coding: 00010A46C041A2E169E44000091C07201800000000000000000000000000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 04518BE16E9D0F97EDF-8050
       Component: WWS    160625  043 0551
       Serial number:         160704040805
       Component: RLHS  037 0059
       Serial number: S4Y16M07D12H05M42S00
       Coding: 90A8DD
       Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
       Component: ACC BOSCH MQB H10 0571
       Coding: 000000000000000000000000000000
       ASAM Dataset: EV_ACCBOSCHVW416 001005
       ROD: EV_ACCBOSCHVW416_001_VW37.rod
    10 Faults Found:
    0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
              C1103 00 [009] - -
              [FAULT_ALIGNMENT_NOT_OK]
                        Reset counter: 183
                        Mileage: 93246 km
                        Date: 2020.02.05
                        Time: 13:36:13
                        Control Module temperature: 30 °C
                        Voltage terminal 15: 12.1 V
    1810 - Control Module Incorrectly Coded
              U1014 00 [009] - -
              [FAULT_AWV_CODING_IMPLAUSIBLE]
                        Reset counter: 174
                        Mileage: 93246 km
                        Date: 2020.02.05
                        Time: 13:35:55
    0839 - Control Module Incorrectly Coded
              U1014 00 [008] - -
              [FAULT_CODING_DIRECTION_OF_TRAVEL_SENSOR]
                        Fault Frequency: 143
                        Reset counter: 223
                        Mileage: 93246 km
                        Date: 2020.02.05
                        Time: 15:22:55
                        Control Module temperature: 8 °C
                        Voltage terminal 15: 14.6 V
                        Velocity_vehicle_reference: 5.30 m/s
                        Longitudinal_acceleration_vehicle_reference: 2.50 m/s²
    1811 - Control module not coded
              U1013 00 [009] - -
              [FAULT_ECU_NO_CODING]
                        Reset counter: 174
                        Mileage: 93246 km
                        Date: 2020.02.05
                        Time: 13:35:55
    2143 - Control Module Incorrectly Coded
              U1014 00 [009] - -
              [FAULT_ENGINE_PLAUS_FAIL]
                        Reset counter: 174
                        Mileage: 93246 km
                        Date: 2020.02.05
                        Time: 13:35:55
                        Voltage terminal 15: 12.0 V
    1807 - No Enable Indentifications Active
              B2032 00 [009] - -
              [FAULT_SWAP_NO_FSID_ACTIVE]
                        Reset counter: 174
                        Mileage: 93246 km
                        Date: 2020.02.05
                        Time: 13:35:55
    0268 - Dynamometer Mode Detected
              C10A7 00 [008] - -
              [FAULT_SYC_ROLLERMODE_ACTIVE]
                        Reset counter: 214
                        Mileage: 93246 km
                        Date: 2020.02.05
                        Time: 14:06:59
                        Control Module temperature: 34 °C
                        Voltage terminal 15: 12.2 V
    15361024 - Component Protection
              U1101 00 [009] - Active
              [FAULT_THP_EC_OTHER_ERROR]
                        Reset counter: 174
                        Mileage: 93246 km
                        Date: 2020.02.05
                        Time: 13:35:55
    13762560 - Component protection
              U1114 00 [009] - GFA key
              [FAULT_THP_GFA_KEY]
                        Reset counter: 174
                        Mileage: 93246 km
                        Date: 2020.02.05
                        Time: 13:35:55
    13697024 - Component Protection
              U1100 00 [009] - No Basic Setting
              [FAULT_THP_START_KEY]
                        Reset counter: 174
                        Mileage: 93246 km
                        Date: 2020.02.05
                        Time: 13:35:55
       Serial number: 26061641350304
       ROD: EV_DRCONTITEMIC_VW37.rod
       VCID: 38292F1162D59B77317-806C
       Serial number: 003GCR054AYP
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 47CB5CED1F2BE48F48D-8012
       Occupant Detection:
       Component: BF-Gewichtss.  H12 0021
       Serial number: IBH0000000000058N1VS
       Coding: 30324E
       Subsystem 2 - Part No SW: -----------    HW: 480 000 907 16
       Serial number: 3570000000069AD0AC1X
       Subsystem 3 - Part No SW: -----------    HW: 480 000 907 16
       Serial number: 3580000000086051DC1J
       Subsystem 4 - Part No SW: -----------    HW: 480 400 707 16
       Serial number: 35100029920F195440D$
       Subsystem 5 - Part No SW: -----------    HW: 480 400 607 16
       Serial number: 3520002B920FC7455332
       Subsystem 6 - Part No SW: -----------    HW: 480 400 407 16
       Serial number: 3550002B320FC743830/
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 400 407 16
       Serial number: 3560002AF20F195282A9
       Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 08071604400853
       Coding: 0400
       VCID: 074B9CED5FAB248F88D-8052
       Part No SW: 5G1 920 858 B    HW: 5G1 920 858 B
       Component: KOMBI         303 8311
       Coding: 03AD0812BF88CF0502886B295400000000000000
       VCID: 2F3B144D979B5CCF60D-807A
    16776996 - Databus
              [FCW_01 keine Kommunikation]
                        Reset counter: 183
                        Mileage: 93330 km
                        Date: 2020.02.10
                        Time: 02:16:21
       Revision: --------    Serial number: 0005104044
       Coding: 0101000838085900FB00023A880F00000001050000000000000000000000
       ROD: EV_GatewLear_013.rod
       VCID: 7CA1F301166D775795F-8028
       Subsystem 2 - Part No SW: 5G0 959 442 S    HW: 5G0 959 442 S  Labels: 3C8-959-537.CLB
       Serial number: 29160000962240036211
       Coding: 34FFFF
    65798 - Extended CAN in One-Wire Mode
              U0054 00 [008] - -
              [Eindrahtfehler CAN-Extended]
                        Fault Frequency: 82
                        Reset counter: 219
                        Mileage: 93197 km
                        Date: 2020.02.04
                        Time: 19:05:42
                        Supply voltage: Terminal 30: 14.0 V
                        Terminal 15: On
                        Reset counter: 171
                        Mileage: 93195 km
                        Date: 2020.02.04
                        Time: 18:27:32
                        Supply voltage: Terminal 30: 14.5 V
                        Terminal 15: On
       Serial number: HA1-00001.06.16
       Coding: 3829
       Shop #: WSC 12345 123 61029
       VCID: 4ACD65D90C3919E7573-801E
       Revision: 00000000    Serial number: 16000111197008
       Coding: 5500000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 34311B217EBD7F171DF-8060
       Component: HRE_Master    H12 0071
       Serial number: 0410682641
       Coding: 01011103
       ROD: EV_HREntryHella_VW37.rod
       VCID: 3C21330156EDB757D5F-8068
       Lane Change Assistant 2:
       Component: HRE_Slave  H12 0071
       Serial number: 0407473932
       Coding: 010111
       Serial number: 050716EG508003
       Coding: 003E13208000040000000000
       VCID: 43D348FD2B13C8AF945-8016
       Serial number: 00000000000010799137
       Coding: 111000
       Coding: 8102
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 3A2D35195CD98967C73-806E
    Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
       Part No SW: 5Q0 035 456     HW: 5Q0 035 456
       Component: MIB2_lite_amp H20 0150
       Revision: 00000001    Serial number: VWZ8Z1GBA022TGD
       Coding: 2200000000AAAAAA000000000000
       ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
       ROD: EV_AMPMst12C1Gen2ALPI.rod
       VCID: 6D87CE455D17EEDF121-8038
       Serial number: 080716EG714547
       Coding: 003E13208000040000800000
       VCID: 42DD4DF93409C1A79F3-8016
       Serial number: 00000000000010672251
       Coding: 091000
       Coding: 022202010B000400
       VCID: 40D947F13A05D3B7897-8014
       Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Coding: 2E0000
       Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Coding: 2E0000
       Part No SW: 3Q0 035 876 A    HW: 3Q0 035 876 A
       Component: MU-S-NS-US    840 0751
       Coding: 027300020000000051220002001808009F0207F401200105C6
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 323D1D3984A971270F3-8066
       Subsystem 1 - Part No SW: 5GM 919 605     HW: 5GM 919 605
       Component: ABT_Std-2_Nav  H53 1031
       Serial number: VWZ8Z9SJX006RW
       Subsystem 2 - Part No SW: 3G0 919 866 AC    HW: -----------
       Component: NAR 2016/17  --- 0445
              U1111 00 [009] - -
              [ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 171
                        Mileage: 93195 km
                        Date: 2020.02.04
                        Time: 18:27:35
                        Voltage terminal 30: 14.5 V
                        BAP-BAP_Function_ID: 02
       Component: OCULowMQBUS   007 0568
       Coding: 02730002C2821A017F1E06020000
       ROD: EV_OCULowMQB.rod
       Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
       Serial number: 160505203343
    End----------(Elapsed Time: 01:39, VBatt start/end: 14.9V/14.8V)-----------
    Feb 2020
    My distance sensor was hit by a chunk of ice/snow. Tried to program it out (adaptive cruise) but couldn't. Took to dealer they told me sensor was bad... not really sure as I messed with coding. I replaced the sensor anyway, but the coding is all zeros, wasn't, shouldn't be. I have replaced this sensor before and there was no issue, self calibrated in less than 100 miles. I would really like some guidance here, there is something obvious I'm missing.
    2017 golf R 6mt
    Check any previous scans (which VCDS auto saves) for the correct coding.
    Even if it was coded correct, with those Component Protection faults, it's not gonna work properly (if at all).
  5. Likes PetrolDave, downtime liked this post
    Apr 2018
    ITALY
    ok you replaced the radar, now there is nothing you can do with VCDS. go back to dealer to clear Component Protection and have the FeC restored into the new radar. until you do this it will NEVER work.
    most probably you'll need calibration too.
    my Golf came out of the factory with 13 ECUs. now she has 20. and counting
  7. Likes Uwe liked this post
    Feb 2020
    I would love to, but I don't have any. I got vcds recently because to hell with obd11.
    I'm just confused by what the dealer must have done. The last time I lost one of these I replaced it and scheduled the realignment for the distance sensor. On the way there the warning light went out and i turned the cruise on and had 2 trouble free years of operation.
    Feb 2020
    Nonetheless, this is what I was guessing.
    It would figure the thing that was pressing me to get vcds would be proprietary and untouchable by it.
  10. #8
    Feb 2020
    thanks everyone for the input and direction.
