Results 1 to 8 of 8
Thread: 2003 VW Polo none start (Fixed!)
    Nov 2019
    Norwich, UK
    Hope for some advice the vehicle will turn over and cut out the person who owns it says they only changed a battery !! im hoping they have no put the terminals round the wrong way all fuses checked and fine
    The immobiliser light / key is flashing on dash vehicle ECU is standard and has not been mapped or altered in anyway its looking to me like there is an issue with the ECU please see full scan and the scan after initial clear any advice appreciated
    Regards
    Marty
    Monday,10,February,2020,16:19:15:16673
    VIN: WVWZZZ9NZ4Y138273   License Plate:
    Mileage: 242550km-150713mi   Repair Order:
    Chassis Type: 9N (9N - VW Polo (2002 > 2010))
    Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
    VIN: WVWZZZ9NZ4Y138273   Mileage: 242550km-150713miles
    Address 01: Engine        Labels: 036-906-034-APE.lbl
       Part No: 036 906 034 GP
       Component:  MARELLI 4MV        5161
       Coding: 00071
       VCID: 6695B19A8173DF2753B-4B5C
    18048 - Internal Control Module
                P1640 - 35-00 - EEPROM Error
                P1570 - 35-00 -
    Readiness: 1110 0101
    Address 03: ABS Brakes        Labels: 6Q0-907-37x-ABS2.lbl
       Part No: 6Q0 907 379 L
       Component: ABS FRONT MK60      0101
       Coding: 0001097
       Shop #: WSC 00788 785 00200
       VCID: 46D5511AE4B3FF27B3B-50D0
    Address 08: Auto HVAC        Labels: 6Q0-820-045.lbl
       Part No: 6Q0 820 045
       Component: Klimaanlage        X0840
       VCID: 6A8DC5AA956BFB47773-50D0
    65535 - Internal Control Module Memory Error
                00-00 - -
    01271 - Positioning Motor for Temperature Flap (V68)
                28-10 - Short to Plus - Intermittent
    Address 09: Cent. Elect.        Labels:. 6Qx-937-049-C.lbl
       Part No: 6Q1 937 049 D
       Component: 0000 BN-SG.         1S34
       Coding: 25774
       Shop #: WSC 00788
       VCID: 3C2133F2AF7FB5F7D5F-50D0
    11 Faults Found:
    00903 - Fuse for Heated Outside Mirrors (S196)
                37-10 - Faulty - Intermittent
    01598 - Drive Battery Voltage
    00906 - Horn (H1)
    00975 - Heated Rear Window (Z1)
       Part No: 1C0 909 605 K
       Component: 0J AIRBAG VW51 0N   0008
       Coding: 12362
       Shop #: WSC 00788
       VCID: 2C0103B25F1F257745F-50D0
    00532 - Supply Voltage B+
    Address 17: Instruments        Labels: 6Q0-920-xxx-17.lbl
       Part No: 6Q0 920 900
       Component: KOMBI+WEGFAHRSP VDO V18
       Coding: 01441
       VCID: 6B83C0AE9A91E24F0C5-50D0
       WVWZZZ9NZ4Y138273     VWZ7Z0C8255386
    01177 - Engine Control Unit
                65-10 - Unauthorized - Intermittent
       Part No: 6N0 909 901
       Component: 0010 GATEWAY CAN    1S34
       Coding: 00014
       Shop #: WSC 00788
       VCID: 70B9D7C2B3B70197397-50D0
       Part No: 6Q0 423 156 AB
       Component: LenkhilfeTRW        V270
       Coding: 10140
       Shop #: WSC 00788
       VCID: 6FBBD4BEAE891E6F20D-50D0
    Address 46: Central Conv.        Labels:. 6Q0-959-433.clb
       Part No: 6Q0 959 433 G
       Component: 20 Komfortgerát     0002
       Coding: 00065
       Shop #: WSC 00788
       VCID: 3FDB44FEBE69AEEFF0D-4B1E
       Subsystem 1 - Part No: 6Q1959801A
       Component: 20 Tőrsteuer.FS TFK 0004
       Subsystem 2 - Part No: 6Q1959802A
       Component: 20 Tőrsteuer.BF TFK 0004
    6 Faults Found:
                52-10 - Supply Voltage Too High - Intermittent
                53-10 - Supply Voltage Too Low - Intermittent
    End----(Elapsed Time: 02:45, VBatt start/end: 12.5V/12.5V. VIgn 0.0V)------
    Address 01: DTCs cleared
    Address 03: DTCs cleared
    Address 08: DTCs cleared
    Address 09: DTCs cleared
    Address 15: DTCs cleared
    Address 17: DTCs cleared
    Address 19: DTCs cleared
    Address 25: DTCs cleared
    Address 44: DTCs cleared
    Address 46: DTCs cleared
       Coding: 00071
                P1570 - 35-00 -
       Coding: 0001097
       Coding: 25774
       Shop #: WSC 00788
       Coding: 12362
       Shop #: WSC 00788
       Coding: 01441
       Coding: 00014
       Shop #: WSC 00788
       Coding: 10140
       Shop #: WSC 00788
       Coding: 00065
       Shop #: WSC 00788
    End----(Elapsed Time: 02:39, VBatt start/end: 12.4V/12.4V. VIgn 0.0V)------
    The EEPROM fault in the ECU is rather daunting, but..
    It couldn't hurt to check Immobilizer Measuring Blocks in Instrument Cluster to see what they show:
    https://www.ross-tech.com/vag-com/ca...ng-blocks.html
    Nov 2019
    Norwich, UK
    Thanks Uwe I'll take a look at that later today and report back with my findings or if I work out the solution.
    Yes the EEprom fault is a daunting one I would expect to see that if an ECU has had map altered and there is a checksum error but its 100% not had anything done with the rom file unless them changing the battery has caused the error but as you know the rom file is hard written and very unlikely I like a challenge
    Nov 2019
    Norwich, UK
    I'm getting the following
    Group
    022..... 0 1 1 1
    023..... 1 1 1 6
    024.... 0.0 0.0 0.0 0.0
    Have you tried cold-booting everything? Disconnect battery cables. Short battery cables together (away from the battery!). Reconnect. This has been known to help with inexplicable immobilizer problems. I don't have much hope for it here, but it doesn't cost much to try.
  6. Likes NZDubNurd liked this post
    Nov 2019
    Norwich, UK
    I have tried the cold reboot I think the EEprom error is the issue as it's a marelli ECU I'm unable to pull the map file off if it was Bosch I would simply pull map off and remove immobiliser this one i have suggested they order a full replacement kit to go in they found a set ECU , Clocks ect for Ł50 so should be a cheap fix
    Did you try to recode it to default the eeprom table several times?
    Eeprom's do fail and can indeed be replaced.
  9. #8
    Nov 2019
    Norwich, UK
    Thought I would update as nothing worse then someone searching and not seeing the result
    It was the EEprom error causing it the login for ECU would not be accepted yet the dash logged in fine it was obviously something within that partition that was at fault.
    Fitted the replacement kit ECU,BCM,Cluster and first turn of the key and away it went
    Could an admin or mod kindly edit post title to include ***Fixed***
  10. Likes Uwe liked this post
