KESSY KEYS ISSUE MK7 GOLF
webup
Auckland
C?ID=256879
Can any knowledgeable folk interpret this VW agent repair on a mk7 Golf that the keys stopped talking to the car?
They fixed it and this is the supposed fix.
Not sure what the on-band power supply control unit is and also what needed doing to the cluster.
Spacewalker
C?ID=159607
kessy stopped talking , but remote too ? key start in emegrency place ?
post autoscan and tell more what happen
downtime
C?ID=280813
That means most likely BCM = body control module. They ran online SVM on it which re-parameterizes and codes the unit online.
Basically means it restores it to per factory spec.
So is the issue that the ”remote” part did not work?
Spacewalker
C?ID=159607
On Board Power supply for me is Voltage Stabilizer not BCM
waste of time to talk if we dont know what is going on
downtime
C?ID=280813
Yes it could be but VAG uses this power supply naming in their official documentation for the bcm. I think it’s a relic from the past the naming.
http://www.volkspage.net/technik/ssp/ssp/SSP_298_d2.pdf
But had to add that I agree, this all is waste of time until OP clarifies what he’s expecting from here?
Is there a problem now after the fixes?
webup
Auckland
C?ID=256879
Maybe I should have added more details
Car is fixed and no longer have it, by VW and this is their job report to fix it.
Now have another car with the same issue so trying to work out what "re parametrise the on band power supply control unit" means
Also what they would have done to "readapted the instrument cluster"
Sounds like some simple coding reset/relearn etc but due to the nomenclature its hard to know what it is.
downtime
C?ID=280813
Readapted instrument cluster means they paired the keys again to immo which is in the instrument cluster.
Both operations they’ve done need online account and access to VW security / FaZit.
webup
Auckland
C?ID=256879
Damn so this one will have to go to VW as well?
downtime
C?ID=280813
If you don’t have online access to VW systems then I’m afraid yes :(
Spacewalker
C?ID=159607
I suggesst you talk with yourself on private - send message to yourself and replay,
we dont know what is going one, what is a issue ...nothing
we just see how mad your are because of that - and give useless advice ,guesswork.....
you not beginner , you know the rules
webup
Auckland
C?ID=256879
Im guessing youre talking to the wrong person here?
